    4. Adapterwarnungen / web stürzt ab
      Thomas Braun Most Active @MichaelF last edited by
      @michaelf
      Vermutlich nur die ham-Module nochmal reinjubeln.
      MichaelF 1 Reply Last reply Reply Quote 0
      • MichaelF
        MichaelF @Thomas Braun last edited by
        @thomas-braun said in Adapterwarnungen / web stürzt ab:
        @michaelf
        In Arbeit
        • MichaelF
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.25-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : armhf
          Systemuptime and Load:
           22:15:39 up  2:30,  1 user,  load average: 1.57, 1.65, 1.71
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Wed 2023-11-08 22:15:40 CET
                     Universal time: Wed 2023-11-08 21:15:40 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            7.8G        3.0G        3.3G        1.0M        1.6G        4.7G
          Swap:            99M          0B         99M
          Total:          7.9G        3.0G        3.4G
                   7811 M total memory
                   2968 M used memory
                   3133 M active memory
                    984 M inactive memory
                   3258 M free memory
                    318 M buffer memory
                   1266 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      117G   17G   95G  15% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  876K  1.6G   1% /run
          /dev/sda1      vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
          [Wed Nov  8 19:45:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:9F:6B:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=247e04bb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Nov  8 19:45:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Nov  8 19:45:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Wed Nov  8 19:45:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime,stripe=8191
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          4.4G    /var/
          3.6G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
          3.6G    /var/log
          574M    /var/cache
          Archived and active journals take up 3.5G in the file system.
          /opt/iobroker/backups:
          826M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          2.0G    /opt/iobroker/iobroker-data/
          1.1G    /opt/iobroker/iobroker-data/sqlite
          659M    /opt/iobroker/iobroker-data/files
          132M    /opt/iobroker/iobroker-data/backup-objects
          88M     /opt/iobroker/iobroker-data/files/echarts.admin
          1.1G    /opt/iobroker/iobroker-data/sqlite/sqlite.db
          49M     /opt/iobroker/iobroker-data/states.jsonl
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          25M     /opt/iobroker/iobroker-data/objects.jsonl
          23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
               12.22.12~dfsg-1~deb11u4 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
          npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
          npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
          npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
          npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
          npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
          npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
          npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/debug
          npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/ms
          npm ERR! extraneous: tslib@2.4.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/tslib
          npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.4
          npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/mock-require/node_modules/get-caller-file
          npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
          npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/node-persist/node_modules/mkdirp
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T21_15_50_546Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.12.0
          javascript:     7.1.4
          Adapters from github:   9
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : IoBroker64Bit                            -  enabled
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
          + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          + system.adapter.envertech-pv.0           : envertech-pv          : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
          + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
          + system.adapter.hekr.0                   : hekr                  : IoBroker64Bit                            -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
            system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
            system.adapter.midea.0                  : midea                 : IoBroker64Bit                            - disabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
          + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.69
          + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
          + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
          + system.adapter.octoprint.1              : octoprint             : iobroker                                 -  enabled
          + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
          + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
          + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
          + system.adapter.psa.0                    : psa                   : iobroker                                 -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
          + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
          + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.69
          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
          + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
          + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
          + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
            system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
          Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
          Adapter    "device-reminder": 3.0.0  , installed 3.0.0
          Adapter    "device-watcher": 2.9.4   , installed 2.9.4
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "echarts"      : 1.5.1    , installed 1.5.1
          Adapter    "envertech-pv" : 1.0.2    , installed 1.0.2
          Adapter    "evcc"         : 0.0.10   , installed 0.0.10
          Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "hekr"         : 0.0.6    , installed 0.0.6
          Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 1.14.5   , installed 1.14.5
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "logparser"    : 2.2.0    , installed 2.2.0
          Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
          Adapter    "midea"        : 0.0.7    , installed 0.1.0
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "parcel"       : 0.0.27   , installed 0.0.27
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "psa"          : 0.0.11   , installed 0.0.11
          Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
          Adapter    "s7"           : 1.3.15   , installed 1.3.15
          Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "synology"     : 3.0.1    , installed 3.0.1
          Adapter    "telegram"     : 2.0.1    , installed 2.0.1
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
          Adapter    "worx"         : 2.3.4    , installed 2.3.4
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Objects and States
          Objects:        28839
          States:         24330
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.178.69:45000    0.0.0.0:*               LISTEN      1001       150559     18465/io.sainlogic.
