    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      Gismoh @crunchip last edited by Gismoh
      @crunchip
      merci, den Befehl kannte ich noch nicht 😉
      hier ein Auszug, scheint wirklich, das er nach 12 Minuten nichts mehr gemacht hatte:
      2023-11-08 11:45:41.207  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-timeandweather created/updated
      2023-11-08 11:45:42.267  - info: host.ioBrokerVM iobroker npm-install: exit 0
      2023-11-08 11:45:43.267  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
      2023-11-08 11:45:43.268  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
      2023-11-08 11:45:44.908  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
      2023-11-08 11:45:44.909  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
      2023-11-08 11:45:49.371  - info: vis.0 (6542) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
      2023-11-08 11:45:49.603  - info: vis.0 (6542) vis license is OK.
      2023-11-08 11:45:49.792  - error: vis.0 (6542) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-11-08 11:45:49.793  - error: vis.0 (6542) unhandled promise rejection: Not exists
      2023-11-08 11:45:49.793  - error: vis.0 (6542) Error: Not exists
          at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
          at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
          at process.processImmediate (node:internal/timers:478:21)
      2023-11-08 11:45:49.794  - error: vis.0 (6542) Not exists
      2023-11-08 11:45:50.298  - info: vis.0 (6542) terminating
      2023-11-08 11:45:50.299  - warn: vis.0 (6542) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-11-08 11:45:50.965  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_45_45_224Z-debug-0.log
      2023-11-08 11:45:50.965  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
      2023-11-08 11:45:51.981  - info: host.ioBrokerVM iobroker npm-install: exit 25
      2023-11-08 11:45:52.982  - warn: host.ioBrokerVM startInstance cannot find adapter "web@4.3.0". Try to install it... 1 attempt
      2023-11-08 11:45:52.982  - info: host.ioBrokerVM iobroker install web@4.3.0 using installedFrom
      2023-11-08 11:45:54.660  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
      2023-11-08 11:45:54.661  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.web@4.3.0... (System call)
      2023-11-08 11:46:01.177  - info: host.ioBrokerVM iobroker npm-install: added 12 packages in 6s
      2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install:
      2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install: 150 packages are looking for funding
      2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
      2023-11-08 11:46:01.205  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter web@4.3.0
      2023-11-08 11:46:01.278  - info: host.ioBrokerVM iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
      2023-11-08 11:46:01.285  - info: host.ioBrokerVM iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      2023-11-08 11:46:01.290  - info: host.ioBrokerVM iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
      2023-11-08 11:46:01.293  - info: host.ioBrokerVM iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
      2023-11-08 11:46:01.297  - info: host.ioBrokerVM iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      2023-11-08 11:46:01.301  - info: host.ioBrokerVM iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
      2023-11-08 11:46:01.305  - info: host.ioBrokerVM iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      2023-11-08 11:46:01.309  - info: host.ioBrokerVM iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
      2023-11-08 11:46:01.313  - info: host.ioBrokerVM iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
      2023-11-08 11:46:01.329  - info: host.ioBrokerVM iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
      2023-11-08 11:46:01.333  - info: host.ioBrokerVM iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
      2023-11-08 11:46:01.679  - info: host.ioBrokerVM iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
      2023-11-08 11:46:01.683  - info: host.ioBrokerVM iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
      2023-11-08 11:46:01.686  - info: host.ioBrokerVM iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
      2023-11-08 11:46:01.693  - info: host.ioBrokerVM iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
      2023-11-08 11:46:01.696  - info: host.ioBrokerVM iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
      2023-11-08 11:46:01.699  - info: host.ioBrokerVM iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
      2023-11-08 11:46:01.748  - info: host.ioBrokerVM iobroker npm-install: upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
      2023-11-08 11:46:01.875  - info: host.ioBrokerVM iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
      2023-11-08 11:46:02.022  - info: host.ioBrokerVM iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
      2023-11-08 11:46:02.170  - info: host.ioBrokerVM iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
      2023-11-08 11:46:02.346  - info: host.ioBrokerVM iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
      2023-11-08 11:46:02.520  - info: host.ioBrokerVM iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
      2023-11-08 11:46:02.705  - info: host.ioBrokerVM iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
      2023-11-08 11:46:02.739  - info: host.ioBrokerVM iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
      2023-11-08 11:46:02.776  - info: host.ioBrokerVM iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
      2023-11-08 11:46:02.808  - info: host.ioBrokerVM iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
      2023-11-08 11:46:02.844  - info: host.ioBrokerVM iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
      2023-11-08 11:46:02.897  - info: host.ioBrokerVM iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
