    4. Adapterwarnungen / web stürzt ab
      Thomas Braun Most Active @MichaelF last edited by
      @michaelf sagte in Adapterwarnungen / web stürzt ab:
      wie passiert sowas ?
      Durch übermäßigen Einsatz von Adaptern direkt aus dem Github.
      • MichaelF
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.25-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         21:56:14 up  2:11,  1 user,  load average: 1.59, 1.63, 1.82
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2023-11-08 21:56:15 CET
                   Universal time: Wed 2023-11-08 20:56:15 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            7.8G        2.9G        3.3G        1.0M        1.6G        4.7G
        Swap:            99M          0B         99M
        Total:          7.9G        2.9G        3.4G
                 7811 M total memory
                 2933 M used memory
                 3096 M active memory
                  963 M inactive memory
                 3317 M free memory
                  302 M buffer memory
                 1258 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      117G   17G   95G  15% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  876K  1.6G   1% /run
        /dev/sda1      vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
        [Wed Nov  8 19:45:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:9F:6B:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=247e04bb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Wed Nov  8 19:45:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Nov  8 19:45:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Wed Nov  8 19:45:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime,stripe=8191
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        4.4G    /var/
        3.6G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
        3.6G    /var/log
        574M    /var/cache
        Archived and active journals take up 3.5G in the file system.
        /opt/iobroker/backups:
        826M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.0G    /opt/iobroker/iobroker-data/
        1.1G    /opt/iobroker/iobroker-data/sqlite
        671M    /opt/iobroker/iobroker-data/files
        132M    /opt/iobroker/iobroker-data/backup-objects
        88M     /opt/iobroker/iobroker-data/files/echarts.admin
        1.1G    /opt/iobroker/iobroker-data/sqlite/sqlite.db
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        26M     /opt/iobroker/iobroker-data/states.jsonl
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: typescript@5.1.6 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
        npm ERR! missing: homebridge-midea-air@^1.7.3, required by iobroker.ham@5.3.1
        npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
        npm ERR! extraneous: @aashutoshrathi/word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
        npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
        npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
        npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
        npm ERR! extraneous: @alcalzone/release-script-plugin-exec@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
        npm ERR! extraneous: @alcalzone/release-script-plugin-git@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
        npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
        npm ERR! extraneous: @alcalzone/release-script-plugin-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
        npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
        npm ERR! extraneous: @alcalzone/release-script-plugin-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
        npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
        npm ERR! extraneous: @eslint-community/eslint-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
        npm ERR! extraneous: @eslint-community/regexpp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
        npm ERR! extraneous: @eslint/eslintrc@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc
        npm ERR! extraneous: @eslint/js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
        npm ERR! extraneous: @humanwhocodes/config-array@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
        npm ERR! extraneous: @humanwhocodes/module-importer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
        npm ERR! extraneous: @humanwhocodes/object-schema@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
        npm ERR! extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
        npm ERR! extraneous: @iobroker/testing@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
        npm ERR! extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
        npm ERR! extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
        npm ERR! extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk
        npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commons
        npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
        npm ERR! extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
        npm ERR! extraneous: @sinonjs/text-encoding@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
        npm ERR! extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
        npm ERR! extraneous: @types/cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
        npm ERR! extraneous: @types/cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
        npm ERR! extraneous: @types/expect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
        npm ERR! extraneous: @types/http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
        npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker
        npm ERR! extraneous: @types/vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
        npm ERR! extraneous: abbrev@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
        npm ERR! extraneous: accepts@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
        npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
        npm ERR! extraneous: acorn-jsx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
        npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
        npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared
        npm ERR! extraneous: ansi-align@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
        npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
        npm ERR! extraneous: ansi-gray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
        npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
        npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
        npm ERR! extraneous: ansi-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
        npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
        npm ERR! extraneous: append-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
        npm ERR! extraneous: archy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
        npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
        npm ERR! extraneous: arr-diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
        npm ERR! extraneous: arr-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
        npm ERR! extraneous: arr-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
        npm ERR! extraneous: arr-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
        npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
        npm ERR! extraneous: array-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
        npm ERR! extraneous: array-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
        npm ERR! extraneous: array-initial@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
        npm ERR! extraneous: array-last@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
        npm ERR! extraneous: array-slice@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
        npm ERR! extraneous: array-sort@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
        npm ERR! extraneous: array-unique@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
        npm ERR! extraneous: assertion-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
        npm ERR! extraneous: assign-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
        npm ERR! extraneous: astral-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
        npm ERR! extraneous: async-done@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
        npm ERR! extraneous: async-each-series@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
        npm ERR! extraneous: async-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
        npm ERR! extraneous: async-settle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
        npm ERR! extraneous: async@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
        npm ERR! extraneous: atob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
        npm ERR! extraneous: bach@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
        npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
        npm ERR! extraneous: base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
        npm ERR! extraneous: base64id@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
        npm ERR! extraneous: batch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
        npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
        npm ERR! extraneous: binaryextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions
        npm ERR! extraneous: bindings@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bindings
        npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
        npm ERR! extraneous: boxen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
        npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
        npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
        npm ERR! extraneous: browser-request@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
        npm ERR! extraneous: browser-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
        npm ERR! extraneous: browser-sync-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
        npm ERR! extraneous: browser-sync-ui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
        npm ERR! extraneous: browser-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
        npm ERR! extraneous: bs-html-injector@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector
        npm ERR! extraneous: bs-recipes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
        npm ERR! extraneous: buffer-equal@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
        npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
        npm ERR! extraneous: bytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
        npm ERR! extraneous: cache-base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
        npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
        npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
        npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
        npm ERR! extraneous: chai-as-promised@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promised
        npm ERR! extraneous: chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
        npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
        npm ERR! extraneous: check-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
        npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
        npm ERR! extraneous: class-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
        npm ERR! extraneous: cli-boxes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
        npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
        npm ERR! extraneous: clone-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
        npm ERR! extraneous: clone-stats@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
        npm ERR! extraneous: clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
        npm ERR! extraneous: cloneable-readable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
        npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
        npm ERR! extraneous: collection-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
        npm ERR! extraneous: collection-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit
        npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
        npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
        npm ERR! extraneous: color-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
        npm ERR! extraneous: colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
