    5. json datei für Chart aus vorhandenen DP's erstellen
    • mickym
      mickym Most Active @dos1973 last edited by mickym
      @dos1973 So der Flow ist simple
      Du musst nur das übergeordnete Verzeichnis in Deine List Node eintragen:
      Also wie auf dem Bild unten siehst Du ja dass ich bei den Objekten ein Verzeichnis dos-1973 erstellt habe.
      Hier der Flow:
             "id": "7f416d63e5ece5a5",
             "type": "ioBroker list",
             "z": "5a7d3179c5870381",
             "name": "",
             "topic": "0_userdata.0.Test.dos-1973.*",
             "objType": "state",
             "regex": "",
             "asArray": "true",
             "onlyIDs": "false",
             "withValues": "true",
             "x": 360,
             "y": 940,
             "wires": [
                     "bd4ad0d8a225e159"
             "id": "f297aa12a709d590",
             "type": "inject",
             "name": "Trigger",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "",
             "payloadType": "date",
             "x": 150,
             "y": 940,
             "wires": [
                     "7f416d63e5ece5a5"
             "id": "bd4ad0d8a225e159",
             "type": "change",
             "name": "Analyse",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload.{\"axisLabels\":$contains(_id,\"Datum\") ? val,\"data\": $contains(_id,\"Verbrauch\") ? val}",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 580,
             "y": 940,
             "wires": [
                     "86fca619786d1e49"
             "id": "86fca619786d1e49",
             "type": "change",
             "name": "Erstelle Graph",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "{\t   \"axisLabels\":payload.axisLabels,\t   \"graphs\":[\t       {\t           \"type\":\"line\",\t           \"data\":payload.data,\t           \"yAxis_id\":0,\t           \"yAxis_zeroLineWidth\":0.1,\t           \"yAxis_zeroLineColor\":\"black\",\t           \"barIsStacked\":true,\t           \"line_pointSize\":0,\t           \"line_Thickness\":4,\t           \"datalabel_show\":true,\t           \"datalabel_maxDigits\":2,\t           \"datalabel_minDigits\":2,\t           \"datalabel_fontFamily\":\"OpenSans-CondLight\",\t           \"datalabel_fontSize\":16,\t           \"datalabel_borderRadius\":6,\t           \"datalabel_offset\":-10,\t           \"datalabel_backgroundColor\":\"#3E4765\",\t           \"datalabel_color\":\"#f5f5f5\",\t           \"color\":\"#ff9900\",\t           \"line_UseFillColor\":false,\t           \"yAxis_gridLines_show\":false,\t           \"use_gradient_color\":true,\t           \"gradient_color\":[\t               {\"value\":8.5,\"color\":\"#d43e3a\"},\t               {\"value\":6,\"color\":\"#ff9900\"},\t               {\"value\":3,\"color\":\"#4f6765\"}\t           ],\t           \"yAxis_appendix\":\" kw/h\"\t       },\t       {\t           \"type\":\"bar\",\t           \"barIsStacked\":true,\t           \"data\":payload.data,\t           \"yAxis_id\":0,\t           \"barStackId\":0,\t           \"datalabel_show\":false,\t           \"color\":\"#000000\",\t           \"datalabel_color\":\"#FFFFFF\",\t           \"datalabel_align\":\"start\",\t           \"use_gradient_color\":true,\t           \"yAxis_show\":false,\t           \"yAxis_min\":0,\t           \"yAxis_maxSteps\":4,\t           \"yAxis_gridLines_border_show\":false,\t           \"yAxis_gridLines_ticks_show\":false,\t           \"yAxis_gridLines_show\":false,\t           \"gradient_color\":[\t               {\"value\":9.1,\"color\":\"#ED97A8\"},\t               {\"value\":5.5,\"color\":\"#F3D8A5\"},\t               {\"value\":-5,\"color\":\"#7CA27E\"}\t           ]\t       }\t   ]\t}",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 760,
             "y": 940,
             "wires": [
                     "f1e2f69ae8e15d75"
             "id": "f1e2f69ae8e15d75",
             "type": "debug",
             "name": "fertig",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 950,
             "y": 940,
             "wires": []
      Ich werde diese Blockly-Quälerei NIE verstehen!!!!
        dos1973 @mickym last edited by
        @mickym
        moment, ich schau mal...
