    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      Thomas Braun Most Active @Gismoh last edited by
      @gismoh
      iob list adapters
        Gismoh @Thomas Braun last edited by
        idash@ioBrokerVM:~$ iob list adapters
        system.adapter.accuweather             : accuweather    - v1.1.4
        system.adapter.admin                   : admin          - v6.3.5
        system.adapter.alarm                   : alarm          - v3.3.13
        system.adapter.alexa2                  : alexa2         - v3.23.2
        system.adapter.asuswrt                 : asuswrt        - v1.0.1
        system.adapter.backitup                : backitup       - v2.8.1
        system.adapter.broadlink2              : broadlink2     - v2.0.3
        system.adapter.cloud                   : cloud          - v4.0.4
        system.adapter.daikin-cloud            : daikin-cloud   - v0.3.0
        system.adapter.daswetter               : daswetter      - v3.1.10
        system.adapter.deconz                  : deconz         - v1.3.21
        system.adapter.device-reminder         : device-reminder - v1.2.9
        system.adapter.discovery               : discovery      - v3.1.0
        system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.13
        system.adapter.enigma2                 : enigma2        - v2.0.3
        system.adapter.fb-checkpresence        : fb-checkpresence - v1.2.2
        system.adapter.fiat                    : fiat           - v0.0.8
        system.adapter.flot                    : flot           - v1.12.0
        system.adapter.fritzdect               : fritzdect      - v2.1.11
        system.adapter.fullybrowser            : fullybrowser   - v2.1.2
        system.adapter.go-e                    : go-e           - v1.0.27
        system.adapter.ham                     : ham            - v5.3.1
        system.adapter.harmony                 : harmony        - v1.2.2
        system.adapter.hue                     : hue            - v3.10.0
        system.adapter.hue-extended            : hue-extended   - v2.0.0
        system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
        system.adapter.influxdb                : influxdb       - v3.2.0
        system.adapter.info                    : info           - v2.0.0
        system.adapter.iot                     : iot            - v1.14.5
        system.adapter.javascript              : javascript     - v7.1.4
        system.adapter.meross                  : meross         - v1.15.1
        system.adapter.mihome-vacuum           : mihome-vacuum  - v4.0.0
        system.adapter.mobile                  : mobile         - v1.0.1
        system.adapter.openweathermap          : openweathermap - v0.3.9
        system.adapter.parser                  : parser         - v1.3.2
        system.adapter.pi-hole                 : pi-hole        - v1.3.6
        system.adapter.ping                    : ping           - v1.4.12
        system.adapter.pushover                : pushover       - v3.0.3
        system.adapter.pvforecast              : pvforecast     - v2.8.1
        system.adapter.radar2                  : radar2         - v2.0.7
        system.adapter.shelly                  : shelly         - v6.4.1
        system.adapter.simple-api              : simple-api     - v2.7.2
        system.adapter.smartcontrol            : smartcontrol   - v2.0.1
        system.adapter.socketio                : socketio       - v6.5.5
        system.adapter.sonoff                  : sonoff         - v2.5.3
        system.adapter.tado                    : tado           - v0.4.9
        system.adapter.telegram                : telegram       - v1.16.0
        system.adapter.tibberlink              : tibberlink     - v1.0.0
        system.adapter.tr-064                  : tr-064         - v4.2.4
        system.adapter.vis                     : vis            - v1.4.16
        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.4.0
        system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
        system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.4
        system.adapter.vis-metro               : vis-metro      - v1.2.0
        system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
        system.adapter.weatherunderground      : weatherunderground - v3.6.0
        system.adapter.web                     : web            - v4.3.0
        system.adapter.worx                    : worx           - v2.3.2
        system.adapter.ws                      : ws             - v2.5.5
          @gismoh
          iobroker install ble
            idash@ioBrokerVM:~$ iobroker install ble
            NPM version: 9.8.1
            Installing iobroker.ble@0.13.4... (System call)
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
            npm ERR! command failed
            npm ERR! command sh -c node-gyp-build
            npm ERR! (node:1950) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
            npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
            npm ERR! Traceback (most recent call last):
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
            npm ERR!     sys.exit(gyp.script_main())
            npm ERR!              ^^^^^^^^^^^^^^^^^
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
            npm ERR!     return main(sys.argv[1:])
            npm ERR!            ^^^^^^^^^^^^^^^^^^
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
            npm ERR!     return gyp_main(args)
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
            npm ERR!     [generator, flat_list, targets, data] = Load(
            npm ERR!                                             ^^^^^
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
            npm ERR!     result = gyp.input.Load(
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
            npm ERR!     LoadTargetBuildFile(
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
            npm ERR!     build_file_data = LoadOneBuildFile(
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
            npm ERR!     build_file_contents = open(build_file_path, "rU").read()
            npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
            npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
            npm ERR! gyp ERR! configure error
            npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
            npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
            npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
            npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
            npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
            npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
            npm ERR! gyp ERR! node -v v18.18.2
            npm ERR! gyp ERR! node-gyp -v v7.1.2
            npm ERR! gyp ERR! not ok
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T23_26_40_665Z-debug-0.log
            host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
              @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
              Ich muss lagsam mal in die Heia...
              nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
              gibt es nicht?
                leider nicht:
                Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                Dann wünsch ich dir eine gute Nacht, und besten Dank!
                  Gismoh @Gismoh last edited by Gismoh
                  @all
                  Besten Dank an alle, welche sich hier als helfende Hand mit eingebunden haben! 👏 💐
                  Habe mir nun auch noch ein USB-Bluetooth Modul bestellt - keine Ahnung ob es damit evtl. besser geht.
                  Was mich immer nur wundert, das die "Erstinstallation" incl. BLE geklappt hat, also der BLE grün war und auch Geräte gefunden hat. Erst nach Backup Einspielung verweigerte der ble seinen Dienst.
                  Würde mich freuen, wenn noch eine Lösung gefunden werden könnte 😉
                    crunchip Forum Testing Most Active @Gismoh last edited by
                    letzte Variante,
                    den Ble auf dem alten System deinstallieren, dann ein backup erstellen, dieses auf deinen neuen System spielen und danach dann den ble installieren.
                    G 2 Replies Last reply Reply Quote 1
                      Gismoh @crunchip last edited by
                      @crunchip
                      Guten Morgen,
                      kann ich gerne mache, mit einer "rest-Hoffnung".
                      Allerdings sehe ich selber als Laie keinen großen unterschied zur Vorgehensweise von gestern,
                      dort hatte ich ja auf dem alten System den ble entfernt -
                      und auf dem neuen System den ble belassen. Leider wurde der bestehende ble auf dem neuen System mit dem Backup entfernt.
                      Werde ich aber gerne ausprobieren, mache vorher noch einer Sicherung der jetzigen VM - für den Fall das evtl. jemand dort noch mal ansetzen mag -und kann ja nicht schaden.
                      Spiele dann nun wieder die Sicherung von der Erstinstallation auf der neuen Maschine ein, wo ioBroker frisch installiert wurde, deinstalliere außer admin und backitup die Adapter und spiele dann das gestrige Backup von der alten Maschine (Raspi) ein, wo ich das ble deinstalliert hatte.
                      Melde mich dann nach "Verzug" wieder 😉
                        @crunchip
                        nach
                        iob logs --watch
                        ist ioBroker seit über 20 min mit der Backup-Einspielung durch.
