    4. Backup wiederherstellen
      Thomas Braun Most Active @André Koschnik last edited by
      @andré-koschnik
      iob diag
      sagt?
      André Koschnik 1 Reply Last reply Reply Quote 0
      • André Koschnik
        André Koschnik @André Koschnik last edited by André Koschnik
        postgresql.conf
        pg_hba.conf
        status postgres
        • André Koschnik
          André Koschnik @Thomas Braun last edited by
          @thomas-braun said in Backup wiederherstellen:
          iob diag
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi6-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           12:30:07 up 22:12,  5 users,  load average: 0.90, 0.89, 0.75
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Thu 2023-11-09 12:30:07 CET
                     Universal time: Thu 2023-11-09 11:30:07 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.0G        2.3G        507M         23M        1.3G        1.7G
          Swap:           104M        5.5M         99M
          Total:          4.1G        2.3G        606M
                   3792 M total memory
                   2192 M used memory
                   2221 M active memory
                    829 M inactive memory
                    483 M free memory
                     26 M buffer memory
                   1187 M swap cache
                     99 M total swap
                      5 M used swap
                     94 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
            UNIT                       LOAD   ACTIVE SUB    DESCRIPTION
          * postgresql@13-main.service loaded failed failed PostgreSQL Cluster 13-main
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                              Type      Size  Used Avail Use% Mounted on
          udev                                    devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs                                   tmpfs     380M  1.4M  378M   1% /run
          /dev/sda2                               ext4      235G  7.7G  215G   4% /
          tmpfs                                   tmpfs     1.9G  4.3M  1.9G   1% /dev/shm
          tmpfs                                   tmpfs     5.0M   16K  5.0M   1% /run/lock
          /dev/sda1                               vfat      510M   73M  438M  15% /boot/firmware
          tmpfs                                   tmpfs     380M   36K  380M   1% /run/user/1000
          //192.168.100.2/share/ioBrokerbackupDir cifs      5.4T  2.3T  3.2T  42% /opt/iobroker/backups
          [Wed Nov  8 14:17:42 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:54:39:F9 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=20713d2e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Nov  8 14:17:46 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Nov  8 14:17:48 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET                              SOURCE                                  FSTYPE      OPTIONS
          /                                   /dev/sda2                               ext4        rw,noatime
          |-/run/user/1000/doc                portal                                  fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          |-/boot/firmware                    /dev/sda1                               vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          `-/opt/iobroker/backups             //192.168.100.2/share/ioBrokerbackupDir cifs        rw,relatime,vers=3.1.1,cache=strict,username=iobroker,domain=leevan.de,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.100.2,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
            `-/opt/iobroker/backups           //192.168.100.2/share/ioBrokerbackupDir cifs        rw,relatime,vers=1.0,cache=strict,username=iobroker,domain=leevan.de,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.100.2,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
          /var:
          890M    /var/
          463M    /var/cache
          454M    /var/cache/apt
          340M    /var/cache/apt/archives
          248M    /var/lib
          Archived and active journals take up 48.0M in the file system.
          /opt/iobroker/backups:
          11G     /opt/iobroker/backups/
          9.2G    /opt/iobroker/backups/1/iobroker/iobroker-tar-backup-20230129-122153
          84M     /opt/iobroker/backups/iobroker_2023_03_06-02_40_21_backupiobroker.tar
          /opt/iobroker/iobroker-data:
          255M    /opt/iobroker/iobroker-data/
          171M    /opt/iobroker/iobroker-data/files
          52M     /opt/iobroker/iobroker-data/files/javascript.admin
          45M     /opt/iobroker/iobroker-data/files/devices.admin/static
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          27M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.eafddf6f.js.map
          8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.eafddf6f.js
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_36651404c719ec11b22276e5f01c6278-if00-port0
          /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0037-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.5.1
          /usr/bin/node           v20.5.1
          /usr/bin/npm            9.8.0
          /usr/bin/npx            9.8.0
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 20.5.1-deb-1nodesource1
            Candidate: 20.5.1-deb-1nodesource1
            Version table:
           *** 20.5.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_20.x bookworm/main arm64 Packages
                  100 /var/lib/dpkg/status
               18.13.0+dfsg1-1 500
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! missing: moment-parseformat@^4.0.0, required by iobroker.javascript@7.1.4
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-09T11_30_15_066Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.12.0
          javascript:     7.1.4
          Adapters from github:   1
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 - disabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
            system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
          + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled
          + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
          + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
          + system.adapter.meater.0                 : meater                : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
          + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
          + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
            system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 5432
          + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          + system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
          + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
          Adapter    "go-e"         : 1.0.27   , installed 1.0.28
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
          Adapter    "meater"       : 1.0.2    , installed 1.0.2
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "parser"       : 1.3.2    , installed 1.3.2
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
          Adapter    "socketio"     : 6.5.5    , installed 6.5.7
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "web"          : 6.1.4    , installed 6.1.4
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "worx"         : 2.3.4    , installed 2.3.4
          Adapter    "ws"           : 2.5.5    , installed 2.5.7
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
