    3. Einsteigerfragen
    4. Installation
    5. Raspberry Pi 5 8Gb Iobroker Installation
    • teletapi
      teletapi @teletapi last edited by Homoran
      @teletapi
       login as: pi
      pi@192.168.178.121's password:
      Linux Raspberrypi 6.1.0-rpi6-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (202                                  3-10-27) aarch64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Wed Nov  8 20:06:04 2023 from 192.168.178.63
      pi@Raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2023-10-13
          Welcome to the ioBroker installer!
          Installer version: 2023-10-13
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      OK:1 http://archive.raspberrypi.com/debian bookworm InRelease
      OK:2 http://deb.debian.org/debian bookworm InRelease
      OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
      OK:4 http://deb.debian.org/debian bookworm-updates InRelease
      Holen:5 http://deb.debian.org/debian bookworm/main Translation-de [1.748 kB]
      Holen:6 http://deb.debian.org/debian bookworm/main Translation-de_DE [830 B]
      OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Es wurden 1.749 kB in 1 s geholt (1.422 kB/s).
      Paketlisten werden gelesen… Fertig
          Node.js not found. Installing...
      OK:1 http://deb.debian.org/debian bookworm InRelease
      OK:2 http://deb.debian.org/debian-security bookworm-security InRelease
      OK:3 http://deb.debian.org/debian bookworm-updates InRelease
      OK:4 http://archive.raspberrypi.com/debian bookworm InRelease
      OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      ca-certificates ist schon die neueste Version (20230311).
      curl ist schon die neueste Version (7.88.1-10+deb12u4).
      gnupg ist schon die neueste Version (2.2.40-1.1).
      Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
        libpisp0.0.1
      Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
      Überschreiben (j/N)? j
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      login as: pi
      library: loaded
        libpisp0.0.1
        Thomas Braun Most Active @teletapi last edited by
        @teletapi
        Bad timing. Schaut so aus, als ob da auf dem Server von nodesource gerade etwas klemmt. Im iob-Installer werden allerdings Fehlermeldungen weitgehend unterdrückt, weswegen man die hier nicht sieht.
        Versuch es später nochmal.
        teletapi 1 Reply Last reply Reply Quote 0
        • teletapi
          teletapi @Thomas Braun last edited by
          @thomas-braun okay danke
            @teletapi
            Hab das gerade mal auf meinem System nachgestellt. Hier hat es funktioniert.
            • teletapi
              teletapi @Thomas Braun last edited by Homoran
              @thomas-braun Ich bin gerade dabei die SD Karte neu einzurichten dann probiere ich das erneut. Hab jetzt erstmal das Betriebssystem installiert und danach sudo raspi config und die einstellungen auf Deutsch usw ausgeführt, dann "sudo apt update && sudo apt upgrade" ausgeführt
              Wieso krieg ich das wieder nicht in Code tags....? was mach ich da jetzt gerade wieder falsch.
               login as: pi
              Linux Raspberrypi5 6.1.0-rpi4-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.54-1+rpt2 (20                                     23-10-05) aarch64
              pi@Raspberrypi5:~ $ sudo raspi-config
              Generating locales (this might take a while)...
                de_DE.UTF-8... done
                en_GB.UTF-8... done
              Generation complete.
              Current default time zone: 'Europe/Berlin'
              Local time is now:      Wed Nov  8 21:25:39 CET 2023.
              Universal Time is now:  Wed Nov  8 20:25:39 UTC 2023.
              Reloading keymap. This may take a short while
              Welcome to fdisk (util-linux 2.38.1).
              Changes will remain in memory only, until you decide to write them.
              Be careful before using the write command.
              This disk is currently in use - repartitioning is probably a bad idea.
              It's recommended to umount all file systems, and swapoff all swap
              partitions on this disk.
              Command (m for help):
              Disk /dev/mmcblk0: 59.48 GiB, 63864569856 bytes, 124735488 sectors
              Units: sectors of 1 * 512 = 512 bytes
              Sector size (logical/physical): 512 bytes / 512 bytes
              I/O size (minimum/optimal): 512 bytes / 512 bytes
              Disklabel type: dos
              Disk identifier: 0x639be77c
              Device         Boot   Start       End   Sectors  Size Id Type
              /dev/mmcblk0p1         8192   1056767   1048576  512M  c W95 FAT32 (LBA)
              /dev/mmcblk0p2      1056768 124735487 123678720   59G 83 Linux
              Command (m for help): Partition number (1,2, default 2):
              Partition 2 has been deleted.