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16499      531/cupsd
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13823      917/exim4
          tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       138031     17482/io.hm-rpc.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       140028     17700/io.mqtt.1
          tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       143721     17847/io.shelly.1
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140027     17700/io.mqtt.1
          tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       140025     17692/io.hm-rpc.3
          tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       141320     17505/io.hm-rpc.1
          tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       136160     17568/io.hm-rpc.2
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15217      611/sshd: /usr/sbin
          tcp        0      0 192.168.178.69:1887     0.0.0.0:*               LISTEN      1001       140070     17813/io.mqtt.3
          tcp        0      0 192.168.178.69:1886     0.0.0.0:*               LISTEN      1001       140069     17813/io.mqtt.3
          tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      1001       141739     17790/io.sonoff.0
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       138417     17273/iobroker.js-c
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       138410     17273/iobroker.js-c
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       148037     18544/io.simple-api
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       137827     17298/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       158639     20102/io.web.0
          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       168901     18256/io.upnp.0
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13824      917/exim4
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16498      531/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15219      611/sshd: /usr/sbin
          tcp6       0      0 :::80                   :::*                    LISTEN      0          15245      658/apache2
          udp        0      0 0.0.0.0:51507           0.0.0.0:*                           1001       146871     18210/io.broadlink2
          udp        0      0 0.0.0.0:59804           0.0.0.0:*                           1001       146875     18210/io.broadlink2
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141936     17828/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141937     17828/io.tuya.0
          udp        0      0 0.0.0.0:55830           0.0.0.0:*                           108        14770      396/avahi-daemon: r
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       146867     18210/io.broadlink2
          udp        0      0 0.0.0.0:36315           0.0.0.0:*                           1001       146874     18210/io.broadlink2
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16646      459/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13758      596/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14768      396/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141737     17779/io.shelly.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       147689     18256/io.upnp.0
          udp6       0      0 :::45149                :::*                                108        14771      396/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          16667      459/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14769      396/avahi-daemon: r
          2023-11-08 22:13:47.920  - info: host.iobroker stopInstance system.adapter.ham.0 send kill signal
          2023-11-08 22:13:48.530  - info: host.iobroker instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-11-08 22:13:51.656  - info: host.iobroker instance system.adapter.ham.0 started with pid 9182
          2023-11-08 22:13:59.930  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 22:14:00.117  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9213
          2023-11-08 22:14:02.468  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478042468_9572
          2023-11-08 22:14:07.867  - info: luftdaten.0 (9213) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
          2023-11-08 22:14:08.618  - info: luftdaten.0 (9213) Terminated (NO_ERROR): Without reason
          2023-11-08 22:14:09.228  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
          2023-11-08 22:14:41.287  - info: admin.0 (17298) ==> Connected system.user.admin from ::ffff:192.168.178.52
          2023-11-08 22:14:53.476  - info: admin.0 (17298) <== Disconnect system.user.admin from ::ffff:192.168.178.52 ham
          2023-11-08 22:15:00.071  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9336
          2023-11-08 22:15:00.709  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 22:15:01.255  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478101254_3328
          2023-11-08 22:15:08.139  - info: dwd.0 (9336) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
          2023-11-08 22:15:11.054  - info: dwd.0 (9336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-11-08 22:15:11.882  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-11-08 22:15:59.500  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 22:16:00.460  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9883
          2023-11-08 22:16:02.080  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478162080_8235
          2023-11-08 22:16:09.485  - info: luftdaten.0 (9883) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
          2023-11-08 22:16:11.630  - info: luftdaten.0 (9883) Terminated (NO_ERROR): Without reason
          2023-11-08 22:16:12.196  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
          2023-11-08 22:17:00.326  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 22:17:00.872  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478220871_7431
            @michaelf sagte in Adapterwarnungen / web stürzt ab:
            Da wird im javascript-Adapter das Modul fehlen. Brauchst du das überhaupt?
            • MichaelF
              Ja auch grade gesehen, und neu eingetragen seit dem läuft der Adapter wieder.
              Moment neuer Diag
              • MichaelF
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : armhf
                 22:25:47 up  2:40,  1 user,  load average: 2.07, 2.07, 1.94
                CPU threads: 4
                Current issues:
                               Local time: Wed 2023-11-08 22:25:47 CET
                           Universal time: Wed 2023-11-08 21:25:47 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.8G        3.3G        2.8G        1.0M        1.7G        4.4G
                Swap:            99M          0B         99M
                Total:          7.9G        3.3G        2.9G
                         7811 M total memory
                         3290 M used memory
                         3449 M active memory
                         1073 M inactive memory
                         2841 M free memory
                          326 M buffer memory
                         1352 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                4.4G    /var/
                3.6G    /var/log
                574M    /var/cache
                61M     /opt/iobroker/iobroker-data/states.jsonl
                29M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        28839
                States:         24407
                Pending Updates: 0
                2023-11-08 22:25:39.551  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                2023-11-08 22:25:39.552  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                2023-11-08 22:25:40.711  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                2023-11-08 22:25:59.446  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                2023-11-08 22:26:00.445  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 13249
                2023-11-08 22:26:02.012  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478762011_8296
                2023-11-08 22:26:12.328  - info: luftdaten.0 (13249) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                2023-11-08 22:26:14.168  - info: luftdaten.0 (13249) Terminated (NO_ERROR): Without reason
                2023-11-08 22:26:15.000  - warn: luftdaten.0 (13249) get state error: Connection is closed.
