    3. Einsteigerfragen
    4. Installation
    5. Raspberry Pi 5 8Gb Iobroker Installation
      Thomas Braun Most Active @teletapi last edited by
      @teletapi
      Hab das gerade mal auf meinem System nachgestellt. Hier hat es funktioniert.
      teletapi 1 Reply Last reply Reply Quote 0
      • teletapi
        teletapi @Thomas Braun last edited by Homoran
        @thomas-braun Ich bin gerade dabei die SD Karte neu einzurichten dann probiere ich das erneut. Hab jetzt erstmal das Betriebssystem installiert und danach sudo raspi config und die einstellungen auf Deutsch usw ausgeführt, dann "sudo apt update && sudo apt upgrade" ausgeführt
        Wieso krieg ich das wieder nicht in Code tags....? was mach ich da jetzt gerade wieder falsch.
         login as: pi
        pi@192.168.178.121's password:
        Linux Raspberrypi5 6.1.0-rpi4-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.54-1+rpt2 (20                                     23-10-05) aarch64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        pi@Raspberrypi5:~ $ sudo raspi-config
        Generating locales (this might take a while)...
          de_DE.UTF-8... done
          en_GB.UTF-8... done
        Generation complete.
        Current default time zone: 'Europe/Berlin'
        Local time is now:      Wed Nov  8 21:25:39 CET 2023.
        Universal Time is now:  Wed Nov  8 20:25:39 UTC 2023.
        Reloading keymap. This may take a short while
        Welcome to fdisk (util-linux 2.38.1).
        Changes will remain in memory only, until you decide to write them.
        Be careful before using the write command.
        This disk is currently in use - repartitioning is probably a bad idea.
        It's recommended to umount all file systems, and swapoff all swap
        partitions on this disk.
        Command (m for help):
        Disk /dev/mmcblk0: 59.48 GiB, 63864569856 bytes, 124735488 sectors
        Units: sectors of 1 * 512 = 512 bytes
        Sector size (logical/physical): 512 bytes / 512 bytes
        I/O size (minimum/optimal): 512 bytes / 512 bytes
        Disklabel type: dos
        Disk identifier: 0x639be77c
        Device         Boot   Start       End   Sectors  Size Id Type
        /dev/mmcblk0p1         8192   1056767   1048576  512M  c W95 FAT32 (LBA)
        /dev/mmcblk0p2      1056768 124735487 123678720   59G 83 Linux
        Command (m for help): Partition number (1,2, default 2):
        Partition 2 has been deleted.
        Command (m for help): Partition type
           p   primary (1 primary, 0 extended, 3 free)
           e   extended (container for logical partitions)
        Select (default p): Partition number (2-4, default 2): First sector (2048-124735                                     487, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (1056768-12473                                     5487, default 124735487):
        Created a new partition 2 of type 'Linux' and of size 59 GiB.
        Partition #2 contains a ext4 signature.
        Disklabel type: dos
        Command (m for help): The partition table has been altered.
        Syncing disks.
        Broadcast message from root@Raspberrypi5 on pts/1 (Wed 2023-11-08 21:26:10 CET):
        The system will reboot now!
        pi@Raspberrypi5:~ $
        login as: pi
        Last login: Wed Nov  8 21:24:22 2023 from 192.168.178.63
        pi@Raspberrypi5:~ $ sudo apt update && sudo apt upgrade
        OK:1 http://deb.debian.org/debian bookworm InRelease
        Holen:2 http://deb.debian.org/debian-security bookworm-security InRelease [48,0                                      kB]
        Holen:3 http://deb.debian.org/debian bookworm-updates InRelease [52,1 kB]
        Holen:4 http://deb.debian.org/debian bookworm/main Translation-de_DE [830 B]
        Holen:5 http://archive.raspberrypi.com/debian bookworm InRelease [23,6 kB]
        Holen:6 http://deb.debian.org/debian bookworm/main Translation-de [1.748 kB]
        Holen:7 http://deb.debian.org/debian-security bookworm-security/main arm64 Packa                                     ges [93,4 kB]
        Holen:8 http://deb.debian.org/debian-security bookworm-security/main armhf Packa                                     ges [91,1 kB]
        Holen:9 http://deb.debian.org/debian-security bookworm-security/main Translation                                     -en [54,7 kB]
        Holen:10 http://deb.debian.org/debian-security bookworm-security/contrib Transla                                     tion-en [372 B]
        Holen:11 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [6.67                                     2 B]
        Holen:12 http://deb.debian.org/debian bookworm-updates/main armhf Packages [6.64                                     8 B]
        Holen:13 http://deb.debian.org/debian bookworm-updates/main Translation-en [5.20                                     4 B]
        Holen:14 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [346                                      kB]
        Holen:15 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [338                                      kB]
        Es wurden 2.815 kB in 1 s geholt (2.332 kB/s).
        Paketlisten werden gelesen… Fertig
        Abhängigkeitsbaum wird aufgebaut… Fertig
        Statusinformationen werden eingelesen… Fertig
        Aktualisierung für 31 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,                                      um sie anzuzeigen.