      2023-11-08 11:46:02.932  - info: host.ioBrokerVM iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
      2023-11-08 11:46:02.967  - info: host.ioBrokerVM iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
      2023-11-08 11:46:03.003  - info: host.ioBrokerVM iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
      2023-11-08 11:46:03.008  - info: host.ioBrokerVM iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
      2023-11-08 11:46:03.029  - info: host.ioBrokerVM iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
      2023-11-08 11:46:03.033  - info: host.ioBrokerVM iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
      2023-11-08 11:46:03.040  - info: host.ioBrokerVM iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
      2023-11-08 11:46:03.046  - info: host.ioBrokerVM iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
      2023-11-08 11:46:03.050  - info: host.ioBrokerVM iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
      2023-11-08 11:46:03.056  - info: host.ioBrokerVM iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
      2023-11-08 11:46:03.061  - info: host.ioBrokerVM iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
      2023-11-08 11:46:03.066  - info: host.ioBrokerVM iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
      2023-11-08 11:46:03.071  - info: host.ioBrokerVM iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
      2023-11-08 11:46:03.079  - info: host.ioBrokerVM iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
      2023-11-08 11:46:03.085  - info: host.ioBrokerVM iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
      2023-11-08 11:46:03.089  - info: host.ioBrokerVM iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
      2023-11-08 11:46:03.100  - info: host.ioBrokerVM iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
      2023-11-08 11:46:03.107  - info: host.ioBrokerVM iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
      2023-11-08 11:46:03.124  - info: host.ioBrokerVM iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
      2023-11-08 11:46:03.135  - info: host.ioBrokerVM iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
      2023-11-08 11:46:03.139  - info: host.ioBrokerVM iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
      2023-11-08 11:46:03.143  - info: host.ioBrokerVM iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
      2023-11-08 11:46:03.147  - info: host.ioBrokerVM iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
      2023-11-08 11:46:03.328  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.web created/updated
      2023-11-08 11:46:04.395  - info: host.ioBrokerVM iobroker npm-install: exit 0
      2023-11-08 11:46:05.396  - warn: host.ioBrokerVM startInstance cannot find adapter "worx@2.3.2". Try to install it... 1 attempt
      2023-11-08 11:46:05.396  - info: host.ioBrokerVM iobroker install worx@2.3.2 using installedFrom
      2023-11-08 11:46:07.069  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
      2023-11-08 11:46:07.070  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.worx@2.3.2... (System call)
      2023-11-08 11:46:17.160  - info: host.ioBrokerVM iobroker npm-install: added 42 packages in 10s152 packages are looking for funding  run `npm fund` for details
      2023-11-08 11:46:17.184  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter worx@2.3.2
      2023-11-08 11:46:17.263  - info: host.ioBrokerVM iobroker npm-install: upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
      2023-11-08 11:46:17.270  - info: host.ioBrokerVM iobroker npm-install: upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
      2023-11-08 11:46:17.274  - info: host.ioBrokerVM iobroker npm-install: upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
      2023-11-08 11:46:17.281  - info: host.ioBrokerVM iobroker npm-install: upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      2023-11-08 11:46:17.285  - info: host.ioBrokerVM iobroker npm-install: upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
      2023-11-08 11:46:17.288  - info: host.ioBrokerVM iobroker npm-install: upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      2023-11-08 11:46:17.291  - info: host.ioBrokerVM iobroker npm-install: upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      2023-11-08 11:46:17.294  - info: host.ioBrokerVM iobroker npm-install: upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      2023-11-08 11:46:17.298  - info: host.ioBrokerVM iobroker npm-install: upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      2023-11-08 11:46:17.301  - info: host.ioBrokerVM iobroker npm-install: upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      2023-11-08 11:46:17.304  - info: host.ioBrokerVM iobroker npm-install: upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      2023-11-08 11:46:17.307  - info: host.ioBrokerVM iobroker npm-install: upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
      2023-11-08 11:46:17.310  - info: host.ioBrokerVM iobroker npm-install: upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
      2023-11-08 11:46:17.313  - info: host.ioBrokerVM iobroker npm-install: upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
      2023-11-08 11:46:17.434  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.worx created/updated
      2023-11-08 11:46:18.498  - info: host.ioBrokerVM iobroker npm-install: exit 0
      2023-11-08 11:46:19.499  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
      2023-11-08 11:46:19.499  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
      2023-11-08 11:46:21.160  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
      2023-11-08 11:46:21.161  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
      2023-11-08 11:46:25.314  - info: vis.0 (6854) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
      2023-11-08 11:46:25.483  - info: vis.0 (6854) vis license is OK.
