    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      Gismoh @Gismoh last edited by
      Nun kommt aber immer noch bei :
      sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
      Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
        Gismoh @Thomas Braun last edited by
        @thomas-braun said in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
        whoami && sudo whoami
        idash
        root
          idash@ioBrokerVM:/opt/iobroker/node_modules$ ls
          abab                            is-potential-custom-element-name
          @abandonware                    is-primitive
          abbrev                          is-regex
          accepts                         is-shared-array-buffer
          acme-http-01-standalone         is-stream
          acorn                           isstream
          acorn-globals                   is-string
          acorn-walk                      is-symbol
          after                           is-typed-array
          agent-base                      is-typedarray
          ajv                             is-weakref
          @alcalzone                      joi
          alcalzone-shared                jose
          alexa-cookie2                   jsbi
          alexa-remote2                   jsbn
          ansi-colors                     jsdom
          ansi-regex                      jshashes
          ansi-styles                     json2iob
          anymatch                        jsonata
          @apollon                        json-bigint
          aproba                          json-buffer
          archiver                        jsonc-parser
          archiver-utils                  jsonfile
          are-we-there-yet                json-schema
          array-buffer-byte-length        json-schema-traverse
          arraybuffer.prototype.slice     json-stringify-safe
          arraybuffer.slice               jsonwebtoken
          array-flatten                   jsprim
          array.prototype.findindex       js-sdsl
          asn1                            jszip
          assert-plus                     jwa
          async                           jws
          asynckit                        keypairs
          async-limiter                   keyv
          autobind-decorator              kuler
          available-typed-arrays          layerr
          aws4                            lazystream
          aws-crt                         le-acme-core
          aws-iot-device-sdk              le-challenge-fs
          aws-iot-device-sdk-v2           @leichtgewicht
          @aws-sdk                        le-sni-auto
          aws-sign2                       leven
          axios                           lie
          b4a                             loadavg-windows
          backo2                          localforage
          backoff                         locate-path
          balanced-match                  lodash
          base-64                         lodash.assign
          base64-arraybuffer              lodash.defaults
          base64id                        lodash.difference
          base64-js                       lodash.flatten
          bcrypt-pbkdf                    lodash.includes
          bignumber.js                    lodash.isarguments
          binary-extensions               lodash.isboolean
          bindings                        lodash.isinteger
          bl                              lodash.isnumber
          blob                            lodash.isplainobject
          bluebird                        lodash.isstring
          body-parser                     lodash.once
          boolbase                        lodash.union
          bottleneck                      logform
          brace-expansion                 loglevel
          braces                          long
          browser-request                 long-timeout
          buffer                          lowercase-keys
          buffer-crc32                    lru-cache
          buffer-equal-constant-time      lru_map
          buffer-from                     ltx
          bufferhelper                    luxon
          buffer-shims                    lzma
          busboy                          make-dir
          @buttercup                      @mapbox
          byte-length                     map-stream
          bytes                           md5
          cacheable-lookup                md5.js
          cacheable-request               mdns-discovery
          call-bind                       media-typer
          callsite                        merge-descriptors
          camelcase                       merge-stream
          canvas                          meross-cloud
          capitalize                      methods
          caseless                        micromatch
          cert-info                       @microsoft
          chalk                           mime
          charenc                         mime-db
          cheerio                         mime-types
          cheerio-select                  mimic-fn
          chokidar                        mimic-response
          chownr                          minimatch
          ci-info                         minimist
          cli                             minipass
          cliff                           minizlib
          cliui                           mkdirp
          cluster-key-slot                mkdirp-classic
          coap                            mock-require
          coap-packet                     module-not-found-error
          coffeescript                    moment
          color                           mqtt
          color-convert                   mqtt-connection
          color-name                      mqtt-packet
          @colors                         ms
          colors                          mute-stream
          colorspace                      nan
          color-string                    napi-build-utils
          color-support                   nearest-color
          combined-stream                 negotiator
          commist                         nested-property
          component-bind                  netmask
          component-emitter               node-abi
          component-inherit               node-addon-api
          compress-commons                node-arp
          compressible                    node-ble
          compression                     node-domexception
          compress-json                   node.extend
          concat-map                      node-fetch
          concat-stream                   node-forge
          connect-flash                   node-gyp-build
          console-control-strings         node-hue-api
          content-disposition             node-inspect
          content-type                    node-machine-id
          cookie                          node-mndp
          cookie-parser                   node-persist
          cookie-signature                node-rest-client
          core-util-is                    node-schedule
          crc-32                          node-ssdp
          crc32-stream                    node-telegram-bot-api
          cron                            node-wol
          cron-parser                     node-xmpp-client
          cross-spawn                     node-xmpp-core
          crypt                           node-xmpp-tls-connect
          crypto                          nopt
          crypto-js                       normalize-path