        • mickym
          @dos1973
          Wenn Du den flow triggerst (also die Inject Node drückst) brauchst ja nur den Wert raus zu kopieren, um zu sehen, ob es passt
          Wenn Du das ganze in einem Datenpunkt haben willst - einfach noch eine JSON Node und eine iobroker-Out Node dahinter machen. Falls Du es über einen Datenpunkt triggern willst - zum Beispiel über VIS dann halt noch eine iobroker-IN Node mit dem Datenpunkt triggern.
            @mickym
            scheint zu passen. wenn ich das manuell in den DP kopiere siehts gut aus.
            • mickym
              @dos1973 sagte in json datei für Chart aus vorhandenen DP's erstellen:
              @mickym
              Na dann ist ja alles gut - dann kann ich meine Datenpunkte zum Testen und den Flow wieder löschen? Oder brauchst Du noch Hilfe zum externen triggern und um das Objekt in einem Datenpunkt zu schreiben?
                dos1973 @mickym last edited by dos1973
                @mickym
                warte noch mit löschen 🙂
                • mickym
                  @dos1973 Wenn Du was am Graphen ändern willst, dann kannst Du das direkt einfach in der 2. Change Node machen:
                  also Farben oder was Du sonst noch so einstellen willst.
                    @mickym
                    puhh... ich schaffs nicht den kram in den DP zu schreiben. irgendwas mache ich, aber es zerschiesst mir dann den chart
                    • mickym
                      @dos1973 keine Ahnung was Du machst - wenn es mit direktem kopieren geklappt hat:
                      einfach nur eine JSON und eine iobroker-Out Node dranhängen:
                             "id": "2de45b53a28dc5d2",
                             "type": "json",
                             "name": "",
                             "property": "payload",
                             "action": "",
                             "pretty": false,
                             "x": 950,
                             "y": 600,
                             "wires": [
                                     "da9c29a8ea6ad983"
                             "id": "da9c29a8ea6ad983",
                             "type": "ioBroker out",
                             "name": "",
                             "topic": "0_userdata.0.Test.dos-1973.Graph",
                             "ack": "true",
                             "autoCreate": "false",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "readonly": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 1200,
                             "y": 600,
                             "wires": []
                      Dann hast Du doch ein JSON Objekt in Deinem iobroker Datenpunkt?
                        @mickym
                        deins geht auch nicht
                        • mickym
                          @dos1973 Was geht denn nicht? Siehst Du keinen JSON? Ist an dem was verkehrt ? Ich hab den JSON genommen, den Du am Anfang gepostet hast und Du hast doch gerade gesagt, wenn Du den Wert manuell kopierst geht das.
                          Hast Du den Datenpunkt auch auf String oder JSON eingestellt?
                            @mickym
                            ja, das stimmt. wenn ich es aus dem dem debug kopiere gehts.
                            wenn ich es über node red triggere gehts nicht.
                            das steht dann im DP - da fehlen die daten und datum
                            {"graphs":[{"type":"line","yAxis_id":0,"yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","barIsStacked":true,"line_pointSize":0,"line_Thickness":4,"datalabel_show":true,"datalabel_maxDigits":2,"datalabel_minDigits":2,"datalabel_fontFamily":"OpenSans-CondLight","datalabel_fontSize":16,"datalabel_borderRadius":6,"datalabel_offset":-10,"datalabel_backgroundColor":"#3E4765","datalabel_color":"#f5f5f5","color":"#ff9900","line_UseFillColor":false,"yAxis_gridLines_show":false,"use_gradient_color":true,"gradient_color":[{"value":8.5,"color":"#d43e3a"},{"value":6,"color":"#ff9900"},{"value":3,"color":"#4f6765"}],"yAxis_appendix":" kw/h"},{"type":"bar","barIsStacked":true,"yAxis_id":0,"barStackId":0,"datalabel_show":false,"color":"#000000","datalabel_color":"#FFFFFF","datalabel_align":"start","use_gradient_color":true,"yAxis_show":false,"yAxis_min":0,"yAxis_maxSteps":4,"yAxis_gridLines_border_show":false,"yAxis_gridLines_ticks_show":false,"yAxis_gridLines_show":false,"gradient_color":[{"value":9.1,"color":"#ED97A8"},{"value":5.5,"color":"#F3D8A5"},{"value":-5,"color":"#7CA27E"}]}]}
                            • mickym
                              @dos1973 na das ist doch klar - wenn das aus dem Debug kommt - dann ist es ja auch ein JSON - ein Objekt in dem Datenpunkt ist es aber nur ein String - den musst Du wieder zum Objekt wandeln.