        npm ERR! extraneous: commander@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
        npm ERR! extraneous: component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
        npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
        npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
        npm ERR! extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
        npm ERR! extraneous: connect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
        npm ERR! extraneous: content-disposition@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
        npm ERR! extraneous: content-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
        npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
        npm ERR! extraneous: cookie-signature@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signature
        npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
        npm ERR! extraneous: copy-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
        npm ERR! extraneous: copy-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
        npm ERR! extraneous: cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
        npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
        npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
        npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
        npm ERR! extraneous: d@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
        npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
        npm ERR! extraneous: decode-uri-component@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
        npm ERR! extraneous: deep-eql@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
        npm ERR! extraneous: deep-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
        npm ERR! extraneous: default-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
        npm ERR! extraneous: default-resolution@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
        npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
        npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
        npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
        npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
        npm ERR! extraneous: detect-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
        npm ERR! extraneous: dev-ip@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
        npm ERR! extraneous: diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
        npm ERR! extraneous: doctrine@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
        npm ERR! extraneous: dom-compare-temp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-temp
        npm ERR! extraneous: dom-serializer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
        npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
        npm ERR! extraneous: domhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
        npm ERR! extraneous: domutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
        npm ERR! extraneous: duplexer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
        npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
        npm ERR! extraneous: each-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
        npm ERR! extraneous: easy-extender@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
        npm ERR! extraneous: eazy-logger@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
        npm ERR! extraneous: ee-first@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
        npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
        npm ERR! extraneous: encodeurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
        npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
        npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client
        npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parser
        npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
        npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
        npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
        npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
        npm ERR! extraneous: es5-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
        npm ERR! extraneous: es6-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
        npm ERR! extraneous: es6-symbol@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
        npm ERR! extraneous: es6-weak-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
        npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
        npm ERR! extraneous: escape-html@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
        npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
        npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
        npm ERR! extraneous: eslint-scope@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
        npm ERR! extraneous: eslint-visitor-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
        npm ERR! extraneous: eslint@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
        npm ERR! extraneous: espree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
        npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
        npm ERR! extraneous: esquery@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
        npm ERR! extraneous: esrecurse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
        npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
        npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
        npm ERR! extraneous: etag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
        npm ERR! extraneous: event-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
        npm ERR! extraneous: eventemitter3@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
        npm ERR! extraneous: execa@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
        npm ERR! extraneous: expand-brackets@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
        npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
        npm ERR! extraneous: express@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
        npm ERR! extraneous: ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
        npm ERR! extraneous: extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
        npm ERR! extraneous: fancy-log@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
        npm ERR! extraneous: fast-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
        npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein
        npm ERR! extraneous: fastq@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
        npm ERR! extraneous: file-entry-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache
        npm ERR! extraneous: file-uri-to-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-uri-to-path
        npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
        npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
        npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
        npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync
        npm ERR! extraneous: fined@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined
        npm ERR! extraneous: flagged-respawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn
        npm ERR! extraneous: flat-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache
        npm ERR! extraneous: flat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat
        npm ERR! extraneous: flatted@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted
        npm ERR! extraneous: flush-write-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream
        npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in
        npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own
        npm ERR! extraneous: forwarded@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/forwarded
        npm ERR! extraneous: fragment-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache
        npm ERR! extraneous: fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fresh
        npm ERR! extraneous: from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/from
        npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra
        npm ERR! extraneous: fs-mkdirp-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream
        npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath
        npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fsevents
        npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind
        npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file
        npm ERR! extraneous: get-func-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name
        npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic
        npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream
        npm ERR! extraneous: get-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value
        npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent
        npm ERR! extraneous: glob-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream
        npm ERR! extraneous: glob-watcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher
        npm ERR! extraneous: glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
        npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules
        npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix
        npm ERR! extraneous: globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals
        npm ERR! extraneous: globalyzer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer
        npm ERR! extraneous: globrex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex
        npm ERR! extraneous: glogg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg
        npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gopd
        npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs
        npm ERR! extraneous: graphemer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer
        npm ERR! extraneous: gulp-cli@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli
        npm ERR! extraneous: gulp-rename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
        npm ERR! extraneous: gulp-replace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
        npm ERR! extraneous: gulp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
        npm ERR! extraneous: gulplog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog
        npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag
        npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors
        npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-proto
        npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols
        npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value
        npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values
        npm ERR! extraneous: has@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has
        npm ERR! extraneous: he@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/he
        npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill
        npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info
        npm ERR! extraneous: htmlparser2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2
        npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-errors
        npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy-middleware
        • MichaelF
          npm ERR! extraneous: http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy
          npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
          npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
          npm ERR! extraneous: ignore-by-default@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default
          npm ERR! extraneous: ignore@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
          npm ERR! extraneous: immutable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable
          npm ERR! extraneous: import-fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
          npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
          npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
          npm ERR! extraneous: ini@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
          npm ERR! extraneous: interpret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
          npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
          npm ERR! extraneous: ipaddr.js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js