          Objects and States
          Objects:        12144
          States:         9183
          W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
          W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
          W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
          W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://packages.grafana.com/oss/deb stable InRelease
          Hit:6 https://deb.nodesource.com/node_20.x bookworm InRelease
          Hit:7 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1938       819/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        19800      1452/pihole-FTL
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          19860      1470/lighttpd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19044      789/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14231      789/iobroker.js-con
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          356850     63306/cupsd
          tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        19806      1452/pihole-FTL
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21150      2537/io.mqtt.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       609835     106360/node-red
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1940       819/sshd: /usr/sbin
          tcp6       0      0 :::53                   :::*                    LISTEN      999        19802      1452/pihole-FTL
          tcp6       0      0 :::80                   :::*                    LISTEN      0          19859      1470/lighttpd
          tcp6       0      0 ::1:4711                :::*                    LISTEN      999        19807      1452/pihole-FTL
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          356849     63306/cupsd
          tcp6       0      0 :::3000                 :::*                    LISTEN      112        133357     24886/grafana
          tcp6       0      0 :::8091                 :::*                    LISTEN      1001       25648      2944/io.lovelace.0
          tcp6       0      0 :::8090                 :::*                    LISTEN      1001       631380     106360/node-red
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       25985      3106/io.terminal.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       215821     39107/io.admin.0
          tcp6       0      0 :::2011                 :::*                    LISTEN      1001       629991     106360/node-red
          tcp6       0      0 :::2010                 :::*                    LISTEN      1001       629973     106360/node-red
          tcp6       0      0 :::2009                 :::*                    LISTEN      1001       629975     106360/node-red
          tcp6       0      0 :::2008                 :::*                    LISTEN      1001       629977     106360/node-red
          tcp6       0      0 :::2007                 :::*                    LISTEN      1001       629989     106360/node-red
          tcp6       0      0 :::2006                 :::*                    LISTEN      1001       629987     106360/node-red
          tcp6       0      0 :::2005                 :::*                    LISTEN      1001       629985     106360/node-red
          tcp6       0      0 :::2004                 :::*                    LISTEN      1001       629983     106360/node-red
          tcp6       0      0 :::2003                 :::*                    LISTEN      1001       629979     106360/node-red
          tcp6       0      0 :::2002                 :::*                    LISTEN      1001       631382     106360/node-red
          tcp6       0      0 :::2001                 :::*                    LISTEN      1001       631384     106360/node-red
          tcp6       0      0 :::2000                 :::*                    LISTEN      1001       629981     106360/node-red
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          356185     63324/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13697      603/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       629993     106360/node-red
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       629992     106360/node-red
          udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        19799      1452/pihole-FTL
          udp        0      0 0.0.0.0:55396           0.0.0.0:*                           104        13699      603/avahi-daemon: r
          udp6       0      0 fe80::f4dc:1a48:40a:546 :::*                                0          17893      756/NetworkManager
          udp6       0      0 :::47665                :::*                                104        13700      603/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        13698      603/avahi-daemon: r
          udp6       0      0 :::53                   :::*                                999        19801      1452/pihole-FTL
          2023-11-09 12:12:45.260  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:14:02.441  - info: smartmeter.0 (2697) Received 351 values, 1 updated
          2023-11-09 12:15:19.701  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:16:37.058  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:17:54.089  - info: smartmeter.0 (2697) Received 351 values, 4 updated
          2023-11-09 12:19:11.274  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:20:28.407  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:21:45.645  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:22:03.305  - info: admin.0 (39107) ==> Connected system.user.admin from ::ffff:192.168.100.241
          2023-11-09 12:22:26.668  - info: admin.0 (39107) ==> Connected system.user.admin from ::ffff:192.168.100.241
          2023-11-09 12:22:28.653  - info: admin.0 (39107) ==> Connected system.user.admin from ::ffff:192.168.100.241
          2023-11-09 12:22:28.994  - info: zigbee.0 (2757) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"36651404c719ec11b22276e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_36651404c719ec11b22276e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0037","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0037-if00-port0","vendorId":"10c4","productId":"ea60"}]
          2023-11-09 12:23:02.860  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:23:28.510  - error: zigbee.0 (2757) Send command to 0xa4c138ab4e1a5a57 failed with no error code (undefined)
          2023-11-09 12:23:49.390  - error: zigbee.0 (2757) Send command to 0xa4c138aadf131aa8 failed with no error code (undefined)
          2023-11-09 12:23:52.068  - error: zigbee.0 (2757) Send command to 0xa4c138aadf131aa8 failed with no error code (undefined)
          2023-11-09 12:23:55.604  - error: zigbee.0 (2757) Send command to 0xa4c138ab4e1a5a57 failed with no error code (undefined)
          2023-11-09 12:24:20.139  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:24:59.312  - info: admin.0 (39107) <== Disconnect system.user.admin from ::ffff:192.168.100.241
          2023-11-09 12:25:00.815  - info: admin.0 (39107) ==> Connected system.user.admin from ::ffff:192.168.100.241
          2023-11-09 12:25:37.319  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:26:54.526  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:28:11.561  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:29:28.694  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          2023-11-09 12:30:45.784  - info: smartmeter.0 (2697) Received 351 values, 2 updated
          iob diag has finished.
          Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
          • Codierknecht
            Codierknecht Developer Most Active @André Koschnik last edited by
            @andré-koschnik
            1. Deine Versionen von Node und NPM passen nicht zusammen
            2. Node 20 ist nicht die empfohlene Version
            3. 4 GB RAM sind reichlich knapp
              Das Backup braucht jede Menge RAM
            4. Kleinigkeit: graphical.target .... Reste eines Desktop?
              Das sollte multi-user.target sein
            • André Koschnik
              André Koschnik @Codierknecht last edited by André Koschnik
              @codierknecht said in Backup wiederherstellen:
              gibt es eine einfache möglichkeit auf die empfolen version zu gehen ohne das ich mir bei der hilfe von googel wieder alles zerschieße?
              sorry was meinst du? ist das das falsche OS für den iob auf dem rasbi.
                Thomas Braun Most Active @André Koschnik last edited by Thomas Braun
                @andré-koschnik sagte in Backup wiederherstellen:
                Installier nodejs@18
                iob stop
                iob fix
                iob nodejs-update
                Und was veranstaltest du mit der Freigabe bitte?
                Siebenmal übereinander gestapelt? Macht gar keinen Sinn, bzw. ist falsch.
                André Koschnik 2 Replies Last reply Reply Quote 0
                • André Koschnik
                  das ist mein share zu meinem NAS für das iobroker backup
                  • Codierknecht
                    Codierknecht Developer Most Active @André Koschnik last edited by Codierknecht
                    Was Du bei Tante Gurgel so alles findest, ist meisten veraltet und/oder falsch.
                    Schau in die Signatur von @Thomas-Braun
                    Nein. Musst Du nur umstellen.
                    sudo systemctl set-default multi-user.target
                      Aber das hängt man nicht 7x übereinander.
                      • André Koschnik
                        keine ahnung wo das 7 mal herkommt
                          Ich auch nicht.
                          Vor allen dingen mit unterschiedlichen mount-Optionen. Hast du das in der fstab eingetragen?
                          cat /etc/fstab
                          • André Koschnik
                            cat /etc/fstab
                            den befehl kenne ich nicht
                              Homoran Global Moderator Administrators @André Koschnik last edited by
                              @andré-koschnik keinen abgeschnittenen Screenshot, sondern Text in code-tags!
                              klappt aber
                              • André Koschnik
                                node.js ist gefixed
                                  @andré-koschnik
                                  Dann mountest du das von Hand?
                                  Und/oder mit dem Backitup-Adapter? Wobei ich das von dem noch nie gesehen habe, der mountet und umountet nämlich vorher und nachher.
                                  • André Koschnik
                                    André Koschnik @Thomas Braun last edited by André Koschnik
                                    nein
                                    aber der backup adapter, ist beim backup wiederherstellen ein paar abgebrochen. Evlt. deshalb die mehrfachen mounts.
                                    die sind aber nach einem neustart wieder weg oder?
                                      Homoran Global Moderator Administrators @André Koschnik last edited by Homoran
                                      nein!
                                      wenn da bereits ein mount existiert gibt's ne Fehlermeldung und nichts passiert.
                                      Auf keinen Fall wird "drübergemountet"
                                      wieso gibt es keinen port der auf 5432 hört?
                                      ich komme mit dem PG admin von anderen rechner an die db
                                      was ist das denn jetzt wieder?
                                        Sollte...
                                        Oder
                                        sudo umount /opt/iobroker/backups
                                        • André Koschnik
                                          André Koschnik @Homoran last edited by
                                          OK muss ich das beheben?wenn ja wie?
                                          und
                                          ich komme mit dem PG admin von anderen rechnern an die db
                                          und kann ich das backfile der postgres per pg admin einspielen.
                                          Das SQL Script was sich darin verbirgt kann ich nicht im PG admin ausführen.
                                          danke schon mal für eure unterstützung
                                            @thomas-braun sagte in Backup wiederherstellen:
                                            Sollte...
                                            Oder
                                            das hat doch nichts mit iobroker zu tun!
                                            oder?
                                            8125