                        Habe nun auch direkt wieder einen "Nicht root" User angelegt 😉
                          idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug
                          NPM version: 9.8.1
                          npm ERR! code 1
                          npm ERR! gyp info it worked if it ends with ok
                          npm ERR! gyp info using node-gyp@7.1.2
                          npm ERR! gyp info using node@18.18.2 | linux | x64
                          npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                          npm ERR! (node:2880) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                          npm ERR! gyp info spawn /usr/bin/python3
                          npm ERR! gyp info spawn args [
                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                          npm ERR! gyp info spawn args   'binding.gyp',
                          npm ERR! gyp info spawn args   '-f',
                          npm ERR! gyp info spawn args   'make',
                          npm ERR! gyp info spawn args   '-I',
                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                          npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
                          npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                          npm ERR! gyp info spawn args   '-Dvisibility=default',
                          npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
                          npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                          npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
                          npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
                          npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                          npm ERR! gyp info spawn args   '--depth=.',
                          npm ERR! gyp info spawn args   '--no-parallel',
                          npm ERR! gyp info spawn args   '--generator-output',
                          npm ERR! gyp info spawn args   'build',
                          npm ERR! gyp info spawn args   '-Goutput_dir=.'
                          npm ERR! gyp info spawn args ]
                          npm ERR!                                             ^^^^^
                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T10_08_33_310Z-debug-0.log
                          npm ERR! code 1
                          npm ERR!                                             ^^^^^
                          idash@ioBrokerVM:~$
                            crunchip Forum Testing Most Active @Gismoh last edited by crunchip
                            welche Adapter?
                            du sollst den iobroker frisch aufsetzen, nichts deinstallieren.
                            vom alten iobroker ein backup machen, aber vorher den ble deinstallieren, damit dein backup ohne ble kommt und du anschließend diesen in deinem neuen iobroker frisch einpflegen kannst
                            sonst schleifst du dein node-gyp Problem ja weiter mit
                              Gismoh @crunchip last edited by Gismoh
                              @crunchip
                              Na, hatte noch einen adapter zum Test drin und eben discovery , welche ich vor dem backup gelöscht hatte.
                              Habe es nun aber wieder frisch aufgesetzt.
                              Und das Backup wird wieder eingespielt - die ohne ble (wie gestern).
                                Ohne Adapter oder nur ohne Instanz?
                                  @crunchip
                                  hatte beides deinstalliert also 1x unter Instanz, und 1x unter Adapter.
                                  Oder sollte ich nur eines von beiden rausnehmen?
                                    iob logs --watch:
                                    2023-11-09 14:05:41.577  - info: host.ioBrokerVM iobroker npm-install: upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
                                    2023-11-09 14:05:41.588  - info: host.ioBrokerVM iobroker npm-install: upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
                                    2023-11-09 14:05:41.591  - info: host.ioBrokerVM iobroker npm-install: upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
                                    2023-11-09 14:05:41.595  - info: host.ioBrokerVM iobroker npm-install: upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                                    2023-11-09 14:05:41.598  - info: host.ioBrokerVM iobroker npm-install: upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                    2023-11-09 14:05:41.726  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.info created/updated
                                    2023-11-09 14:05:42.798  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:05:43.798  - warn: host.ioBrokerVM startInstance cannot find adapter "iot@1.14.5". Try to install it... 1 attempt
                                    2023-11-09 14:05:43.799  - info: host.ioBrokerVM iobroker install iot@1.14.5 using installedFrom
                                    2023-11-09 14:05:45.448  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:05:45.449  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.iot@1.14.5... (System call)
                                    2023-11-09 14:05:56.266  - info: host.ioBrokerVM iobroker npm-install: added 82 packages in 11s
                                    2023-11-09 14:05:56.267  - info: host.ioBrokerVM iobroker npm-install: 124 packages are looking for funding
                                    2023-11-09 14:05:56.270  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                                    2023-11-09 14:05:56.298  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter iot@1.14.5
                                    2023-11-09 14:05:57.781  - info: host.ioBrokerVM iobroker npm-install: upload [132] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                                    2023-11-09 14:06:02.982  - info: host.ioBrokerVM iobroker npm-install: upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
                                    2023-11-09 14:06:03.012  - info: host.ioBrokerVM iobroker npm-install: upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
                                    2023-11-09 14:06:03.038  - info: host.ioBrokerVM iobroker npm-install: upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
                                    2023-11-09 14:06:03.065  - info: host.ioBrokerVM iobroker npm-install: upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
                                    2023-11-09 14:06:03.091  - info: host.ioBrokerVM iobroker npm-install: upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
                                    2023-11-09 14:06:03.118  - info: host.ioBrokerVM iobroker npm-install: upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
                                    2023-11-09 14:06:03.145  - info: host.ioBrokerVM iobroker npm-install: upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml
                                    2023-11-09 14:06:03.173  - info: host.ioBrokerVM iobroker npm-install: upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml
                                    2023-11-09 14:06:03.202  - info: host.ioBrokerVM iobroker npm-install: upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
                                    2023-11-09 14:06:03.205  - info: host.ioBrokerVM iobroker npm-install: upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                    2023-11-09 14:06:03.209  - info: host.ioBrokerVM iobroker npm-install: upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                    2023-11-09 14:06:03.212  - info: host.ioBrokerVM iobroker npm-install: upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                    2023-11-09 14:06:03.216  - info: host.ioBrokerVM iobroker npm-install: upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                    2023-11-09 14:06:03.219  - info: host.ioBrokerVM iobroker npm-install: upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                    2023-11-09 14:06:03.222  - info: host.ioBrokerVM iobroker npm-install: upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                    2023-11-09 14:06:03.226  - info: host.ioBrokerVM iobroker npm-install: upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                    2023-11-09 14:06:03.230  - info: host.ioBrokerVM iobroker npm-install: upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                    2023-11-09 14:06:03.234  - info: host.ioBrokerVM iobroker npm-install: upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                    2023-11-09 14:06:03.239  - info: host.ioBrokerVM iobroker npm-install: upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                    2023-11-09 14:06:03.242  - info: host.ioBrokerVM iobroker npm-install: upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                                    2023-11-09 14:06:03.246  - info: host.ioBrokerVM iobroker npm-install: upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                    2023-11-09 14:06:03.250  - info: host.ioBrokerVM iobroker npm-install: upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                    2023-11-09 14:06:03.253  - info: host.ioBrokerVM iobroker npm-install: upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                                    2023-11-09 14:06:03.257  - info: host.ioBrokerVM iobroker npm-install: upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                    2023-11-09 14:06:03.260  - info: host.ioBrokerVM iobroker npm-install: upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                                    2023-11-09 14:06:03.263  - info: host.ioBrokerVM iobroker npm-install: upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                    2023-11-09 14:06:03.267  - info: host.ioBrokerVM iobroker npm-install: upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                                    2023-11-09 14:06:03.270  - info: host.ioBrokerVM iobroker npm-install: upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                                    2023-11-09 14:06:03.273  - info: host.ioBrokerVM iobroker npm-install: upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                    2023-11-09 14:06:03.402  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.iot created/updated