          npm ERR! extraneous: is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
          npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
          npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
          npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
          npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
          npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
          npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
          npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
          npm ERR! extraneous: is-extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
          npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
          npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
          npm ERR! extraneous: is-negated-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
          npm ERR! extraneous: is-number-like@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like
          npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
          npm ERR! extraneous: is-path-inside@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
          npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
          npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
          npm ERR! extraneous: is-relative@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
          npm ERR! extraneous: is-unc-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
          npm ERR! extraneous: is-unicode-supported@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
          npm ERR! extraneous: is-utf8@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
          npm ERR! extraneous: is-valid-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
          npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
          npm ERR! extraneous: is-wsl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl
          npm ERR! extraneous: isexe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isexe
          npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isobject
          npm ERR! extraneous: istextorbinary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/istextorbinary
          npm ERR! extraneous: js-yaml@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/js-yaml
          npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom
          npm ERR! extraneous: json-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer
          npm ERR! extraneous: json-stable-stringify-without-jsonify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stable-stringify-without-jsonify
          npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonfile
          npm ERR! extraneous: just-debounce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-debounce
          npm ERR! extraneous: just-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-extend
          npm ERR! extraneous: keyv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/kind-of
          npm ERR! extraneous: last-run@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/last-run
          npm ERR! extraneous: lazystream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream
          npm ERR! extraneous: lcid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lcid
          npm ERR! extraneous: lead@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lead
          npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/levn
          npm ERR! extraneous: liftoff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff
          npm ERR! extraneous: limiter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/limiter
          npm ERR! extraneous: load-json-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/load-json-file
          npm ERR! extraneous: localtunnel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel
          npm ERR! extraneous: locate-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/locate-path
          npm ERR! extraneous: lodash.get@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.get
          npm ERR! extraneous: lodash.isfinite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.isfinite
          npm ERR! extraneous: lodash.merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.merge
          npm ERR! extraneous: lodash.truncate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.truncate
          npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash
          npm ERR! extraneous: log-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/log-symbols
          npm ERR! extraneous: loupe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/loupe
          npm ERR! extraneous: make-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator
          npm ERR! extraneous: map-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-cache
          npm ERR! extraneous: map-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-stream
          npm ERR! extraneous: map-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-visit
          npm ERR! extraneous: matchdep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep
          npm ERR! extraneous: media-typer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/media-typer
          npm ERR! extraneous: merge-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-descriptors
          npm ERR! extraneous: merge-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-stream
          npm ERR! extraneous: merge2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge2
          npm ERR! extraneous: methods@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/methods
          npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch
          npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime
          npm ERR! extraneous: mimic-fn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-fn
          npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
          npm ERR! extraneous: mitt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mitt
          npm ERR! extraneous: mixin-deep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep
          npm ERR! extraneous: mocha@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
          npm ERR! extraneous: mute-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mute-stdout
          npm ERR! extraneous: nanoid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanoid
          npm ERR! extraneous: nanomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch
          npm ERR! extraneous: natural-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/natural-compare
          npm ERR! extraneous: negotiator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/negotiator
          npm ERR! extraneous: next-tick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/next-tick
          npm ERR! extraneous: nise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise
          npm ERR! extraneous: nodemon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon
          npm ERR! extraneous: nopt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nopt
          npm ERR! extraneous: normalize-package-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data
          npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-path
          npm ERR! extraneous: now-and-later@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/now-and-later
          npm ERR! extraneous: npm-run-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/npm-run-path
          npm ERR! extraneous: number-is-nan@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/number-is-nan
          npm ERR! extraneous: nwmatcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nwmatcher
          npm ERR! extraneous: object-assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign
          npm ERR! extraneous: object-copy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy
          npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-inspect
          npm ERR! extraneous: object-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
          npm ERR! extraneous: object-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-visit
          npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
          npm ERR! extraneous: object.defaults@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.defaults
          npm ERR! extraneous: object.map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.map
          npm ERR! extraneous: object.pick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.pick
          npm ERR! extraneous: object.reduce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.reduce
          npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/on-finished
          npm ERR! extraneous: once@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
          npm ERR! extraneous: onetime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/onetime
          npm ERR! extraneous: openurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/openurl
          npm ERR! extraneous: opn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/opn
          npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/optionator
          npm ERR! extraneous: ordered-read-streams@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ordered-read-streams
          npm ERR! extraneous: os-locale@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/os-locale
          npm ERR! extraneous: p-limit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-limit
          npm ERR! extraneous: p-locate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-locate
          npm ERR! extraneous: parent-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parent-module
          npm ERR! extraneous: parse-filepath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-filepath
          npm ERR! extraneous: parse-json@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-json
          npm ERR! extraneous: parse-node-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-node-version
          npm ERR! extraneous: parse-passwd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-passwd
          npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5
          npm ERR! extraneous: parseurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parseurl
          npm ERR! extraneous: pascalcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pascalcase
          npm ERR! extraneous: path-dirname@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-dirname
          npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-exists
          npm ERR! extraneous: path-is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
          npm ERR! extraneous: path-key@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-key
          npm ERR! extraneous: path-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-parse
          npm ERR! extraneous: path-root-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root-regex
          npm ERR! extraneous: path-root@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root
          npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-to-regexp
          npm ERR! extraneous: path-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-type
          npm ERR! extraneous: pathval@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pathval
          npm ERR! extraneous: pause-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pause-stream
          npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/picomatch
          npm ERR! extraneous: pify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pify
          npm ERR! extraneous: pinkie-promise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise
          npm ERR! extraneous: pinkie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie
          npm ERR! extraneous: portscanner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/portscanner
          npm ERR! extraneous: posix-character-classes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/posix-character-classes
          npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/prelude-ls
          npm ERR! extraneous: pretty-hrtime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pretty-hrtime
          npm ERR! extraneous: proxy-addr@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-addr
          npm ERR! extraneous: ps-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ps-tree
          npm ERR! extraneous: pstree.remy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pstree.remy
          npm ERR! extraneous: pump@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pump
          npm ERR! extraneous: pumpify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pumpify
