    4. Einfach mal zeigen will….. :-) - Teil 3
      woupi @dos1973 last edited by
      @dos1973
      mir gefällt es richtig gut.
      Ich möchte glaube ich gar nicht wissen, wieviel Arbeit da drin steckt.
      Irgendwann komme ich hoffentlich auch mal dazu.
        Kuddel @Ro75 last edited by
        @ro75 wie hast du deine PiHole Statistiken in die VIS integriert?
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          Ro75 @Kuddel last edited by Ro75
          @kuddel ich nutze den Phiole Adapter und zur Darstellung den MaterialDesign Adapter. Das Json aus dem pihole Adapter konvertiere ich in ein passendes Json für das MaterialDesign Balkendiagramm.
          Ro75.
          Nachtrag:
          JS:
          const ubuntu_PiHoleJSON         = 'pi-hole.0.overTimeData10mins.domains_over_time.data-table';
          createState('0_userdata.0.piHole', "[]", {read: true, write: true, desc: "JSON String", type: "string", def: "[]"});
          on(ubuntu_PiHoleJSON, function(dp) {
              let ConsumList = [];
              var text = dp.state.val.split(',');
              for (let i = 0; i <= text.length-1; i++) {
                  let startTime = moment((text[i].split(':')[0].replace('"','').replace('"','').replace('[{',''))*1000);
                  ConsumList.push({
                      label: startTime.format('HH:mm').replace('Invalid date',''),
                      value: parseFloat(text[i].split(':')[1]),
                      valueColor: '#ffffff'
              setState('0_userdata.0.piHole', JSON.stringify(ConsumList), true);
              ConsumList = [];
          Widget:
          [{"tpl":"tplVis-materialdesign-Chart-Bar","data":{"oid":"0_userdata.0.RPI.piHole","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","chartDataMethod":"jsonStringObject","dataCount":"0","chartType":"vertical","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.background","chartAreaBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.background_chart","titleLayout":"#mdwTheme:vis-materialdesign.0.fontSizes.card.title","titleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.card.title","colorBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background","colorTitleSectionBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background_title","colorTextSectionBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background_body","colorTitle":"#mdwTheme:vis-materialdesign.0.colors.card.title","globalColor":"rgba(120, 144, 156, 0.45)","hoverColor":"#mdwTheme:vis-materialdesign.0.colors.charts.bar.hover","hoverBorderColor":"#mdwTheme:vis-materialdesign.0.colors.charts.bar.hover_border","showValues":"showValuesOff","valuesFontColor":"#ffffff","valuesFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.value","valuesFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.value","valuesPositionAnchor":"end","valuesPositionAlign":"top","valuesTextAlign":"center","yAxisPosition":"left","yAxisTitleColor":"#ffffff","yAxisTitleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.y_axis_title","yAxisTitleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.y_axis_title","yAxisValueLabelColor":"#ffffff","yAxisValueFontFamily":"RobotoCondensed-Regular","yAxisValueFontSize":"10","yAxisValueDistanceToAxis":"2","yAxisShowAxis":false,"yAxisShowAxisLabels":true,"yAxisShowGridLines":false,"yAxisGridLinesColor":"#mdwTheme:vis-materialdesign.0.colors.charts.y_axis_gridlines","yAxisShowTicks":true,"yAxisZeroLineColor":"#mdwTheme:vis-materialdesign.0.colors.charts.y_axis_zeroline","xAxisPosition":"bottom","xAxisTicksSource":"auto","xAxisTitleColor":"#mdwTheme:vis-materialdesign.0.colors.charts.x_axis_title","xAxisTitleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.x_axis_title","xAxisTitleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.x_axis_title","xAxisValueLabelColor":"#ffffff","xAxisValueFontFamily":"RobotoCondensed-Regular","xAxisValueFontSize":"10","xAxisValueDistanceToAxis":"7","xAxisShowAxis":true,"xAxisShowAxisLabels":true,"xAxisShowGridLines":false,"xAxisGridLinesColor":"#mdwTheme:vis-materialdesign.0.colors.charts.x_axis_gridlines","xAxisShowTicks":false,"xAxisZeroLineColor":"#mdwTheme:vis-materialdesign.0.colors.charts.x_axis_zeroline","xAxisMinRotation":"0","xAxisMaxRotation":"0","legendPosition":"right","legendFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.legend","legendFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.legend","legendFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.legend","legendPointStyle":"true","showTooltip":false,"tooltipBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_background","tooltipShowColorBox":"true","tooltipTitleFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_title","tooltipTitleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.tooltip_title","tooltipTitleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.tooltip_title","tooltipBodyFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_text","tooltipBodyFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.tooltip_text","tooltipBodyFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.tooltip_text","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_oids":false,"g_layoutForData_§0":false,"colorScheme":"","cardUse":false,"axisMaxLabel":"","chartPaddingTop":"","animationDuration":"0","disableHoverEffects":true},"style":{"left":"1409px","top":"545px","width":"494px","height":"95px","z-index":"3"},"widgetSet":"materialdesign"}]
            @ro75 und die Hintergründe hinter den Zahlen hast du wie gemacht? Sieht halt genau so aus wie direkt im PiHole
            • Ro75
              @kuddel die 4 Bildchen habe ich mir zurechtgebastelt.