        N: Für das Depot »http://archive.raspberrypi.com/debian bookworm InRelease« wurd                                     e der »Suite«-Wert von »testing« in »stable« geändert.
        Paketaktualisierung (Upgrade) wird berechnet… Fertig
        Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
          libpisp0.0.1
        Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
        Die folgenden NEUEN Pakete werden installiert:
          libpisp1.0.0 linux-headers-6.1.0-rpi6-common-rpi
          linux-headers-6.1.0-rpi6-rpi-2712 linux-headers-6.1.0-rpi6-rpi-v8
          linux-image-6.1.0-rpi6-rpi-2712 linux-image-6.1.0-rpi6-rpi-v8
        Die folgenden Pakete werden aktualisiert (Upgrade):
          bluez-firmware curl libcamera-apps-lite libcamera-ipa libcamera0.1
          libcurl3-gnutls libcurl4 libpam-chksshpwd libpam-modules libpam-modules-bin
          libpam-runtime libpam0g libpisp-common libraspberrypi-bin libraspberrypi-dev
          libraspberrypi-doc libraspberrypi0 libssl3 libwbclient0
          linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-rpi-2712
          linux-image-rpi-v8 linux-kbuild-6.1 linux-libc-dev openssl
          raspberrypi-net-mods raspi-config raspi-firmware raspi-utils rpi-eeprom
        31 aktualisiert, 6 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen 83,3 MB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 118 MB Plattenplatz zusätzlich benutzt.
        Möchten Sie fortfahren? [J/n] J
        Holen:1 http://deb.debian.org/debian-security bookworm-security/main arm64 curl                                      arm64 7.88.1-10+deb12u4 [308 kB]
        Holen:2 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam0g arm64                                      1.5.2-6+rpt2+deb12u1 [90,7 kB]
        Holen:3 http://deb.debian.org/debian-security bookworm-security/main arm64 libcu                                     rl4 arm64 7.88.1-10+deb12u4 [366 kB]
        Holen:4 http://deb.debian.org/debian-security bookworm-security/main arm64 libcu                                     rl3-gnutls arm64 7.88.1-10+deb12u4 [361 kB]
        Holen:5 http://deb.debian.org/debian-security bookworm-security/main arm64 libwb                                     client0 arm64 2:4.17.12+dfsg-0+deb12u1 [52,8 kB]
        Holen:6 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-modules                                     -bin arm64 1.5.2-6+rpt2+deb12u1 [75,0 kB]
        Holen:7 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-modules                                      arm64 1.5.2-6+rpt2+deb12u1 [286 kB]
        Holen:8 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-firmware                                      all 1:1.20231024+ds-1+rpt1 [4.550 kB]
        Holen:9 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-runtime                                      all 1.5.2-6+rpt2+deb12u1 [161 kB]
        Holen:10 http://archive.raspberrypi.com/debian bookworm/main arm64 bluez-firmwar                                     e all 1.2-9+rpt2 [205 kB]
        Holen:11 http://archive.raspberrypi.com/debian bookworm/main arm64 libssl3 arm64                                      3.0.11-1~deb12u2+rpt1 [1.808 kB]
        Holen:12 http://archive.raspberrypi.com/debian bookworm/main arm64 libpisp-commo                                     n all 1.0.0-1 [4.160 B]
        Holen:13 http://archive.raspberrypi.com/debian bookworm/main arm64 libpisp1.0.0                                      arm64 1.0.0-1 [137 kB]
        Holen:14 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera-ipa                                      arm64 0.1.0+rpt20231020-1 [389 kB]
        Holen:15 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera0.1                                      arm64 0.1.0+rpt20231020-1 [506 kB]
        Holen:16 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera-app                                     s-lite arm64 1.3.0-1 [293 kB]
        Holen:17 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-chkssh                                     pwd arm64 1.5.2-6+rpt2+deb12u1 [46,4 kB]
        Holen:18 http://archive.raspberrypi.com/debian bookworm/main arm64 libraspberryp                                     i-bin arm64 1:2+git20231018~131943+3c97f76-1 [49,6 kB]
        Holen:19 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils a                                     rm64 20231017-1 [65,9 kB]
        Holen:20 http://archive.raspberrypi.com/debian bookworm/main arm64 libraspberryp                                     i-dev arm64 1:2+git20231018~131943+3c97f76-1 [130 kB]
        Holen:21 http://archive.raspberrypi.com/debian bookworm/main arm64 libraspberryp                                     i0 arm64 1:2+git20231018~131943+3c97f76-1 [78,6 kB]
        Holen:22 http://archive.raspberrypi.com/debian bookworm/main arm64 libraspberryp                                     i-doc all 1:2+git20231018~131943+3c97f76-1 [2.392 B]
        Holen:23 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -6.1.0-rpi6-common-rpi all 1:6.1.58-1+rpt2 [7.855 kB]
        Holen:24 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-kbuild-                                     6.1 arm64 1:6.1.58-1+rpt2 [913 kB]
        Holen:25 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -6.1.0-rpi6-rpi-2712 arm64 1:6.1.58-1+rpt2 [1.024 kB]
        Holen:26 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -6.1.0-rpi6-rpi-v8 arm64 1:6.1.58-1+rpt2 [1.024 kB]
        Holen:27 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -rpi-2712 arm64 1:6.1.58-1+rpt2 [1.156 B]
        Holen:28 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers                                     -rpi-v8 arm64 1:6.1.58-1+rpt2 [1.152 B]
        Holen:29 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6                                     .1.0-rpi6-rpi-2712 arm64 1:6.1.58-1+rpt2 [28,1 MB]
        Holen:30 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6                                     .1.0-rpi6-rpi-v8 arm64 1:6.1.58-1+rpt2 [28,1 MB]
        Holen:31 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-r                                     pi-2712 arm64 1:6.1.58-1+rpt2 [1.424 B]
        Holen:32 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-r                                     pi-v8 arm64 1:6.1.58-1+rpt2 [1.424 B]
        Holen:33 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-libc-de                                     v arm64 1:6.1.58-1+rpt2 [1.788 kB]
        Holen:34 http://archive.raspberrypi.com/debian bookworm/main arm64 openssl arm64                                      3.0.11-1~deb12u2+rpt1 [1.386 kB]
        Holen:35 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config                                      all 20231108 [29,8 kB]
        Holen:36 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-n                                     et-mods all 1.4.0 [2.160 B]
        Holen:37 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom al                                     l 20.0-2 [3.167 kB]
        Es wurden 83,3 MB in 7 s geholt (11,9 MB/s).
