    4. SDA1 voll Home/IOBroker nach Node Update
      deifel @deifel last edited by
      Ok, der User war nicht Mitglied in sudo.
      Jetzt hats geklappt.
      Welcher Bereich der Ausgabe wird denn benötigt?
      Hier mal ein Auszug bis zu den Adaptern:
      *** BASE SYSTEM ***
         Static hostname: IOBrokerhost
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-26-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       00:22:17 up  1:11,  1 user,  load average: 0.60, 0.50, 0.47
      CPU threads: 12
      *** Time and Time Zones ***
                     Local time: Wed 2023-11-08 00:22:17 CET
                 Universal time: Tue 2023-11-07 23:22:17 UTC
                       RTC time: Tue 2023-11-07 23:22:18
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      deifel
      /home/deifel
      deifel cdrom floppy sudo audio dip video plugdev netdev
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             11G        6.8G        2.7G        0.0K        2.2G        4.6G
      Swap:           8.0G          0B        8.0G
      Total:           19G        6.8G         10G
              11680 M total memory
               6790 M used memory
                573 M active memory
               7728 M inactive memory
               2665 M free memory
                342 M buffer memory
               1882 M swap cache
               7997 M total swap
                  0 M used swap
               7997 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  5.7G     0  5.7G   0% /dev
      tmpfs          tmpfs     1.2G  588K  1.2G   1% /run
      /dev/sda1      ext4       24G   14G  8.5G  63% /
      tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/0
      tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
      [Tue Nov  7 23:11:11 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Tue Nov  7 23:11:11 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      5.2G    /var/
      4.7G    /var/log
      2.4G    /var/log/journal/65e07a91f8664c7a966da0df42f616fe
      331M    /var/cache
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      24K     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.9G    /opt/iobroker/iobroker-data/
      615M    /opt/iobroker/iobroker-data/files
      367M    /opt/iobroker/iobroker-data/backup-objects
      291M    /opt/iobroker/iobroker-data/history
      88M     /opt/iobroker/iobroker-data/files/echarts.admin
      228M    /opt/iobroker/iobroker-data/BSZExtLog_1_Oelverbrauch_Liter.csv
      117M    /opt/iobroker/iobroker-data/objects.jsonl
      99M     /opt/iobroker/iobroker-data/states.jsonl
      58M     /opt/iobroker/iobroker-data/objects.json.migrated
      58M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A9S6J1O6-if00-port0
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AB0LP1A8-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
      npm ERR! invalid: samsungtv@0.0.0 /opt/iobroker/node_modules/samsungtv
      npm ERR! invalid: syno@3.0.0 /opt/iobroker/node_modules/syno
      npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
      npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
      npm ERR! invalid: cli@1.0.1 /opt/iobroker/node_modules/cli
      npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
      npm ERR! A complete log of this run can be found in: /home/deifel/.npm/_logs/2023-11-07T23_22_18_923Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.12.0
      javascript:     7.1.4
      npm ERR! A complete log of this run can be found in: /home/deifel/.npm/_logs/2023-11-07T23_22_26_500Z-debug-0.log
      Adapters from github:   1
      OliverIO Thomas Braun 2 Replies Last reply Reply Quote 0
      • OliverIO
        OliverIO @deifel last edited by OliverIO
        @deifel
        zum thema großes /var/log/journal hier ein interessanter artikel
        https://askubuntu.com/questions/1238214/big-var-log-journal
        evtl müsste man da aber auch mal reinschauen, was da soviel logs erzeugt
        da ist sicherlich auch im betriebssystem noch was krumm
        die anderen Probleme die du noch hast, überlasse ich wieder den anderen
          Thomas Braun Most Active @deifel last edited by Thomas Braun
          @deifel
          Immer vollständige Ausgaben posten.
          Setz den User noch in die Gruppe adm rein.
          Und bring das nodesource-Repo auf Stand.
          iob nodejs-update
            Danke! Habe ich beides gemacht. Keine Fehler o.ä.
            Er hat mir dann das Update auf 18.18.2 angeboten. Habe ich gemacht.
            Sonst ist Dir nichts aufgefallen? Dann würde ich das jetzt einfach mal beobachten.
            Herzlichen Dank nochmals für die schnelle und kompetente Hilfe!
              deifel @OliverIO last edited by
              @oliverio
              Danke für den Hinweis. Habe jetzt das Journal Log auf 900MB limitiert (was ja auch schon viel ist).
