    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      Thomas Braun Most Active @Gismoh last edited by Thomas Braun
      @gismoh
      whoami && sudo whoami
      sagt?
        Gismoh @Gismoh last edited by
        Nun kommt aber immer noch bei :
        sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
        Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
          Gismoh @Thomas Braun last edited by
          @thomas-braun said in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
          idash
          root
            idash@ioBrokerVM:/opt/iobroker/node_modules$ ls
            abab                            is-potential-custom-element-name
            @abandonware                    is-primitive
            abbrev                          is-regex
            accepts                         is-shared-array-buffer
            acme-http-01-standalone         is-stream
            acorn                           isstream
            acorn-globals                   is-string
            acorn-walk                      is-symbol
            after                           is-typed-array
            agent-base                      is-typedarray
            ajv                             is-weakref
            @alcalzone                      joi
            alcalzone-shared                jose
            alexa-cookie2                   jsbi
            alexa-remote2                   jsbn
            ansi-colors                     jsdom
            ansi-regex                      jshashes
            ansi-styles                     json2iob
            anymatch                        jsonata
            @apollon                        json-bigint
            aproba                          json-buffer
            archiver                        jsonc-parser
            archiver-utils                  jsonfile
            are-we-there-yet                json-schema
            array-buffer-byte-length        json-schema-traverse
            arraybuffer.prototype.slice     json-stringify-safe
            arraybuffer.slice               jsonwebtoken
            array-flatten                   jsprim
            array.prototype.findindex       js-sdsl
            asn1                            jszip
            assert-plus                     jwa
            async                           jws
            asynckit                        keypairs
            async-limiter                   keyv
            autobind-decorator              kuler
            available-typed-arrays          layerr
            aws4                            lazystream
            aws-crt                         le-acme-core
            aws-iot-device-sdk              le-challenge-fs
            aws-iot-device-sdk-v2           @leichtgewicht
            @aws-sdk                        le-sni-auto
            aws-sign2                       leven
            axios                           lie
            b4a                             loadavg-windows
            backo2                          localforage
            backoff                         locate-path
            balanced-match                  lodash
            base-64                         lodash.assign
            base64-arraybuffer              lodash.defaults
            base64id                        lodash.difference
            base64-js                       lodash.flatten
            bcrypt-pbkdf                    lodash.includes
            bignumber.js                    lodash.isarguments
            binary-extensions               lodash.isboolean
            bindings                        lodash.isinteger
            bl                              lodash.isnumber
            blob                            lodash.isplainobject
            bluebird                        lodash.isstring
            body-parser                     lodash.once
            boolbase                        lodash.union
            bottleneck                      logform
            brace-expansion                 loglevel
            braces                          long
            browser-request                 long-timeout
            buffer                          lowercase-keys
            buffer-crc32                    lru-cache
            buffer-equal-constant-time      lru_map
            buffer-from                     ltx
            bufferhelper                    luxon
            buffer-shims                    lzma
            busboy                          make-dir
            @buttercup                      @mapbox
            byte-length                     map-stream
            bytes                           md5
            cacheable-lookup                md5.js
            cacheable-request               mdns-discovery
            call-bind                       media-typer
            callsite                        merge-descriptors
            camelcase                       merge-stream
            canvas                          meross-cloud
            capitalize                      methods
            caseless                        micromatch
            cert-info                       @microsoft
            chalk                           mime
            charenc                         mime-db
            cheerio                         mime-types
            cheerio-select                  mimic-fn
            chokidar                        mimic-response
            chownr                          minimatch
            ci-info                         minimist
            cli                             minipass
            cliff                           minizlib
            cliui                           mkdirp
            cluster-key-slot                mkdirp-classic
            coap                            mock-require
            coap-packet                     module-not-found-error
            coffeescript                    moment
            color                           mqtt
            color-convert                   mqtt-connection
            color-name                      mqtt-packet
            @colors                         ms
            colors                          mute-stream
            colorspace                      nan
            color-string                    napi-build-utils
            color-support                   nearest-color
            combined-stream                 negotiator
            commist                         nested-property
            component-bind                  netmask
            component-emitter               node-abi
            component-inherit               node-addon-api
            compress-commons                node-arp
            compressible                    node-ble
            compression                     node-domexception
            compress-json                   node.extend
            concat-map                      node-fetch
            concat-stream                   node-forge
            connect-flash                   node-gyp-build
            console-control-strings         node-hue-api
            content-disposition             node-inspect
            content-type                    node-machine-id
            cookie                          node-mndp
            cookie-parser                   node-persist
            cookie-signature                node-rest-client
            core-util-is                    node-schedule
            crc-32                          node-ssdp
            crc32-stream                    node-telegram-bot-api
            cron                            node-wol
            cron-parser                     node-xmpp-client
            cross-spawn                     node-xmpp-core
            crypt                           node-xmpp-tls-connect