        Changelogs werden gelesen... Fertig
        Extrahiere Vorlagen aus Paketen: 100%
        Vorkonfiguration der Pakete ...
        (Lese Datenbank ... 55058 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../libpam0g_1.5.2-6+rpt2+deb12u1_arm64.deb ...
        Entpacken von libpam0g:arm64 (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2) ...
        libpam0g:arm64 (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
        Vorbereitung zum Entpacken von .../libpam-modules-bin_1.5.2-6+rpt2+deb12u1_arm64                                     .deb ...
        Entpacken von libpam-modules-bin (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2) ...
        libpam-modules-bin (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
        Vorbereitung zum Entpacken von .../libpam-modules_1.5.2-6+rpt2+deb12u1_arm64.deb                                      ...
        Entpacken von libpam-modules:arm64 (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2) ..                                     .
        libpam-modules:arm64 (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
        Vorbereitung zum Entpacken von .../raspi-firmware_1%3a1.20231024+ds-1+rpt1_all.d                                     eb ...
        Entpacken von raspi-firmware (1:1.20231024+ds-1+rpt1) über (1:1.20230829+ds-1~rp                                     t3) ...
        Vorbereitung zum Entpacken von .../libpam-runtime_1.5.2-6+rpt2+deb12u1_all.deb .                                     ..
        Entpacken von libpam-runtime (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2) ...
        libpam-runtime (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
        Vorbereitung zum Entpacken von .../00-bluez-firmware_1.2-9+rpt2_all.deb ...
        Entpacken von bluez-firmware (1.2-9+rpt2) über (1.2-9+rpt1) ...
        Vorbereitung zum Entpacken von .../01-libssl3_3.0.11-1~deb12u2+rpt1_arm64.deb ..                                     .
        Entpacken von libssl3:arm64 (3.0.11-1~deb12u2+rpt1) über (3.0.11-1~deb12u1) ...
        Vorbereitung zum Entpacken von .../02-curl_7.88.1-10+deb12u4_arm64.deb ...
        Entpacken von curl (7.88.1-10+deb12u4) über (7.88.1-10+deb12u3) ...
        Vorbereitung zum Entpacken von .../03-libcurl4_7.88.1-10+deb12u4_arm64.deb ...
        Entpacken von libcurl4:arm64 (7.88.1-10+deb12u4) über (7.88.1-10+deb12u3) ...
        Vorbereitung zum Entpacken von .../04-libpisp-common_1.0.0-1_all.deb ...
        Entpacken von libpisp-common (1.0.0-1) über (0.0.1-1) ...
        Vormals nicht ausgewähltes Paket libpisp1.0.0:arm64 wird gewählt.
        Vorbereitung zum Entpacken von .../05-libpisp1.0.0_1.0.0-1_arm64.deb ...
        Entpacken von libpisp1.0.0:arm64 (1.0.0-1) ...
        Vorbereitung zum Entpacken von .../06-libcamera-ipa_0.1.0+rpt20231020-1_arm64.de                                     b ...
        Entpacken von libcamera-ipa:arm64 (0.1.0+rpt20231020-1) über (0.1.0+pi5~0-1) ...
        Vorbereitung zum Entpacken von .../07-libcamera0.1_0.1.0+rpt20231020-1_arm64.deb                                      ...
        Entpacken von libcamera0.1:arm64 (0.1.0+rpt20231020-1) über (0.1.0+pi5~0-1) ...
        Vorbereitung zum Entpacken von .../08-libcamera-apps-lite_1.3.0-1_arm64.deb ...
        Entpacken von libcamera-apps-lite (1.3.0-1) über (1.2.1-1+bookworm+1) ...