                @deifel sagte in SDA1 voll Home/IOBroker nach Node Update:
                Poste halt vollständig, dann kann man sich das auch in Gänze anschauen.
                  Gerne. Hier das vollständige Log:
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                             Chassis: vm
                      Virtualization: kvm
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                   07:55:48 up 30 min,  1 user,  load average: 0.27, 0.35, 0.50
                  CPU threads: 12
                                 Local time: Wed 2023-11-08 07:55:48 CET
                             Universal time: Wed 2023-11-08 06:55:48 UTC
                                   RTC time: Wed 2023-11-08 06:55:49
                                NTP service: active
                            RTC in local TZ: no
                  deifel
                  /home/deifel
                  deifel adm cdrom floppy sudo audio dip video plugdev netdev
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:             11G        6.1G        4.8G        0.0K        799M        5.3G
                  Swap:           8.0G          0B        8.0G
                  Total:           19G        6.1G         12G
                           6087 M used memory
                            179 M active memory
                           6391 M inactive memory
                           4793 M free memory
                             67 M buffer memory
                            732 M swap cache
                           7997 M total swap
                              0 M used swap
                           7997 M free swap
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     1.2G  572K  1.2G   1% /run
                  /dev/sda1      ext4       24G   13G  9.8G  57% /
                  /var:
                  3.7G    /var/
                  3.2G    /var/log
                  833M    /var/log/journal/65e07a91f8664c7a966da0df42f616fe
                  360M    /var/cache
                  Archived and active journals take up 832.1M in the file system.
                  2.1G    /opt/iobroker/iobroker-data/
                  250M    /opt/iobroker/iobroker-data/states.jsonl
                  142M    /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                  /usr/bin/nodejs         v18.18.2
                  /usr/bin/node           v18.18.2
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  /usr/bin/corepack       0.19.0
                  nodejs:
                    Installed: 18.18.2-1nodesource1
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                   *** 18.18.2-1nodesource1 1001
                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                          500 http://deb.debian.org/debian-security bullseye-security/main amd64 P        ackages
                  Errors in npm tree:
                  npm ERR! A complete log of this run can be found in: /home/deifel/.npm/_logs/2023-11-08T06_55_51_252Z-debug-0.log
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.4
                  npm ERR! A complete log of this run can be found in: /home/deifel/.npm/_logs/2023-11-08T06_55_58_943Z-debug-0.log
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : IOBrokerhost                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : IOBrokerhost                             -  enabled
                  + system.adapter.backitup.1               : backitup              : IOBrokerhost                             -  enabled
                  + system.adapter.ble.0                    : ble                   : IOBrokerhost                             -  enabled
                    system.adapter.daswetter.0              : daswetter             : IOBrokerhost                             -  enabled
                  + system.adapter.discovery.0              : discovery             : IOBrokerhost                             -  enabled
                    system.adapter.dwd.0                    : dwd                   : IOBrokerhost                             -  enabled
                  + system.adapter.echarts.0                : echarts               : IOBrokerhost                             -  enabled
                  + system.adapter.email.0                  : email                 : IOBrokerhost                             -  enabled
                    system.adapter.eusec.0                  : eusec                 : IOBrokerhost                             - disabled
                    system.adapter.feiertage.0              : feiertage             : IOBrokerhost                             -  enabled
                    system.adapter.flot.0                   : flot                  : IOBrokerhost                             -  enabled
                  + system.adapter.govee.0                  : govee                 : IOBrokerhost                             -  enabled
                  + system.adapter.history.0                : history               : IOBrokerhost                             -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : IOBrokerhost                             -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : IOBrokerhost                             -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : IOBrokerhost                             -  enabled, port: 0
                  + system.adapter.hm-rpc.2                 : hm-rpc                : IOBrokerhost                             -  enabled, port: 0
                  + system.adapter.homeconnect.1            : homeconnect           : IOBrokerhost                             -  enabled
                  + system.adapter.hue.0                    : hue                   : IOBrokerhost                             -  enabled, port: 443
                    system.adapter.ical.0                   : ical                  : IOBrokerhost                             -  enabled
                    system.adapter.ico-cloud.0              : ico-cloud             : IOBrokerhost                             -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: IOBrokerhost                             -  enabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : IOBrokerhost                             -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : IOBrokerhost                             -  enabled
                    system.adapter.icons-material-png.0     : icons-material-png    : IOBrokerhost                             -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBrokerhost                             -  enabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBrokerhost                             -  enabled
                  + system.adapter.info.0                   : info                  : IOBrokerhost                             -  enabled
