    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      crunchip Forum Testing Most Active @Gismoh last edited by
      @gismoh seltsam, dann probier mal so
      iob stop
      iob fix
      cd /opt/iobroker
      npm install iobroker.ble
      iobroker upload ble
      iobroker start ble
        Gismoh @crunchip last edited by
        @crunchip
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
        npm ERR! command failed
        npm ERR! command sh -c node-gyp-build
        npm ERR! gyp info it worked if it ends with ok
        npm ERR! gyp info using node-gyp@7.1.2
        npm ERR! gyp info using node@18.18.2 | linux | x64
        npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
        npm ERR! (node:3121) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
        npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
        npm ERR! gyp info spawn /usr/bin/python3
        npm ERR! gyp info spawn args [
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
        npm ERR! gyp info spawn args   'binding.gyp',
        npm ERR! gyp info spawn args   '-f',
        npm ERR! gyp info spawn args   'make',
        npm ERR! gyp info spawn args   '-I',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
        npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
        npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
        npm ERR! gyp info spawn args   '-Dvisibility=default',
        npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
        npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
        npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
        npm ERR! gyp info spawn args   '-Dnode_engine=v8',
        npm ERR! gyp info spawn args   '--depth=.',
        npm ERR! gyp info spawn args   '--no-parallel',
        npm ERR! gyp info spawn args   '--generator-output',
        npm ERR! gyp info spawn args   'build',
        npm ERR! gyp info spawn args   '-Goutput_dir=.'
        npm ERR! gyp info spawn args ]
        npm ERR! Traceback (most recent call last):
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
        npm ERR!     sys.exit(gyp.script_main())
        npm ERR!              ^^^^^^^^^^^^^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
        npm ERR!     return main(sys.argv[1:])
        npm ERR!            ^^^^^^^^^^^^^^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
        npm ERR!     return gyp_main(args)
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
        npm ERR!     [generator, flat_list, targets, data] = Load(
        npm ERR!                                             ^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
        npm ERR!     result = gyp.input.Load(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
        npm ERR!     LoadTargetBuildFile(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
        npm ERR!     build_file_data = LoadOneBuildFile(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
        npm ERR!     build_file_contents = open(build_file_path, "rU").read()
        npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
        npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
        npm ERR! gyp ERR! configure error
        npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
        npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
        npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
        npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
        npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
        npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
        npm ERR! gyp ERR! node -v v18.18.2
        npm ERR! gyp ERR! node-gyp -v v7.1.2
        npm ERR! gyp ERR! not ok
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_11_08_735Z-debug-0.log
        Verstehe es wirklich nicht, warum der ble läuft, aber nach dem einspielen des Backups nicht mehr.
        Kann man den ble irgendwie "sperren", so das das Backitup den nicht "anfasst" ?
          Thomas Braun Most Active @Gismoh last edited by
          @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
          Da muss in einer Datei was umgestellt werden. Hatte den Fall erst unlängst. Such mal im Forum danach.
            crunchip Forum Testing Most Active @Thomas Braun last edited by
            @thomas-braun das ahb ich ihm ja oben schon geschrieben, er findet sie aber nicht in seinem System
              @crunchip
              verstehe ich nicht:
              root@ioBrokerVM:/# cd /opt
              root@ioBrokerVM:/opt# ls
              iobroker
              root@ioBrokerVM:/opt# cd /iobroker
              -bash: cd: /iobroker: Datei oder Verzeichnis nicht gefunden
              er zeigt mit das Verzeichnis iobroker erst an, dann sagt er, er hätte nichts gefunden.
              Ober ist meine Eingabe falsch?
                Thomas Braun Most Active @Gismoh last edited by Thomas Braun
                Dein Herumgehampel als root ist falsch.
                Und relative Pfade werden ohne / angesprochen. Absolute Pfade halt mit /
                Linux-Grundschule, Herr root.
                  Homoran Global Moderator Administrators @Gismoh last edited by Homoran
                  @gismoh cd /opt/iobroker
                  oder
                  cd /opt
                  cd iobroker
                  beim zweiten kein / davor
                    Gismoh @Homoran last edited by
                    argh, merci, ein Verzeichniswechsel dacht ich da muss ein "/" vor merci
                      das bringt dich wieder in die root-ebene
                      was nicht bedeutet dass man da als root rumläuft
                        Okay, hatte ich nach einer Anleitung aufgesetzt, dort wurde es mit "root" gemacht, sogar auch in weiteren.
                        also das Verzeichnis node-gyp gibt es bei mir nicht, nur ein node-gyp-build.
                        Dieser taucht dann auf, wenn ich mich mit etwas anderem anmelde?
                        Ich suche mal nach ner Anleitung, wie ich mich andres anmelde.
                        Merci
                        Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                          Dann schmeiß die Anleitung weg, leg dir einen User an, falls noch keiner vorhanden ist und stolper mit dem durch das System.
                            Ich hab dir den Befehl doch oben geschrieben
                            https://forum.iobroker.net/post/1076264
                              @crunchip
                              ja, hatte ich ja auch gelesen, aber den Pfad gibt es ja bei mir (aktuell) nicht.
                              Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                              So wie ich @Thomas-Braun verstanden habe liegt das daran, das ich mit root unterwegs bin. Versuche also gleich einen anderen user anzulegen, und dann komme ich wohl zur Datei 😉
                              Thomas Braun G 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @crunchip last edited by
                                @crunchip sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                                sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                Bei mir kommt die direkt über nodejs/gyp:
                                echad@chet:~ $ locate input.py
                                /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                  Die Datei ist auch für einen anderen user nicht vorhanden. Aber grundsätzlich kapsert man nicht als root durch das System. Schon mal gar nicht, wenn man überhaupt keine Ahnung hat was man da wo warum überhaupt macht.
                                    Gismoh @Gismoh last edited by
                                    hmm, irgendwie bekomme ich njun mit dem anderen user diese Meldung:
                                    idash@ioBrokersudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.pyput.[sudo] Passwort für idash:
                                    Sorry, user idash is not allowed to execute '/usr/bin/nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py' as root on ioBrokerVM.
                                    idash@ioBrokerVM:~$
                                      groups
                                      sagt? Der ist mit Sicherheit nicht in der Gruppe 'sudo' drin.
                                      Ist aber auch für diese Datei nicht erforderlich, da mit root-Rechten zu agieren.
                                        Gismoh @Thomas Braun last edited by
                                        idash@ioBrokerVM:~$ groups
                                        idash users
                                          @gismoh
                                          Siehste...
                                          Als root:
                                          usermod -a -G adm,dialout,sudo,plugdev,input,netdev,iobroker idash
                                          exit
                                          Danach niemehr als root anmelden. Den 'idash' auch ab- und wieder anmelden.
                                            merci, nun kommt wenn ich unter user "idash" eingebe:
                                            idash adm dialout sudo plugdev users input netdev iobroker
                                            Hoffe es stimmt nun 😉
                                            24271