        Vorbereitung zum Entpacken von .../09-libcurl3-gnutls_7.88.1-10+deb12u4_arm64.de                                     b ...
        Entpacken von libcurl3-gnutls:arm64 (7.88.1-10+deb12u4) über (7.88.1-10+deb12u3)                                      ...
        Vorbereitung zum Entpacken von .../10-libpam-chksshpwd_1.5.2-6+rpt2+deb12u1_arm6                                     4.deb ...
        Entpacken von libpam-chksshpwd:arm64 (1.5.2-6+rpt2+deb12u1) über (1.5.2-6+rpt2)                                      ...
        Vorbereitung zum Entpacken von .../11-libraspberrypi-bin_1%3a2+git20231018~13194                                     3+3c97f76-1_arm64.deb ...
        Entpacken von libraspberrypi-bin (1:2+git20231018~131943+3c97f76-1) über (1:2+gi                                     t20230913~095424+44a3953-1) ...
        Vorbereitung zum Entpacken von .../12-raspi-utils_20231017-1_arm64.deb ...
        Entpacken von raspi-utils (20231017-1) über (20230922+1-1~rc1) ...
        Vorbereitung zum Entpacken von .../13-libraspberrypi-dev_1%3a2+git20231018~13194                                     3+3c97f76-1_arm64.deb ...
        Entpacken von libraspberrypi-dev (1:2+git20231018~131943+3c97f76-1) über (1:2+gi                                     t20230913~095424+44a3953-1) ...
        Vorbereitung zum Entpacken von .../14-libraspberrypi0_1%3a2+git20231018~131943+3                                     c97f76-1_arm64.deb ...
        Entpacken von libraspberrypi0:arm64 (1:2+git20231018~131943+3c97f76-1) über (1:2                                     +git20230913~095424+44a3953-1) ...
        Vorbereitung zum Entpacken von .../15-libraspberrypi-doc_1%3a2+git20231018~13194                                     3+3c97f76-1_all.deb ...
        Entpacken von libraspberrypi-doc (1:2+git20231018~131943+3c97f76-1) über (1:2+gi                                     t20230913~095424+44a3953-1) ...
        Vorbereitung zum Entpacken von .../16-libwbclient0_2%3a4.17.12+dfsg-0+deb12u1_ar                                     m64.deb ...
        Entpacken von libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) über (2:4.17.11+dfsg                                     -0+deb12u1) ...
        Vormals nicht ausgewähltes Paket linux-headers-6.1.0-rpi6-common-rpi wird gewähl                                     t.
        Vorbereitung zum Entpacken von .../17-linux-headers-6.1.0-rpi6-common-rpi_1%3a6.                                     1.58-1+rpt2_all.deb ...
        Entpacken von linux-headers-6.1.0-rpi6-common-rpi (1:6.1.58-1+rpt2) ...
        Vorbereitung zum Entpacken von .../18-linux-kbuild-6.1_1%3a6.1.58-1+rpt2_arm64.d                                     eb ...
        Entpacken von linux-kbuild-6.1 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
        Vormals nicht ausgewähltes Paket linux-headers-6.1.0-rpi6-rpi-2712 wird gewählt.
        Vorbereitung zum Entpacken von .../19-linux-headers-6.1.0-rpi6-rpi-2712_1%3a6.1.                                     58-1+rpt2_arm64.deb ...
        Entpacken von linux-headers-6.1.0-rpi6-rpi-2712 (1:6.1.58-1+rpt2) ...
        Vormals nicht ausgewähltes Paket linux-headers-6.1.0-rpi6-rpi-v8 wird gewählt.
        Vorbereitung zum Entpacken von .../20-linux-headers-6.1.0-rpi6-rpi-v8_1%3a6.1.58                                     -1+rpt2_arm64.deb ...
        Entpacken von linux-headers-6.1.0-rpi6-rpi-v8 (1:6.1.58-1+rpt2) ...
        Vorbereitung zum Entpacken von .../21-linux-headers-rpi-2712_1%3a6.1.58-1+rpt2_a                                     rm64.deb ...
        Entpacken von linux-headers-rpi-2712 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ..                                     .
        Vorbereitung zum Entpacken von .../22-linux-headers-rpi-v8_1%3a6.1.58-1+rpt2_arm                                     64.deb ...
        Entpacken von linux-headers-rpi-v8 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
        Vormals nicht ausgewähltes Paket linux-image-6.1.0-rpi6-rpi-2712 wird gewählt.
        Vorbereitung zum Entpacken von .../23-linux-image-6.1.0-rpi6-rpi-2712_1%3a6.1.58                                     Fortschritt: [ 44%] [########################...............................]
        Entpacken von linux-image-6.1.0-rpi6-rpi-2712 (1:6.1.58-1+rpt2) ...
        Vormals nicht ausgewähltes Paket linux-image-6.1.0-rpi6-rpi-v8 wird gewählt.
        Vorbereitung zum Entpacken von .../24-linux-image-6.1.0-rpi6-rpi-v8_1%3a6.1.58-1+rpt2_arm64.deb ...
