    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      Gismoh @crunchip last edited by
      @crunchip
      Besten Dank für deine unermüdliche Hilfe!
      muss allerdings erst schauen, wo die Datei bei mir ist, zumindest konnte ich die Datei mit "sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py" nicht finden, bzw. es wurde mir eine leere Datei angezeigt.
        crunchip Forum Testing Most Active @Gismoh last edited by
        @gismoh dann installier mal zuerst die v0.13.3
        iob add ble@0.13.3
          @crunchip
          NPM version: 9.8.1
          Installing iobroker.ble@0.13.3... (System call)
          npm ERR! code 1
          npm ERR! path /opt/iobroker/node_modules/@abandonware/noble
          npm ERR! command failed
          npm ERR! command sh -c node-gyp-build
          npm ERR! (node:3259) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
          npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
          npm ERR! Traceback (most recent call last):
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
          npm ERR!     sys.exit(gyp.script_main())
          npm ERR!              ^^^^^^^^^^^^^^^^^
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
          npm ERR!     return main(sys.argv[1:])
          npm ERR!            ^^^^^^^^^^^^^^^^^^
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
          npm ERR!     return gyp_main(args)
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
          npm ERR!     [generator, flat_list, targets, data] = Load(
          npm ERR!                                             ^^^^^
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
          npm ERR!     result = gyp.input.Load(
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
          npm ERR!     LoadTargetBuildFile(
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
          npm ERR!     build_file_data = LoadOneBuildFile(
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
          npm ERR!     build_file_contents = open(build_file_path, "rU").read()
          npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
          npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
          npm ERR! gyp ERR! configure error
          npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
          npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
          npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
          npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
          npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
          npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
          npm ERR! gyp ERR! node -v v18.18.2
          npm ERR! gyp ERR! node-gyp -v v7.1.2
          npm ERR! gyp ERR! not ok
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T00_24_15_069Z-debug-0.log
          host.ioBrokerVM Cannot install iobroker.ble@0.13.3: 1
            @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
            npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile npm ERR! build_file_contents = open(build_file_path, "rU").read() npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^ npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
            die Datei muss es geben
              @gismoh ok, bei mir ging die 0.13.3 damals, vllt auch weil sie vorher schon lief und das Problem bei einem upgrade auf die 0.13.4 entstand
              G 3 Replies Last reply Reply Quote 0
                @crunchip
                Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                  @crunchip
                  ich verstehe auch "Logisch" nicht, das der ble vorher lief, nach Backup einspieleung nicht mehr. Kann ja auch nicht sein, das dadurch ganze ordner gelöscht wurden, denn andere Adapter laufen ja auch nach der Einspielung.
                    Gismoh @crunchip last edited by Gismoh
                    @crunchip
                    hmmm, vielleicht sollte ich nochmal das prozedre durchspielen, aber diesmal vor dem Backup das ble von der bestehenden Installation löschen - damit er diesen nicht mit sichert und einspielt - also den von der frischen Installation evtl. einfach behält? (hoffe das Backup löscht den dann nicht - weil nicht im Restore des Backups vorhanden.)
                      nochmal,
                      neu gebaut werden, aufgrund der Einstellungen aus deinem Backup und der neuen iobroker/nodejs Umgebung
                        crunchip Forum Testing Most Active @Gismoh last edited by crunchip
                        @gismoh kannst du machen, ble wird nicht gelöscht, der bleibt bestehen
                        ich bin jetzt aber mal weg, viel Erfolg noch
                          @crunchip
                          dann werde ich mich mal ransetzen, wird aber vermutlich dauern, da ich vorher noch ein Karten-Kopie mache usw.
                          Besten Dank an dich und dir eine schöne Nachtruhe!
                            Gismoh @Gismoh last edited by
                            Scheinbar ist das Backup einspielen von ioBroker (ohne Influx) doch schneller, als ich so gelesen habe.
                            CPU und Netz-Auslastung sind nach 12 Minuten wieder quasi im Ruhezustand.
                            Warte aber nun sicherheitshalber noch weiter ab.