                                    2023-11-09 14:06:04.578  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:06:05.579  - warn: host.ioBrokerVM startInstance cannot find adapter "mobile@1.0.1". Try to install it... 1 attempt
                                    2023-11-09 14:06:05.579  - info: host.ioBrokerVM iobroker install mobile@1.0.1 using installedFrom
                                    2023-11-09 14:06:07.137  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:06:07.138  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.mobile@1.0.1... (System call)
                                    2023-11-09 14:06:11.607  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s
                                    2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install:
                                    2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install: 124 packages are looking for funding
                                    2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                                    2023-11-09 14:06:11.629  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter mobile@1.0.1
                                    2023-11-09 14:06:11.635  - info: host.ioBrokerVM iobroker npm-install: upload [1] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/index.html index.html text/html
                                    2023-11-09 14:06:11.708  - info: host.ioBrokerVM iobroker npm-install: upload [0] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/mobile.png mobile.png image/png
                                    2023-11-09 14:06:11.749  - info: host.ioBrokerVM iobroker npm-install: upload [69] mobile /opt/iobroker/node_modules/iobroker.mobile/www/cache.manifest cache.manifest text/cache-manifest
                                    2023-11-09 14:06:11.780  - info: host.ioBrokerVM iobroker npm-install: upload [60] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind0.png img/blind0.png image/png
                                    2023-11-09 14:06:11.805  - info: host.ioBrokerVM iobroker npm-install: upload [50] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind90.png img/blind90.png image/png
                                    2023-11-09 14:06:11.830  - info: host.ioBrokerVM iobroker npm-install: upload [40] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/rgb-green.png img/rgb-green.png image/png
                                    2023-11-09 14:06:11.854  - info: host.ioBrokerVM iobroker npm-install: upload [30] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/windowClosed.png img/windowClosed.png image/png
                                    2023-11-09 14:06:11.880  - info: host.ioBrokerVM iobroker npm-install: upload [20] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/nl/translations.json js/i18n/nl/translations.json application/json
                                    2023-11-09 14:06:11.884  - info: host.ioBrokerVM iobroker npm-install: upload [19] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/pl/translations.json js/i18n/pl/translations.json application/json
                                    2023-11-09 14:06:11.887  - info: host.ioBrokerVM iobroker npm-install: upload [18] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/pt/translations.json js/i18n/pt/translations.json application/json
                                    2023-11-09 14:06:11.891  - info: host.ioBrokerVM iobroker npm-install: upload [17] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/ru/translations.json js/i18n/ru/translations.json application/json
                                    2023-11-09 14:06:11.894  - info: host.ioBrokerVM iobroker npm-install: upload [16] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/zh-cn/translations.json js/i18n/zh-cn/translations.json application/json
                                    2023-11-09 14:06:11.897  - info: host.ioBrokerVM iobroker npm-install: upload [15] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/mobile.js js/mobile.js application/javascript
                                    2023-11-09 14:06:11.901  - info: host.ioBrokerVM iobroker npm-install: upload [14] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/words.js js/words.js application/javascript
                                    2023-11-09 14:06:11.906  - info: host.ioBrokerVM iobroker npm-install: upload [13] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/images/ajax-loader.gif lib/css/default/images/ajax-loader.gif image/gif
                                    2023-11-09 14:06:11.909  - info: host.ioBrokerVM iobroker npm-install: upload [12] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/jquery.mobile.icons.min.css lib/css/default/jquery.mobile.icons.min.css text/css
                                    2023-11-09 14:06:11.914  - info: host.ioBrokerVM iobroker npm-install: upload [11] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/jquery.mobile.min.css lib/css/default/jquery.mobile.min.css text/css
                                    2023-11-09 14:06:11.917  - info: host.ioBrokerVM iobroker npm-install: upload [10] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/images/ajax-loader.gif lib/css/grey/images/ajax-loader.gif image/gif
                                    2023-11-09 14:06:11.921  - info: host.ioBrokerVM iobroker npm-install: upload [9] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/jquery.mobile.icons.min.css lib/css/grey/jquery.mobile.icons.min.css text/css
                                    2023-11-09 14:06:11.926  - info: host.ioBrokerVM iobroker npm-install: upload [8] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/jquery.mobile.min.css lib/css/grey/jquery.mobile.min.css text/css
                                    2023-11-09 14:06:11.930  - info: host.ioBrokerVM iobroker npm-install: upload [7] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/jquery.mobile.structure-1.4.5.min.css lib/css/jquery.mobile.structure-1.4.5.min.css text/css
                                    2023-11-09 14:06:11.933  - info: host.ioBrokerVM iobroker npm-install: upload [6] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/light/jquery.mobile.icons.min.css lib/css/light/jquery.mobile.icons.min.css text/css
                                    2023-11-09 14:06:11.937  - info: host.ioBrokerVM iobroker npm-install: upload [5] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/light/jquery.mobile.min.css lib/css/light/jquery.mobile.min.css text/css
                                    2023-11-09 14:06:11.940  - info: host.ioBrokerVM iobroker npm-install: upload [4] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.mobile-1.4.5.min.js lib/js/jquery.mobile-1.4.5.min.js application/javascript
                                    2023-11-09 14:06:11.944  - info: host.ioBrokerVM iobroker npm-install: upload [3] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.mobile-1.4.5.min.map lib/js/jquery.mobile-1.4.5.min.map application/json
                                    2023-11-09 14:06:11.949  - info: host.ioBrokerVM iobroker npm-install: upload [2] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.ui.touch-punch.min.js lib/js/jquery.ui.touch-punch.min.js application/javascript
                                    2023-11-09 14:06:11.952  - info: host.ioBrokerVM iobroker npm-install: upload [1] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/loStorage.min.js lib/js/loStorage.min.js application/javascript
                                    2023-11-09 14:06:11.955  - info: host.ioBrokerVM iobroker npm-install: upload [0] mobile /opt/iobroker/node_modules/iobroker.mobile/www/offline.html offline.html text/html
                                    2023-11-09 14:06:12.050  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.mobile created/updated
                                    2023-11-09 14:06:12.097  - info: host.ioBrokerVM iobroker npm-install: Update "system.adapter.mobile.0"
                                    2023-11-09 14:06:13.120  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:06:14.120  - warn: host.ioBrokerVM startInstance cannot find adapter "pi-hole@1.3.6". Try to install it... 1 attempt
                                    2023-11-09 14:06:14.121  - info: host.ioBrokerVM iobroker install pi-hole@1.3.6 using installedFrom
                                    2023-11-09 14:06:15.736  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.pi-hole@1.3.6... (System call)
                                    2023-11-09 14:06:21.920  - info: host.ioBrokerVM iobroker npm-install: added 14 packages in 6s
                                    2023-11-09 14:06:21.921  - info: host.ioBrokerVM iobroker npm-install:
                                    2023-11-09 14:06:21.922  - info: host.ioBrokerVM iobroker npm-install: 129 packages are looking for funding
                                    2023-11-09 14:06:21.922  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                                    2023-11-09 14:06:21.943  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pi-hole@1.3.6
                                    2023-11-09 14:06:22.013  - info: host.ioBrokerVM iobroker npm-install: upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
                                    2023-11-09 14:06:22.021  - info: host.ioBrokerVM iobroker npm-install: upload [3] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/index_m.html index_m.html text/html
                                    2023-11-09 14:06:22.024  - info: host.ioBrokerVM iobroker npm-install: upload [2] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/pi-hole.png pi-hole.png image/png
                                    2023-11-09 14:06:22.028  - info: host.ioBrokerVM iobroker npm-install: upload [1] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/style.css style.css text/css
                                    2023-11-09 14:06:22.031  - info: host.ioBrokerVM iobroker npm-install: upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javascript
                                    2023-11-09 14:06:22.045  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pi-hole created/updated
                                    2023-11-09 14:06:23.108  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:06:24.109  - warn: host.ioBrokerVM startInstance cannot find adapter "pvforecast@2.8.1". Try to install it... 1 attempt