              Ro75.
                @ro75 magst du mir die vllt. zur Verfügung stellen?
                • Ro75
                  @kuddel kommt in den nächsten Tagen. Stelledie hier rein.
                  Ro75.
                  K 1 Reply Last reply Reply Quote 2
                    @ro75 vielen Dank für die Bilder etc.
                    Ich habe selber parallel angefangen. Die vier Grafiken haben ich schon hinbekommen
                    Beim Skript für das Widget, läuft aber noch irgendetwas schief
                    javascript.0	2023-11-08 13:58:17.896	error	at processImmediate (node:internal/timers:466:21)
                    javascript.0	2023-11-08 13:58:17.896	error	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8462:62)
                    javascript.0	2023-11-08 13:58:17.896	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                    javascript.0	2023-11-08 13:58:17.896	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                    javascript.0	2023-11-08 13:58:17.896	error	at Object.<anonymous> (script.js.java.abfragen.pihole_diagramme:11:25)
                    javascript.0	2023-11-08 13:58:17.896	error	Error in callback: ReferenceError: moment is not defined
                    Skript
                    const pihole_1_data = 'pi-hole.0.overTimeData10mins.domains_over_time.data-table';
                    if(!existsState('0_userdata.0.PiHole-Diagramme.PiHole-1-Diagramm')){
                       createState('0_userdata.0.PiHole-Diagramme.PiHole-1-Diagramm', "[]", {read: true, write: true, desc: "JSON String", type: "string", def: "[]"});
                    on(pihole_1_data, function(dp) {
                           ConsumList.push({
                       setState('0_userdata.0.PiHole-Diagramme.PiHole-1-Diagramm', JSON.stringify(ConsumList), true);
                       ConsumList = [];
                    Muss ich bzgl. "moment" noch was in der Javascript Adapter Konfig ergänzen?
                    • Ro75
                      @kuddel genau, muss rein
                        @ro75 hmm, komisch. Ist schon eingetragen. Habe den Eintrag mal entfernt, die Instanz neu gestartet und "moment" wieder eingetragen.
                        Der Fehler kommt trotzdem noch.
                        • Ro75
                          @kuddel zeig Mal bitte
                            @ro75
                            • Ro75
                              @kuddel füge Mal ganz am Anfang ein
                              const moment = require('moment');
                              Ro75.
                                @ro75 sagte in Einfach mal zeigen will….. 🙂 - Teil 3:
                                Ro75.
                                Super, jetzt läuft es
                                • Flexer
                                  Flexer last edited by
                                  Habe heute mal mit Vis2 angefangen. Es wird eine neue Vis fürs Handy. Hier einfach mal zwei Screenshots.
                                  Ist alles noch work in progress
                                  • Negalein
                                    Negalein Global Moderator @Flexer last edited by
                                    @flexer sagte in Einfach mal zeigen will….. 🙂 - Teil 3:
                                    Hab dir im Chat geschrieben, da ich dachte das ist der Vis-2 Thread. 😉
                                    Hier nochmal öffentlich. 🙂
                                    Hast du für Vis-1 auch eine Unifi-View?
                                    VIS-2 ist mir noch zu buggie. 😉
                                    Flexer 1 Reply Last reply Reply Quote 0
                                    • Flexer
                                      Flexer @Negalein last edited by
                                      @negalein Hast du Telegram? Kann dir mal was schicken was ich früher mal gebaut habe. Ist uralt aber so in der Art plane ich es wieder
                                      • Frederik Buss
                                        Frederik Buss @dos1973 last edited by
                                        @dos1973 Schönes Design... Eins interessiert mich: Wie hast Du die Graphen in die VIS eingebunden? Grafana oder was anderes? Ich habe seit kurzem ein 14" Touch Display am Raspi hängen und bin auch dabei die VIS etwas aufzupeppen...
                                          dos1973 @Frederik Buss last edited by
                                          @frederik-buss
                                          hier habe ich es beschrieben: https://forum.iobroker.net/topic/23917/einfach-mal-zeigen-will-teil-3/722?_=1701952775588
                                          W Frederik Buss 2 Replies Last reply Reply Quote 0
                                            @dos1973 sagte in Einfach mal zeigen will….. 🙂 - Teil 3:
                                            @frederik-buss
                                            Und das hat auch super funktioniert. Danke an dieser Stelle nochmal 😀
                                            1.0k
                                            vis vis editor visualisierung visualization
                                            155
                                            813
                                            312959