          css-select                      normalize-url
          cssstyle                        @nornagon
          css-what                        npmlog
          cycle                           npm-run-path
          @dabh                           nth-check
          daemonize2                      number-allocator
          daikin-controller-cloud         nwsapi
          dashdash                        oauth-sign
          @datalust                       object-assign
          data-uri-to-buffer              object.assign
          data-urls                       object-hash
          dbus-next                       object-inspect
          debug                           object-keys
          decache                         oidc-token-hash
          decamelize                      once
          decimal.js                      onedrive-api
          decompress-response             one-time
          deep-clone                      onetime
          deep-extend                     on-finished
          defer-to-connect                on-headers
          define-data-property            openid-client
          define-properties               options
          delayed-stream                  pako
          delegates                       parse5
          denque                          parse5-htmlparser2-tree-adapter
          depd                            parseqs
          destroy                         parseuri
          detect-libc                     parseurl
          dgram                           passport
          dijkstrajs                      passport-local
          diskusage                       passport-strategy
          dns-packet                      path-exists
          dns-socket                      path-is-absolute
          domelementtype                  path-key
          domexception                    path-parse
          domhandler                      path-posix
          dom-serializer                  path-to-regexp
          domutils                        pause
          dropbox-v2-api                  pause-stream
          duplexer                        p-cancelable
          duplexify                       performance-now
          ecc-jsbn                        p-finally
          ecdsa-sig-formatter             picocolors
          echarts                         picomatch
          eckles                          pidusage
          ecovacs-deebot                  ping
          ee-first                        pkginfo
          emoji-regex                     p-limit
          enabled                         p-locate
          encodeurl                       p-map
          encode-utf8                     pngjs
          end-of-stream                   p-queue
          engine.io                       prebuild-install
          engine.io-client                process
          engine.io-parser                process-nextick-args
          enquirer                        promisify-child-process
          entities                        prompt
          es6-promise                     proxy-addr
          es-abstract                     proxy-from-env
          esbuild                         proxyquire
          escalade                        psl
          escape-html                     p-timeout
          escodegen                       p-try
          @esm2cjs                        pump
          esprima                         punycode
          es-set-tostringtag              pushover-notifications
          es-shim-unscopables             q
          es-to-primitive                 qbox
          estraverse                      qrcode
          esutils                         qr-image
          etag                            qs
          eventemitter3                   querystring
          eventsource                     querystringify
          event-stream                    queue-tick
          execa                           quick-lru
          expand-template                 random-bytes
          express                         range-parser
          express-fileupload              rasha
          express-session                 raw-body
          extend                          rc
          extsprintf                      read
          eyes                            readable-stream
          fast-deep-equal                 readdir-glob
          fast-fifo                       readdirp
          fast-json-stable-stringify      readline
          fastseries                      readline-sync
          fast-xml-parser                 reconnect-core
          fecha                           redirect-https
          fetch-blob                      redis-commands
          file-stream-rotator             redis-errors
          file-type                       redis-parser
          file-uri-to-path                regexp.prototype.flags
          fill-keys                       reinterval
          fill-range                      remove-trailing-separator
          finalhandler                    request
          find-up                         request-promise
          fn.name                         request-promise-core
          follow-redirects                request-promise-native
          for-each                        require-directory
          forever-agent                   require-main-filename
          form-data                       requires-port
          form-data-encoder               resolve
          formdata-polyfill               resolve-alpn
          forwarded                       respjs
          fresh                           responselike
          from                            retry
          fs-constants                    revalidator
          fs-extra                        rfdc
          fs-minipass                     rimraf
          fs.realpath                     @root
          ftp                             rrule
          function-bind                   rrweb-cssom
          function.prototype.name         rsa-compat
          functions-have-names            safe-array-concat
          futoin-hkdf                     safe-buffer
          gauge                           safer-buffer
          gaxios                          safe-regex-test
          gcp-metadata                    safe-replace
          get-caller-file                 safe-stable-stringify
          get-intrinsic                   sax
          getpass                         saxes
          get-ssl-certificate             semaphore
          get-stream                      semver
          get-symbol-description          send
          github-from-package             @sentry
          glob                            @sentry-internal
          globalthis                      seq-logging
          globalyzer                      @serialport
          glob-parent                     serialport
          globrex                         serve-static
          glossy                          set-blocking
          @googleapis                     set-function-length
          googleapis-common               set-function-name
          google-auth-library             setimmediate
          gopd                            setprototypeof
          got                             set-value
          graceful-fs                     sharp
          @greenlock                      shebang-command
          greenlock                       shebang-regex
          greenlock-express               shelly-iot
          greenlock-manager-fs            side-channel