              Command (m for help): Partition type
                 p   primary (1 primary, 0 extended, 3 free)
                 e   extended (container for logical partitions)
              Select (default p): Partition number (2-4, default 2): First sector (2048-124735                                     487, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (1056768-12473                                     5487, default 124735487):
              Created a new partition 2 of type 'Linux' and of size 59 GiB.
              Partition #2 contains a ext4 signature.
              Disklabel type: dos
              Command (m for help): The partition table has been altered.
              Syncing disks.
              Broadcast message from root@Raspberrypi5 on pts/1 (Wed 2023-11-08 21:26:10 CET):
              The system will reboot now!
              pi@Raspberrypi5:~ $
              login as: pi
              Last login: Wed Nov  8 21:24:22 2023 from 192.168.178.63
              pi@Raspberrypi5:~ $ sudo apt update && sudo apt upgrade
              Holen:2 http://deb.debian.org/debian-security bookworm-security InRelease [48,0                                      kB]
              Holen:3 http://deb.debian.org/debian bookworm-updates InRelease [52,1 kB]
              Holen:4 http://deb.debian.org/debian bookworm/main Translation-de_DE [830 B]
              Holen:5 http://archive.raspberrypi.com/debian bookworm InRelease [23,6 kB]
              Holen:6 http://deb.debian.org/debian bookworm/main Translation-de [1.748 kB]
              Holen:7 http://deb.debian.org/debian-security bookworm-security/main arm64 Packa                                     ges [93,4 kB]
              Holen:8 http://deb.debian.org/debian-security bookworm-security/main armhf Packa                                     ges [91,1 kB]
              Holen:9 http://deb.debian.org/debian-security bookworm-security/main Translation                                     -en [54,7 kB]
              Holen:10 http://deb.debian.org/debian-security bookworm-security/contrib Transla                                     tion-en [372 B]
              Holen:11 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [6.67                                     2 B]
              Holen:12 http://deb.debian.org/debian bookworm-updates/main armhf Packages [6.64                                     8 B]
              Holen:13 http://deb.debian.org/debian bookworm-updates/main Translation-en [5.20                                     4 B]
              Holen:14 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [346                                      kB]
              Holen:15 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [338                                      kB]
              Es wurden 2.815 kB in 1 s geholt (2.332 kB/s).
              Aktualisierung für 31 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,                                      um sie anzuzeigen.
              N: Für das Depot »http://archive.raspberrypi.com/debian bookworm InRelease« wurd                                     e der »Suite«-Wert von »testing« in »stable« geändert.
              Paketaktualisierung (Upgrade) wird berechnet… Fertig
                libpisp0.0.1
              Die folgenden NEUEN Pakete werden installiert:
                libpisp1.0.0 linux-headers-6.1.0-rpi6-common-rpi
                linux-headers-6.1.0-rpi6-rpi-2712 linux-headers-6.1.0-rpi6-rpi-v8
                linux-image-6.1.0-rpi6-rpi-2712 linux-image-6.1.0-rpi6-rpi-v8
              Die folgenden Pakete werden aktualisiert (Upgrade):
                bluez-firmware curl libcamera-apps-lite libcamera-ipa libcamera0.1
                libcurl3-gnutls libcurl4 libpam-chksshpwd libpam-modules libpam-modules-bin
                libpam-runtime libpam0g libpisp-common libraspberrypi-bin libraspberrypi-dev
                libraspberrypi-doc libraspberrypi0 libssl3 libwbclient0
                linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-rpi-2712
                linux-image-rpi-v8 linux-kbuild-6.1 linux-libc-dev openssl
                raspberrypi-net-mods raspi-config raspi-firmware raspi-utils rpi-eeprom
              31 aktualisiert, 6 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
              Es müssen 83,3 MB an Archiven heruntergeladen werden.
              Nach dieser Operation werden 118 MB Plattenplatz zusätzlich benutzt.
