    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    • Frederik Buss
      Frederik Buss @DJMarc75 last edited by
      @djmarc75 Genau das wollte ich ja vermeiden... Falls das Format geändert wird, fange ich wieder an. Aber ja, wenns nicht anders geht, werde ich das wohl so machen.
      • Boronsbruder
        Boronsbruder last edited by
        Bei mir hat vorhin der Adapter folgenden Fehler ausgespuckt, ist dann aber von selbst ohne Probleme neugestartet.
        Ich weiß nicht, ob das wichtig oder interessant ist...
        2023-11-04 16:12:29.540 - error: parcel.0 (12430) refresh token failed
        2023-11-04 16:12:29.544 - error: parcel.0 (12430) Error: getaddrinfo EAI_AGAIN login.dhl.de
        2023-11-04 16:12:29.544 - error: parcel.0 (12430) Start relogin in 1min
        2023-11-04 16:13:46.255 - info: parcel.0 (12430) Login to DHL
        2023-11-04 16:13:47.533 - warn: parcel.0 (12430) Please enter undefined code in instance settings and press save
        2023-11-04 16:13:47.535 - error: parcel.0 (12430) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-11-04 16:13:47.536 - error: parcel.0 (12430) unhandled promise rejection: undefined is not a valid state value
        2023-11-04 16:13:47.701 - error: parcel.0 (12430) Error: undefined is not a valid state value
        at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
        at Parcel._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7594:26)
        at Parcel.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7552:21)
        at /opt/iobroker/node_modules/iobroker.parcel/main.js:535:16
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
        at Parcel.loginDHL (/opt/iobroker/node_modules/iobroker.parcel/main.js:508:7)
        2023-11-04 16:13:47.702 - error: parcel.0 (12430) undefined is not a valid state value
        2023-11-04 16:13:47.717 - info: parcel.0 (12430) terminating
        2023-11-04 16:13:47.718 - warn: parcel.0 (12430) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-11-04 16:13:48.219 - info: parcel.0 (12430) terminating
        2023-11-04 16:13:48.970 - error: host.zerobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2023-11-04 16:13:48.971 - error: host.zerobroker Caught by controller[1]: Error: undefined is not a valid state value
        2023-11-04 16:13:48.971 - error: host.zerobroker Caught by controller[1]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
        2023-11-04 16:13:48.971 - error: host.zerobroker Caught by controller[1]: at Parcel._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7594:26)
        2023-11-04 16:13:48.971 - error: host.zerobroker Caught by controller[1]: at Parcel.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7552:21)
        2023-11-04 16:13:48.971 - error: host.zerobroker Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.parcel/main.js:535:16
        2023-11-04 16:13:48.971 - error: host.zerobroker Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
        2023-11-04 16:13:48.972 - error: host.zerobroker Caught by controller[1]: at Parcel.loginDHL (/opt/iobroker/node_modules/iobroker.parcel/main.js:508:7)
        2023-11-04 16:13:48.972 - error: host.zerobroker instance system.adapter.parcel.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-11-04 16:13:48.972 - info: host.zerobroker Restart adapter system.adapter.parcel.0 because enabled
          tombox @Boronsbruder last edited by
          Der Adapter 0.2.0 kann wieder Briefankündigung anzeigen bitte mal testen
            bommel_030 @tombox last edited by
            @tombox
            Meinst du das Bild der Briefankündigung? Aktuell ein Brief im Zulauf, aber image_url und thumbnail_url laufen ins Leere.
              tombox @bommel_030 last edited by
              @bommel_030 die url gehen nicht direkt nur das image Objekt aber es scheint so als wäre die 0.2.x nicht richtig installiert
                @tombox
                Ein Updatezyklus später (Intervall 30 min) kommt die Briefankündigung mit Bild per Telegram rein und unter image steht data:image statt data:application
                Läuft wieder, Danke!
                Olli_M 1 Reply Last reply Reply Quote 0
                  LibertyX82 last edited by
                  Bei jedem Abruf gibt es folgenden Fehler
                  • Rene55
                    Rene55 @tombox last edited by Rene55
                    @tombox Auch gestern die 0.2.0 installiert - heute waren direkt zwei Briefe in der Briefankündigung drin. Klasse!
                    NACHTRAG: Auch ich hab die Warnung (siehe @LibertyX82). Einen so lautenden Datenpunkt habe ich in parcel.0.dhl.json und ist mit neuen Daten befüllt. Möglicherweise nur eine Kleinigkeit.
                      tombox @LibertyX82 last edited by
                      @libertyx82 die GitHub version sollte das nicht mehr anzeigen oder?
                        LibertyX82 @tombox last edited by
                        @tombox
                        Hab die 0.2.1 von GitHub installiert
                        • Ro75
                          Ro75 last edited by Ro75
                          Seit heute taucht bei mir im Log wieder auf:
                          Unknown Error: Login to Amazon failed, please login to Amazon and check your credentials
                          Logindaten + 2FA schon neu eingegeben. Cookies auch mal gelöscht. Zwischendurch geht es wieder mal und dann kommt aller 10 Minuten (eingestellter Wert) die Meldung. Im Moment läuft bei mir die 0.2.1.
                          Der Adapter wird dann auch immer wieder "gelb".
                          Ro75.
                          Chris76e Ro75 3 Replies Last reply Reply Quote 0
                          • Chris76e
                            Chris76e @Ro75 last edited by
                            @ro75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                            bei mir genauso
                            • Olli_M
                              Olli_M @bommel_030 last edited by
                              @bommel_030
                              Hi wie hast du das gemacht dass dein Bild an telegram übergeben wird ? Blockly ?
                                @olli_m
                                Einfach nur in den Instanzeinstellungen Telegramm als Benachrichtigung gewählt
                                • Ro75
                                  Ro75 @Ro75 last edited by
                                  Ich habe heute "Sentry" für den Adapter deaktiviert und ich habe bisher keine Fehler mehr. Wer also gleiche Probleme hat - ein Versuch sollte es Wert sein.
                                  Ro75.
                                  Chris76e 1 Reply Last reply Reply Quote 0
                                  • Chris76e
                                    Wo kann man das einstellen?
                                    Ro75 1 Reply Last reply Reply Quote 0
                                    • Ro75
                                      Ro75 @Chris76e last edited by
                                      @chris76e wollte dir gerade die Details geben und... Das Problem ist immer noch da. Das war es also nicht.
                                      Ro75.
                                      • Chris76e
                                        @ro75 OK
                                        • Ro75
                                          Ro75 last edited by
                                          @tombox kannst du dir bitte das mal ansehen. 0.2.1 und Amazon Login Probleme.
                                          Ro75.
                                            tombox @Ro75 last edited by
                                            @ro75 Taucht nur bei MFA accounts auf?
                                            B Chris76e Xsev W 4 Replies Last reply Reply Quote 0
                                            81.1k
                                            17track amazon briefe dhl dpd gls ups
                                            123
                                            1537
                                            534943
