    4. Test Adapter renault v0.0.x für myRenault und myDacia
      DPO99 last edited by
      Habe zzt. massive Probleme mit dem Adapter (keine Ahnung ob das an Renault liegt):
      Häufig dies:
      2023-10-11 05:02:43.315 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:12:43.315 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:12:49.314 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:12:56.475 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:13:02.429 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:32:43.277 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:32:49.244 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:32:54.440 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:33:00.376 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:33:07.039 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:42:43.248 - warn: renault.0 (1266) Renault Server error: 500
      2023-10-11 07:42:48.539 - warn: renault.0 (1266) Renault Server error: 500
      Heute dies:
      2023-10-12 05:00:00.746 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/XXX/battery-status?country=de
      2023-10-12 05:00:00.753 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
      2023-10-12 05:00:28.786 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/battery-inhibition-status?country=de
      2023-10-12 05:00:28.788 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
      2023-10-12 05:00:56.824 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/cockpit?country=de
      2023-10-12 05:00:56.825 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
      2023-10-12 05:01:15.863 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/XXX/cockpit?country=de
      2023-10-12 05:01:15.864 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
      2023-10-12 05:01:34.902 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/charge-mode?country=de
      2023-10-12 05:01:34.902 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
      2023-10-12 05:01:53.936 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/hvac-status?country=de
      2023-10-12 05:01:53.937 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
      2023-10-12 05:02:12.979 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/hvac-settings?country=de
      2023-10-12 05:02:12.979 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
      2023-10-12 05:02:32.014 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/charging-settings?country=de
      2023-10-12 05:02:32.015 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
      Beim Aufruf der API krieg ich im Browser diese Meldung:
      {"error":"missing_authorization","error_description":"Missing API Key header"}
        kohli-vie last edited by kohli-vie
        erledigt, hab wohl zuviel herumgelöscht etc gg
        nach dem erneuten anlernen des autos in der handy-app kommen jetzt die daten
        vielleicht hat jemand einen tip:
        ich habe unseren Dacia Spring nun eingebunden, adapter version 0.0.21
        anscheinend wird das fahrzeug grundsätzlich ja erkannt, es sind jede menge daten da.
        aber eigentlich nur konfigurationsdaten
        daten wie akkustand und so kommen keine
        ich habe den loglevel erhöht und zb folgende fehler gefunden (so axios fehler sind einige mehr):
        renault.0 2023-10-13 22:58:35.604 debug AxiosError: Request failed with status code 500
        renault.0 2023-10-13 22:58:35.604 info Feature not found for UU1xxx. Ignore charge-mode for updates.
        renault.0 2023-10-13 22:58:35.263 debug {"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"}
        renault.0 2023-10-13 22:58:35.263 debug AxiosError: Request failed with status code 500
        renault.0 2023-10-13 22:58:35.263 info Feature not found for UU1xxx. Ignore cockpitv2 for updates.
        renault.0 2023-10-13 22:58:34.933 debug {"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"}
        renault.0 2023-10-13 22:58:34.933 debug AxiosError: Request failed with status code 500
        renault.0 2023-10-13 22:58:34.933 info Feature not found for UU1xxx. Ignore cockpit for updates.
          Heute wieder massive Probleme:
          2023-10-21 15:29:03.916 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/xxxx/battery-status?country=de
          2023-10-21 15:29:03.918 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:29:25.950 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/battery-inhibition-status?country=de
          2023-10-21 15:29:25.950 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:29:47.981 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/cockpit?country=de
          2023-10-21 15:29:47.982 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:30:10.014 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/xxxx/cockpit?country=de
          2023-10-21 15:30:10.014 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:30:32.044 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charge-mode?country=de
          2023-10-21 15:30:32.045 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:30:54.077 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-status?country=de
          2023-10-21 15:30:54.077 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:31:10.102 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-settings?country=de
          2023-10-21 15:31:10.103 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:31:26.135 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charging-settings?country=de
          2023-10-21 15:31:26.136 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:31:48.166 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charges?start=1970-01-01&end=2023-10-21&country=de
          2023-10-21 15:31:48.166 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:32:10.201 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/location?country=de
          2023-10-21 15:32:10.201 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:49:06.919 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/xxxx/battery-status?country=de
          2023-10-21 15:49:06.920 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:49:34.955 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/battery-inhibition-status?country=de
          2023-10-21 15:49:34.955 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:50:02.992 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/cockpit?country=de
          2023-10-21 15:50:02.993 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:50:31.033 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/xxxx/cockpit?country=de
          2023-10-21 15:50:31.033 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:50:59.072 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charge-mode?country=de
          2023-10-21 15:50:59.073 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:51:27.109 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-status?country=de
          2023-10-21 15:51:27.109 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:51:55.144 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-settings?country=de
          2023-10-21 15:51:55.144 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:52:23.180 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charging-settings?country=de
          2023-10-21 15:52:23.180 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:52:51.255 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charges?start=1970-01-01&end=2023-10-21&country=de
          2023-10-21 15:52:51.256 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:53:19.290 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/location?country=de
          2023-10-21 15:53:19.291 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
          2023-10-21 15:54:06.731 - error: renault.0 (196348) refresh token failed
          2023-10-21 15:54:06.732 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN accounts.eu1.gigya.com
          2023-10-21 15:54:06.732 - error: renault.0 (196348) Start relogin in 1min
          2023-10-21 15:55:34.772 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN accounts.eu1.gigya.com
          2023-10-21 15:55:34.772 - error: renault.0 (196348) No session found for this account
          @tombox wird der Adapter noch supported?
            tombox @DPO99 last edited by
            @dpo99 Ja aber das sind server Fehler wenn die nicht dauerhaft auftreten bitte bei Renault beschweren
              DPO99 @tombox last edited by
              @tombox
              Das reicht mir als Antwort danke! 🙂 Wollte nur sichergehen, dass ich wirklich nichts dran ändern kann.