              Möchten Sie fortfahren? [J/n] J
              Holen:1 http://deb.debian.org/debian-security bookworm-security/main arm64 curl                                      arm64 7.88.1-10+deb12u4 [308 kB]
              Holen:2 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam0g arm64                                      1.5.2-6+rpt2+deb12u1 [90,7 kB]
              Holen:3 http://deb.debian.org/debian-security bookworm-security/main arm64 libcu                                     rl4 arm64 7.88.1-10+deb12u4 [366 kB]
              Holen:4 http://deb.debian.org/debian-security bookworm-security/main arm64 libcu                                     rl3-gnutls arm64 7.88.1-10+deb12u4 [361 kB]
              Holen:5 http://deb.debian.org/debian-security bookworm-security/main arm64 libwb                                     client0 arm64 2:4.17.12+dfsg-0+deb12u1 [52,8 kB]
              Holen:6 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-modules                                     -bin arm64 1.5.2-6+rpt2+deb12u1 [75,0 kB]
              Holen:7 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-modules                                      arm64 1.5.2-6+rpt2+deb12u1 [286 kB]
              Holen:8 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-firmware                                      all 1:1.20231024+ds-1+rpt1 [4.550 kB]
              Holen:9 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-runtime                                      all 1.5.2-6+rpt2+deb12u1 [161 kB]
              Holen:10 http://archive.raspberrypi.com/debian bookworm/main arm64 bluez-firmwar                                     e all 1.2-9+rpt2 [205 kB]
              Holen:11 http://archive.raspberrypi.com/debian bookworm/main arm64 libssl3 arm64                                      3.0.11-1~deb12u2+rpt1 [1.808 kB]
              Holen:12 http://archive.raspberrypi.com/debian bookworm/main arm64 libpisp-commo                                     n all 1.0.0-1 [4.160 B]
              Holen:13 http://archive.raspberrypi.com/debian bookworm/main arm64 libpisp1.0.0                                      arm64 1.0.0-1 [137 kB]
              Holen:14 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera-ipa                                      arm64 0.1.0+rpt20231020-1 [389 kB]
              Holen:15 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera0.1                                      arm64 0.1.0+rpt20231020-1 [506 kB]
              Holen:16 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera-app                                     s-lite arm64 1.3.0-1 [293 kB]
              Holen:17 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-chkssh                                     pwd arm64 1.5.2-6+rpt2+deb12u1 [46,4 kB]
              Holen:18 http://archive.raspberrypi.com/debian bookworm/main arm64 libraspberryp                                     i-bin arm64 1:2+git20231018~131943+3c97f76-1 [49,6 kB]
              Holen:19 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils a                                     rm64 20231017-1 [65,9 kB]
              Holen:20 http://archive.raspberrypi.com/debian bookworm/main arm64 libraspberryp                                     i-dev arm64 1:2+git20231018~131943+3c97f76-1 [130 kB]
              Holen:21 http://archive.raspberrypi.com/debian bookworm/main arm64 libraspberryp                                     i0 arm64 1:2+git20231018~131943+3c97f76-1 [78,6 kB]
              Holen:22 http://archive.raspberrypi.com/debian bookworm/main arm64 libraspberryp                                     i-doc all 1:2+git20231018~131943+3c97f76-1 [2.392 B]
              Holen:23 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -6.1.0-rpi6-common-rpi all 1:6.1.58-1+rpt2 [7.855 kB]
              Holen:24 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-kbuild-                                     6.1 arm64 1:6.1.58-1+rpt2 [913 kB]
              Holen:25 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -6.1.0-rpi6-rpi-2712 arm64 1:6.1.58-1+rpt2 [1.024 kB]
              Holen:26 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -6.1.0-rpi6-rpi-v8 arm64 1:6.1.58-1+rpt2 [1.024 kB]
              Holen:27 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -rpi-2712 arm64 1:6.1.58-1+rpt2 [1.156 B]
              Holen:28 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -rpi-v8 arm64 1:6.1.58-1+rpt2 [1.152 B]
              Holen:29 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6                                     .1.0-rpi6-rpi-2712 arm64 1:6.1.58-1+rpt2 [28,1 MB]
              Holen:30 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6                                     .1.0-rpi6-rpi-v8 arm64 1:6.1.58-1+rpt2 [28,1 MB]
              Holen:31 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-r                                     pi-2712 arm64 1:6.1.58-1+rpt2 [1.424 B]
              Holen:32 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-r                                     pi-v8 arm64 1:6.1.58-1+rpt2 [1.424 B]
              Holen:33 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-libc-de                                     v arm64 1:6.1.58-1+rpt2 [1.788 kB]
              Holen:34 http://archive.raspberrypi.com/debian bookworm/main arm64 openssl arm64                                      3.0.11-1~deb12u2+rpt1 [1.386 kB]
              Holen:35 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config                                      all 20231108 [29,8 kB]
              Holen:36 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-n                                     et-mods all 1.4.0 [2.160 B]
              Holen:37 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom al                                     l 20.0-2 [3.167 kB]
              Es wurden 83,3 MB in 7 s geholt (11,9 MB/s).