                                    2023-11-09 14:06:24.109  - info: host.ioBrokerVM iobroker install pvforecast@2.8.1 using installedFrom
                                    2023-11-09 14:06:25.728  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.pvforecast@2.8.1... (System call)
                                    2023-11-09 14:06:30.535  - info: host.ioBrokerVM iobroker npm-install: added 4 packages in 5s129 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:06:30.556  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pvforecast@2.8.1
                                    2023-11-09 14:06:30.631  - info: host.ioBrokerVM iobroker npm-install: upload [14] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    2023-11-09 14:06:30.638  - info: host.ioBrokerVM iobroker npm-install: upload [13] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    2023-11-09 14:06:30.642  - info: host.ioBrokerVM iobroker npm-install: upload [12] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    2023-11-09 14:06:30.645  - info: host.ioBrokerVM iobroker npm-install: upload [11] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    2023-11-09 14:06:30.649  - info: host.ioBrokerVM iobroker npm-install: upload [10] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    2023-11-09 14:06:30.652  - info: host.ioBrokerVM iobroker npm-install: upload [9] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    2023-11-09 14:06:30.656  - info: host.ioBrokerVM iobroker npm-install: upload [8] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    2023-11-09 14:06:30.659  - info: host.ioBrokerVM iobroker npm-install: upload [7] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    2023-11-09 14:06:30.663  - info: host.ioBrokerVM iobroker npm-install: upload [6] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    2023-11-09 14:06:30.667  - info: host.ioBrokerVM iobroker npm-install: upload [5] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                    2023-11-09 14:06:30.670  - info: host.ioBrokerVM iobroker npm-install: upload [4] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    2023-11-09 14:06:30.673  - info: host.ioBrokerVM iobroker npm-install: upload [3] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/img/Azimuth.png img/Azimuth.png image/png
                                    2023-11-09 14:06:30.678  - info: host.ioBrokerVM iobroker npm-install: upload [2] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/jsonConfig.json jsonConfig.json application/json
                                    2023-11-09 14:06:30.681  - info: host.ioBrokerVM iobroker npm-install: upload [1] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/pvforecast.png pvforecast.png image/png
                                    2023-11-09 14:06:30.685  - info: host.ioBrokerVM iobroker npm-install: upload [0] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/style.css style.css text/css
                                    2023-11-09 14:06:30.778  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pvforecast created/updated
                                    2023-11-09 14:06:31.844  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:06:32.845  - warn: host.ioBrokerVM startInstance cannot find adapter "smartcontrol@2.0.1". Try to install it... 1 attempt
                                    2023-11-09 14:06:32.845  - info: host.ioBrokerVM iobroker install smartcontrol@2.0.1 using installedFrom
                                    2023-11-09 14:06:34.428  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:06:34.430  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.smartcontrol@2.0.1... (System call)
                                    2023-11-09 14:06:39.890  - info: host.ioBrokerVM iobroker npm-install: added 15 packages in 5s
                                    2023-11-09 14:06:39.891  - info: host.ioBrokerVM iobroker npm-install:
                                    2023-11-09 14:06:39.891  - info: host.ioBrokerVM iobroker npm-install: 140 packages are looking for funding
                                    2023-11-09 14:06:39.892  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                                    2023-11-09 14:06:39.915  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter smartcontrol@2.0.1
                                    2023-11-09 14:06:39.991  - info: host.ioBrokerVM iobroker npm-install: upload [81] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/admin.d.ts admin.d.ts video/mp2t
                                    2023-11-09 14:06:39.999  - info: host.ioBrokerVM iobroker npm-install: upload [80] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/check_box-24px.svg doc-md/img/check_box-24px.svg image/svg+xml
                                    2023-11-09 14:06:40.036  - info: host.ioBrokerVM iobroker npm-install: upload [70] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/table-zones_select-target-devices-overwrite.gif doc-md/img/table-zones_select-target-devices-overwrite.gif image/gif
                                    2023-11-09 14:06:40.065  - info: host.ioBrokerVM iobroker npm-install: upload [60] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-target-devices_de.md doc-md/table-target-devices_de.md text/markdown
                                    2023-11-09 14:06:40.093  - info: host.ioBrokerVM iobroker npm-install: upload [50] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-trigger-times_de.md doc-md/table-trigger-times_de.md text/markdown
                                    2023-11-09 14:06:40.120  - info: host.ioBrokerVM iobroker npm-install: upload [40] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/fancytree/skin-lion/vline-rtl.gif fancytree/skin-lion/vline-rtl.gif image/gif
                                    2023-11-09 14:06:40.145  - info: host.ioBrokerVM iobroker npm-install: upload [30] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    2023-11-09 14:06:40.172  - info: host.ioBrokerVM iobroker npm-install: upload [20] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-target-devices.png img/option-screenshots/tab-target-devices.png image/png
                                    2023-11-09 14:06:40.175  - info: host.ioBrokerVM iobroker npm-install: upload [19] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-motion.png img/option-screenshots/tab-triggers-motion.png image/png
                                    2023-11-09 14:06:40.179  - info: host.ioBrokerVM iobroker npm-install: upload [18] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-other.png img/option-screenshots/tab-triggers-other.png image/png
                                    2023-11-09 14:06:40.182  - info: host.ioBrokerVM iobroker npm-install: upload [17] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-time.png img/option-screenshots/tab-triggers-time.png image/png
                                    2023-11-09 14:06:40.186  - info: host.ioBrokerVM iobroker npm-install: upload [16] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones-execution.png img/option-screenshots/tab-zones-execution.png image/png
                                    2023-11-09 14:06:40.189  - info: host.ioBrokerVM iobroker npm-install: upload [15] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones.png img/option-screenshots/tab-zones.png image/png
                                    2023-11-09 14:06:40.193  - info: host.ioBrokerVM iobroker npm-install: upload [14] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/sc_always.png img/sc_always.png image/png
                                    2023-11-09 14:06:40.196  - info: host.ioBrokerVM iobroker npm-install: upload [13] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/select-target-devices-overwrite.gif img/select-target-devices-overwrite.gif image/gif
                                    2023-11-09 14:06:40.199  - info: host.ioBrokerVM iobroker npm-install: upload [12] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options1.gif img/smartControl_options1.gif image/gif
                                    2023-11-09 14:06:40.213  - info: host.ioBrokerVM iobroker npm-install: upload [11] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown.gif img/smartControl_options_dropdown.gif image/gif
                                    2023-11-09 14:06:40.217  - info: host.ioBrokerVM iobroker npm-install: upload [10] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown_2.gif img/smartControl_options_dropdown_2.gif image/gif
                                    2023-11-09 14:06:40.221  - info: host.ioBrokerVM iobroker npm-install: upload [9] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.html index_m.html text/html
                                    2023-11-09 14:06:40.225  - info: host.ioBrokerVM iobroker npm-install: upload [8] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.js index_m.js application/javascript
                                    2023-11-09 14:06:40.228  - info: host.ioBrokerVM iobroker npm-install: upload [7] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol-banner.png smartcontrol-banner.png image/png
                                    2023-11-09 14:06:40.232  - info: host.ioBrokerVM iobroker npm-install: upload [6] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol.png smartcontrol.png image/png
                                    2023-11-09 14:06:40.235  - info: host.ioBrokerVM iobroker npm-install: upload [5] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/style.css style.css text/css
                                    2023-11-09 14:06:40.239  - info: host.ioBrokerVM iobroker npm-install: upload [4] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/tsconfig.json tsconfig.json application/json
                                    2023-11-09 14:06:40.243  - info: host.ioBrokerVM iobroker npm-install: upload [3] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/words.js words.js application/javascript
                                    2023-11-09 14:06:40.247  - info: host.ioBrokerVM iobroker npm-install: upload [2] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/readme.txt zero-md/readme.txt text/plain
                                    2023-11-09 14:06:40.250  - info: host.ioBrokerVM iobroker npm-install: upload [1] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/webcomponents-loader.min.js zero-md/webcomponents-loader.min.js application/javascript