            crypto                          nopt
            crypto-js                       normalize-path
            css-select                      normalize-url
            cssstyle                        @nornagon
            css-what                        npmlog
            cycle                           npm-run-path
            @dabh                           nth-check
            daemonize2                      number-allocator
            daikin-controller-cloud         nwsapi
            dashdash                        oauth-sign
            @datalust                       object-assign
            data-uri-to-buffer              object.assign
            data-urls                       object-hash
            dbus-next                       object-inspect
            debug                           object-keys
            decache                         oidc-token-hash
            decamelize                      once
            decimal.js                      onedrive-api
            decompress-response             one-time
            deep-clone                      onetime
            deep-extend                     on-finished
            defer-to-connect                on-headers
            define-data-property            openid-client
            define-properties               options
            delayed-stream                  pako
            delegates                       parse5
            denque                          parse5-htmlparser2-tree-adapter
            depd                            parseqs
            destroy                         parseuri
            detect-libc                     parseurl
            dgram                           passport
            dijkstrajs                      passport-local
            diskusage                       passport-strategy
            dns-packet                      path-exists
            dns-socket                      path-is-absolute
            domelementtype                  path-key
            domexception                    path-parse
            domhandler                      path-posix
            dom-serializer                  path-to-regexp
            domutils                        pause
            dropbox-v2-api                  pause-stream
            duplexer                        p-cancelable
            duplexify                       performance-now
            ecc-jsbn                        p-finally
            ecdsa-sig-formatter             picocolors
            echarts                         picomatch
            eckles                          pidusage
            ecovacs-deebot                  ping
            ee-first                        pkginfo
            emoji-regex                     p-limit
            enabled                         p-locate
            encodeurl                       p-map
            encode-utf8                     pngjs
            end-of-stream                   p-queue
            engine.io                       prebuild-install
            engine.io-client                process
            engine.io-parser                process-nextick-args
            enquirer                        promisify-child-process
            entities                        prompt
            es6-promise                     proxy-addr
            es-abstract                     proxy-from-env
            esbuild                         proxyquire
            escalade                        psl
            escape-html                     p-timeout
            escodegen                       p-try
            @esm2cjs                        pump
            esprima                         punycode
            es-set-tostringtag              pushover-notifications
            es-shim-unscopables             q
            es-to-primitive                 qbox
            estraverse                      qrcode
            esutils                         qr-image
            etag                            qs
            eventemitter3                   querystring
            eventsource                     querystringify
            event-stream                    queue-tick
            execa                           quick-lru
            expand-template                 random-bytes
            express                         range-parser
            express-fileupload              rasha
            express-session                 raw-body
            extend                          rc
            extsprintf                      read
            eyes                            readable-stream
            fast-deep-equal                 readdir-glob
            fast-fifo                       readdirp
            fast-json-stable-stringify      readline
            fastseries                      readline-sync
            fast-xml-parser                 reconnect-core
            fecha                           redirect-https
            fetch-blob                      redis-commands
            file-stream-rotator             redis-errors
            file-type                       redis-parser
            file-uri-to-path                regexp.prototype.flags
            fill-keys                       reinterval
            fill-range                      remove-trailing-separator
            finalhandler                    request
            find-up                         request-promise
            fn.name                         request-promise-core
            follow-redirects                request-promise-native
            for-each                        require-directory
            forever-agent                   require-main-filename
            form-data                       requires-port
            form-data-encoder               resolve
            formdata-polyfill               resolve-alpn
            forwarded                       respjs
            fresh                           responselike
            from                            retry
            fs-constants                    revalidator
            fs-extra                        rfdc
            fs-minipass                     rimraf
            fs.realpath                     @root
            ftp                             rrule
            function-bind                   rrweb-cssom
            function.prototype.name         rsa-compat
            functions-have-names            safe-array-concat
            futoin-hkdf                     safe-buffer
            gauge                           safer-buffer
            gaxios                          safe-regex-test
            gcp-metadata                    safe-replace
            get-caller-file                 safe-stable-stringify
            get-intrinsic                   sax
            getpass                         saxes
            get-ssl-certificate             semaphore
            get-stream                      semver
            get-symbol-description          send
            github-from-package             @sentry
            glob                            @sentry-internal
            globalthis                      seq-logging
            globalyzer                      @serialport
            glob-parent                     serialport
            globrex                         serve-static
            glossy                          set-blocking
            @googleapis                     set-function-length
            googleapis-common               set-function-name
            google-auth-library             setimmediate
            gopd                            setprototypeof
            got                             set-value
            graceful-fs                     sharp
            @greenlock                      shebang-command
            greenlock                       shebang-regex