              Changelogs werden gelesen... Fertig
              Extrahiere Vorlagen aus Paketen: 100%
              Vorkonfiguration der Pakete ...
              (Lese Datenbank ... 55058 Dateien und Verzeichnisse sind derzeit installiert.)
              Vorbereitung zum Entpacken von .../libpam0g_1.5.2-6+rpt2+deb12u1_arm64.deb ...
              Entpacken von libpam0g:arm64 (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2) ...
              libpam0g:arm64 (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
              Vorbereitung zum Entpacken von .../libpam-modules-bin_1.5.2-6+rpt2+deb12u1_arm64                                     .deb ...
              Entpacken von libpam-modules-bin (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2) ...
              libpam-modules-bin (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
              Vorbereitung zum Entpacken von .../libpam-modules_1.5.2-6+rpt2+deb12u1_arm64.deb                                      ...
              Entpacken von libpam-modules:arm64 (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2) ..                                     .
              libpam-modules:arm64 (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
              Vorbereitung zum Entpacken von .../raspi-firmware_1%3a1.20231024+ds-1+rpt1_all.d                                     eb ...
              Entpacken von raspi-firmware (1:1.20231024+ds-1+rpt1) über (1:1.20230829+ds-1~rp                                     t3) ...
              Vorbereitung zum Entpacken von .../libpam-runtime_1.5.2-6+rpt2+deb12u1_all.deb .                                     ..
              Entpacken von libpam-runtime (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2) ...
              libpam-runtime (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
              Vorbereitung zum Entpacken von .../00-bluez-firmware_1.2-9+rpt2_all.deb ...
              Entpacken von bluez-firmware (1.2-9+rpt2) über (1.2-9+rpt1) ...
              Vorbereitung zum Entpacken von .../01-libssl3_3.0.11-1~deb12u2+rpt1_arm64.deb ..                                     .
              Entpacken von libssl3:arm64 (3.0.11-1~deb12u2+rpt1) über (3.0.11-1~deb12u1) ...
              Vorbereitung zum Entpacken von .../02-curl_7.88.1-10+deb12u4_arm64.deb ...
              Entpacken von curl (7.88.1-10+deb12u4) über (7.88.1-10+deb12u3) ...
              Vorbereitung zum Entpacken von .../03-libcurl4_7.88.1-10+deb12u4_arm64.deb ...
              Entpacken von libcurl4:arm64 (7.88.1-10+deb12u4) über (7.88.1-10+deb12u3) ...
              Vorbereitung zum Entpacken von .../04-libpisp-common_1.0.0-1_all.deb ...
              Entpacken von libpisp-common (1.0.0-1) über (0.0.1-1) ...
              Vormals nicht ausgewähltes Paket libpisp1.0.0:arm64 wird gewählt.
              Vorbereitung zum Entpacken von .../05-libpisp1.0.0_1.0.0-1_arm64.deb ...
              Entpacken von libpisp1.0.0:arm64 (1.0.0-1) ...
              Vorbereitung zum Entpacken von .../06-libcamera-ipa_0.1.0+rpt20231020-1_arm64.de                                     b ...
              Entpacken von libcamera-ipa:arm64 (0.1.0+rpt20231020-1) über (0.1.0+pi5~0-1) ...
              Vorbereitung zum Entpacken von .../07-libcamera0.1_0.1.0+rpt20231020-1_arm64.deb                                      ...