                                    2023-11-09 14:06:40.253  - info: host.ioBrokerVM iobroker npm-install: upload [0] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/zero-md.min.js.js zero-md/zero-md.min.js.js application/javascript
                                    2023-11-09 14:06:40.344  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.smartcontrol created/updated
                                    2023-11-09 14:06:41.412  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:06:42.412  - warn: host.ioBrokerVM startInstance cannot find adapter "socketio@6.5.5". Try to install it... 1 attempt
                                    2023-11-09 14:06:42.413  - info: host.ioBrokerVM iobroker install socketio@6.5.5 using installedFrom
                                    2023-11-09 14:06:44.040  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.socketio@6.5.5... (System call)
                                    2023-11-09 14:06:49.603  - info: host.ioBrokerVM iobroker npm-install: added 41 packages in 5s140 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:06:49.624  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter socketio@6.5.5
                                    2023-11-09 14:06:49.697  - info: host.ioBrokerVM iobroker npm-install: upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    2023-11-09 14:06:49.704  - info: host.ioBrokerVM iobroker npm-install: upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    2023-11-09 14:06:49.707  - info: host.ioBrokerVM iobroker npm-install: upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    2023-11-09 14:06:49.710  - info: host.ioBrokerVM iobroker npm-install: upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    2023-11-09 14:06:49.714  - info: host.ioBrokerVM iobroker npm-install: upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    2023-11-09 14:06:49.717  - info: host.ioBrokerVM iobroker npm-install: upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    2023-11-09 14:06:49.721  - info: host.ioBrokerVM iobroker npm-install: upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    2023-11-09 14:06:49.724  - info: host.ioBrokerVM iobroker npm-install: upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    2023-11-09 14:06:49.727  - info: host.ioBrokerVM iobroker npm-install: upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    2023-11-09 14:06:49.730  - info: host.ioBrokerVM iobroker npm-install: upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    2023-11-09 14:06:49.733  - info: host.ioBrokerVM iobroker npm-install: upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                                    2023-11-09 14:06:49.736  - info: host.ioBrokerVM iobroker npm-install: upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                    2023-11-09 14:06:49.857  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.socketio created/updated
                                    2023-11-09 14:06:50.920  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:06:51.921  - warn: host.ioBrokerVM startInstance cannot find adapter "tado@0.4.9". Try to install it... 1 attempt
                                    2023-11-09 14:06:51.921  - info: host.ioBrokerVM iobroker install tado@0.4.9 using installedFrom
                                    2023-11-09 14:06:53.545  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:06:53.546  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tado@0.4.9... (System call)
                                    2023-11-09 14:07:07.999  - info: host.ioBrokerVM iobroker npm-install:
                                    2023-11-09 14:07:08.000  - info: host.ioBrokerVM iobroker npm-install: added 27 packages in 14s149 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:07:08.023  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tado@0.4.9
                                    2023-11-09 14:07:08.098  - info: host.ioBrokerVM iobroker npm-install: upload [6] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t
                                    2023-11-09 14:07:08.105  - info: host.ioBrokerVM iobroker npm-install: upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
                                    2023-11-09 14:07:08.109  - info: host.ioBrokerVM iobroker npm-install: upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html
                                    2023-11-09 14:07:08.112  - info: host.ioBrokerVM iobroker npm-install: upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/jsonConfig.json jsonConfig.json application/json
                                    2023-11-09 14:07:08.115  - info: host.ioBrokerVM iobroker npm-install: upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css
                                    2023-11-09 14:07:08.121  - info: host.ioBrokerVM iobroker npm-install: upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
                                    2023-11-09 14:07:08.125  - info: host.ioBrokerVM iobroker npm-install: upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript
                                    2023-11-09 14:07:08.225  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tado created/updated
                                    2023-11-09 14:07:09.286  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:07:10.286  - warn: host.ioBrokerVM startInstance cannot find adapter "tibberlink@1.0.0". Try to install it... 1 attempt
                                    2023-11-09 14:07:10.286  - info: host.ioBrokerVM iobroker install tibberlink@1.0.0 using installedFrom
                                    2023-11-09 14:07:11.896  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:07:11.897  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tibberlink@1.0.0... (System call)
                                    2023-11-09 14:07:17.244  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 5s149 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:07:17.264  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tibberlink@1.0.0
                                    2023-11-09 14:07:17.337  - info: host.ioBrokerVM iobroker npm-install: upload [12] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    2023-11-09 14:07:17.345  - info: host.ioBrokerVM iobroker npm-install: upload [11] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    2023-11-09 14:07:17.348  - info: host.ioBrokerVM iobroker npm-install: upload [10] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    2023-11-09 14:07:17.351  - info: host.ioBrokerVM iobroker npm-install: upload [9] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    2023-11-09 14:07:17.355  - info: host.ioBrokerVM iobroker npm-install: upload [8] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    2023-11-09 14:07:17.359  - info: host.ioBrokerVM iobroker npm-install: upload [7] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    2023-11-09 14:07:17.362  - info: host.ioBrokerVM iobroker npm-install: upload [6] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    2023-11-09 14:07:17.366  - info: host.ioBrokerVM iobroker npm-install: upload [5] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    2023-11-09 14:07:17.369  - info: host.ioBrokerVM iobroker npm-install: upload [4] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    2023-11-09 14:07:17.373  - info: host.ioBrokerVM iobroker npm-install: upload [3] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                    2023-11-09 14:07:17.376  - info: host.ioBrokerVM iobroker npm-install: upload [2] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    2023-11-09 14:07:17.379  - info: host.ioBrokerVM iobroker npm-install: upload [1] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/jsonConfig.json jsonConfig.json application/json
                                    2023-11-09 14:07:17.383  - info: host.ioBrokerVM iobroker npm-install: upload [0] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/tibberlink.png tibberlink.png image/png
                                    2023-11-09 14:07:17.476  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tibberlink created/updated
                                    2023-11-09 14:07:18.536  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:07:19.536  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-hqwidgets@1.4.0". Try to install it... 1 attempt
                                    2023-11-09 14:07:19.537  - info: host.ioBrokerVM iobroker install vis-hqwidgets@1.4.0 using installedFrom
                                    2023-11-09 14:07:21.131  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis-hqwidgets@1.4.0... (System call)
                                    2023-11-09 14:07:25.562  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s149 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:07:25.582  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-hqwidgets@1.4.0
                                    2023-11-09 14:07:25.653  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                    2023-11-09 14:07:25.660  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                    2023-11-09 14:07:25.667  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                    2023-11-09 14:07:25.785  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-hqwidgets created/updated
                                    2023-11-09 14:07:26.849  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:07:27.849  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-jqui-mfd@1.0.12". Try to install it... 1 attempt
                                    2023-11-09 14:07:27.850  - info: host.ioBrokerVM iobroker install vis-jqui-mfd@1.0.12 using installedFrom
                                    2023-11-09 14:07:29.442  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:07:29.444  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-jqui-mfd@1.0.12... (System call)
                                    2023-11-09 14:07:33.873  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s
                                    2023-11-09 14:07:33.874  - info: host.ioBrokerVM iobroker npm-install:
                                    2023-11-09 14:07:33.874  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                                    2023-11-09 14:07:33.875  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                                    2023-11-09 14:07:33.898  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-jqui-mfd@1.0.12