        Entpacken von linux-image-6.1.0-rpi6-rpi-v8 (1:6.1.58-1+rpt2) ...
        Vorbereitung zum Entpacken von .../25-linux-image-rpi-2712_1%3a6.1.58-1+rpt2_arm64.deb ...
        Entpacken von linux-image-rpi-2712 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
        Vorbereitung zum Entpacken von .../26-linux-image-rpi-v8_1%3a6.1.58-1+rpt2_arm64.deb ...
        Entpacken von linux-image-rpi-v8 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
        Vorbereitung zum Entpacken von .../27-linux-libc-dev_1%3a6.1.58-1+rpt2_arm64.deb ...
        Entpacken von linux-libc-dev:arm64 (1:6.1.58-1+rpt2) über (1:6.1.54-1+rpt2) ...
        Vorbereitung zum Entpacken von .../28-openssl_3.0.11-1~deb12u2+rpt1_arm64.deb ...
        Entpacken von openssl (3.0.11-1~deb12u2+rpt1) über (3.0.11-1~deb12u1) ...
        Vorbereitung zum Entpacken von .../29-raspi-config_20231108_all.deb ...
        Entpacken von raspi-config (20231108) über (20231009) ...
        Vorbereitung zum Entpacken von .../30-raspberrypi-net-mods_1.4.0_all.deb ...
        Entpacken von raspberrypi-net-mods (1.4.0) über (1.3.4) ...
        Vorbereitung zum Entpacken von .../31-rpi-eeprom_20.0-2_all.deb ...
        Entpacken von rpi-eeprom (20.0-2) über (19-1) ...
        bluez-firmware (1.2-9+rpt2) wird eingerichtet ...
        linux-image-6.1.0-rpi6-rpi-v8 (1:6.1.58-1+rpt2) wird eingerichtet ...
        I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.1.0-rpi4-rpi-v8
        I: /initrd.img.old is now a symlink to boot/initrd.img-6.1.0-rpi4-rpi-v8
        I: /vmlinuz is now a symlink to boot/vmlinuz-6.1.0-rpi6-rpi-v8
        I: /initrd.img is now a symlink to boot/initrd.img-6.1.0-rpi6-rpi-v8
        /etc/kernel/postinst.d/initramfs-tools:
        update-initramfs: Generating /boot/initrd.img-6.1.0-rpi6-rpi-v8
        libssl3:arm64 (3.0.11-1~deb12u2+rpt1) wird eingerichtet ...
        linux-libc-dev:arm64 (1:6.1.58-1+rpt2) wird eingerichtet ...
        libcurl3-gnutls:arm64 (7.88.1-10+deb12u4) wird eingerichtet ...
        libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) wird eingerichtet ...
        libpam-chksshpwd:arm64 (1.5.2-6+rpt2+deb12u1) wird eingerichtet ...
        libpisp-common (1.0.0-1) wird eingerichtet ...
        raspi-firmware (1:1.20231024+ds-1+rpt1) wird eingerichtet ...
        Neue Version der Konfigurationsdatei /etc/kernel/postinst.d/z50-raspi-firmware wird installiert ...
        linux-image-rpi-v8 (1:6.1.58-1+rpt2) wird eingerichtet ...
        linux-headers-6.1.0-rpi6-common-rpi (1:6.1.58-1+rpt2) wird eingerichtet ...
        libraspberrypi0:arm64 (1:2+git20231018~131943+3c97f76-1) wird eingerichtet ...
        linux-image-6.1.0-rpi6-rpi-2712 (1:6.1.58-1+rpt2) wird eingerichtet ...
        I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.1.0-rpi6-rpi-v8
        I: /initrd.img.old is now a symlink to boot/initrd.img-6.1.0-rpi6-rpi-v8
        I: /vmlinuz is now a symlink to boot/vmlinuz-6.1.0-rpi6-rpi-2712
        I: /initrd.img is now a symlink to boot/initrd.img-6.1.0-rpi6-rpi-2712
        update-initramfs: Generating /boot/initrd.img-6.1.0-rpi6-rpi-2712
        libcurl4:arm64 (7.88.1-10+deb12u4) wird eingerichtet ...
        libpisp1.0.0:arm64 (1.0.0-1) wird eingerichtet ...
        curl (7.88.1-10+deb12u4) wird eingerichtet ...
        linux-kbuild-6.1 (1:6.1.58-1+rpt2) wird eingerichtet ...
        openssl (3.0.11-1~deb12u2+rpt1) wird eingerichtet ...
        raspi-config (20231108) wird eingerichtet ...
        libraspberrypi-bin (1:2+git20231018~131943+3c97f76-1) wird eingerichtet ...
        linux-image-rpi-2712 (1:6.1.58-1+rpt2) wird eingerichtet ...
        linux-headers-6.1.0-rpi6-rpi-v8 (1:6.1.58-1+rpt2) wird eingerichtet ...
        linux-headers-6.1.0-rpi6-rpi-2712 (1:6.1.58-1+rpt2) wird eingerichtet ...
        linux-headers-rpi-2712 (1:6.1.58-1+rpt2) wird eingerichtet ...