                2023-11-08 22:26:15.340  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                2023-11-08 22:27:00.253  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                2023-11-08 22:27:00.796  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478820795_8708
                Alle Fehler Weg............
                Mega, Riesen Dank
                  Homoran Global Moderator Administrators @MichaelF last edited by Homoran
                  auch alle extraneous im npm tree??
                  wie kommt man suf soooo viele Adapter aus Github?
                  MichaelF 2 Replies Last reply Reply Quote 0
                  • MichaelF
                    Ich lasse heute Nacht ein Backup laufen und versuche morgen Abend nochmal das Update des Web Adapters.
                    • MichaelF
                      MichaelF @Homoran last edited by
                      @homoran said in Adapterwarnungen / web stürzt ab:
                      Ich Schaue, Moment
                      • MichaelF
                        pi@iobroker:~ $ npm ls
                        pi@ /home/pi
                        └── canvas@2.9.3
                        pi@iobroker:~ $
                        • MichaelF
                          Mmh, mit den Adaptern ist halt irgendwie so gewachsen. Also da war jetzt nicht irgendwie Absicht dahinter
                            immer wieder ins normale Repo überführen wenn vorhanden
                              @michaelf
                              cd /opt/iobroker
                              npm ls
                              canvas haste mal daneben geworfen... 😉
                              • MichaelF
                                Das hatte ich nie gemacht, aber in Zukunft.............
                                • MichaelF
                                  @michaelf
                                  cd /opt/iobroker
                                  npm ls
                                  Das erklärt einiges...........
                                  pi@iobroker:/opt/iobroker $ npm ls
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├── @types/caseless@0.12.2 extraneous
                                  ├── @types/request@2.48.8 extraneous
                                  ├── @types/tough-cookie@4.0.2 extraneous
                                  ├── buffer-shims@1.0.0 extraneous
                                  ├── coffeescript@1.12.7 extraneous
                                  ├── futoin-hkdf@1.4.3 extraneous
                                  ├── homebridge-plugin-wrapper@3.2.0 extraneous
                                  ├── iobroker.accuweather@1.3.1
                                  ├── iobroker.admin@6.12.0
                                  ├── iobroker.alexa2@3.25.5
                                  ├── iobroker.backitup@2.8.7
                                  ├── iobroker.bosesoundtouch@0.10.3
                                  ├── iobroker.broadlink2@2.1.5
                                  ├── iobroker.device-reminder@3.0.0
                                  ├── iobroker.device-watcher@2.9.4
                                  ├── iobroker.devices@1.1.5
                                  ├── iobroker.discovery@3.1.0
                                  ├── iobroker.dwd@2.8.5
                                  ├── iobroker.echarts@1.5.1
                                  ├── iobroker.energiefluss-erweitert@0.0.2-alpha.20 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#07858bd9e4cbb8e005a3585cf5a480650fc47296)
                                  ├── iobroker.envertech-pv@1.0.2
                                  ├── iobroker.evcc@0.0.10
                                  ├── iobroker.eventlist@1.2.3
                                  ├── iobroker.fb-checkpresence@1.2.2
                                  ├── iobroker.fritzdect@2.3.1
                                  ├── iobroker.fully-tablet-control@0.3.6-1 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#f7d8e7ac363adbe19b99c060d77895097228d7ca)
                                  ├── iobroker.ham@5.3.1
                                  ├── iobroker.hekr@0.0.6
                                  ├── iobroker.history@3.0.1
                                  ├── iobroker.hm-rega@3.0.47
                                  ├── iobroker.hm-rpc@1.15.19
                                  ├── iobroker.ical@1.13.3
                                  ├── iobroker.icons-material-png@0.1.0
                                  ├── iobroker.icons-mfd-png@1.1.0
                                  ├── iobroker.icons-mfd-svg@1.1.0
                                  ├── iobroker.icons-open-icon-library-png@0.1.2
                                  ├── iobroker.influxdb@3.2.0
                                  ├── iobroker.info@2.0.0
                                  ├── iobroker.iot@1.14.5
                                  ├── iobroker.javascript@7.1.4
                                  ├── iobroker.js-controller@5.0.12
                                  ├── iobroker.logparser@2.2.0
                                  ├── iobroker.luftdaten@3.1.0