                                    2023-11-09 14:07:33.968  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                                    2023-11-09 14:07:33.976  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                                    2023-11-09 14:07:34.095  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-jqui-mfd created/updated
                                    2023-11-09 14:07:34.142  - info: host.ioBrokerVM iobroker npm-install: Update "system.adapter.vis-jqui-mfd.0"
                                    2023-11-09 14:07:35.159  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:07:36.160  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-material-advanced@1.7.4". Try to install it... 1 attempt
                                    2023-11-09 14:07:36.160  - info: host.ioBrokerVM iobroker install vis-material-advanced@1.7.4 using installedFrom
                                    2023-11-09 14:07:37.726  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:07:37.726  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-material-advanced@1.7.4... (System call)
                                    2023-11-09 14:07:42.344  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s
                                    2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install:
                                    2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                                    2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                                    2023-11-09 14:07:42.370  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-material-advanced@1.7.4
                                    2023-11-09 14:07:42.445  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/vis-material-advanced.png vis-material-advanced.png image/png
                                    2023-11-09 14:07:42.451  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/words.js words.js application/javascript
                                    2023-11-09 14:07:42.455  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Nothing was uploaded or deleted.
                                    2023-11-09 14:07:42.575  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-material-advanced created/updated
                                    2023-11-09 14:07:43.640  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:07:44.641  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-metro@1.2.0". Try to install it... 1 attempt
                                    2023-11-09 14:07:44.641  - info: host.ioBrokerVM iobroker install vis-metro@1.2.0 using installedFrom
                                    2023-11-09 14:07:46.237  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:07:46.239  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-metro@1.2.0... (System call)
                                    2023-11-09 14:07:50.907  - info: host.ioBrokerVM iobroker npm-install: added 3 packages in 4s149 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:07:50.930  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-metro@1.2.0
                                    2023-11-09 14:07:51.001  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
                                    2023-11-09 14:07:51.008  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
                                    2023-11-09 14:07:51.013  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
                                    2023-11-09 14:07:51.132  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-metro created/updated
                                    2023-11-09 14:07:52.192  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:07:53.193  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-timeandweather@1.2.2". Try to install it... 1 attempt
                                    2023-11-09 14:07:53.193  - info: host.ioBrokerVM iobroker install vis-timeandweather@1.2.2 using installedFrom
                                    2023-11-09 14:07:54.800  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis-timeandweather@1.2.2... (System call)
                                    2023-11-09 14:07:59.358  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s149 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:07:59.378  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-timeandweather@1.2.2
                                    2023-11-09 14:07:59.448  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                                    2023-11-09 14:07:59.455  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                                    2023-11-09 14:07:59.461  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                                    2023-11-09 14:07:59.579  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-timeandweather created/updated
                                    2023-11-09 14:08:00.640  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:08:01.641  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
                                    2023-11-09 14:08:01.641  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                                    2023-11-09 14:08:03.252  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
                                    2023-11-09 14:08:07.741  - info: vis.0 (14808) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-09 14:08:07.936  - info: vis.0 (14808) vis license is OK.
                                    2023-11-09 14:08:08.132  - error: vis.0 (14808) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-11-09 14:08:08.133  - error: vis.0 (14808) unhandled promise rejection: Not exists
                                    2023-11-09 14:08:08.133  - error: vis.0 (14808) Error: Not exists
                                        at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
                                        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
                                        at process.processImmediate (node:internal/timers:478:21)
                                    2023-11-09 14:08:08.134  - error: vis.0 (14808) Not exists
                                    2023-11-09 14:08:08.638  - info: vis.0 (14808) terminating
                                    2023-11-09 14:08:08.639  - warn: vis.0 (14808) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-11-09 14:08:09.330  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_03_548Z-debug-0.log
                                    2023-11-09 14:08:09.330  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                    2023-11-09 14:08:10.348  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                    2023-11-09 14:08:11.349  - warn: host.ioBrokerVM startInstance cannot find adapter "web@4.3.0". Try to install it... 1 attempt
                                    2023-11-09 14:08:11.349  - info: host.ioBrokerVM iobroker install web@4.3.0 using installedFrom
                                    2023-11-09 14:08:13.009  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:08:13.011  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.web@4.3.0... (System call)
                                    2023-11-09 14:08:19.346  - info: host.ioBrokerVM iobroker npm-install: added 12 packages in 6s150 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:08:19.371  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter web@4.3.0
                                    2023-11-09 14:08:19.442  - info: host.ioBrokerVM iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                    2023-11-09 14:08:19.449  - info: host.ioBrokerVM iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                    2023-11-09 14:08:19.454  - info: host.ioBrokerVM iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                    2023-11-09 14:08:19.457  - info: host.ioBrokerVM iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                                    2023-11-09 14:08:19.461  - info: host.ioBrokerVM iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                    2023-11-09 14:08:19.465  - info: host.ioBrokerVM iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                    2023-11-09 14:08:19.468  - info: host.ioBrokerVM iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                    2023-11-09 14:08:19.471  - info: host.ioBrokerVM iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                    2023-11-09 14:08:19.474  - info: host.ioBrokerVM iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
                                    2023-11-09 14:08:19.488  - info: host.ioBrokerVM iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
                                    2023-11-09 14:08:19.491  - info: host.ioBrokerVM iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
                                    2023-11-09 14:08:19.822  - info: host.ioBrokerVM iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
                                    2023-11-09 14:08:19.834  - info: host.ioBrokerVM iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
                                    2023-11-09 14:08:19.838  - info: host.ioBrokerVM iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
                                    2023-11-09 14:08:19.840  - info: host.ioBrokerVM iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
