    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      Gismoh @crunchip last edited by
      @crunchip
      ist für mich ok mit VIS, wenn alles wieder da ist, wenn ich nur den Adapter neu installiere.
      ansonsten:
      Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp existiert nicht
      Mache dann später weiter.
        crunchip Forum Testing Most Active @Gismoh last edited by
        @gismoh seltsam, dann probier mal so
        iob stop
        iob fix
        cd /opt/iobroker
        npm install iobroker.ble
        iobroker upload ble
        iobroker start ble
          @crunchip
          npm ERR! code 1
          npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
          npm ERR! command failed
          npm ERR! command sh -c node-gyp-build
          npm ERR! gyp info it worked if it ends with ok
          npm ERR! gyp info using node-gyp@7.1.2
          npm ERR! gyp info using node@18.18.2 | linux | x64
          npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
          npm ERR! (node:3121) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
          npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
          npm ERR! gyp info spawn /usr/bin/python3
          npm ERR! gyp info spawn args [
          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
          npm ERR! gyp info spawn args   'binding.gyp',
          npm ERR! gyp info spawn args   '-f',
          npm ERR! gyp info spawn args   'make',
          npm ERR! gyp info spawn args   '-I',
          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
          npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
          npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
          npm ERR! gyp info spawn args   '-Dvisibility=default',
          npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
          npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
          npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
          npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
          npm ERR! gyp info spawn args   '-Dnode_engine=v8',
          npm ERR! gyp info spawn args   '--depth=.',
          npm ERR! gyp info spawn args   '--no-parallel',
          npm ERR! gyp info spawn args   '--generator-output',
          npm ERR! gyp info spawn args   'build',
          npm ERR! gyp info spawn args   '-Goutput_dir=.'
          npm ERR! gyp info spawn args ]
          npm ERR! Traceback (most recent call last):
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
          npm ERR!     sys.exit(gyp.script_main())
          npm ERR!              ^^^^^^^^^^^^^^^^^
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
          npm ERR!     return main(sys.argv[1:])
          npm ERR!            ^^^^^^^^^^^^^^^^^^
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
          npm ERR!     return gyp_main(args)
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
          npm ERR!     [generator, flat_list, targets, data] = Load(
          npm ERR!                                             ^^^^^
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
          npm ERR!     result = gyp.input.Load(
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
          npm ERR!     LoadTargetBuildFile(
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
          npm ERR!     build_file_data = LoadOneBuildFile(
          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
          npm ERR!     build_file_contents = open(build_file_path, "rU").read()
          npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
          npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
          npm ERR! gyp ERR! configure error
          npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
          npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
          npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
          npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
          npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
          npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
          npm ERR! gyp ERR! node -v v18.18.2
          npm ERR! gyp ERR! node-gyp -v v7.1.2
          npm ERR! gyp ERR! not ok
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_11_08_735Z-debug-0.log
          Verstehe es wirklich nicht, warum der ble läuft, aber nach dem einspielen des Backups nicht mehr.
          Kann man den ble irgendwie "sperren", so das das Backitup den nicht "anfasst" ?
            Thomas Braun Most Active @Gismoh last edited by
            @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
            Da muss in einer Datei was umgestellt werden. Hatte den Fall erst unlängst. Such mal im Forum danach.
              crunchip Forum Testing Most Active @Thomas Braun last edited by
              @thomas-braun das ahb ich ihm ja oben schon geschrieben, er findet sie aber nicht in seinem System
                @crunchip
                verstehe ich nicht:
                root@ioBrokerVM:/# cd /opt
                root@ioBrokerVM:/opt# ls
                iobroker
                root@ioBrokerVM:/opt# cd /iobroker
                -bash: cd: /iobroker: Datei oder Verzeichnis nicht gefunden
                er zeigt mit das Verzeichnis iobroker erst an, dann sagt er, er hätte nichts gefunden.
                Ober ist meine Eingabe falsch?
                  Thomas Braun Most Active @Gismoh last edited by Thomas Braun
                  Dein Herumgehampel als root ist falsch.
                  Und relative Pfade werden ohne / angesprochen. Absolute Pfade halt mit /
                  Linux-Grundschule, Herr root.
                    Homoran Global Moderator Administrators @Gismoh last edited by Homoran
                    @gismoh cd /opt/iobroker
                    oder
                    cd /opt
                    cd iobroker
                    beim zweiten kein / davor
                      Gismoh @Homoran last edited by
                      argh, merci, ein Verzeichniswechsel dacht ich da muss ein "/" vor merci
                        das bringt dich wieder in die root-ebene
                        was nicht bedeutet dass man da als root rumläuft
                          Okay, hatte ich nach einer Anleitung aufgesetzt, dort wurde es mit "root" gemacht, sogar auch in weiteren.
                          also das Verzeichnis node-gyp gibt es bei mir nicht, nur ein node-gyp-build.
                          Dieser taucht dann auf, wenn ich mich mit etwas anderem anmelde?
                          Ich suche mal nach ner Anleitung, wie ich mich andres anmelde.
                          Merci
                          Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                            Dann schmeiß die Anleitung weg, leg dir einen User an, falls noch keiner vorhanden ist und stolper mit dem durch das System.
                              Ich hab dir den Befehl doch oben geschrieben
                              https://forum.iobroker.net/post/1076264
                                @crunchip
                                ja, hatte ich ja auch gelesen, aber den Pfad gibt es ja bei mir (aktuell) nicht.
                                Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                                So wie ich @Thomas-Braun verstanden habe liegt das daran, das ich mit root unterwegs bin. Versuche also gleich einen anderen user anzulegen, und dann komme ich wohl zur Datei 😉
                                Thomas Braun G 2 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @crunchip last edited by
                                  @crunchip sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                                  sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                  Bei mir kommt die direkt über nodejs/gyp:
                                  echad@chet:~ $ locate input.py
                                  /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                    Die Datei ist auch für einen anderen user nicht vorhanden. Aber grundsätzlich kapsert man nicht als root durch das System. Schon mal gar nicht, wenn man überhaupt keine Ahnung hat was man da wo warum überhaupt macht.
                                      Gismoh @Gismoh last edited by
                                      hmm, irgendwie bekomme ich njun mit dem anderen user diese Meldung:
                                      idash@ioBrokersudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.pyput.[sudo] Passwort für idash:
                                      Sorry, user idash is not allowed to execute '/usr/bin/nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py' as root on ioBrokerVM.
                                      idash@ioBrokerVM:~$
                                        groups
                                        sagt? Der ist mit Sicherheit nicht in der Gruppe 'sudo' drin.
                                        Ist aber auch für diese Datei nicht erforderlich, da mit root-Rechten zu agieren.
                                          Gismoh @Thomas Braun last edited by
                                          idash@ioBrokerVM:~$ groups
                                          idash users
                                            @gismoh
                                            Siehste...
                                            Als root:
                                            usermod -a -G adm,dialout,sudo,plugdev,input,netdev,iobroker idash
                                            exit
                                            Danach niemehr als root anmelden. Den 'idash' auch ab- und wieder anmelden.
                                            24256