          npm ERR! extraneous: qs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
          npm ERR! extraneous: queue-microtask@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/queue-microtask
          npm ERR! extraneous: randombytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/randombytes
          npm ERR! extraneous: range-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/range-parser
          npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/raw-body
          npm ERR! extraneous: read-pkg-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up
          npm ERR! extraneous: read-pkg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg
          npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp
          npm ERR! extraneous: rechoir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rechoir
          npm ERR! extraneous: regex-not@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not
          npm ERR! extraneous: remove-bom-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-buffer
          npm ERR! extraneous: remove-bom-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-stream
          npm ERR! extraneous: remove-trailing-separator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-trailing-separator
          npm ERR! extraneous: repeat-element@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-element
          npm ERR! extraneous: repeat-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-string
          npm ERR! extraneous: replace-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-ext
          npm ERR! extraneous: replace-homedir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-homedir
          npm ERR! extraneous: replacestream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream
          npm ERR! extraneous: require-directory@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-directory
          npm ERR! extraneous: require-from-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-from-string
          npm ERR! extraneous: require-main-filename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-main-filename
          npm ERR! extraneous: requires-port@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/requires-port
          npm ERR! extraneous: resolve-dir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-dir
          npm ERR! extraneous: resolve-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-from
          npm ERR! extraneous: resolve-options@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-options
          npm ERR! extraneous: resolve-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-url
          npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve
          npm ERR! extraneous: resp-modifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier
          npm ERR! extraneous: ret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ret
          npm ERR! extraneous: reusify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/reusify
          npm ERR! extraneous: rimraf@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
          npm ERR! extraneous: run-parallel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/run-parallel
          npm ERR! extraneous: rx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rx
          npm ERR! extraneous: safe-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-regex
          npm ERR! extraneous: semver-greatest-satisfied-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver-greatest-satisfied-range
          npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send
          npm ERR! extraneous: serialize-javascript@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialize-javascript
          npm ERR! extraneous: serve-index@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index
          npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-static
          npm ERR! extraneous: server-destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/server-destroy
          npm ERR! extraneous: set-blocking@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-blocking
          npm ERR! extraneous: set-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value
          npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/setprototypeof
          npm ERR! extraneous: shebang-command@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-command
          npm ERR! extraneous: shebang-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-regex
          npm ERR! extraneous: side-channel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/side-channel
          npm ERR! extraneous: signal-exit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/signal-exit
          npm ERR! extraneous: simple-update-notifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier
          npm ERR! extraneous: sinon-chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon-chai
          npm ERR! extraneous: sinon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon
          npm ERR! extraneous: slice-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/slice-ansi
          npm ERR! extraneous: snapdragon-node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node
          npm ERR! extraneous: snapdragon-util@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util
          npm ERR! extraneous: snapdragon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon
          npm ERR! extraneous: socket.io-adapter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter
          npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-client
          npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-parser
          npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io
          npm ERR! extraneous: source-map-resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-resolve
          npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support
          npm ERR! extraneous: source-map-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-url
          npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map
          npm ERR! extraneous: sparkles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sparkles
          npm ERR! extraneous: spdx-correct@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-correct
          npm ERR! extraneous: spdx-exceptions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-exceptions
          npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-expression-parse
          npm ERR! extraneous: spdx-license-ids@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-license-ids
          npm ERR! extraneous: split-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string
          npm ERR! extraneous: split@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split
          npm ERR! extraneous: stack-trace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stack-trace
          npm ERR! extraneous: static-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend
          npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/statuses
          npm ERR! extraneous: stream-combiner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
          npm ERR! extraneous: stream-exhaust@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-exhaust
          npm ERR! extraneous: stream-shift@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-shift
          npm ERR! extraneous: stream-throttle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-throttle
          npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/string-width
          npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-ansi
          npm ERR! extraneous: strip-bom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-bom
          npm ERR! extraneous: strip-final-newline@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-final-newline
          npm ERR! extraneous: strip-json-comments@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-json-comments
          npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-color
          npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-preserve-symlinks-flag
          npm ERR! extraneous: sver-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sver-compat
          npm ERR! extraneous: symbol-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/symbol-tree
          npm ERR! extraneous: table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table
          npm ERR! extraneous: text-table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/text-table
          npm ERR! extraneous: textextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/textextensions
          npm ERR! extraneous: through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
          npm ERR! extraneous: through2-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2-filter
          npm ERR! extraneous: through2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2
          npm ERR! extraneous: time-stamp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/time-stamp
          npm ERR! extraneous: timekeeper@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
          npm ERR! extraneous: tiny-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tiny-glob
          npm ERR! extraneous: to-absolute-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-absolute-glob
          npm ERR! extraneous: to-object-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path
          npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex-range
          npm ERR! extraneous: to-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex
          npm ERR! extraneous: to-through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-through
          npm ERR! extraneous: toidentifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/toidentifier
          npm ERR! extraneous: touch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/touch
          npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
          npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-check
          npm ERR! extraneous: type-detect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-detect
          npm ERR! extraneous: type-fest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-fest
          npm ERR! extraneous: type-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-is
          npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type
          npm ERR! extraneous: typedarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/typedarray
          npm ERR! extraneous: ua-parser-js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ua-parser-js
          npm ERR! extraneous: unc-path-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unc-path-regex
          npm ERR! extraneous: undefsafe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undefsafe
          npm ERR! extraneous: undertaker-registry@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker-registry
          npm ERR! extraneous: undertaker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker
          npm ERR! extraneous: union-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value
          npm ERR! extraneous: unique-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unique-stream
          npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/universalify
          npm ERR! extraneous: unpipe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unpipe
          npm ERR! extraneous: unset-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value
          npm ERR! extraneous: upath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/upath
          npm ERR! extraneous: urix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/urix
          npm ERR! extraneous: use@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/use
          npm ERR! extraneous: utils-merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/utils-merge
          npm ERR! extraneous: v8flags@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/v8flags
          npm ERR! extraneous: validate-npm-package-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/validate-npm-package-license
          npm ERR! extraneous: value-or-function@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/value-or-function
          npm ERR! extraneous: vary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vary
          npm ERR! extraneous: vinyl-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-fs
          npm ERR! extraneous: vinyl-sourcemap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap
          npm ERR! extraneous: vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl
          npm ERR! extraneous: whatwg-url-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url-compat
          npm ERR! extraneous: which-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-module
          npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which
          npm ERR! extraneous: widest-line@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/widest-line
          npm ERR! extraneous: word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/word-wrap
          npm ERR! extraneous: workerpool@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/workerpool
          npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrap-ansi
          npm ERR! extraneous: wrappy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
          npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ws
          npm ERR! extraneous: xml-name-validator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml-name-validator
          npm ERR! extraneous: xmldom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmldom
          npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest-ssl
          npm ERR! extraneous: xmlhttprequest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest
          npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/y18n
          npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-parser
          npm ERR! extraneous: yargs-unparser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser
          npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs
          npm ERR! extraneous: yocto-queue@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yocto-queue
          npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
          npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
          npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak/node_modules/axios
          npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker/node_modules/axios
          npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script/node_modules/axios
          npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server/node_modules/axios
          npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
          npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals/node_modules/acorn
          npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial/node_modules/is-number
          npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last/node_modules/is-number
          npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/define-property
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/debug
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/ms
          npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/raw-body
          npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/fs-extra
          npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/jsonfile
          npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/universalify
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/debug
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/ms
          npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/define-property
          npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor
          npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor
          npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-descriptor
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/debug
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/ms
          npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/domelementtype
          npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/entities
          npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props/node_modules/is-plain-object
          npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client/node_modules/ws
          npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/cookie
          npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/ws
          npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/estraverse
          npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/levn
          npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/optionator
          npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/prelude-ls
          npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/source-map
          npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/type-check
          npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint/node_modules/glob-parent
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/debug
          npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/define-property
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/extend-shallow
          npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor
          npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor
          npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-descriptor
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-extendable
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/ms
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/debug
          npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/finalhandler
          npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/mime
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/ms
          npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send
          npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/serve-static
          npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext/node_modules/type
          npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/define-property
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/extend-shallow
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/is-extendable
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/debug
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/ms
          npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/on-finished
          npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/statuses
          npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces
          npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-extendable
          npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/kind-of
          npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/micromatch
          npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/to-regex-range
          npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined/node_modules/is-plain-object
          npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/glob-parent
          npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/is-glob
          npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch
          npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/binary-extensions
          npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces
          npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/chokidar
          npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range
          npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fsevents
          npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent
          npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-binary-path
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-extendable
          npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-number
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/kind-of
          npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch
          npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/readdirp
          npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/to-regex-range
          npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix/node_modules/which
          npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-colors
          npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-regex
          npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/camelcase
          npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/cliui
          npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/decamelize
          npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/get-caller-file
          npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/is-fullwidth-code-point
          npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/string-width
          npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/strip-ansi
          npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/wrap-ansi
          npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/y18n
          npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs-parser
          npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs
          npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/kind-of
          npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/node_modules/readable-stream
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor/node_modules/kind-of
          npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable/node_modules/is-plain-object
          npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom/node_modules/acorn
          npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff/node_modules/is-plain-object
          npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/axios
          npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/cliui
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/debug
          npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs-parser
          npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator/node_modules/kind-of
          npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces
          npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range
          npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/findup-sync
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-extendable
          npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-glob
          npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/kind-of
          npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/micromatch
          npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/to-regex-range
          npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ansi-colors
          npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/brace-expansion
          npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/cliui
          npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/minimatch
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ms
          npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/supports-color
          npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs-parser
          npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/kind-of
          npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers
          npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/isarray
          npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/path-to-regexp
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/debug
          npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/has-flag
          npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/semver
          npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/supports-color
          npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data/node_modules/semver
          npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/define-property
          npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-accessor-descriptor
          npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-data-descriptor
          npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/kind-of
          npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/find-up
          npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/path-exists
          npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream/node_modules/escape-string-regexp
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/debug
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/ms
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/debug
          npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/depd
          npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/destroy
          npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/http-errors
          npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/inherits
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/ms
          npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/on-finished
          npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/setprototypeof
          npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/statuses
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/debug
          npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/depd
          npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/http-errors
          npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/inherits
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/ms
          npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/setprototypeof
          npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/statuses
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/extend-shallow
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-extendable
          npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-plain-object
          npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier/node_modules/semver
          npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/define-property
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util/node_modules/kind-of
          npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/debug
          npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/define-property
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/extend-shallow
          npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor
          npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor
          npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-descriptor
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-extendable
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/ms
          npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/source-map
          npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter/node_modules/ws
          npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support/node_modules/source-map
          npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/define-property
          npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor
          npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor
          npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-descriptor
          npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/ajv
          npm ERR! extraneous: json-schema-traverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/json-schema-traverse
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path/node_modules/kind-of
          npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker/node_modules/fast-levenshtein
          npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value/node_modules/is-extendable
          npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value
          npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-values
          npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap/node_modules/normalize-path
          npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser/node_modules/is-plain-obj
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor/node_modules/kind-of
          npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send/node_modules/ms
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces/node_modules/extend-shallow
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range/node_modules/extend-shallow
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number/node_modules/kind-of
          npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch/node_modules/normalize-path
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces/node_modules/extend-shallow
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range/node_modules/extend-shallow
          npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent/node_modules/is-glob
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number/node_modules/kind-of
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces/node_modules/extend-shallow
          npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range/node_modules/extend-shallow
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number/node_modules/kind-of
          npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
          npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value/node_modules/isobject
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T20_56_24_842Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.12.0
          javascript:     7.1.4
          Adapters from github:   9
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : IoBroker64Bit                            -  enabled
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
          + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          + system.adapter.envertech-pv.0           : envertech-pv          : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
          + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
          + system.adapter.hekr.0                   : hekr                  : IoBroker64Bit                            -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
            system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
            system.adapter.midea.0                  : midea                 : IoBroker64Bit                            - disabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
          + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.69
          + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
          + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
          + system.adapter.octoprint.1              : octoprint             : iobroker                                 -  enabled
          + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
          + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
          + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
          + system.adapter.psa.0                    : psa                   : iobroker                                 -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
          + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
          + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.69
          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
          + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
          + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
          + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
            system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
          Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
          Adapter    "device-reminder": 3.0.0  , installed 3.0.0
          Adapter    "device-watcher": 2.9.4   , installed 2.9.4
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "echarts"      : 1.5.1    , installed 1.5.1
          Adapter    "envertech-pv" : 1.0.2    , installed 1.0.2
          Adapter    "evcc"         : 0.0.10   , installed 0.0.10
          Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "hekr"         : 0.0.6    , installed 0.0.6
          Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 1.14.5   , installed 1.14.5
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "logparser"    : 2.2.0    , installed 2.2.0
          Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
          Adapter    "midea"        : 0.0.7    , installed 0.1.0
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "parcel"       : 0.0.27   , installed 0.0.27
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "psa"          : 0.0.11   , installed 0.0.11
          Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
          Adapter    "s7"           : 1.3.15   , installed 1.3.15
          Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "synology"     : 3.0.1    , installed 3.0.1
          Adapter    "telegram"     : 2.0.1    , installed 2.0.1
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
          Adapter    "worx"         : 2.3.4    , installed 2.3.4
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Objects and States
          Objects:        28839
          States:         24330
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.178.69:45000    0.0.0.0:*               LISTEN      1001       150559     18465/io.sainlogic.
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16499      531/cupsd
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13823      917/exim4
          tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       138031     17482/io.hm-rpc.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       140028     17700/io.mqtt.1
          tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       143721     17847/io.shelly.1
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140027     17700/io.mqtt.1
          tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       140025     17692/io.hm-rpc.3
          tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       141320     17505/io.hm-rpc.1
          tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       136160     17568/io.hm-rpc.2
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15217      611/sshd: /usr/sbin
          tcp        0      0 192.168.178.69:1887     0.0.0.0:*               LISTEN      1001       140070     17813/io.mqtt.3
          tcp        0      0 192.168.178.69:1886     0.0.0.0:*               LISTEN      1001       140069     17813/io.mqtt.3
          tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      1001       141739     17790/io.sonoff.0
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       138417     17273/iobroker.js-c
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       138410     17273/iobroker.js-c
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       148037     18544/io.simple-api
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       137827     17298/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       158639     20102/io.web.0
          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       168901     18256/io.upnp.0
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13824      917/exim4
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16498      531/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15219      611/sshd: /usr/sbin
          tcp6       0      0 :::80                   :::*                    LISTEN      0          15245      658/apache2
          udp        0      0 0.0.0.0:51507           0.0.0.0:*                           1001       146871     18210/io.broadlink2
          udp        0      0 0.0.0.0:59804           0.0.0.0:*                           1001       146875     18210/io.broadlink2
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141936     17828/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141937     17828/io.tuya.0
          udp        0      0 0.0.0.0:55830           0.0.0.0:*                           108        14770      396/avahi-daemon: r
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       146867     18210/io.broadlink2
          udp        0      0 0.0.0.0:36315           0.0.0.0:*                           1001       146874     18210/io.broadlink2
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16646      459/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13758      596/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14768      396/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141737     17779/io.shelly.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       147689     18256/io.upnp.0
          udp6       0      0 :::45149                :::*                                108        14771      396/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          16667      459/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14769      396/avahi-daemon: r
          2023-11-08 21:52:08.090  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
          2023-11-08 21:53:00.347  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 21:53:00.888  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476780888_7107
          2023-11-08 21:53:58.129  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 21:54:00.072  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 3554
          2023-11-08 21:54:01.670  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476841669_4609
          2023-11-08 21:54:07.965  - info: luftdaten.0 (3554) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
          2023-11-08 21:54:08.604  - info: luftdaten.0 (3554) Terminated (NO_ERROR): Without reason
          2023-11-08 21:54:09.169  - warn: luftdaten.0 (3554) get state error: Connection is closed.