          greenlock-store-fs              @sideway
          gtoken                          signal-exit
          @hapi                           simple-concat
          @harmonyhub                     simple-get
          harmonyhubws                    simple-oauth2
          har-schema                      simple-swizzle
          har-validator                   simple-xmpp
          has-bigints                     @sindresorhus
          has-binary2                     socket.io
          has-cors                        socket.io-adapter
          has-flag                        socket.io-client
          hash-base                       socket.io-parser
          hasown                          socksv5
          has-property-descriptors        sorted-array-functions
          has-proto                       source-map
          has-symbols                     source-map-support
          has-tostringtag                 split
          has-unicode                     split2
          he                              sshpk
          help-me                         stack-trace
          hexy                            standard-as-callback
          homebridge-plugin-wrapper       statuses
          hot-patcher                     stealthy-require
          html-encoding-sniffer           stream-combiner
          htmlparser2                     streamsearch
          http2-wrapper                   stream-shift
          http-cache-semantics            streamx
          http-errors                     string-argv
          http-mitm-proxy                 string_decoder
          http-proxy                      string.prototype.trim
          http-proxy-agent                string.prototype.trimend
          http-proxy-middleware           string.prototype.trimstart
          http-proxy-response-rewrite     string-width
          https                           strip-ansi
          http-signature                  strip-final-newline
          https-proxy-agent               strip-json-comments
          @httptoolkit                    strnum
          hue-push-client                 suncalc2
          human-signals                   supports-color
          iconv-lite                      supports-preserve-symlinks-flag
          ieee754                         symbol-tree
          immediate                       systeminformation
          indexof                         @szmarczak
          inflight                        tar
          influx                          tar-fs
          @influxdata                     tar-stream
          inherits                        tcp-ping
          ini                             text-hex
          internal-slot                   through
          @iobroker                       through2
          iobroker.admin                  tibber-api
          iobroker.alarm                  tiny-glob
          iobroker.alexa2                 to-array
          iobroker.backitup               toidentifier
          iobroker.daikin-cloud           @tootallnate
          iobroker.daswetter              to-regex-range
          iobroker.deconz                 tough-cookie
          iobroker.device-reminder        tr46
          iobroker.discovery              treemap-js
          iobroker.ecovacs-deebot         triple-beam
          iobroker.fb-checkpresence       tslib
          iobroker.fiat                   tunnel-agent
          iobroker.flot                   tweetnacl
          iobroker.fullybrowser           typedarray
          iobroker.go-e                   typed-array-buffer
          iobroker.ham                    typed-array-byte-length
          iobroker.harmony                typed-array-byte-offset
          iobroker.hue                    typed-array-length
          iobroker.hue-extended           type-is
          iobroker.icons-mfd-svg          @types
          iobroker.influxdb               typescript
          iobroker.info                   uid-safe
          iobroker.iot                    ultron
          iobroker.javascript             unbox-primitive
          iobroker.js-controller          undici-types
          iobroker-jsonexplorer           uniqid
          iobroker.meross                 universalify
          iobroker.mihome-vacuum          unix-dgram
          iobroker.mobile                 unpipe
          iobroker.openweathermap         uri-js
          iobroker.pi-hole                url-join
          iobroker.pushover               url-parse
          iobroker.pvforecast             url-template
          iobroker.radar2                 ursa-optional
          iobroker.shelly                 usb
          iobroker.simple-api             util-deprecate
          iobroker.smartcontrol           utils-merge
          iobroker.socketio               uuid
          iobroker.sonoff                 vary
          iobroker.tado                   verror
          iobroker.telegram               virtual-tsc
          iobroker.tibberlink             w3c-xmlserializer
          iobroker.type-detector          wake_on_lan
          iobroker.vis-hqwidgets          weak-daemon
          iobroker.vis-jqui-mfd           webdav
          iobroker.vis-material-advanced  webidl-conversions
          iobroker.vis-metro              websocket-stream
          iobroker.vis-timeandweather     web-streams-polyfill
          iobroker.weatherunderground     whatwg-encoding
          iobroker.web                    whatwg-mimetype
          iobroker.worx                   whatwg-url
          iobroker.ws                     which
          iobroker.ws.server              which-boxed-primitive
          ioredis                         which-module
          ip                              which-typed-array
          ipaddr.js                       wide-align
          ip-regex                        winston
          is                              winston-daily-rotate-file
          isarray                         winston-seq-updated
          is-array-buffer                 winston-syslog
          is-arrayish                     winston-transport
          is-bigint                       wrap-ansi
          is-binary-path                  wrappy
          is-boolean-object               ws
          is-buffer                       xml2js
          is-callable                     xml2json-light
          is-core-module                  xmlbuilder
          is-date-object                  xmlchars
          is-empty-object                 @xmldom
          isexe                           xmlhttprequest-ssl
          is-extglob                      xml-name-validator
          is-fullwidth-code-point         @xmpp
          is-glob                         xregexp
          is-ip                           xtend
          is-negative-zero                y18n
          is-number                       yallist
          is-number-object                yargs
          is-object                       yargs-parser
          isobject                        yeast
          isomorphic-ws                   zip-stream
          is-plain-obj                    zlib
          is-plain-object                 zrender
            Thomas Braun Most Active @Gismoh last edited by
            @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
            sudo nano
            Du sollst nicht ohne Not jetzt vor jeden Befehl sudo setzen. Das wird nur unter besonderen Umständen benötigt. Für Aktionen in /opt/iobroker werden keine root-Rechte benötigt (in einer gesunden Installation).