                              einfach eine Konsole deiner Wahl aufmachen und das aktuelle log anschauen
                              iob logs --watch
                                @crunchip
                                merci, den Befehl kannte ich noch nicht 😉
                                hier ein Auszug, scheint wirklich, das er nach 12 Minuten nichts mehr gemacht hatte:
                                2023-11-08 11:45:41.207  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-timeandweather created/updated
                                2023-11-08 11:45:42.267  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                2023-11-08 11:45:43.267  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
                                2023-11-08 11:45:43.268  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                                2023-11-08 11:45:44.908  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                2023-11-08 11:45:44.909  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                2023-11-08 11:45:49.371  - info: vis.0 (6542) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                2023-11-08 11:45:49.603  - info: vis.0 (6542) vis license is OK.
                                2023-11-08 11:45:49.792  - error: vis.0 (6542) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2023-11-08 11:45:49.793  - error: vis.0 (6542) unhandled promise rejection: Not exists
                                2023-11-08 11:45:49.793  - error: vis.0 (6542) Error: Not exists
                                    at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
                                    at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
                                    at process.processImmediate (node:internal/timers:478:21)
                                2023-11-08 11:45:49.794  - error: vis.0 (6542) Not exists
                                2023-11-08 11:45:50.298  - info: vis.0 (6542) terminating
                                2023-11-08 11:45:50.299  - warn: vis.0 (6542) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2023-11-08 11:45:50.965  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_45_45_224Z-debug-0.log
                                2023-11-08 11:45:50.965  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                2023-11-08 11:45:51.981  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                2023-11-08 11:45:52.982  - warn: host.ioBrokerVM startInstance cannot find adapter "web@4.3.0". Try to install it... 1 attempt
                                2023-11-08 11:45:52.982  - info: host.ioBrokerVM iobroker install web@4.3.0 using installedFrom
                                2023-11-08 11:45:54.660  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                2023-11-08 11:45:54.661  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.web@4.3.0... (System call)
                                2023-11-08 11:46:01.177  - info: host.ioBrokerVM iobroker npm-install: added 12 packages in 6s
                                2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install:
                                2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install: 150 packages are looking for funding
                                2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                                2023-11-08 11:46:01.205  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter web@4.3.0
                                2023-11-08 11:46:01.278  - info: host.ioBrokerVM iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                2023-11-08 11:46:01.285  - info: host.ioBrokerVM iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                2023-11-08 11:46:01.290  - info: host.ioBrokerVM iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                2023-11-08 11:46:01.293  - info: host.ioBrokerVM iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                                2023-11-08 11:46:01.297  - info: host.ioBrokerVM iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                2023-11-08 11:46:01.301  - info: host.ioBrokerVM iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                2023-11-08 11:46:01.305  - info: host.ioBrokerVM iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                2023-11-08 11:46:01.309  - info: host.ioBrokerVM iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                2023-11-08 11:46:01.313  - info: host.ioBrokerVM iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
                                2023-11-08 11:46:01.329  - info: host.ioBrokerVM iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
                                2023-11-08 11:46:01.333  - info: host.ioBrokerVM iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
                                2023-11-08 11:46:01.679  - info: host.ioBrokerVM iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
                                2023-11-08 11:46:01.683  - info: host.ioBrokerVM iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
                                2023-11-08 11:46:01.686  - info: host.ioBrokerVM iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
                                2023-11-08 11:46:01.693  - info: host.ioBrokerVM iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
                                2023-11-08 11:46:01.696  - info: host.ioBrokerVM iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                                2023-11-08 11:46:01.699  - info: host.ioBrokerVM iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                2023-11-08 11:46:01.748  - info: host.ioBrokerVM iobroker npm-install: upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                2023-11-08 11:46:01.875  - info: host.ioBrokerVM iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                2023-11-08 11:46:02.022  - info: host.ioBrokerVM iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                2023-11-08 11:46:02.170  - info: host.ioBrokerVM iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                2023-11-08 11:46:02.346  - info: host.ioBrokerVM iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                2023-11-08 11:46:02.520  - info: host.ioBrokerVM iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                2023-11-08 11:46:02.705  - info: host.ioBrokerVM iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                2023-11-08 11:46:02.739  - info: host.ioBrokerVM iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                2023-11-08 11:46:02.776  - info: host.ioBrokerVM iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                2023-11-08 11:46:02.808  - info: host.ioBrokerVM iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                