                                  ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#262717eed55656f1c79056eccd8c209666015421)
                                  ├── iobroker.mqtt-client@1.6.5
                                  ├── iobroker.mqtt@4.1.1
                                  ├── iobroker.nuki@1.6.0
                                  ├── iobroker.nut@1.6.0
                                  ├── iobroker.octoprint@5.1.0
                                  ├── iobroker.parcel@0.0.27
                                  ├── iobroker.pi-hole@1.3.6
                                  ├── iobroker.pioneer_sc_vsx@0.1.0 (git+ssh://git@github.com/okeck1982/ioBroker.pioneer_sc_vsx.git#6902280218c6709de322058c19704839f241c069)
                                  ├── iobroker.psa@0.0.11
                                  ├── iobroker.pvforecast@2.9.0
                                  ├── iobroker.rpi2@1.3.2
                                  ├── iobroker.s7@1.3.15
                                  ├── iobroker.sainlogic@0.10.5
                                  ├── iobroker.shelly@6.6.1
                                  ├── iobroker.simple-api@2.7.2
                                  ├── iobroker.socketio@6.5.5
                                  ├── iobroker.sonoff@2.5.3
                                  ├── iobroker.sql@2.2.0
                                  ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
                                  ├── iobroker.synology@3.0.1
                                  ├── iobroker.tankerkoenig@3.3.7
                                  ├── iobroker.telegram@2.0.1
                                  ├── iobroker.tr-064@4.2.18
                                  ├── iobroker.trashschedule@2.3.0
                                  ├── iobroker.tuya@3.14.2
                                  ├── iobroker.upnp@1.0.21
                                  ├── iobroker.vis-bars@0.1.4
                                  ├── iobroker.vis-canvas-gauges@1.0.1
                                  ├── iobroker.vis-colorpicker@2.0.3
                                  ├── iobroker.vis-google-fonts@1.0.4
                                  ├── iobroker.vis-history@1.0.0
                                  ├── iobroker.vis-hqwidgets@1.4.0
                                  ├── iobroker.vis-icontwo@0.96.0
                                  ├── iobroker.vis-inventwo@3.3.3
                                  ├── iobroker.vis-jqui-mfd@1.0.12
                                  ├── iobroker.vis-justgage@1.0.2
                                  ├── iobroker.vis-material@0.1.5 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.vis-material.git#0384950a1e05ec2fa6b6c4bb774afa5e97a13b6c)
                                  ├── iobroker.vis-materialdesign@0.5.76 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#43f3a07d7b48f367612c19ef678935709f718aae)
                                  ├── iobroker.vis-metro@1.2.0
                                  ├── iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                                  ├── iobroker.vis-players@0.1.6
                                  ├── iobroker.vis-rgraph@0.0.2
                                  ├── iobroker.vis-timeandweather@1.2.2
                                  ├── iobroker.vis@1.4.16
                                  ├── iobroker.web@6.1.2
                                  ├── iobroker.worx@2.3.4
                                  ├── iobroker.ws@2.5.5
                                  ├── mock-require@3.0.3 extraneous
                                  ├── node-inspect@2.0.0 extraneous
                                  ├── node-persist@0.0.11 extraneous
                                  ├── pioneer-avr@0.0.1 (git+ssh://git@github.com/EbSe/node-pioneer-avr.git#7affedc95c277a2c9b4ef102b9a96adab6948ba3)
                                  ├── q@1.1.2 extraneous
                                  ├── string-argv@0.3.1 extraneous
                                  ├── typescript@5.1.6 extraneous
                                  ├── virtual-tsc@0.6.2 extraneous
                                  └── wake_on_lan@1.0.0 extraneous
                                    @michaelf
                                    cd /opt/iobroker
                                    npm prune
                                    Danach könnte es sauber sein.
                                    • MichaelF
                                      └── pioneer-avr@0.0.1 (git+ssh://git@github.com/EbSe/node-pioneer-avr.git#7affedc95c277a2c9b4ef102b9a96adab6948ba3)
                                        @michaelf geht doch 😀
                                        hattest du beim letzten prune 7m falschen Verzeichnis gestanden?
                                        • MichaelF
                                          Riesen Dank !!!!!
                                            pioneer-avr
                                            Der gehört aber eigentlich auch nicht in die erste Ebene.
                                            Aber lass das jetzt so.
                                            3793