      2023-11-08 11:46:25.699  - error: vis.0 (6854) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-11-08 11:46:25.699  - error: vis.0 (6854) unhandled promise rejection: Not exists
      2023-11-08 11:46:25.700  - error: vis.0 (6854) Error: Not exists
      2023-11-08 11:46:25.700  - error: vis.0 (6854) Not exists
      2023-11-08 11:46:26.207  - info: vis.0 (6854) terminating
      2023-11-08 11:46:26.208  - warn: vis.0 (6854) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-11-08 11:46:26.909  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_21_469Z-debug-0.loghost.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
      2023-11-08 11:46:27.929  - info: host.ioBrokerVM iobroker npm-install: exit 25
      2023-11-08 11:46:28.929  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
      2023-11-08 11:46:28.929  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
      2023-11-08 11:46:30.593  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
      2023-11-08 11:46:30.594  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
      2023-11-08 11:46:34.599  - info: vis.0 (6963) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
      2023-11-08 11:46:34.921  - info: vis.0 (6963) vis license is OK.
      2023-11-08 11:46:35.089  - error: vis.0 (6963) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-11-08 11:46:35.089  - error: vis.0 (6963) unhandled promise rejection: Not exists
      2023-11-08 11:46:35.090  - error: vis.0 (6963) Error: Not exists
      2023-11-08 11:46:35.090  - error: vis.0 (6963) Not exists
      2023-11-08 11:46:35.593  - info: vis.0 (6963) terminating
      2023-11-08 11:46:35.594  - warn: vis.0 (6963) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-11-08 11:46:36.231  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_30_898Z-debug-0.log
      2023-11-08 11:46:36.231  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
      2023-11-08 11:46:37.248  - info: host.ioBrokerVM iobroker npm-install: exit 25
      2023-11-08 11:46:38.248  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
      2023-11-08 11:46:38.249  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
      2023-11-08 11:46:39.906  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
      2023-11-08 11:46:39.908  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
      2023-11-08 11:46:43.890  - info: vis.0 (7072) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
      2023-11-08 11:46:44.072  - info: vis.0 (7072) vis license is OK.
      2023-11-08 11:46:44.242  - error: vis.0 (7072) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-11-08 11:46:44.242  - error: vis.0 (7072) unhandled promise rejection: Not exists
      2023-11-08 11:46:44.243  - error: vis.0 (7072) Error: Not exists
      2023-11-08 11:46:44.243  - error: vis.0 (7072) Not exists
      2023-11-08 11:46:44.747  - info: vis.0 (7072) terminating
      2023-11-08 11:46:44.747  - warn: vis.0 (7072) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-11-08 11:46:45.412  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_40_207Z-debug-0.log
      2023-11-08 11:46:45.413  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
      2023-11-08 11:46:46.434  - info: host.ioBrokerVM iobroker npm-install: exit 25
      2023-11-08 11:46:47.435  - error: host.ioBrokerVM Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        Gismoh @Gismoh last edited by Gismoh
        @gismoh said in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
        @crunchip
        Mist, der ble wurde doch entfernt..... bzw. ist nicht mehr da
          diesmal vor Update der anderen Adapter versucht ble hinzuzufügen, wieder selbe Meldung:
          Installing iobroker.ble@0.13.4... (System call)
          npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:7362) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T12_24_29_118Z-debug-0.log
          host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
          ERROR: Process exited with code 25
            crunchip Forum Testing Most Active @Gismoh last edited by
            @gismoh dann seh doch jetzt nach, ob der Pfad/ Datei, die zu ändern wäre, nun vorhanden ist
              @crunchip
              muss ich leider auf später verschieben.
                @gismoh und wie du siehst, der vis bug, denn laut deinem log wurde vis nicht installiert
                  @crunchip
                  ist für mich ok mit VIS, wenn alles wieder da ist, wenn ich nur den Adapter neu installiere.
                  ansonsten:
                  Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp existiert nicht
                  Mache dann später weiter.