              Entpacken von libcamera0.1:arm64 (0.1.0+rpt20231020-1) über (0.1.0+pi5~0-1) ...
              Vorbereitung zum Entpacken von .../08-libcamera-apps-lite_1.3.0-1_arm64.deb ...
              Entpacken von libcamera-apps-lite (1.3.0-1) über (1.2.1-1+bookworm+1) ...
              Vorbereitung zum Entpacken von .../09-libcurl3-gnutls_7.88.1-10+deb12u4_arm64.de                                     b ...
              Entpacken von libcurl3-gnutls:arm64 (7.88.1-10+deb12u4) über (7.88.1-10+deb12u3)                                      ...
              Vorbereitung zum Entpacken von .../10-libpam-chksshpwd_1.5.2-6+rpt2+deb12u1_arm6                                     4.deb ...
              Entpacken von libpam-chksshpwd:arm64 (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2)                                      ...
              Vorbereitung zum Entpacken von .../11-libraspberrypi-bin_1%3a2+git20231018~13194                                     3+3c97f76-1_arm64.deb ...
              Entpacken von libraspberrypi-bin (1:2+git20231018~131943+3c97f76-1) über (1:2+gi                                     t20230913~095424+44a3953-1) ...
              Vorbereitung zum Entpacken von .../12-raspi-utils_20231017-1_arm64.deb ...
              Entpacken von raspi-utils (20231017-1) über (20230922+1-1~rc1) ...
              Vorbereitung zum Entpacken von .../13-libraspberrypi-dev_1%3a2+git20231018~13194                                     3+3c97f76-1_arm64.deb ...
              Entpacken von libraspberrypi-dev (1:2+git20231018~131943+3c97f76-1) über (1:2+gi                                     t20230913~095424+44a3953-1) ...
              Vorbereitung zum Entpacken von .../14-libraspberrypi0_1%3a2+git20231018~131943+3                                     c97f76-1_arm64.deb ...
              Entpacken von libraspberrypi0:arm64 (1:2+git20231018~131943+3c97f76-1) über (1:2                                     +git20230913~095424+44a3953-1) ...
              Vorbereitung zum Entpacken von .../15-libraspberrypi-doc_1%3a2+git20231018~13194                                     3+3c97f76-1_all.deb ...
              Entpacken von libraspberrypi-doc (1:2+git20231018~131943+3c97f76-1) über (1:2+gi                                     t20230913~095424+44a3953-1) ...
              Vorbereitung zum Entpacken von .../16-libwbclient0_2%3a4.17.12+dfsg-0+deb12u1_ar                                     m64.deb ...
              Entpacken von libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) über (2:4.17.11+dfsg                                     -0+deb12u1) ...
              Vormals nicht ausgewähltes Paket linux-headers-6.1.0-rpi6-common-rpi wird gewähl                                     t.
              Vorbereitung zum Entpacken von .../17-linux-headers-6.1.0-rpi6-common-rpi_1%3a6.                                     1.58-1+rpt2_all.deb ...
              Entpacken von linux-headers-6.1.0-rpi6-common-rpi (1:6.1.58-1+rpt2) ...
              Vorbereitung zum Entpacken von .../18-linux-kbuild-6.1_1%3a6.1.58-1+rpt2_arm64.d                                     eb ...
              Entpacken von linux-kbuild-6.1 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
              Vormals nicht ausgewähltes Paket linux-headers-6.1.0-rpi6-rpi-2712 wird gewählt.
              Vorbereitung zum Entpacken von .../19-linux-headers-6.1.0-rpi6-rpi-2712_1%3a6.1.                                     58-1+rpt2_arm64.deb ...
              Entpacken von linux-headers-6.1.0-rpi6-rpi-2712 (1:6.1.58-1+rpt2) ...
              Vormals nicht ausgewähltes Paket linux-headers-6.1.0-rpi6-rpi-v8 wird gewählt.
              Vorbereitung zum Entpacken von .../20-linux-headers-6.1.0-rpi6-rpi-v8_1%3a6.1.58                                     -1+rpt2_arm64.deb ...
              Entpacken von linux-headers-6.1.0-rpi6-rpi-v8 (1:6.1.58-1+rpt2) ...