        libraspberrypi-dev (1:2+git20231018~131943+3c97f76-1) wird eingerichtet ...
        raspberrypi-net-mods (1.4.0) wird eingerichtet ...
        rpi-eeprom (20.0-2) wird eingerichtet ...
        linux-headers-rpi-v8 (1:6.1.58-1+rpt2) wird eingerichtet ...
        libraspberrypi-doc (1:2+git20231018~131943+3c97f76-1) wird eingerichtet ...
        raspi-utils (20231017-1) wird eingerichtet ...
        libcamera-ipa:arm64 (0.1.0+rpt20231020-1) wird eingerichtet ...
        libcamera0.1:arm64 (0.1.0+rpt20231020-1) wird eingerichtet ...
        libcamera-apps-lite (1.3.0-1) wird eingerichtet ...
        Trigger für initramfs-tools (0.142) werden verarbeitet ...
        update-initramfs: Generating /boot/initrd.img-6.1.0-rpi4-rpi-v8
        update-initramfs: Generating /boot/initrd.img-6.1.0-rpi4-rpi-2712
        Trigger für libc-bin (2.36-9+rpt2+deb12u3) werden verarbeitet ...
        Trigger für man-db (2.11.2-2) werden verarbeitet ...
          @teletapi sagte in Raspberry Pi 5 8Gb Iobroker Installation:
          Die Sprache würde ich allerdings auf Englisch belassen. Die deutschen Meldungen sind immer irritierend und man findet auch im Netz mehr zu den originalen Texten.
          • teletapi
            @thomas-braun Okay danke, ich glaube jetzt geht es weiter Node wurde installiert, ich geb Rückmeldung
            • teletapi
              teletapi @teletapi last edited by
              @teletapi Ich bin nicht sicher wo es hängt aber wie hier im Bild zu sehen bleibt die Installation wieder hängen und Putty ist nichtmehr bedienbar
                Homoran Global Moderator Administrators @teletapi last edited by Homoran
                @teletapi da entpackt er gerade massiv
                WARTEN!
                hat da schon immer Meldungen gegeben, dass er sich aufgehängt hätte.
                Mal sehen, wie lange der 5er da braucht
                • teletapi
                  teletapi @Homoran last edited by
                  @homoran Oh, da hätte ich jetzt nicht mit gerechnet das es so lange dauert, ich lass es mal wieder laufen
                    Thomas Braun Most Active @teletapi last edited by Thomas Braun
                    @teletapi
                    Hol dir ein Bier, geh 'ne Runde um den Block oder tu was andres, während die Kiste arbeitet.
                    'Abstürze' sehen in der Regel anders aus. Die haben nämlich keine Fortschrittsbalken. Hab jedenfalls noch keine 'Kernel Panic' mit einem gesehen...
                    A teletapi 2 Replies Last reply Reply Quote 0
                      Albyricus @Thomas Braun last edited by
                      Hi, ich hab auch Probleme mit einem Pi 4 8Gb.... kämpfe heute schon den ganzen tag mit einem Reinstall (genau das selbe Image)... hab glaub ich mittlerweile die 13ente installation durch... entweder bleibt er irgendwo hängen, oder ich bekomm nen npm err!...
                          Welcome to the ioBroker installer!
                          Installer version: 2023-10-13
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/4)
                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                      Get:3 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
                      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Fetched 52.1 kB in 1s (38.0 kB/s)
                      Reading package lists... Done
                          Creating ioBroker user and directory (2/4)
                      Created /etc/sudoers.d/iobroker
                      Directory /opt/iobroker created
                          Installing ioBroker (3/4)
                      npm ERR! code ERR_SOCKET_TIMEOUT
                      npm ERR! network Socket timeout
                      npm ERR! network This is a problem related to network connectivity.
                      npm ERR! network In most cases you are behind a proxy or have bad network settings.
                      npm ERR! network
                      npm ERR! network If you are behind a proxy, please make sure that the
                      npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                      npm ERR! A complete log of this run can be found in: /home/brokerer/.npm/_logs/2023-11-08T21_13_39_035Z-debug-0.log
                          Finalizing installation (4/4)
                      Enabling autostart...
                      Autostart enabled!
                      Fixing directory permissions...
                          ioBroker was installed successfully
                          Open http://192.168.1.48:8081 in a browser and start configuring!
                      You need to re-login before doing anything else on the console!
                        Homoran Global Moderator Administrators @Albyricus last edited by
                        @albyricus sagte in Raspberry Pi 5 8Gb Iobroker Installation:
                        @thomas-braun sagte in Raspberry Pi 5 8Gb Iobroker Installation:
                        @teletapi
                        hattest du auch das aktuelle RasPiOS gezogen?
                          Albyricus @Homoran last edited by
                          hi, ja ich habe gestern das Raspberry Pi OS Lite (64-bit) geholt. die erste Reinstall hat auch super funktioniert und ich hab mein iobroker aufgebaut... dann beim versuch auf Multihost völlig zerschossen und wollte heute nochmal bei 0 beginnen... tja und ab dann war der wurm drinnen
                            Thomas Braun Most Active @Albyricus last edited by
                            @albyricus
                            Musste mal nach dem Netzwerk schauen.