          2023-11-08 21:54:09.400  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
          2023-11-08 21:54:32.528  - info: fritzdect.0 (18158) DECT ID: 087610101442 identified for command (state) : false
          2023-11-08 21:54:59.917  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 21:55:00.201  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3669
          2023-11-08 21:55:02.467  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476902467_6802
          2023-11-08 21:55:07.827  - info: dwd.0 (3669) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
          2023-11-08 21:55:09.345  - info: dwd.0 (3669) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-11-08 21:55:09.893  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-11-08 21:56:00.181  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 4091
          2023-11-08 21:56:00.710  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 21:56:01.245  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476961244_1751
          2023-11-08 21:56:07.469  - info: luftdaten.0 (4091) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
          2023-11-08 21:56:08.624  - info: luftdaten.0 (4091) Terminated (NO_ERROR): Without reason
          2023-11-08 21:56:09.211  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
          2023-11-08 21:56:59.486  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 21:57:02.037  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699477022036_8863
            Thomas Braun Most Active @MichaelF last edited by
            @michaelf
            Räum das auf:
            npm ERR! missing: homebridge-midea-air@^1.7.3, required by iobroker.ham@5.3.1
            npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
            MichaelF 1 Reply Last reply Reply Quote 0
            • MichaelF
              MichaelF @Thomas Braun last edited by MichaelF
              @thomas-braun said in Adapterwarnungen / web stürzt ab:
              @michaelf
              Räum das auf:
              Aufräumen ?
              Das müsste das hier sein ?
                Thomas Braun Most Active @MichaelF last edited by Thomas Braun
                @michaelf
                Die fehlen aus Sicht von npm.
                Ich weiß aber nicht wie der ham-Adapter das handhabt.
                • MichaelF
                  @michaelf
                  Mal neu trüber installieren ?
                    @michaelf
                    Vermutlich nur die ham-Module nochmal reinjubeln.
                    • MichaelF
                      @michaelf
                      In Arbeit
                      • MichaelF
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                           Static hostname: iobroker
                                 Icon name: computer
                          Operating System: Raspbian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.1.25-v8+
                              Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : armhf
                        Systemuptime and Load:
                         22:15:39 up  2:30,  1 user,  load average: 1.57, 1.65, 1.71
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Wed 2023-11-08 22:15:40 CET
                                   Universal time: Wed 2023-11-08 21:15:40 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            7.8G        3.0G        3.3G        1.0M        1.6G        4.7G
                        Swap:            99M          0B         99M
                        Total:          7.9G        3.0G        3.4G
                                 7811 M total memory
                                 2968 M used memory
                                 3133 M active memory
                                  984 M inactive memory
                                 3258 M free memory
                                  318 M buffer memory
                                 1266 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4      117G   17G   95G  15% /
                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                        tmpfs          tmpfs     1.6G  876K  1.6G   1% /run
                        /dev/sda1      vfat      253M   51M  202M  20% /boot
                        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
                        [Wed Nov  8 19:45:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:9F:6B:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=247e04bb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Wed Nov  8 19:45:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Wed Nov  8 19:45:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                        [Wed Nov  8 19:45:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                        TARGET  SOURCE    FSTYPE OPTIONS
                        /       /dev/sda2 ext4   rw,noatime,stripe=8191
                        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                        /var:
                        4.4G    /var/
                        3.6G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
                        3.6G    /var/log
                        574M    /var/cache
                        Archived and active journals take up 3.5G in the file system.
                        /opt/iobroker/backups:
                        826M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        2.0G    /opt/iobroker/iobroker-data/
                        1.1G    /opt/iobroker/iobroker-data/sqlite
                        659M    /opt/iobroker/iobroker-data/files
                        132M    /opt/iobroker/iobroker-data/backup-objects
                        88M     /opt/iobroker/iobroker-data/files/echarts.admin
                        1.1G    /opt/iobroker/iobroker-data/sqlite/sqlite.db
                        49M     /opt/iobroker/iobroker-data/states.jsonl
                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        25M     /opt/iobroker/iobroker-data/objects.jsonl
                        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                        USB-Devices by-id:
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.18.2
                        /usr/bin/node           v18.18.2
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        /usr/bin/corepack       0.19.0
                        nodejs:
                          Installed: 18.18.2-1nodesource1
                          Candidate: 18.18.2-1nodesource1
                          Version table:
                         *** 18.18.2-1nodesource1 500
                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                100 /var/lib/dpkg/status
                             18.18.1-1nodesource1 500
                             18.18.0-1nodesource1 500
                             18.17.1-1nodesource1 500
                             18.17.0-1nodesource1 500
                             18.16.1-1nodesource1 500
                             18.16.0-1nodesource1 500
                             18.15.0-1nodesource1 500
                             18.14.2-1nodesource1 500
                             18.14.1-1nodesource1 500
                             18.14.0-1nodesource1 500
                             18.13.0-1nodesource1 500
                             18.12.0-1nodesource1 500
                             18.11.0-1nodesource1 500
                             18.10.0-1nodesource1 500
                             18.9.1-1nodesource1 500
                             18.9.0-1nodesource1 500
                             18.8.0-1nodesource1 500
                             18.7.0-1nodesource1 500
                             18.6.0-1nodesource1 500
                             18.5.0-1nodesource1 500
                             18.4.0-1nodesource1 500
                             18.3.0-1nodesource1 500
                             18.2.0-1nodesource1 500
                             18.1.0-1nodesource1 500
                             18.0.0-1nodesource1 500
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                        No problems detected
                        Errors in npm tree:
                        npm ERR! code ELSPROBLEMS
                        npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                        npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                        npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
                        npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                        npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                        npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                        npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
