    • Armilar
      Armilar Most Active Forum Testing @JackONell last edited by
      @jackonell
      Ist bei mir so:
      let Unlock_Service = <PageUnlock>
          'type': 'cardUnlock',
          'heading': 'Service Pages',
          'useColor': true,
          'items': [<PageItem>{ id: 'alias.0.Unlock', targetPage: 'NSPanel_Service' }]
      //Level_0
      let NSPanel_Service = <PageEntities>
          'type': 'cardEntities',
          'heading': 'NSPanel Service',
          'subPage': true,
          'parent': Unlock_Service,
          'home': 'Unlock_Service',
          'useColor': true,
          'items': [
              <PageItem>{ navigate: true, id: 'NSPanel_Infos', icon: 'information-outline', offColor: Menu, onColor: Menu, name: 'Infos', buttonText: 'mehr...'},
              <PageItem>{ navigate: true, id: 'NSPanel_Einstellungen', icon: 'monitor-edit', offColor: Menu, onColor: Menu, name: 'Einstellungen', buttonText: 'mehr...'},
              <PageItem>{ navigate: true, id: 'NSPanel_Firmware', icon: 'update', offColor: Menu, onColor: Menu, name: 'Firmware', buttonText: 'mehr...'},
              <PageItem>{ id: AliasPath + 'Config.rebootNSPanel', name: 'Reboot NSPanel' ,icon: 'refresh', offColor: MSRed, onColor: MSGreen, buttonText: 'Start'},
          pages: [
                  // ... Diverse Seiten
                  Unlock_Service,
                  //NSPanel_Service         //Auto-Alias Service Page
          subPages: [
                      NSPanel_Service,         //Auto-Alias Service Page
                      NSPanel_Infos,                          //Auto-Alias Service Page
                          NSPanel_Wifi_Info_1,                //Auto-Alias Service Page
                          NSPanel_Wifi_Info_2,                //Auto-Alias Service Page
                          NSPanel_Sensoren,                   //Auto-Alias Service Page
                          NSPanel_Hardware,                   //Auto-Alias Service Page
                      NSPanel_Einstellungen,                  //Auto-Alias Service Page
                          NSPanel_Screensaver,                //Auto-Alias Service Page
                              NSPanel_ScreensaverDimmode,     //Auto-Alias Service Page
                              NSPanel_ScreensaverBrightness,  //Auto-Alias Service Page
                              NSPanel_ScreensaverLayout,      //Auto-Alias Service Page
                              NSPanel_ScreensaverWeather,     //Auto-Alias Service Page
                              NSPanel_ScreensaverDateformat,  //Auto-Alias Service Page
                              NSPanel_ScreensaverIndicators,  //Auto-Alias Service Page
                          NSPanel_Relays,                     //Auto-Alias Service Page
                          NSPanel_Script,                     //Auto-Alias Service Page
                      NSPanel_Firmware,                       //Auto-Alias Service Page
                          NSPanel_FirmwareTasmota,            //Auto-Alias Service Page
                          NSPanel_FirmwareBerry,              //Auto-Alias Service Page
                          NSPanel_FirmwareNextion,            //Auto-Alias Service Page
        Thomas Braun Most Active @Venice last edited by
        @venice sagte in SONOFF NSPanel mit Lovelace UI:
        *** nodejs is NOT correctly installed ***
        iob stop
        iob fix
        iob nodejs-update
        • V
          Venice @Armilar last edited by
          @armilar Ist mein System nicht aktuell ? Ich mache eigentlich immer alle updates mit . Was meinst du mit Fehler JS Adapter? Wenn ich das Script starte?
          Vielen Dank schonmal für die tolle Unterstützung.
          • V
            Venice @Thomas Braun last edited by
            Dass wird jetzt angezeigt.....
            Nothing to do - Your installation is using the correct paths.
            You are running nodejs v16.20.2. Do you want to install recommended version 18.18.2?
            Vielen Dank
            • Armilar
              Armilar Most Active Forum Testing last edited by Armilar
              @venice
              Sieht bis auf das bullseye und das NodeJS eigentlich ganz ordentlich aus... Drehe mal das NodeJS auf 18
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              iob stop
              iob fix
              iob iob nodejs-update 18
              iob start
              Wenn es dann läuft, solltest du dir im Forum eine Anleitung suchen, wie du von bullseye auf bookworm kommst.
                Ja, das willst du.
                Armilar V 2 Replies Last reply Reply Quote 1
                • Matthias 0
                  Matthias 0 last edited by
                  seit dem Update erhalte ich immer wiederkehrende Warnmeldungen im Log.
                  Kann mir jemend sagen, wie ich diese beseitigen kann?
                  javascript.0 (911) script.js.common.NS_Panels.Panel_Bad: error at function HandleScreensaverUpdate: parseFormat is not a function
                  Vielen Dank!