              Vorbereitung zum Entpacken von .../21-linux-headers-rpi-2712_1%3a6.1.58-1+rpt2_a                                     rm64.deb ...
              Entpacken von linux-headers-rpi-2712 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ..                                     .
              Vorbereitung zum Entpacken von .../22-linux-headers-rpi-v8_1%3a6.1.58-1+rpt2_arm                                     64.deb ...
              Entpacken von linux-headers-rpi-v8 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
              Vormals nicht ausgewähltes Paket linux-image-6.1.0-rpi6-rpi-2712 wird gewählt.
              Vorbereitung zum Entpacken von .../23-linux-image-6.1.0-rpi6-rpi-2712_1%3a6.1.58                                     Fortschritt: [ 44%] [########################...............................]
              Entpacken von linux-image-6.1.0-rpi6-rpi-2712 (1:6.1.58-1+rpt2) ...
              Vormals nicht ausgewähltes Paket linux-image-6.1.0-rpi6-rpi-v8 wird gewählt.
              Vorbereitung zum Entpacken von .../24-linux-image-6.1.0-rpi6-rpi-v8_1%3a6.1.58-1+rpt2_arm64.deb ...
              Entpacken von linux-image-6.1.0-rpi6-rpi-v8 (1:6.1.58-1+rpt2) ...
              Vorbereitung zum Entpacken von .../25-linux-image-rpi-2712_1%3a6.1.58-1+rpt2_arm64.deb ...
              Entpacken von linux-image-rpi-2712 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
              Vorbereitung zum Entpacken von .../26-linux-image-rpi-v8_1%3a6.1.58-1+rpt2_arm64.deb ...
              Entpacken von linux-image-rpi-v8 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
              Vorbereitung zum Entpacken von .../27-linux-libc-dev_1%3a6.1.58-1+rpt2_arm64.deb ...
              Entpacken von linux-libc-dev:arm64 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
              Vorbereitung zum Entpacken von .../28-openssl_3.0.11-1~deb12u2+rpt1_arm64.deb ...
              Entpacken von openssl (3.0.11-1~deb12u2+rpt1) über (3.0.11-1~deb12u1) ...
              Vorbereitung zum Entpacken von .../29-raspi-config_20231108_all.deb ...
              Entpacken von raspi-config (20231108) über (20231009) ...
              Vorbereitung zum Entpacken von .../30-raspberrypi-net-mods_1.4.0_all.deb ...
              Entpacken von raspberrypi-net-mods (1.4.0) über (1.3.4) ...
              Vorbereitung zum Entpacken von .../31-rpi-eeprom_20.0-2_all.deb ...
              Entpacken von rpi-eeprom (20.0-2) über (19-1) ...
              bluez-firmware (1.2-9+rpt2) wird eingerichtet ...
              linux-image-6.1.0-rpi6-rpi-v8 (1:6.1.58-1+rpt2) wird eingerichtet ...
              I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.1.0-rpi4-rpi-v8
              I: /initrd.img.old is now a symlink to boot/initrd.img-6.1.0-rpi4-rpi-v8
              I: /vmlinuz is now a symlink to boot/vmlinuz-6.1.0-rpi6-rpi-v8
              I: /initrd.img is now a symlink to boot/initrd.img-6.1.0-rpi6-rpi-v8
              /etc/kernel/postinst.d/initramfs-tools:
              update-initramfs: Generating /boot/initrd.img-6.1.0-rpi6-rpi-v8
              libssl3:arm64 (3.0.11-1~deb12u2+rpt1) wird eingerichtet ...
              linux-libc-dev:arm64 (1:6.1.58-1+rpt2) wird eingerichtet ...
              libcurl3-gnutls:arm64 (7.88.1-10+deb12u4) wird eingerichtet ...
              libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) wird eingerichtet ...
              libpam-chksshpwd:arm64 (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
              libpisp-common (1.0.0-1) wird eingerichtet ...
              raspi-firmware (1:1.20231024+ds-1+rpt1) wird eingerichtet ...