                @tombox
                Aktuell erhalte ich diese Fehler, was bedeutet das denn?
                renault.0 2023-11-08 13:52:36.968	error {"errors":[{"errorCode":"11.06.00.02","errorMessage":"Unable to find the default routing configuration."}],"error_reference":"rrt-07a88291a254fbd95-a-eu-18202-14547622-1"}
                renault.0 2023-11-08 13:52:36.967	error	AxiosError: Request failed with status code 500
                renault.0 2023-11-08 13:52:36.966	error	Error while getting account
                  HansJochen @DPO99 last edited by
                  @dpo99
                  Ich bekomme diese 500er Meldungen auch etwa stündlich, machmal auch 10 Mal in einer Minute. Ich habe die 0.21 von Github installiert, damit sind es keine Fehler, sondern Warnungen. Das eigentliche Problem mag bei Renault liegen - offenbar kommen die Meldungen ja von deren Server. Ich habe aber den Eindruck, dass trotz der ständigen Warnungen alle Änderungen auf Fahrzeugseite zeitnah im Adapter aktualisiert werden. @tombox, wenn der Server so unzuverlässig ist, reicht vielleicht auch eine Info anstatt einer Warnung. Bei der Gelegenheit: Danke für den coolen Adapter! Der ist so viel besser als dieser ganze App-Zirkus von Renault.
                    TheGulOfDedra last edited by
                    seit Samstag haben wir einen Kangoo III - 2023 mit easy link.
                    Bis gestern lief der Adapter 0.21 gut - ein wenig zeitverzögert - aber er lief.
                    Am Nachmittag hat er dann die Arbeit eingestellt - der Adapter wird grün angezeigt, aber die Daten kommen nicht. In der Renault App sind die Daten aktuell.
                    Im Log sehe ich keine Einträge für den Adapter.
                    Hat das noch jemand, gibt es etwas was ich beachten muss? Das Intervall stand auf 10 Minuten.
                    Vielen Dank für jeden Tipp
                      tombox @TheGulOfDedra last edited by
                      @thegulofdedra Einfach mal im debug log mode laufen lassen um zu sehen was der adapter bekommt
                        TheGulOfDedra @tombox last edited by
                        @tombox Habe ich - und nun - nun habe ich wieder Daten. Total seltsam... Gibt es ein Maximum pro Tag?
                          Also anscheinend hört der Adapter nachmittags auf zu funktionieren - war gestern Nachmittag wieder so - heute geht er einfach wieder.
                          Gibt es ein Limit an Anfragen pro Tag die das System "verträgt"? Der default Eintrag ist ja bei 10 Minuten - habe es nun mal auf 20 gestellt.
                            HansJochen @TheGulOfDedra last edited by
                            @thegulofdedra
                            Möglicherweise löst Du mit der App zu viele Anfragen aus. Ich rufe über den Adapter mit 10 Minuten Intervallen ab, das funktioniert bis auf die 500er Warnungen vom Server ohne Probleme. Die Daten kommen rund um die Uhr. Die App habe ich aber wieder deinstalliert. Ich hatte sie nur anfangs gebraucht, weil der Server sonst nur langweilige Daten geliefert hatte (den Kram unter general, aber beispielsweise nicht den battery-status).
                            • MichaelSc
                              MichaelSc last edited by
                              Die VIN unserer Megane sehe ich in den renault-Datenpunkten.
                              Aber beispielsweise den Kilometerstand / Mileage: Die steht auf irgendeinem alten Anfangswert.
                              Was kann man da tun?
                                tombox @MichaelSc last edited by
                                @michaelsc Sicher das du im korrekten Objekt nachschaust
                                • MichaelSc
                                  ja, @tombox, hier:
                                  Das ist die "neue Megane". VIN passt.
                                  Die Datenpunkte der "alten ZOE" stehen darüber, die ZOE haben wir aber abgegeben.
                                    @michaelsc bei general steht auch nicht Wird nicht aktualisiert eher unter cockpit schauen
                                    • MichaelSc
                                      "Cockpit"-Datenpunkte gibt es leider nicht, trotz Suche in den Objekten.
                                      Was kann ich tun?
                                        @michaelsc debug log via mail tombox2020@gmail.com
                                        MichaelSc 1 Reply Last reply Reply Quote 0
                                        • MichaelSc
                                          MichaelSc @tombox last edited by
                                          @tombox said in Test Adapter renault v0.0.x für myRenault und myDacia:
                                          thanks...
                                          • set log level to "debug" (formerly: error)
                                          • restart of adapter
                                          • extracted "renault"-lines from log
                                          • MichaelSc
                                            MichaelSc @MichaelSc last edited by MichaelSc
                                            @tombox: Mail returned error...
                                            " This mail has been blocked because the sender is unauthenticated."
                                            How to amend this?
                                            Während der Zustellung Ihrer Nachricht an diese E-Mail-Adresse ist ein Problem aufgetreten. Versuchen Sie, die Nachricht noch mal zu senden. Wenn das Problem weiterhin besteht, wenden Sie sich an Ihren E-Mail-Administrator.
                                            Die folgende Organisation hat Ihre Nachricht abgelehnt: gmail-smtp-in.l.google.com.
                                            T JLeg 2 Replies Last reply Reply Quote 0
                                            356
                                            46806