                    @gismoh seltsam, dann probier mal so
                    iob stop
                    iob fix
                    cd /opt/iobroker
                    npm install iobroker.ble
                    iobroker upload ble
                    iobroker start ble
                      @crunchip
                      npm ERR! code 1
                      npm ERR! gyp info it worked if it ends with ok
                      npm ERR! gyp info using node-gyp@7.1.2
                      npm ERR! gyp info using node@18.18.2 | linux | x64
                      npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                      npm ERR! (node:3121) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                      npm ERR! gyp info spawn /usr/bin/python3
                      npm ERR! gyp info spawn args [
                      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                      npm ERR! gyp info spawn args   'binding.gyp',
                      npm ERR! gyp info spawn args   '-f',
                      npm ERR! gyp info spawn args   'make',
                      npm ERR! gyp info spawn args   '-I',
                      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
                      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                      npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
                      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                      npm ERR! gyp info spawn args   '-Dvisibility=default',
                      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
                      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
                      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
                      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                      npm ERR! gyp info spawn args   '--depth=.',
                      npm ERR! gyp info spawn args   '--no-parallel',
                      npm ERR! gyp info spawn args   '--generator-output',
                      npm ERR! gyp info spawn args   'build',
                      npm ERR! gyp info spawn args   '-Goutput_dir=.'
                      npm ERR! gyp info spawn args ]
                      npm ERR!                                             ^^^^^
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_11_08_735Z-debug-0.log
                      Verstehe es wirklich nicht, warum der ble läuft, aber nach dem einspielen des Backups nicht mehr.
                      Kann man den ble irgendwie "sperren", so das das Backitup den nicht "anfasst" ?
                        Thomas Braun Most Active @Gismoh last edited by
                        @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                        Da muss in einer Datei was umgestellt werden. Hatte den Fall erst unlängst. Such mal im Forum danach.
                          crunchip Forum Testing Most Active @Thomas Braun last edited by
                          @thomas-braun das ahb ich ihm ja oben schon geschrieben, er findet sie aber nicht in seinem System
                            @crunchip
                            verstehe ich nicht:
                            root@ioBrokerVM:/# cd /opt
                            root@ioBrokerVM:/opt# ls
                            iobroker
                            root@ioBrokerVM:/opt# cd /iobroker
                            -bash: cd: /iobroker: Datei oder Verzeichnis nicht gefunden
                            er zeigt mit das Verzeichnis iobroker erst an, dann sagt er, er hätte nichts gefunden.
                            Ober ist meine Eingabe falsch?
                              Thomas Braun Most Active @Gismoh last edited by Thomas Braun
                              Dein Herumgehampel als root ist falsch.
                              Und relative Pfade werden ohne / angesprochen. Absolute Pfade halt mit /
                              Linux-Grundschule, Herr root.
                                Homoran Global Moderator Administrators @Gismoh last edited by Homoran
                                @gismoh cd /opt/iobroker
                                oder
                                cd /opt
                                cd iobroker
                                beim zweiten kein / davor
                                  Gismoh @Homoran last edited by
                                  argh, merci, ein Verzeichniswechsel dacht ich da muss ein "/" vor merci
                                    das bringt dich wieder in die root-ebene
                                    was nicht bedeutet dass man da als root rumläuft
                                      Okay, hatte ich nach einer Anleitung aufgesetzt, dort wurde es mit "root" gemacht, sogar auch in weiteren.
                                      also das Verzeichnis node-gyp gibt es bei mir nicht, nur ein node-gyp-build.
                                      Dieser taucht dann auf, wenn ich mich mit etwas anderem anmelde?
                                      Ich suche mal nach ner Anleitung, wie ich mich andres anmelde.
                                      Merci
                                      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                        Dann schmeiß die Anleitung weg, leg dir einen User an, falls noch keiner vorhanden ist und stolper mit dem durch das System.
                                          Ich hab dir den Befehl doch oben geschrieben
                                          https://forum.iobroker.net/post/1076264
                                            @crunchip
                                            ja, hatte ich ja auch gelesen, aber den Pfad gibt es ja bei mir (aktuell) nicht.
                                            Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                                            So wie ich @Thomas-Braun verstanden habe liegt das daran, das ich mit root unterwegs bin. Versuche also gleich einen anderen user anzulegen, und dann komme ich wohl zur Datei 😉
                                            Thomas Braun G 2 Replies Last reply Reply Quote 0
                                            24271