            Das Verzeichnis gibt es auf meiner Machine auch nicht.
            sudo nano /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
            funktioniert?
              ja, dies funktioniert 😉
                Thomas Braun Most Active @Gismoh last edited by Thomas Braun
                @gismoh
                Dann schau da mal nach dem Eintrag, den crunchip oben genannt hat.
                Ich vermute aber, der ist da so gar nicht mehr drin.
                In meiner Version steht da nämlich:
                    if os.path.exists(build_file_path):
                        build_file_contents = open(build_file_path, encoding='utf-8').read()
                    else:
                        raise GypError(f"{build_file_path} not found (cwd: {os.getcwd()})")
                    build_file_data = None
                G crunchip 2 Replies Last reply Reply Quote 1
                  kann man auch den inhalt der Datei in die Zwischenablage holen, um besser danach suchen zu können?
                    Mit Strg-W sucht man in nano
                      denke, das ist es?
                      def LoadOneBuildFile(build_file_path, data, aux_data, includes, is_target, chec>
                          if build_file_path in data:
                              return data[build_file_path]
                          else:
                          try:
                              if check:
                                  build_file_data = CheckedEval(build_file_contents)
                        @gismoh
                        Zeile 228 müsste das sein.
                          Gismoh @Thomas Braun last edited by Gismoh
                          Zeilennummern sehe ich nicht, aber ist es nicht das, was ich oben gepostet habe?
                            @gismoh
                            Strg-C zeigt die aktuelle Zeile.
                            Aber das passt wohl bei dir dann.
                              Merci - ist dann aber wohl kein gutes Zeichen, weil ich immer noch nicht den ble zum laufen bekomme nach Backitup rückspielung. 😰
                                @gismoh
                                iob stop
                                iob fix
                                cd /home/iobroker
                                sudo -u iobroker npm cache clear --force
                                cd
                                iobroker upgrade ble@0.13.4
                                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                                  @thomas-braun sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                                  in der einen ja, ich hab da beide
                                  und die Fehlermeldung spuckt ja auch aus
                                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
                                  npm ERR!     build_file_contents = open(build_file_path, "rU").read()
                                  npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
                                  npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
                                    idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force
                                    npm WARN using --force Recommended protections disabled.
                                    npm ERR! code ENOTEMPTY
                                    npm ERR! syscall rmdir
                                    npm ERR! path /home/iobroker/.npm/_cacache
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache'
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T22_45_40_333Z-debug-0.log
                                    denke, es sollte anders aussehen?
                                      @gismoh
                                      Ja, das sollte so aussehen:
                                      echad@chet:/home/iobroker $ sudo -u iobroker npm cache clear --force
                                      ls -lah /home/iobroker/.npm/_cacache
                                      sagt?
                                        idash@ioBrokerVM:/home/iobroker$ ls -lah /home/iobroker/.npm/_cacache
                                        insgesamt 12K
                                        drwxr-xr-x 3 iobroker iobroker 4,0K  8. Nov 23:45 .
                                        drwxr-xr-x 7 iobroker iobroker 4,0K  8. Nov 22:10 ..
                                        drwxr-xr-x 2 iobroker iobroker 4,0K  8. Nov 23:45 tmp
                                          rm -rf /home/iobroker/.npm/_cacache/tmp
                                            rm: das Entfernen von '/home/iobroker/.npm/_cacache/tmp/d411385f' ist nicht möglich: Keine Berechtigung
                                            24298