                              Bei mir fehlt das nicht:
                              Wenn ich den Wert aus den iobroker-Objekten kopiere - ist alles da:
                              {"axisLabels":["30.10.","31.10.","01.11.","02.11.","03.11.","04.11.","05.11.","06.11.","07.11.","08.11."],"graphs":[{"type":"line","data":[9.489,7.709,5.883,7.404,5.454,6.69,9.776,7.608,6.662,7.655],"yAxis_id":0,"yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","barIsStacked":true,"line_pointSize":0,"line_Thickness":4,"datalabel_show":true,"datalabel_maxDigits":2,"datalabel_minDigits":2,"datalabel_fontFamily":"OpenSans-CondLight","datalabel_fontSize":16,"datalabel_borderRadius":6,"datalabel_offset":-10,"datalabel_backgroundColor":"#3E4765","datalabel_color":"#f5f5f5","color":"#ff9900","line_UseFillColor":false,"yAxis_gridLines_show":false,"use_gradient_color":true,"gradient_color":[{"value":8.5,"color":"#d43e3a"},{"value":6,"color":"#ff9900"},{"value":3,"color":"#4f6765"}],"yAxis_appendix":" kw/h"},{"type":"bar","barIsStacked":true,"data":[9.489,7.709,5.883,7.404,5.454,6.69,9.776,7.608,6.662,7.655],"yAxis_id":0,"barStackId":0,"datalabel_show":false,"color":"#000000","datalabel_color":"#FFFFFF","datalabel_align":"start","use_gradient_color":true,"yAxis_show":false,"yAxis_min":0,"yAxis_maxSteps":4,"yAxis_gridLines_border_show":false,"yAxis_gridLines_ticks_show":false,"yAxis_gridLines_show":false,"gradient_color":[{"value":9.1,"color":"#ED97A8"},{"value":5.5,"color":"#F3D8A5"},{"value":-5,"color":"#7CA27E"}]}]}
                                @mickym
                                wo holst/ liest du denn die DP ein?
                                • mickym
                                  @dos1973 Mit der list Node - lese ich alles ein, was darunter ist und am einlesen liegt es doch nicht, sonst würdest Du im Debug Fenster doch nicht das gesamte Objekt mit den Daten sehen. Wenn Du hier alles siehst - dann ist doch alles eingelesen:
                                    @mickym
                                    aber du sagst doch irgendwoe - lese datum-1, datum-2.... wo passiert das.
                                    hier braucht es meinen ordner wo die ganzen DP drunter liegen, korrekt?
                                    mickym 3 Replies Last reply Reply Quote 0
                                    • mickym
                                      @dos1973 Nein das mache ich nicht - Wenn das alles unter einem Ast ist - werden sämtliche Datenpunkte gelesen mit der List. Node. Über das Sternchen werden ALLE Datenpunkte gelesen.
                                      Wenn Du eine Debug Node hinter der List NODE machst siehst Du ALLE Datenpunkte!!!
                                      Wie gesagt Du würdest im Debug Fenster nicht sehen!
                                      • mickym
                                        @dos1973 Ja den gesamten übergeordneten Pfad.
                                        • mickym
                                          @dos1973 Wie gesagt wenn im Debug FENSTER Alles drin Ist, dann ist ALLES eingelesen - ich habe nirgendwo manuell Datumsangaben in dem Flow versteckt.
                                            @mickym
                                            ich hab da ja mehr als 10 Tage drin...
                                            3174