              Neue Version der Konfigurationsdatei /etc/kernel/postinst.d/z50-raspi-firmware wird installiert ...
              linux-image-rpi-v8 (1:6.1.58-1+rpt2) wird eingerichtet ...
              linux-headers-6.1.0-rpi6-common-rpi (1:6.1.58-1+rpt2) wird eingerichtet ...
              libraspberrypi0:arm64 (1:2+git20231018~131943+3c97f76-1) wird eingerichtet ...
              linux-image-6.1.0-rpi6-rpi-2712 (1:6.1.58-1+rpt2) wird eingerichtet ...
              I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.1.0-rpi6-rpi-v8
              I: /initrd.img.old is now a symlink to boot/initrd.img-6.1.0-rpi6-rpi-v8
              I: /vmlinuz is now a symlink to boot/vmlinuz-6.1.0-rpi6-rpi-2712
              I: /initrd.img is now a symlink to boot/initrd.img-6.1.0-rpi6-rpi-2712
              update-initramfs: Generating /boot/initrd.img-6.1.0-rpi6-rpi-2712
              libcurl4:arm64 (7.88.1-10+deb12u4) wird eingerichtet ...
              libpisp1.0.0:arm64 (1.0.0-1) wird eingerichtet ...
              curl (7.88.1-10+deb12u4) wird eingerichtet ...
              linux-kbuild-6.1 (1:6.1.58-1+rpt2) wird eingerichtet ...
              openssl (3.0.11-1~deb12u2+rpt1) wird eingerichtet ...
              raspi-config (20231108) wird eingerichtet ...
              libraspberrypi-bin (1:2+git20231018~131943+3c97f76-1) wird eingerichtet ...
              linux-image-rpi-2712 (1:6.1.58-1+rpt2) wird eingerichtet ...
              linux-headers-6.1.0-rpi6-rpi-v8 (1:6.1.58-1+rpt2) wird eingerichtet ...
              linux-headers-6.1.0-rpi6-rpi-2712 (1:6.1.58-1+rpt2) wird eingerichtet ...
              linux-headers-rpi-2712 (1:6.1.58-1+rpt2) wird eingerichtet ...
              libraspberrypi-dev (1:2+git20231018~131943+3c97f76-1) wird eingerichtet ...
              raspberrypi-net-mods (1.4.0) wird eingerichtet ...
              rpi-eeprom (20.0-2) wird eingerichtet ...
              linux-headers-rpi-v8 (1:6.1.58-1+rpt2) wird eingerichtet ...
              libraspberrypi-doc (1:2+git20231018~131943+3c97f76-1) wird eingerichtet ...
              raspi-utils (20231017-1) wird eingerichtet ...
              libcamera-ipa:arm64 (0.1.0+rpt20231020-1) wird eingerichtet ...
              libcamera0.1:arm64 (0.1.0+rpt20231020-1) wird eingerichtet ...
              libcamera-apps-lite (1.3.0-1) wird eingerichtet ...
              Trigger für initramfs-tools (0.142) werden verarbeitet ...
              update-initramfs: Generating /boot/initrd.img-6.1.0-rpi4-rpi-v8
              update-initramfs: Generating /boot/initrd.img-6.1.0-rpi4-rpi-2712
              Trigger für libc-bin (2.36-9+rpt2+deb12u3) werden verarbeitet ...
              Trigger für man-db (2.11.2-2) werden verarbeitet ...
                @teletapi sagte in Raspberry Pi 5 8Gb Iobroker Installation:
                Die Sprache würde ich allerdings auf Englisch belassen. Die deutschen Meldungen sind immer irritierend und man findet auch im Netz mehr zu den originalen Texten.
                • teletapi
                  @thomas-braun Okay danke, ich glaube jetzt geht es weiter Node wurde installiert, ich geb Rückmeldung
                  • teletapi
                    @teletapi Ich bin nicht sicher wo es hängt aber wie hier im Bild zu sehen bleibt die Installation wieder hängen und Putty ist nichtmehr bedienbar
                      Homoran Global Moderator Administrators @teletapi last edited by Homoran
                      @teletapi da entpackt er gerade massiv
                      WARTEN!
                      hat da schon immer Meldungen gegeben, dass er sich aufgehängt hätte.