            greenlock-express               shelly-iot
            greenlock-manager-fs            side-channel
            greenlock-store-fs              @sideway
            gtoken                          signal-exit
            @hapi                           simple-concat
            @harmonyhub                     simple-get
            harmonyhubws                    simple-oauth2
            har-schema                      simple-swizzle
            har-validator                   simple-xmpp
            has-bigints                     @sindresorhus
            has-binary2                     socket.io
            has-cors                        socket.io-adapter
            has-flag                        socket.io-client
            hash-base                       socket.io-parser
            hasown                          socksv5
            has-property-descriptors        sorted-array-functions
            has-proto                       source-map
            has-symbols                     source-map-support
            has-tostringtag                 split
            has-unicode                     split2
            he                              sshpk
            help-me                         stack-trace
            hexy                            standard-as-callback
            homebridge-plugin-wrapper       statuses
            hot-patcher                     stealthy-require
            html-encoding-sniffer           stream-combiner
            htmlparser2                     streamsearch
            http2-wrapper                   stream-shift
            http-cache-semantics            streamx
            http-errors                     string-argv
            http-mitm-proxy                 string_decoder
            http-proxy                      string.prototype.trim
            http-proxy-agent                string.prototype.trimend
            http-proxy-middleware           string.prototype.trimstart
            http-proxy-response-rewrite     string-width
            https                           strip-ansi
            http-signature                  strip-final-newline
            https-proxy-agent               strip-json-comments
            @httptoolkit                    strnum
            hue-push-client                 suncalc2
            human-signals                   supports-color
            iconv-lite                      supports-preserve-symlinks-flag
            ieee754                         symbol-tree
            immediate                       systeminformation
            indexof                         @szmarczak
            inflight                        tar
            influx                          tar-fs
            @influxdata                     tar-stream
            inherits                        tcp-ping
            ini                             text-hex
            internal-slot                   through
            @iobroker                       through2
            iobroker.admin                  tibber-api
            iobroker.alarm                  tiny-glob
            iobroker.alexa2                 to-array
            iobroker.backitup               toidentifier
            iobroker.daikin-cloud           @tootallnate
            iobroker.daswetter              to-regex-range
            iobroker.deconz                 tough-cookie
            iobroker.device-reminder        tr46
            iobroker.discovery              treemap-js
            iobroker.ecovacs-deebot         triple-beam
            iobroker.fb-checkpresence       tslib
            iobroker.fiat                   tunnel-agent
            iobroker.flot                   tweetnacl
            iobroker.fullybrowser           typedarray
            iobroker.go-e                   typed-array-buffer
            iobroker.ham                    typed-array-byte-length
            iobroker.harmony                typed-array-byte-offset
            iobroker.hue                    typed-array-length
            iobroker.hue-extended           type-is
            iobroker.icons-mfd-svg          @types
            iobroker.influxdb               typescript
            iobroker.info                   uid-safe
            iobroker.iot                    ultron
            iobroker.javascript             unbox-primitive
            iobroker.js-controller          undici-types
            iobroker-jsonexplorer           uniqid
            iobroker.meross                 universalify
            iobroker.mihome-vacuum          unix-dgram
            iobroker.mobile                 unpipe
            iobroker.openweathermap         uri-js
            iobroker.pi-hole                url-join
            iobroker.pushover               url-parse
            iobroker.pvforecast             url-template
            iobroker.radar2                 ursa-optional
            iobroker.shelly                 usb
            iobroker.simple-api             util-deprecate
            iobroker.smartcontrol           utils-merge
            iobroker.socketio               uuid
            iobroker.sonoff                 vary
            iobroker.tado                   verror
            iobroker.telegram               virtual-tsc
            iobroker.tibberlink             w3c-xmlserializer
            iobroker.type-detector          wake_on_lan
            iobroker.vis-hqwidgets          weak-daemon
            iobroker.vis-jqui-mfd           webdav
            iobroker.vis-material-advanced  webidl-conversions
            iobroker.vis-metro              websocket-stream
            iobroker.vis-timeandweather     web-streams-polyfill
            iobroker.weatherunderground     whatwg-encoding
            iobroker.web                    whatwg-mimetype
            iobroker.worx                   whatwg-url
            iobroker.ws                     which
            iobroker.ws.server              which-boxed-primitive
            ioredis                         which-module
            ip                              which-typed-array
            ipaddr.js                       wide-align
            ip-regex                        winston
            is                              winston-daily-rotate-file
            isarray                         winston-seq-updated
            is-array-buffer                 winston-syslog
            is-arrayish                     winston-transport
            is-bigint                       wrap-ansi
            is-binary-path                  wrappy
            is-boolean-object               ws
            is-buffer                       xml2js
            is-callable                     xml2json-light
            is-core-module                  xmlbuilder
            is-date-object                  xmlchars
            is-empty-object                 @xmldom
            isexe                           xmlhttprequest-ssl
            is-extglob                      xml-name-validator
            is-fullwidth-code-point         @xmpp
            is-glob                         xregexp
            is-ip                           xtend
            is-negative-zero                y18n
            is-number                       yallist
            is-number-object                yargs
            is-object                       yargs-parser
            isobject                        yeast
            isomorphic-ws                   zip-stream
            is-plain-obj                    zlib
            is-plain-object                 zrender
              @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
              sudo nano
              Du sollst nicht ohne Not jetzt vor jeden Befehl sudo setzen. Das wird nur unter besonderen Umständen benötigt. Für Aktionen in /opt/iobroker werden keine root-Rechte benötigt (in einer gesunden Installation).