                  + system.adapter.iot.0                    : iot                   : IOBrokerhost                             -  enabled
                  + system.adapter.iqontrol.0               : iqontrol              : IOBrokerhost                             -  enabled
                  + system.adapter.javascript.0             : javascript            : IOBrokerhost                             -  enabled
                    system.adapter.material.0               : material              : IOBrokerhost                             -  enabled
                  + system.adapter.mbus.0                   : mbus                  : raspberrypikeller                        -  enabled, port: 3493
                  + system.adapter.mbus.1                   : mbus                  : IOBrokerhost                             -  enabled, port: 3493
                  + system.adapter.mbus.2                   : mbus                  : IOBrokerhost                             -  enabled, port: 3493
                  + system.adapter.melcloud.0               : melcloud              : IOBrokerhost                             -  enabled
                  + system.adapter.mihome-vacuum.1          : mihome-vacuum         : IOBrokerhost                             -  enabled, port: 54321
                  + system.adapter.mihome-vacuum.2          : mihome-vacuum         : IOBrokerhost                             -  enabled, port: 54321
                  + system.adapter.mihome.0                 : mihome                : IOBrokerhost                             -  enabled, port: 9898, bind: 0.0.0.0
                  + system.adapter.milight.0                : milight               : IOBrokerhost                             -  enabled, port: 5987
                    system.adapter.mqtt.0                   : mqtt                  : IOBrokerhost                             - disabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.musiccast.0              : musiccast             : IOBrokerhost                             -  enabled
                    system.adapter.openweathermap.0         : openweathermap        : IOBrokerhost                             -  enabled
                  + system.adapter.ping.0                   : ping                  : IOBrokerhost                             -  enabled
                  + system.adapter.pollenflug.0             : pollenflug            : IOBrokerhost                             -  enabled
                  + system.adapter.samsung.0                : samsung               : IOBrokerhost                             -  enabled
                  + system.adapter.scenes.0                 : scenes                : IOBrokerhost                             -  enabled
                  + system.adapter.shelly.0                 : shelly                : IOBrokerhost                             -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.smartgarden.0            : smartgarden           : IOBrokerhost                             -  enabled
                  + system.adapter.smartthings.0            : smartthings           : IOBrokerhost                             -  enabled
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBrokerhost                             -  enabled
                  + system.adapter.synology.0               : synology              : IOBrokerhost                             -  enabled, port: 5001
                  + system.adapter.telegram.0               : telegram              : IOBrokerhost                             -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tibberlink.0             : tibberlink            : IOBrokerhost                             -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : IOBrokerhost                             -  enabled
                  + system.adapter.unifi.0                  : unifi                 : IOBrokerhost                             -  enabled
                  + system.adapter.velux.0                  : velux                 : IOBrokerhost                             -  enabled
                    system.adapter.viessmannapi.0           : viessmannapi          : IOBrokerhost                             - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IOBrokerhost                             -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBrokerhost                             -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBrokerhost                             -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : IOBrokerhost                             -  enabled
                    system.adapter.vis-keyboard.0           : vis-keyboard          : IOBrokerhost                             -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBrokerhost                             -  enabled
                    system.adapter.vis.0                    : vis                   : IOBrokerhost                             - disabled
                  + system.adapter.web.0                    : web                   : IOBrokerhost                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.wifilight.0              : wifilight             : IOBrokerhost                             -  enabled
                  + system.adapter.worx.0                   : worx                  : IOBrokerhost                             -  enabled
                  + system.adapter.yeelight-2.0             : yeelight-2            : IOBrokerhost                             -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 6.12.0   , installed 6.12.0
                  Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
                  Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                  Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                  Adapter    "ble"          : 0.13.4   , installed 0.13.4
                  Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                  Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                  Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                  Adapter    "email"        : 1.2.0    , installed 1.2.0
                  Adapter    "eusec"        : 1.1.2    , installed 1.1.2
                  Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                  Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                  Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                  Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                  Adapter    "hue"          : 3.10.1   , installed 3.10.1
                  Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
                  Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                  Adapter    "iot"          : 1.14.5   , installed 2.0.3
                  Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                  Controller "js-controller": 5.0.12   , installed 5.0.12