                                    2023-11-09 14:08:19.843  - info: host.ioBrokerVM iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                                    2023-11-09 14:08:19.847  - info: host.ioBrokerVM iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                    2023-11-09 14:08:19.902  - info: host.ioBrokerVM iobroker npm-install: upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                    2023-11-09 14:08:20.034  - info: host.ioBrokerVM iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                    2023-11-09 14:08:20.187  - info: host.ioBrokerVM iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                    2023-11-09 14:08:20.343  - info: host.ioBrokerVM iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                    2023-11-09 14:08:20.507  - info: host.ioBrokerVM iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                    2023-11-09 14:08:20.681  - info: host.ioBrokerVM iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                    2023-11-09 14:08:20.854  - info: host.ioBrokerVM iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                    2023-11-09 14:08:20.886  - info: host.ioBrokerVM iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                    2023-11-09 14:08:20.921  - info: host.ioBrokerVM iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                    2023-11-09 14:08:20.953  - info: host.ioBrokerVM iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                    2023-11-09 14:08:20.986  - info: host.ioBrokerVM iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                    2023-11-09 14:08:21.019  - info: host.ioBrokerVM iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                    2023-11-09 14:08:21.070  - info: host.ioBrokerVM iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                    2023-11-09 14:08:21.106  - info: host.ioBrokerVM iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                    2023-11-09 14:08:21.147  - info: host.ioBrokerVM iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                    2023-11-09 14:08:21.152  - info: host.ioBrokerVM iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                    2023-11-09 14:08:21.158  - info: host.ioBrokerVM iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                    2023-11-09 14:08:21.163  - info: host.ioBrokerVM iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                    2023-11-09 14:08:21.167  - info: host.ioBrokerVM iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                    2023-11-09 14:08:21.172  - info: host.ioBrokerVM iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                    2023-11-09 14:08:21.176  - info: host.ioBrokerVM iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                    2023-11-09 14:08:21.183  - info: host.ioBrokerVM iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                    2023-11-09 14:08:21.188  - info: host.ioBrokerVM iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                    2023-11-09 14:08:21.192  - info: host.ioBrokerVM iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                    2023-11-09 14:08:21.214  - info: host.ioBrokerVM iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                    2023-11-09 14:08:21.221  - info: host.ioBrokerVM iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                    2023-11-09 14:08:21.226  - info: host.ioBrokerVM iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                    2023-11-09 14:08:21.230  - info: host.ioBrokerVM iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                    2023-11-09 14:08:21.235  - info: host.ioBrokerVM iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                    2023-11-09 14:08:21.244  - info: host.ioBrokerVM iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                    2023-11-09 14:08:21.253  - info: host.ioBrokerVM iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                    2023-11-09 14:08:21.258  - info: host.ioBrokerVM iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                    2023-11-09 14:08:21.279  - info: host.ioBrokerVM iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                    2023-11-09 14:08:21.283  - info: host.ioBrokerVM iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                    2023-11-09 14:08:21.288  - info: host.ioBrokerVM iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                    2023-11-09 14:08:21.380  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.web created/updated
                                    2023-11-09 14:08:22.442  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:08:23.443  - warn: host.ioBrokerVM startInstance cannot find adapter "worx@2.3.2". Try to install it... 1 attempt
                                    2023-11-09 14:08:23.443  - info: host.ioBrokerVM iobroker install worx@2.3.2 using installedFrom
                                    2023-11-09 14:08:25.057  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:08:25.059  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.worx@2.3.2... (System call)
                                    2023-11-09 14:08:35.767  - info: host.ioBrokerVM iobroker npm-install:
                                    2023-11-09 14:08:35.767  - info: host.ioBrokerVM iobroker npm-install: added 42 packages in 10s152 packages are looking for funding  run `npm fund` for details
                                    2023-11-09 14:08:35.799  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter worx@2.3.2
                                    2023-11-09 14:08:35.874  - info: host.ioBrokerVM iobroker npm-install: upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    2023-11-09 14:08:35.882  - info: host.ioBrokerVM iobroker npm-install: upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    2023-11-09 14:08:35.885  - info: host.ioBrokerVM iobroker npm-install: upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    2023-11-09 14:08:35.889  - info: host.ioBrokerVM iobroker npm-install: upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    2023-11-09 14:08:35.892  - info: host.ioBrokerVM iobroker npm-install: upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    2023-11-09 14:08:35.896  - info: host.ioBrokerVM iobroker npm-install: upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    2023-11-09 14:08:35.899  - info: host.ioBrokerVM iobroker npm-install: upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    2023-11-09 14:08:35.903  - info: host.ioBrokerVM iobroker npm-install: upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    2023-11-09 14:08:35.906  - info: host.ioBrokerVM iobroker npm-install: upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    2023-11-09 14:08:35.910  - info: host.ioBrokerVM iobroker npm-install: upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                    2023-11-09 14:08:35.913  - info: host.ioBrokerVM iobroker npm-install: upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    2023-11-09 14:08:35.916  - info: host.ioBrokerVM iobroker npm-install: upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
                                    2023-11-09 14:08:35.919  - info: host.ioBrokerVM iobroker npm-install: upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
                                    2023-11-09 14:08:35.922  - info: host.ioBrokerVM iobroker npm-install: upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
                                    2023-11-09 14:08:36.035  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.worx created/updated
                                    2023-11-09 14:08:37.095  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                    2023-11-09 14:08:38.095  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
                                    2023-11-09 14:08:38.096  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                                    2023-11-09 14:08:39.715  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:08:39.716  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                    2023-11-09 14:08:43.855  - info: vis.0 (15120) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-09 14:08:44.030  - info: vis.0 (15120) vis license is OK.
                                    2023-11-09 14:08:44.198  - error: vis.0 (15120) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-11-09 14:08:44.198  - error: vis.0 (15120) unhandled promise rejection: Not exists
                                    2023-11-09 14:08:44.199  - error: vis.0 (15120) Error: Not exists
                                    2023-11-09 14:08:44.199  - error: vis.0 (15120) Not exists
                                    2023-11-09 14:08:44.704  - info: vis.0 (15120) terminating
                                    2023-11-09 14:08:44.705  - warn: vis.0 (15120) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-11-09 14:08:45.368  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_40_023Z-debug-0.log
                                    2023-11-09 14:08:45.369  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                    2023-11-09 14:08:46.386  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                    2023-11-09 14:08:47.386  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
                                    2023-11-09 14:08:47.387  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                                    2023-11-09 14:08:48.955  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
                                    2023-11-09 14:08:53.034  - info: vis.0 (15229) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-09 14:08:53.235  - info: vis.0 (15229) vis license is OK.
                                    2023-11-09 14:08:53.414  - error: vis.0 (15229) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-11-09 14:08:53.414  - error: vis.0 (15229) unhandled promise rejection: Not exists
                                    2023-11-09 14:08:53.415  - error: vis.0 (15229) Error: Not exists
                                    2023-11-09 14:08:53.415  - error: vis.0 (15229) Not exists
                                    2023-11-09 14:08:53.921  - info: vis.0 (15229) terminating
                                    2023-11-09 14:08:53.921  - warn: vis.0 (15229) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-11-09 14:08:54.553  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_49_301Z-debug-0.log
                                    2023-11-09 14:08:54.554  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                    2023-11-09 14:08:55.571  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                    2023-11-09 14:08:56.572  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
                                    2023-11-09 14:08:56.572  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                                    2023-11-09 14:08:58.196  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                    2023-11-09 14:08:58.196  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                    2023-11-09 14:09:02.223  - info: vis.0 (15338) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-09 14:09:02.401  - info: vis.0 (15338) vis license is OK.