              Das Verzeichnis gibt es auf meiner Machine auch nicht.
              sudo nano /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
              funktioniert?
                ja, dies funktioniert 😉
                  @gismoh
                  Dann schau da mal nach dem Eintrag, den crunchip oben genannt hat.
                  Ich vermute aber, der ist da so gar nicht mehr drin.
                  In meiner Version steht da nämlich:
                      if os.path.exists(build_file_path):
                          build_file_contents = open(build_file_path, encoding='utf-8').read()
                      else:
                          raise GypError(f"{build_file_path} not found (cwd: {os.getcwd()})")
                      build_file_data = None
                  G crunchip 2 Replies Last reply Reply Quote 1
                    kann man auch den inhalt der Datei in die Zwischenablage holen, um besser danach suchen zu können?
                      Mit Strg-W sucht man in nano
                        denke, das ist es?
                        def LoadOneBuildFile(build_file_path, data, aux_data, includes, is_target, chec>
                            if build_file_path in data:
                                return data[build_file_path]
                            else:
                            try:
                                if check:
                                    build_file_data = CheckedEval(build_file_contents)
                          @gismoh
                          Zeile 228 müsste das sein.
                            Gismoh @Thomas Braun last edited by Gismoh
                            Zeilennummern sehe ich nicht, aber ist es nicht das, was ich oben gepostet habe?
                              @gismoh
                              Strg-C zeigt die aktuelle Zeile.
                              Aber das passt wohl bei dir dann.
                                Merci - ist dann aber wohl kein gutes Zeichen, weil ich immer noch nicht den ble zum laufen bekomme nach Backitup rückspielung. 😰
                                  @gismoh
                                  iob stop
                                  iob fix
                                  cd /home/iobroker
                                  sudo -u iobroker npm cache clear --force
                                  cd
                                  iobroker upgrade ble@0.13.4
                                    crunchip Forum Testing Most Active @Thomas Braun last edited by
                                    @thomas-braun sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                                    in der einen ja, ich hab da beide
                                    und die Fehlermeldung spuckt ja auch aus
                                    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
                                    npm ERR!     build_file_contents = open(build_file_path, "rU").read()
                                    npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
                                    npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
                                      idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force
                                      npm WARN using --force Recommended protections disabled.
                                      npm ERR! code ENOTEMPTY
                                      npm ERR! syscall rmdir
                                      npm ERR! path /home/iobroker/.npm/_cacache
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache'
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T22_45_40_333Z-debug-0.log
                                      denke, es sollte anders aussehen?
                                        @gismoh
                                        Ja, das sollte so aussehen:
                                        echad@chet:/home/iobroker $ sudo -u iobroker npm cache clear --force
                                        ls -lah /home/iobroker/.npm/_cacache
                                        sagt?
                                          idash@ioBrokerVM:/home/iobroker$ ls -lah /home/iobroker/.npm/_cacache
                                          insgesamt 12K
                                          drwxr-xr-x 3 iobroker iobroker 4,0K  8. Nov 23:45 .
                                          drwxr-xr-x 7 iobroker iobroker 4,0K  8. Nov 22:10 ..
                                          drwxr-xr-x 2 iobroker iobroker 4,0K  8. Nov 23:45 tmp
                                            rm -rf /home/iobroker/.npm/_cacache/tmp
                                            24295