                  Adapter    "material"     : 1.3.1    , installed 1.3.1
                  Adapter    "mbus"         : 2.4.0    , installed 2.4.0
                  Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
                  Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                  Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                  Adapter    "milight"      : 0.4.0    , installed 0.4.0
                  Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                  Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
                  Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
                  Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                  Adapter    "radar2"       : 2.0.8    , installed 2.0.8
                  Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                  Adapter    "shelly"       : 6.6.1    , installed 6.4.5  [Updatable]
                  Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                  Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                  Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                  Adapter    "synology"     : 3.0.1    , installed 3.0.1
                  Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                  Adapter    "tibberlink"   : 1.4.1    , installed 1.4.1
                  Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                  Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                  Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                  Adapter    "velux"        : 0.0.7    , installed 0.0.7
                  Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                  Adapter    "vis"          : 1.4.16   , installed 1.4.16
                  Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                  Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                  Adapter    "web"          : 6.1.4    , installed 6.1.4
                  Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                  Adapter    "worx"         : 2.3.4    , installed 2.3.4
                  Adapter    "ws"           : 2.5.5    , installed 2.5.5
                  Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                  Objects and States
                  Objects:        201968
                  States:         154142
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 192.168.1.172:2001      0.0.0.0:*               LISTEN      1001       1904       945/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12655      784/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          10801      737/exim4
                  tcp        0      0 192.168.1.172:2010      0.0.0.0:*               LISTEN      1001       11161      1013/io.hm-rpc.2
                  tcp        0      0 192.168.1.172:8701      0.0.0.0:*               LISTEN      1001       1923       1006/io.hm-rpc.1
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14898      448/iobroker.js-con
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14891      448/iobroker.js-con
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12347      1/init
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1734       813/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13121      1161/io.web.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          12657      784/sshd: /usr/sbin
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          10802      737/exim4
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          12351      1/init
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16642      1072/io.mihome-vacu
                  udp        0      0 0.0.0.0:53423           0.0.0.0:*                           1001       16569      995/io.mihome-vacuu
                  udp        0      0 0.0.0.0:54015           0.0.0.0:*                           1001       20596      1109/io.shelly.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        10753      443/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20244      1109/io.shelly.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11491      350/dhclient
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12348      1/init
                  udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       22108      1409/io.musiccast.0
                  udp        0      0 0.0.0.0:41946           0.0.0.0:*                           1001       2022       1172/io.milight.0
                  udp        0      0 0.0.0.0:58348           0.0.0.0:*                           107        10755      443/avahi-daemon: r
                  udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       11788      984/io.mihome.0
                  udp6       0      0 :::5353                 :::*                                107        10754      443/avahi-daemon: r
                  udp6       0      0 :::54731                :::*                                107        10756      443/avahi-daemon: r
                  udp6       0      0 :::111                  :::*                                0          12354      1/init
                  2023-11-08 07:56:46.489  - warn: mbus.2 (1727) M-Bus ID 1 err: Error: Error: Failed to send/receive M-Bus request frame[1].
                  2023-11-08 07:56:46.489  - warn: mbus.2 (1727) M-Bus Devices with errors: 2 from 2
                  2023-11-08 07:56:46.489  - error: mbus.2 (1727) All M-Bus devices could not be read, reinitialize and start over
                  2023-11-08 07:56:46.491  - info: mbus.2 (1727) Default Update Interval: 3600
                  2023-11-08 07:56:46.491  - info: mbus.2 (1727) Initialize M-Bus Serial to /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A9S6J1O6-if00-port0 with 115200baud
                  2023-11-08 07:56:46.496  - info: mbus.2 (1727) Schedule initialization for M-Bus-ID 1 with update interval 3600
                  2023-11-08 07:56:46.496  - info: mbus.2 (1727) Schedule initialization for M-Bus-ID 12841572496A0016 with update interval 3600
                  2023-11-08 07:56:48.596  - error: govee.0 (1609) AxiosError: Request failed with status code 400
                  2023-11-08 07:56:48.705  - error: govee.0 (1609) AxiosError: Request failed with status code 400
                  2023-11-08 07:56:48.768  - info: govee.0 (1609) State value to set for "govee.0.93:34:A4:C1:38:38:76:E9.online" has to be type "boolean" but received type "string"
                  2023-11-08 07:56:48.805  - info: govee.0 (1609) State value to set for "govee.0.1C:A6:EA:5A:5F:DB:B4:F7.online" has to be type "boolean" but received type "string"
                  2023-11-08 07:56:49.241  - warn: mbus.2 (1727) M-Bus ID 1 err: Error: Error: Failed to send/receive M-Bus request frame[1].