                  • Armilar
                    Armilar Most Active Forum Testing @Thomas Braun last edited by Armilar
                    @Venice
                    bei @Thomas-Braun hast du jetzt die perfekte Systemhilfe...
                    • Armilar
                      Armilar Most Active Forum Testing @Matthias 0 last edited by
                      @matthias-0
                      Die Frage beantworte ich etwa alle 12 Stunden:
                      https://forum.iobroker.net/post/1077067
                      Matthias 0 1 Reply Last reply Reply Quote 1
                      • Matthias 0
                        Matthias 0 @Armilar last edited by
                        @armilar
                        Vielen Dank für die erneute Antwort.
                        Leider ergab die suche nach der Fehlermeldung kein Ergebnis.
                        Viele Grüße
                        Armilar 1 Reply Last reply Reply Quote 1
                        • V
                          @thomas-braun Ja das habe ich mir schon gedacht und auch so durchgezogen. Jetzt habe ich 18.18 drauf. Weißt du wie ich jetzt von Bullseye auf Bookworm komme?
                          Ist das so Richtig?
                          sudo apt update && sudo apt full-upgrade -y
                          reboot
                          dann
                          apt-mark showhold
                          apt-mark unhold [Paketname]
                          jetzt umstellen auf Bookworm
                          sudo sed -i'.bak' 's/bullseye/bookworm/g' /etc/apt/sources.list
                          sudo apt update
                          sudo apt dist-upgrade
                          reboot
                          cat /etc/debian_version
                          • Armilar
                            @matthias-0
                            Aber gerne doch 😊
                            Wird sicherlich noch öfter kommen 😉
                              @venice
                              https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                              • V
                                @armilar Vielen Lieben Dank.
                                Das ist aktuell mein Fehler im log für das Script. Hast du da eine Idee?
                                script.js.NS_Panels.Panel_Erdgeschoss: TypeScript compilation failed: if ((pageItem.useColor || useColors) && ((typeof (value) === 'boolean' && value) || value > (pageItem.minValueBrightness !== undefined ? pageItem.minValueBrightness : 0))) { ^ERROR: Operator '>' cannot be applied to types 'number | boolean' and 'number'.
                                • Armilar
                                  Armilar Most Active Forum Testing @Venice last edited by Armilar
                                  @venice
                                  Ja, zwei Möglichkeiten, da TypeScript restriktiver geworden ist:
                                  Variante 1) TS-Script auf aktuelle Version updaten
                                  Variante 2) 3.9.0 behalten und folgende Zeile suchen:
                                              return rgb_dec565(pageItem.onColor !== undefined ? pageItem.onColor : config.defaultOnColor);
                                  dann mit:
                                          if ((pageItem.useColor || useColors) && (typeof (value) === 'boolean' && value) || ((typeof (value) === 'number') && (value > (pageItem.minValueBrightness !== undefined ? pageItem.minValueBrightness : 0)))) {
                                  ersetzen!
                                  ist ein Fix vom 12.08.2023
                                  https://github.com/joBr99/nspanel-lovelace-ui/commit/80a881c980cf2bf4421a8e8cab9d4435e354dccc
                                  0 Armilar committed to joBr99/nspanel-lovelace-ui
                                  Update 4.1.4.1 NsPanelTs.ts
                                  - 12.08.2023 - v4.1.4    Upgrade TFT 51 / 4.1.4
                                  - 12.08.2023 - v4.1.4.1  Fix Label CANCEL for popupTimer
                                  - 12.08.2023 - v4.1.4.1  Fix TypeScript Error (JS-Adapter > 7.1.X) by Gargano
                                  - 12.08.2023 - v4.1.4.1  CardGRid with maxItems = 8
                                  - Todo       - v4.1.4.2  Add InSel to popUpLight
                                  - Todo       - v4.1.4.2  Add onStop (function() to Schedules
                                    TT-Tom @JackONell last edited by
                                    @jackonell
                                    Hast du den Alias richtig angelegt, laut Wiki?
                                    Zeige mal bitte die Objekteinstellungen.
                                    • Armilar
                                      Armilar Most Active Forum Testing @TT-Tom last edited by
                                      @tt-tom
                                      @JackONell
                                      vermute auch, dass du bei der falschen Card gelandet bist:
                                      https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#cardunlock-ab-v400
                                        Mucky 0 @Armilar last edited by
                                        @armilar said in SONOFF NSPanel mit Lovelace UI:
                                        @mucky-0 sagte in SONOFF NSPanel mit Lovelace UI:
                                        wie und wo was genau eingetragen und angelegt werden muss....