                      Mal sehen, wie lange der 5er da braucht
                      • teletapi
                        teletapi @Homoran last edited by
                        @homoran Oh, da hätte ich jetzt nicht mit gerechnet das es so lange dauert, ich lass es mal wieder laufen
                          Thomas Braun Most Active @teletapi last edited by Thomas Braun
                          @teletapi
                          Hol dir ein Bier, geh 'ne Runde um den Block oder tu was andres, während die Kiste arbeitet.
                          'Abstürze' sehen in der Regel anders aus. Die haben nämlich keine Fortschrittsbalken. Hab jedenfalls noch keine 'Kernel Panic' mit einem gesehen...
                          A teletapi 2 Replies Last reply Reply Quote 0
                            Albyricus @Thomas Braun last edited by
                            Hi, ich hab auch Probleme mit einem Pi 4 8Gb.... kämpfe heute schon den ganzen tag mit einem Reinstall (genau das selbe Image)... hab glaub ich mittlerweile die 13ente installation durch... entweder bleibt er irgendwo hängen, oder ich bekomm nen npm err!...
                            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                            Get:3 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
                            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Fetched 52.1 kB in 1s (38.0 kB/s)
                            Reading package lists... Done
                                Creating ioBroker user and directory (2/4)
                            Created /etc/sudoers.d/iobroker
                            Directory /opt/iobroker created
                                Installing ioBroker (3/4)
                            npm ERR! code ERR_SOCKET_TIMEOUT
                            npm ERR! network Socket timeout
                            npm ERR! network This is a problem related to network connectivity.
                            npm ERR! network In most cases you are behind a proxy or have bad network settings.
                            npm ERR! network
                            npm ERR! network If you are behind a proxy, please make sure that the
                            npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                            npm ERR! A complete log of this run can be found in: /home/brokerer/.npm/_logs/2023-11-08T21_13_39_035Z-debug-0.log
                                Finalizing installation (4/4)
                            Enabling autostart...
                            Autostart enabled!
                            Fixing directory permissions...
                                ioBroker was installed successfully
                                Open http://192.168.1.48:8081 in a browser and start configuring!
                            You need to re-login before doing anything else on the console!
                              Homoran Global Moderator Administrators @Albyricus last edited by
                              @albyricus sagte in Raspberry Pi 5 8Gb Iobroker Installation:
                              @thomas-braun sagte in Raspberry Pi 5 8Gb Iobroker Installation:
                              @teletapi
                              hattest du auch das aktuelle RasPiOS gezogen?
                                Albyricus @Homoran last edited by
                                hi, ja ich habe gestern das Raspberry Pi OS Lite (64-bit) geholt. die erste Reinstall hat auch super funktioniert und ich hab mein iobroker aufgebaut... dann beim versuch auf Multihost völlig zerschossen und wollte heute nochmal bei 0 beginnen... tja und ab dann war der wurm drinnen
                                  Thomas Braun Most Active @Albyricus last edited by
                                  @albyricus
                                  Musste mal nach dem Netzwerk schauen.
                                    Albyricus @Thomas Braun last edited by Albyricus
                                    ich hab ein stinklangweiliges dsl50 mit fritzbox, ohne proxy, ohne pihole oder sonstige spielereien und der Pi hängt am gigabit lan kabel.... hab auch die Fritzbox schonmal neugestartet... mache gerade versuch nummer 14...
                                    • teletapi
                                      Bin gerade wieder rein und das stand in der Konsole.
                                      Ich mach jetzt nochmal neu.
                                      pi@Raspberrypi5:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                                      library: loaded
                                      Es wurden 52,1 kB in 1 s geholt (59,5 kB/s).
                                      npm ERR! network In most cases you are behind a proxy or have bad network settin gs.
                                      npm ERR! network
                                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11 -08T21_03_31_496Z-debug-0.log
                                      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → / lib/systemd/system/iobroker.service.
                                      Autostart enabled!
                                      Open http://192.168.178.121 192.168.178.122:8081 in a browser and start conf            iguring!
                                        Und warum sollte das Ergebnis bei sonst unverändertem Umfeld dann ein anderes sein?
                                        • teletapi
                                          Weil ich die Fehlerquelle vorm Rechner vermute
                                            Schau in das angegebene Log rein. Vielleicht steht ja was verwertbares drin.
                                            1.3k
                                            48
                                            13293