                                    2023-11-09 14:09:02.571  - error: vis.0 (15338) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-11-09 14:09:02.572  - error: vis.0 (15338) unhandled promise rejection: Not exists
                                    2023-11-09 14:09:02.573  - error: vis.0 (15338) Error: Not exists
                                    2023-11-09 14:09:02.573  - error: vis.0 (15338) Not exists
                                    2023-11-09 14:09:03.076  - info: vis.0 (15338) terminating
                                    2023-11-09 14:09:03.077  - warn: vis.0 (15338) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-11-09 14:09:03.768  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_58_507Z-debug-0.log
                                    2023-11-09 14:09:03.769  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                    2023-11-09 14:09:04.788  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                    2023-11-09 14:09:05.788  - error: host.ioBrokerVM Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                                      Gismoh @Gismoh last edited by
                                      idash@ioBrokerVM:~$ iob stop
                                      idash@ioBrokerVM:~$ iob fix
                                      library: loaded
                                      Library version=2023-10-13
                                          Welcome to the ioBroker installation fixer!
                                          Script version: 2023-10-13
                                          You might need to enter your password a couple of times.
                                          Installing prerequisites (1/5)
                                      [sudo] Passwort für idash:
                                      OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                                      OK:2 http://deb.debian.org/debian bookworm InRelease
                                      OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                                      OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Paketlisten werden gelesen… Fertig
                                          Checking ioBroker user and directory permissions (2/5)
                                      Created /etc/sudoers.d/iobroker
                                      Fixing directory permissions...
                                          Check and cleanup npm temporary directories (3/5)
                                      Done.
                                          Database maintenance (4/5)
                                      Checking for uncompressed JSONL databases... This might take a while!
                                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                      Compressed 2 JSONL files. Done
                                          Checking autostart (5/5)
                                      Enabling autostart...
                                      Autostart enabled!
                                          Your installation was fixed successfully
                                          Run iobroker start to start ioBroker again!
                                      idash@ioBrokerVM:~$ cd /home/iobroker
                                      idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force
                                      npm WARN using --force Recommended protections disabled.
                                      npm ERR! code ENOTEMPTY
                                      npm ERR! syscall rmdir
                                      npm ERR! path /home/iobroker/.npm/_cacache
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache'
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_38_57_713Z-debug-0.log
                                      G Homoran 2 Replies Last reply Reply Quote 0
                                        Gismoh @Gismoh last edited by Gismoh
                                        Ansonsten die Schritte von Gestern abend noch mal durchgegangen, mit scheinbar selbem Ergebnis:
                                        idash@ioBrokerVM:/home/iobroker$ cd /
                                        idash@ioBrokerVM:/$ ls -lah /home/iobroker/.npm/_cacache
                                        insgesamt 12K
                                        drwxr-xr-x 3 iobroker iobroker 4,0K  9. Nov 14:38 .
                                        drwxr-xr-x 7 iobroker iobroker 4,0K  9. Nov 14:38 ..
                                        drwxr-xr-x 2 iobroker iobroker 4,0K  9. Nov 14:38 tmp
                                        idash@ioBrokerVM:/$ rm -rf /home/iobroker/.npm/_cacache/tmp
                                        rm: das Entfernen von '/home/iobroker/.npm/_cacache/tmp/a8c63b11' ist nicht möglich: Keine Berechtigung
                                        idash@ioBrokerVM:/$ sudo -u iobroker rm -rf /home/iobroker/.npm/_cacache/tmp
                                        idash@ioBrokerVM:/$ cd /home/iobroker
                                        idash@ioBrokerVM:~$ iobroker upgrade ble@0.13.4
                                        Adapter "ble"            is not installed.
                                        idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug
                                        NPM version: 9.8.1
                                        Installing iobroker.ble@0.13.4... (System call)
                                        npm ERR! code 1
                                        npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                                        npm ERR! command sh -c node-gyp-build
                                        npm ERR! gyp info it worked if it ends with ok
                                        npm ERR! gyp info using node-gyp@7.1.2
                                        npm ERR! gyp info using node@18.18.2 | linux | x64
                                        npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                                        npm ERR! (node:2039) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                                        npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
                                        npm ERR! gyp info spawn /usr/bin/python3
                                        npm ERR! gyp info spawn args [
                                        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                                        npm ERR! gyp info spawn args   'binding.gyp',
                                        npm ERR! gyp info spawn args   '-f',
                                        npm ERR! gyp info spawn args   'make',
                                        npm ERR! gyp info spawn args   '-I',
                                        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
                                        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                                        npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
                                        npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                                        npm ERR! gyp info spawn args   '-Dvisibility=default',
                                        npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
                                        npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                                        npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
                                        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
                                        npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                                        npm ERR! gyp info spawn args   '--depth=.',
                                        npm ERR! gyp info spawn args   '--no-parallel',
                                        npm ERR! gyp info spawn args   '--generator-output',
                                        npm ERR! gyp info spawn args   'build',
                                        npm ERR! gyp info spawn args   '-Goutput_dir=.'
                                        npm ERR! gyp info spawn args ]
                                        npm ERR! Traceback (most recent call last):
                                        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
                                        npm ERR!     sys.exit(gyp.script_main())
                                        npm ERR!              ^^^^^^^^^^^^^^^^^
                                        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
                                        npm ERR!     return main(sys.argv[1:])
                                        npm ERR!            ^^^^^^^^^^^^^^^^^^
                                        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
                                        npm ERR!     return gyp_main(args)
                                        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
                                        npm ERR!     [generator, flat_list, targets, data] = Load(
                                        npm ERR!                                             ^^^^^
                                        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
                                        npm ERR!     result = gyp.input.Load(
                                        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
                                        npm ERR!     LoadTargetBuildFile(
                                        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
                                        npm ERR!     build_file_data = LoadOneBuildFile(
                                        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
                                        npm ERR!     build_file_contents = open(build_file_path, "rU").read()
                                        npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
                                        npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
                                        npm ERR! gyp ERR! configure error
                                        npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
                                        npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
                                        npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
                                        npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                        npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
                                        npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                                        npm ERR! gyp ERR! node -v v18.18.2
                                        npm ERR! gyp ERR! node-gyp -v v7.1.2
                                        npm ERR! gyp ERR! not ok
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_48_08_783Z-debug-0.log
                                        npm ERR! code 1
                                        npm ERR!                                             ^^^^^
                                        host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                                          Homoran Global Moderator Administrators @Gismoh last edited by
                                          @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                                          https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/1
                                            Gismoh @Homoran last edited by Gismoh
                                            idash@ioBrokerVM:~$ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
                                            idash@ioBrokerVM:~$
                                            ausgeführt, mal sehen
                                            NPM version: 9.8.1
                                            npm ERR! code 1
                                            npm ERR! (node:2237) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                                            npm ERR!                                             ^^^^^
                                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T14_34_50_758Z-debug-0.log
                                            npm ERR! code 1
                                            npm ERR!                                             ^^^^^
                                            idash@ioBrokerVM:~$
                                            crunchip Homoran 2 Replies Last reply Reply Quote 0
                                            24447