2023-11-08 11:46:02.844  - info: host.ioBrokerVM iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                2023-11-08 11:46:02.897  - info: host.ioBrokerVM iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                2023-11-08 11:46:02.932  - info: host.ioBrokerVM iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                2023-11-08 11:46:02.967  - info: host.ioBrokerVM iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                2023-11-08 11:46:03.003  - info: host.ioBrokerVM iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                2023-11-08 11:46:03.008  - info: host.ioBrokerVM iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                2023-11-08 11:46:03.029  - info: host.ioBrokerVM iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                2023-11-08 11:46:03.033  - info: host.ioBrokerVM iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                2023-11-08 11:46:03.040  - info: host.ioBrokerVM iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                2023-11-08 11:46:03.046  - info: host.ioBrokerVM iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                2023-11-08 11:46:03.050  - info: host.ioBrokerVM iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                2023-11-08 11:46:03.056  - info: host.ioBrokerVM iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                2023-11-08 11:46:03.061  - info: host.ioBrokerVM iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                2023-11-08 11:46:03.066  - info: host.ioBrokerVM iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                2023-11-08 11:46:03.071  - info: host.ioBrokerVM iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                2023-11-08 11:46:03.079  - info: host.ioBrokerVM iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                2023-11-08 11:46:03.085  - info: host.ioBrokerVM iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                2023-11-08 11:46:03.089  - info: host.ioBrokerVM iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                2023-11-08 11:46:03.100  - info: host.ioBrokerVM iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                2023-11-08 11:46:03.107  - info: host.ioBrokerVM iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                2023-11-08 11:46:03.124  - info: host.ioBrokerVM iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                2023-11-08 11:46:03.135  - info: host.ioBrokerVM iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                2023-11-08 11:46:03.139  - info: host.ioBrokerVM iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                2023-11-08 11:46:03.143  - info: host.ioBrokerVM iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                2023-11-08 11:46:03.147  - info: host.ioBrokerVM iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                2023-11-08 11:46:03.328  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.web created/updated
                                2023-11-08 11:46:04.395  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                2023-11-08 11:46:05.396  - warn: host.ioBrokerVM startInstance cannot find adapter "worx@2.3.2". Try to install it... 1 attempt
                                2023-11-08 11:46:05.396  - info: host.ioBrokerVM iobroker install worx@2.3.2 using installedFrom
                                2023-11-08 11:46:07.069  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                2023-11-08 11:46:07.070  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.worx@2.3.2... (System call)
                                2023-11-08 11:46:17.160  - info: host.ioBrokerVM iobroker npm-install: added 42 packages in 10s152 packages are looking for funding  run `npm fund` for details
                                2023-11-08 11:46:17.184  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter worx@2.3.2
                                2023-11-08 11:46:17.263  - info: host.ioBrokerVM iobroker npm-install: upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                2023-11-08 11:46:17.270  - info: host.ioBrokerVM iobroker npm-install: upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                2023-11-08 11:46:17.274  - info: host.ioBrokerVM iobroker npm-install: upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                2023-11-08 11:46:17.281  - info: host.ioBrokerVM iobroker npm-install: upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                2023-11-08 11:46:17.285  - info: host.ioBrokerVM iobroker npm-install: upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                2023-11-08 11:46:17.288  - info: host.ioBrokerVM iobroker npm-install: upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                2023-11-08 11:46:17.291  - info: host.ioBrokerVM iobroker npm-install: upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                2023-11-08 11:46:17.294  - info: host.ioBrokerVM iobroker npm-install: upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                2023-11-08 11:46:17.298  - info: host.ioBrokerVM iobroker npm-install: upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                2023-11-08 11:46:17.301  - info: host.ioBrokerVM iobroker npm-install: upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                2023-11-08 11:46:17.304  - info: host.ioBrokerVM iobroker npm-install: upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                2023-11-08 11:46:17.307  - info: host.ioBrokerVM iobroker npm-install: upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
                                2023-11-08 11:46:17.310  - info: host.ioBrokerVM iobroker npm-install: upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
                                2023-11-08 11:46:17.313  - info: host.ioBrokerVM iobroker npm-install: upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
                                2023-11-08 11:46:17.434  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.worx created/updated
                                2023-11-08 11:46:18.498  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                2023-11-08 11:46:19.499  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
                                2023-11-08 11:46:19.499  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                                2023-11-08 11:46:21.160  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                2023-11-08 11:46:21.161  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                2023-11-08 11:46:25.314  - info: vis.0 (6854) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                2023-11-08 11:46:25.483  - info: vis.0 (6854) vis license is OK.