                  2023-11-08 07:56:49.241  - warn: mbus.2 (1727) M-Bus Devices with errors: 2 from 2
                  2023-11-08 07:56:49.241  - error: mbus.2 (1727) All M-Bus devices could not be read, reinitialize and start over
                  2023-11-08 07:56:49.243  - info: mbus.2 (1727) Default Update Interval: 3600
                  2023-11-08 07:56:49.243  - info: mbus.2 (1727) Initialize M-Bus Serial to /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A9S6J1O6-if00-port0 with 115200baud
                  2023-11-08 07:56:49.247  - info: mbus.2 (1727) Schedule initialization for M-Bus-ID 1 with update interval 3600
                  2023-11-08 07:56:49.247  - info: mbus.2 (1727) Schedule initialization for M-Bus-ID 12841572496A0016 with update interval 3600
                  2023-11-08 07:56:51.993  - warn: mbus.2 (1727) M-Bus ID 1 err: Error: Error: Failed to send/receive M-Bus request frame[1].
                  2023-11-08 07:56:51.993  - warn: mbus.2 (1727) M-Bus Devices with errors: 2 from 2
                  2023-11-08 07:56:51.993  - error: mbus.2 (1727) All M-Bus devices could not be read, reinitialize and start over
                  2023-11-08 07:56:51.995  - info: mbus.2 (1727) Default Update Interval: 3600
                  2023-11-08 07:56:51.995  - info: mbus.2 (1727) Initialize M-Bus Serial to /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A9S6J1O6-if00-port0 with 115200baud
                  2023-11-08 07:56:51.999  - info: mbus.2 (1727) Schedule initialization for M-Bus-ID 1 with update interval 3600
                  2023-11-08 07:56:51.999  - info: mbus.2 (1727) Schedule initialization for M-Bus-ID 12841572496A0016 with update interval 3600
                    Kann es sein, dass deine Uhr eine Stunde nachgeht?
                    Boot Target: graphical.target
                    Stell das auf multi-user.target um:
                    sudo systemctl set-defautl multi-user.target
                    Swap: 8.0G
                    Das ist in meinen Augen etwas zu viel des Guten .
                    Den nochmal installieren oder einen der beiden anderen govee-Adapter verwenden. Der scheint mir auch verwaist zu sein.
                    Ähnliches gilt für den:
                    Schau mal ob da nicht eine der Alternativen funktioniert.
                    Bring den nach Möglichkeit auf einen aktuellen Stand.
                    mbus.2
                    Schau dir die Instanz mbus.2 an. Der scheint irgendwas zu fehlen. Die meckert alle 2 Sekunden herum und bläht das Log auf.
                      Vielen Dank.
                      Also Uhrzeit habe ich kontrolliert, die stimmt.
                      Shelly Adapter habe ich aktualisiert.
                      Das mit dem MBUS ist bekannt. Habe dazu einen eigenen Thread aufgemacht, damit ich das mal in den Griff bekomme.
                      Govee habe ich den neuen Adapter installiert (Govee App). Danke für den Hinweis!
                      Samsung Adapter habe ich gelöscht, wird nicht benötigt.
                      Wie kann ich denn den Swap ändern?
                        Homoran Global Moderator Administrators @deifel last edited by
                        welche Uhrzeit stimmt? wie kontrolliert?
                        dann ggf. die Logstufe der Instanz anpassen, um das log zu entlasten
                          deifel @Homoran last edited by
                          Habe das iob diag nochmals laufen lassen.
                          Hier sehe ich folgendes bei der Zeitzone:
                                         Local time: Wed 2023-11-08 10:05:40 CET
                                     Universal time: Wed 2023-11-08 09:05:40 UTC
                                           RTC time: Wed 2023-11-08 09:05:41
                                        NTP service: active
                                    RTC in local TZ: no
                          Die lokale Uhrzeit stimmt mit der aktuellen überein. Dann sollte es doch passen, oder habe ich einen Denkfehler?
                          Logstufe ist angepasst 🙂
                          Die Größe der Swap-Datei würde ich gerne noch verringern, weiß aber leider nicht, wie.
                            @deifel
                            Das SWAP-File ist nicht ganz trivial, aber auch nicht hyperkomplex. Hier wird es beschrieben:
                            https://tecadmin.net/change-swap-file-size-in-ubuntu/
                            704