                        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/debug
                        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/ms
                        npm ERR! extraneous: tslib@2.4.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/tslib
                        npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.4
                        npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/mock-require/node_modules/get-caller-file
                        npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
                        npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/node-persist/node_modules/mkdirp
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T21_15_50_546Z-debug-0.log
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        28839
                        States:         24330
                        Pending Updates: 0
                        2023-11-08 22:13:47.920  - info: host.iobroker stopInstance system.adapter.ham.0 send kill signal
                        2023-11-08 22:13:48.530  - info: host.iobroker instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-11-08 22:13:51.656  - info: host.iobroker instance system.adapter.ham.0 started with pid 9182
                        2023-11-08 22:13:59.930  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                        2023-11-08 22:14:00.117  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9213
                        2023-11-08 22:14:02.468  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478042468_9572
                        2023-11-08 22:14:07.867  - info: luftdaten.0 (9213) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                        2023-11-08 22:14:08.618  - info: luftdaten.0 (9213) Terminated (NO_ERROR): Without reason
                        2023-11-08 22:14:09.228  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                        2023-11-08 22:14:41.287  - info: admin.0 (17298) ==> Connected system.user.admin from ::ffff:192.168.178.52
                        2023-11-08 22:14:53.476  - info: admin.0 (17298) <== Disconnect system.user.admin from ::ffff:192.168.178.52 ham
                        2023-11-08 22:15:00.071  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9336
                        2023-11-08 22:15:00.709  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                        2023-11-08 22:15:01.255  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478101254_3328
                        2023-11-08 22:15:08.139  - info: dwd.0 (9336) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                        2023-11-08 22:15:11.054  - info: dwd.0 (9336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-11-08 22:15:11.882  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-11-08 22:15:59.500  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                        2023-11-08 22:16:00.460  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9883
                        2023-11-08 22:16:02.080  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478162080_8235
                        2023-11-08 22:16:09.485  - info: luftdaten.0 (9883) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                        2023-11-08 22:16:11.630  - info: luftdaten.0 (9883) Terminated (NO_ERROR): Without reason
                        2023-11-08 22:16:12.196  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                        2023-11-08 22:17:00.326  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                        2023-11-08 22:17:00.872  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478220871_7431
                          @michaelf sagte in Adapterwarnungen / web stürzt ab:
                          Da wird im javascript-Adapter das Modul fehlen. Brauchst du das überhaupt?
                          • MichaelF
                            Ja auch grade gesehen, und neu eingetragen seit dem läuft der Adapter wieder.
                            Moment neuer Diag
                            • MichaelF
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                               22:25:47 up  2:40,  1 user,  load average: 2.07, 2.07, 1.94
                              CPU threads: 4
                              Current issues:
                                             Local time: Wed 2023-11-08 22:25:47 CET
                                         Universal time: Wed 2023-11-08 21:25:47 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            7.8G        3.3G        2.8G        1.0M        1.7G        4.4G
                              Swap:            99M          0B         99M
                              Total:          7.9G        3.3G        2.9G
                                       7811 M total memory
                                       3290 M used memory
                                       3449 M active memory
                                       1073 M inactive memory
                                       2841 M free memory
                                        326 M buffer memory
                                       1352 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              4.4G    /var/
                              3.6G    /var/log
                              574M    /var/cache
                              61M     /opt/iobroker/iobroker-data/states.jsonl
                              29M     /opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.12.0
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        28839
                              States:         24407
                              Pending Updates: 0
                              2023-11-08 22:25:39.551  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                              2023-11-08 22:25:39.552  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                              2023-11-08 22:25:40.711  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                              2023-11-08 22:25:59.446  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                              2023-11-08 22:26:00.445  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 13249
                              2023-11-08 22:26:02.012  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478762011_8296
                              2023-11-08 22:26:12.328  - info: luftdaten.0 (13249) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                              2023-11-08 22:26:14.168  - info: luftdaten.0 (13249) Terminated (NO_ERROR): Without reason
                              2023-11-08 22:26:15.000  - warn: luftdaten.0 (13249) get state error: Connection is closed.
                              2023-11-08 22:26:15.340  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                              2023-11-08 22:27:00.253  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                              2023-11-08 22:27:00.796  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478820795_8708
                              Alle Fehler Weg............
                              Mega, Riesen Dank
                                Homoran Global Moderator Administrators @MichaelF last edited by Homoran
                                auch alle extraneous im npm tree??
                                wie kommt man suf soooo viele Adapter aus Github?
                                MichaelF 2 Replies Last reply Reply Quote 0
                                • MichaelF
                                  Ich lasse heute Nacht ein Backup laufen und versuche morgen Abend nochmal das Update des Web Adapters.
                                  • MichaelF
                                    MichaelF @Homoran last edited by
                                    @homoran said in Adapterwarnungen / web stürzt ab:
                                    Ich Schaue, Moment
                                    • MichaelF
                                      pi@iobroker:~ $ npm ls
                                      pi@ /home/pi
                                      └── canvas@2.9.3
                                      pi@iobroker:~ $
                                      • MichaelF
                                        Mmh, mit den Adaptern ist halt irgendwie so gewachsen. Also da war jetzt nicht irgendwie Absicht dahinter
                                          immer wieder ins normale Repo überführen wenn vorhanden
                                            @michaelf
                                            cd /opt/iobroker
                                            npm ls
                                            canvas haste mal daneben geworfen... 😉
                                            3793