                              Albyricus @Thomas Braun last edited by Albyricus
                              ich hab ein stinklangweiliges dsl50 mit fritzbox, ohne proxy, ohne pihole oder sonstige spielereien und der Pi hängt am gigabit lan kabel.... hab auch die Fritzbox schonmal neugestartet... mache gerade versuch nummer 14...
                              • teletapi
                                Bin gerade wieder rein und das stand in der Konsole.
                                Ich mach jetzt nochmal neu.
                                pi@Raspberrypi5:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                                library: loaded
                                Library version=2023-10-13
                                OK:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                OK:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Es wurden 52,1 kB in 1 s geholt (59,5 kB/s).
                                npm ERR! network In most cases you are behind a proxy or have bad network settin gs.
                                npm ERR! network
                                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11 -08T21_03_31_496Z-debug-0.log
                                Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → / lib/systemd/system/iobroker.service.
                                Autostart enabled!
                                Open http://192.168.178.121 192.168.178.122:8081 in a browser and start conf            iguring!
                                  Und warum sollte das Ergebnis bei sonst unverändertem Umfeld dann ein anderes sein?
                                  • teletapi
                                    Weil ich die Fehlerquelle vorm Rechner vermute
                                      Schau in das angegebene Log rein. Vielleicht steht ja was verwertbares drin.
                                      • teletapi
                                        @thomas-braun Mein Problem was den Log angeht das ich garnicht weiß wie ich den aufrufen soll, ich hab dann nochmals alles neu gemacht und nachdem immer wieder fehler autauchten immer erneut den Curl Befehl hinter einander laufen lassen nach dem 6-7 mal ging das dann plötzlich und es wurden keine fehler mehr angezeigt so scheint es im Augenblick zu funktionieren das Grundgerüst sollte jetzt stehen
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                         Static hostname: Raspberrypi5
                                               Icon name: computer
                                                  Kernel: Linux 6.1.0-rpi6-rpi-2712
                                            Architecture: arm64
                                        Model           : Raspberry Pi 5 Model B Rev 1.0
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : arm64
                                        Systemuptime and Load:
                                         00:06:18 up 6 min,  2 users,  load average: 0.21, 0.25, 0.14
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** Time and Time Zones ***
                                                       Local time: Thu 2023-11-09 00:06:18 CET
                                                   Universal time: Wed 2023-11-08 23:06:18 UTC
                                                         RTC time: Wed 2023-11-08 23:06:18
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            8.4G        547M        7.5G        5.3M        455M        7.9G
                                        Swap:           104M          0B        104M
                                        Total:          8.5G        547M        7.6G
                                                 8053 M total memory
                                                  522 M used memory
                                                  456 M active memory
                                                  259 M inactive memory
                                                 7190 M free memory
                                                   30 M buffer memory
                                                  403 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        vc_gencmd_read_response returned -1
                                        error=1 error_msg="Command not registered"
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** FILESYSTEM ***
                                        udev           devtmpfs  3.8G     0  3.8G   0% /dev
                                        tmpfs          tmpfs     806M  5.0M  801M   1% /run
                                        /dev/mmcblk0p2 ext4       59G  2.9G   53G   6% /
                                        tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                        /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
                                        tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                                        [Wed Nov  8 23:59:32 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:A3:25:8A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=beeda195-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                        [Wed Nov  8 23:59:34 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Wed Nov  8 23:59:36 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        TARGET           SOURCE         FSTYPE OPTIONS
                                        /                /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        496M    /var/
                                        201M    /var/cache
                                        195M    /var/cache/apt
                                        163M    /var/lib
                                        131M    /var/lib/apt/lists
                                        Archived and active journals take up 32.0M in the file system.