                                2023-11-08 11:46:25.699  - error: vis.0 (6854) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2023-11-08 11:46:25.699  - error: vis.0 (6854) unhandled promise rejection: Not exists
                                2023-11-08 11:46:25.700  - error: vis.0 (6854) Error: Not exists
                                2023-11-08 11:46:25.700  - error: vis.0 (6854) Not exists
                                2023-11-08 11:46:26.207  - info: vis.0 (6854) terminating
                                2023-11-08 11:46:26.208  - warn: vis.0 (6854) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2023-11-08 11:46:26.909  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_21_469Z-debug-0.loghost.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                2023-11-08 11:46:27.929  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                2023-11-08 11:46:28.929  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
                                2023-11-08 11:46:28.929  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                                2023-11-08 11:46:30.593  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                2023-11-08 11:46:30.594  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                2023-11-08 11:46:34.599  - info: vis.0 (6963) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                2023-11-08 11:46:34.921  - info: vis.0 (6963) vis license is OK.
                                2023-11-08 11:46:35.089  - error: vis.0 (6963) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2023-11-08 11:46:35.089  - error: vis.0 (6963) unhandled promise rejection: Not exists
                                2023-11-08 11:46:35.090  - error: vis.0 (6963) Error: Not exists
                                2023-11-08 11:46:35.090  - error: vis.0 (6963) Not exists
                                2023-11-08 11:46:35.593  - info: vis.0 (6963) terminating
                                2023-11-08 11:46:35.594  - warn: vis.0 (6963) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2023-11-08 11:46:36.231  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_30_898Z-debug-0.log
                                2023-11-08 11:46:36.231  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                2023-11-08 11:46:37.248  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                2023-11-08 11:46:38.248  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
                                2023-11-08 11:46:38.249  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                                2023-11-08 11:46:39.906  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                2023-11-08 11:46:39.908  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                2023-11-08 11:46:43.890  - info: vis.0 (7072) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                2023-11-08 11:46:44.072  - info: vis.0 (7072) vis license is OK.
                                2023-11-08 11:46:44.242  - error: vis.0 (7072) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2023-11-08 11:46:44.242  - error: vis.0 (7072) unhandled promise rejection: Not exists
                                2023-11-08 11:46:44.243  - error: vis.0 (7072) Error: Not exists
                                2023-11-08 11:46:44.243  - error: vis.0 (7072) Not exists
                                2023-11-08 11:46:44.747  - info: vis.0 (7072) terminating
                                2023-11-08 11:46:44.747  - warn: vis.0 (7072) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2023-11-08 11:46:45.412  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_40_207Z-debug-0.log
                                2023-11-08 11:46:45.413  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                2023-11-08 11:46:46.434  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                2023-11-08 11:46:47.435  - error: host.ioBrokerVM Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                                  Gismoh @Gismoh last edited by Gismoh
                                  @gismoh said in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                                  @crunchip
                                  Mist, der ble wurde doch entfernt..... bzw. ist nicht mehr da
                                    diesmal vor Update der anderen Adapter versucht ble hinzuzufügen, wieder selbe Meldung:
                                    Installing iobroker.ble@0.13.4... (System call)
                                    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:7362) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T12_24_29_118Z-debug-0.log
                                    host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                                    ERROR: Process exited with code 25
                                      @gismoh dann seh doch jetzt nach, ob der Pfad/ Datei, die zu ändern wäre, nun vorhanden ist
                                        @crunchip
                                        muss ich leider auf später verschieben.
                                          @gismoh und wie du siehst, der vis bug, denn laut deinem log wurde vis nicht installiert
                                            @crunchip
                                            ist für mich ok mit VIS, wenn alles wieder da ist, wenn ich nur den Adapter neu installiere.
                                            ansonsten:
                                            Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp existiert nicht
                                            Mache dann später weiter.
                                            24252