                                        Kein Problem... dann etwas Starthilfe?
                                        Lege mal einen Datenpunkt unter 0_userdata.0... vom Typ JSON (und Name nach eigenen Vorstellungen oder PowerCard) an:
                                        Dann legst du einen Alias vom Gerätetyp "Info" über diesen Datenpunkt.
                                        In den Datenpunkt wirfst du erst einmal diesen Inhalt:
                                            "id": 0,
                                            "value": 13,
                                            "unit": "kW",
                                            "icon": "emoticon-happy-outline",
                                            "iconColor": 0
                                            "id": 1,
                                            "value": 3,
                                            "unit": "kW",
                                            "icon": "battery-charging-60",
                                            "iconColor": 10,
                                            "speed": 30
                                            "id": 2,
                                            "value": 4.7,
                                            "unit": "kW",
                                            "icon": "solar-power-variant",
                                            "iconColor": 3,
                                            "speed": -20
                                            "id": 3,
                                            "value": 4.3,
                                            "unit": "kW",
                                            "icon": "wind-turbine",
                                            "iconColor": 1,
                                            "speed": -30
                                            "id": 4,
                                            "value": 3.4,
                                            "unit": "kW",
                                            "icon": "shape",
                                            "iconColor": 10,
                                            "speed": 30
                                            "id": 5,
                                            "value": 0.1,
                                            "unit": "kW",
                                            "icon": "transmission-tower",
                                            "iconColor": 0,
                                            "speed": 20
                                            "id": 6,
                                            "value": 2.5,
                                            "unit": "kW",
                                            "icon": "car",
                                            "iconColor": 5,
                                            "speed": 20
                                        Damit sollte die cardPower schon etwas anzeigen...
                                        (Wieder Demo Modus ausschalten)
                                        let CardPowerExample = <PagePower>
                                            'type': 'cardPower',
                                            'heading': 'cardPower Emulator',
                                            'useColor': true,
                                            'items': [
                                                <PageItem>{ id: 'alias.0.NSPanel_1.Power.PowerCard' }, // an Deinen Alias anpassen
                                        //      <PageItem>{ }  // aktivieren für Demomodus der PowerCard, dafür ersten PageItem auskommentieren
                                        Danach kannst du auch die Werte aus diesem JSON verändern und verstehen, was die Parameter denn bewirken.
                                        Ziel ist es ein Blockly oder JS-Script zu erstellen, dass aus deinen Datenpunkten ein solches JSON erstellt...
                                        Es gibt auch ein Blockly als Beispiel: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/Blockly/CardPower_Emulator_Skript.xml
                                        Falls dann noch Fragen offen sind... dann gezielt mit deinen Datenpunkten und deinem Script zur Erstellung nachhaken...
                                        So den Datenpunkt "0_userdata.0.PowerCard" und den Alias "alias.0.PowerCard.PowerCard" habe ich angelegt und verbunden.
                                        Was mir jetzt noch nicht klar ist, die Rolle des Datenpunktes und des Alias ist auf "state" ist das richtig so oder muß das auch "json" und "info" sein?
                                        Und wo genau bzw. wie muß ich das json in den Datenpunkt einfügen?
                                        • Armilar
                                          Armilar Most Active Forum Testing @Mucky 0 last edited by Armilar
                                          @mucky-0
                                          Hast du den manuell erstellt? Das macht der Geräte-Manager automatisch... Für den Fall, dass: "Du solltest keine Aliase manuell per Hand anlegen... Das geht zu 99,99% schief"
                                          Das Script benutzt den Channel des Alias um die korrekte Rolle zu finden...
                                          Also immer schön nach der Wiki mit dem Gerätemanager konfigurieren... Auch keine lustigen Scripte aus dem Forum benutzen... die sind genauso bescheiden...
                                          Falls das alles passt, dann das komplette JSON in den Datenpunkt kippen
                                          nach deinen Informationen wäre es jetzt:
                                              'useColor': true,
                                              'items': [
                                                  <PageItem>{ id: 'alias.0.PowerCard.PowerCard' },
                                          P.S.: Die Rolle des Datenpunktes ist "state" und der Datentyp "json"
                                          Der Channel des Alias ist ein "Info"
                                          Im Geräte-Manager sollte das dann so aussehen:
                                          und unter alias.0... so:
                                          André Koschnik 1 Reply Last reply Reply Quote 0
                                          • André Koschnik
                                            André Koschnik @Armilar last edited by
                                            @armilar
                                            ja hab mir dazu ein eigendes js gebaut.
                                            Funktioniert auch alles. aber ich werde mal den datenpunkt noch mal auf die eigenschaften checken.
                                            1.0k
                                            lovelace ui nspanel sonoff
                                            271
                                            7725
                                            6652390