                                        /opt/iobroker/backups:
                                        4.0K    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        19M     /opt/iobroker/iobroker-data/
                                        15M     /opt/iobroker/iobroker-data/files
                                        13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                        3.9M    /opt/iobroker/iobroker-data/objects.jsonl
                                        2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                        1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                        652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                                        USB-Devices by-id:
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v18.18.2
                                        /usr/bin/node           v18.18.2
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                                        /usr/bin/corepack       0.19.0
                                        nodejs:
                                          Installed: 18.18.2-1nodesource1
                                          Candidate: 18.18.2-1nodesource1
                                          Version table:
                                         *** 18.18.2-1nodesource1 500
                                                100 /var/lib/dpkg/status
                                             18.18.1-1nodesource1 500
                                             18.18.0-1nodesource1 500
                                             18.17.1-1nodesource1 500
                                             18.17.0-1nodesource1 500
                                             18.16.1-1nodesource1 500
                                             18.16.0-1nodesource1 500
                                             18.15.0-1nodesource1 500
                                             18.14.2-1nodesource1 500
                                             18.14.1-1nodesource1 500
                                             18.14.0-1nodesource1 500
                                             18.13.0+dfsg1-1 500
                                             18.13.0-1nodesource1 500
                                             18.12.0-1nodesource1 500
                                             18.11.0-1nodesource1 500
                                             18.10.0-1nodesource1 500
                                             18.9.1-1nodesource1 500
                                             18.9.0-1nodesource1 500
                                             18.8.0-1nodesource1 500
                                             18.7.0-1nodesource1 500
                                             18.6.0-1nodesource1 500
                                             18.5.0-1nodesource1 500
                                             18.4.0-1nodesource1 500
                                             18.3.0-1nodesource1 500
                                             18.2.0-1nodesource1 500
                                             18.1.0-1nodesource1 500
                                             18.0.0-1nodesource1 500
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller:  5.0.12
                                        admin:          6.12.0
                                        javascript:     "javascript" not found
                                        Adapters from github:   0
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
                                        + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                        Controller "js-controller": 5.0.12   , installed 5.0.12
                                        Objects and States
                                        Objects:        144
                                        States:         103
                                        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16053      774/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16060      774/iobroker.js-con
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13986      792/sshd: /usr/sbin
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14223      1098/io.admin.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13988      792/sshd: /usr/sbin
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13828      669/avahi-daemon: r
                                        udp        0      0 0.0.0.0:59718           0.0.0.0:*                           104        13830      669/avahi-daemon: r
                                        udp6       0      0 fe80::f05b:9255:16f:546 :::*                                0          16717      746/NetworkManager
                                        udp6       0      0 fe80::6e03:de62:d22:546 :::*                                0          16706      746/NetworkManager
                                        udp6       0      0 :::5353                 :::*                                104        13829      669/avahi-daemon: r
                                        udp6       0      0 :::60759                :::*                                104        13831      669/avahi-daemon: r
                                        2023-11-09 00:04:39.099  - info: host.Raspberrypi5 stopInstance system.adapter.admin.0 (force=false, process=true)
                                        2023-11-09 00:04:39.103  - info: admin.0 (831) Got terminate signal TERMINATE_YOURSELF
                                        2023-11-09 00:04:39.105  - info: admin.0 (831) terminating http server on port 8081
                                        2023-11-09 00:04:39.107  - info: admin.0 (831) terminating
                                        2023-11-09 00:04:39.107  - info: admin.0 (831) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2023-11-09 00:04:39.143  - info: host.Raspberrypi5 stopInstance system.adapter.admin.0 send kill signal
                                        2023-11-09 00:04:39.609  - info: admin.0 (831) terminating
                                        2023-11-09 00:04:39.666  - info: host.Raspberrypi5 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2023-11-09 00:04:42.105  - info: host.Raspberrypi5 [WEBSERVER_UPGRADE] (admin) Server is running on http://localhost:8081
                                        2023-11-09 00:04:48.188  - info: host.Raspberrypi5 [WEBSERVER_UPGRADE] (admin) Successfully upgraded admin to version 6.12.0
                                        2023-11-09 00:04:48.793  - info: host.Raspberrypi5 [WEBSERVER_UPGRADE] (admin) Final information delivered
                                        2023-11-09 00:04:48.798  - info: host.Raspberrypi5 "system.adapter.admin.0" enabled
                                        2023-11-09 00:04:48.799  - info: host.Raspberrypi5 [WEBSERVER_UPGRADE] (admin) Successfully started adapter
                                        2023-11-09 00:04:48.866  - info: host.Raspberrypi5 instance system.adapter.admin.0 started with pid 1098
                                        2023-11-09 00:04:49.715  - info: admin.0 (1098) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
                                        2023-11-09 00:04:49.745  - info: admin.0 (1098) requesting all objects
                                        2023-11-09 00:04:50.037  - info: admin.0 (1098) received all objects
                                        2023-11-09 00:04:50.169  - info: admin.0 (1098) socket.io server listening on port 8081
                                        2023-11-09 00:04:50.170  - info: admin.0 (1098) http server listening on port 8081
                                        2023-11-09 00:04:50.170  - info: admin.0 (1098) Use link "http://127.0.0.1:8081" to configure.
                                        2023-11-09 00:04:52.193  - info: admin.0 (1098) ==> Connected system.user.admin from ::ffff:192.168.178.63
                                        2023-11-09 00:04:52.941  - info: admin.0 (1098) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
                                        2023-11-09 00:04:53.345  - info: admin.0 (1098) ==> Connected system.user.admin from ::ffff:192.168.178.63
                                        2023-11-09 00:04:53.350  - info: admin.0 (1098) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
                                        2023-11-09 00:04:54.756  - info: admin.0 (1098) ==> Connected system.user.admin from ::ffff:192.168.178.63
                                        iob diag has finished.
                                          @teletapi
                                          Mit einem pager wie z. B.
                                          less /home/pi/.npm/_logs/2023-11 -08T21_03_31_496Z-debug-0.log
                                          • hg6806
                                            hg6806 Most Active @Thomas Braun last edited by
                                            Ich habe seit gestern auf einen Pi5 und das gleiche Problem.
                                            Das Log-File ist zu groß zu posten, deshalb habe ich es angehängt.
                                            2023-11-09T17_43_57_638Z-debug-0.log
                                            1.3k
                                            48
                                            13293
