    5. json datei für Chart aus vorhandenen DP's erstellen
      dos1973 @mickym last edited by
      @mickym
      ich hab da ja mehr als 10 Tage drin...
      • mickym
        mickym Most Active @dos1973 last edited by
        @dos1973 Ja aber Du siehst ja die sind alle drin?
          @mickym
          ja alle 30...
          • mickym
            @dos1973 Ja und die sind doch auch alle im Debug Fenster drin mit den Daten?
              @mickym
              ja, sieht so aus.
              {"axisLabels":["30.10.","08.11.","07.11.","06.11.","05.11.","04.11.","03.11.","02.11.","01.11.","31.10.","29.10.","28.10.","27.10.","26.10.","25.10.","24.10.","23.10.","22.10.","21.10.","20.10.","19.10.","18.10.","14.10.","13.10.","12.10.","11.10.","10.10.","09.10.","08.10.","07.10.","09.11."],"graphs":[{"type":"line","data":[7.709,6.331,7.655,6.662,7.608,9.776,6.69,5.454,7.404,5.883,9.489,5.748,6.746,5.976,7.549,7.555,2.648,8.254,5.387,6.072,6.68,6.175,6.608,7.354,6.241,6.059,5.622,5.839,7.207,6.357],"yAxis_id":0,"yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","barIsStacked":true,"line_pointSize":0,"line_Thickness":4,"datalabel_show":true,"datalabel_maxDigits":2,"datalabel_minDigits":2,"datalabel_fontFamily":"OpenSans-CondLight","datalabel_fontSize":16,"datalabel_borderRadius":6,"datalabel_offset":-10,"datalabel_backgroundColor":"#3E4765","datalabel_color":"#f5f5f5","color":"#ff9900","line_UseFillColor":false,"yAxis_gridLines_show":false,"use_gradient_color":true,"gradient_color":[{"value":8.5,"color":"#d43e3a"},{"value":6,"color":"#ff9900"},{"value":3,"color":"#4f6765"}],"yAxis_appendix":" kw/h"},{"type":"bar","barIsStacked":true,"data":[7.709,6.331,7.655,6.662,7.608,9.776,6.69,5.454,7.404,5.883,9.489,5.748,6.746,5.976,7.549,7.555,2.648,8.254,5.387,6.072,6.68,6.175,6.608,7.354,6.241,6.059,5.622,5.839,7.207,6.357],"yAxis_id":0,"barStackId":0,"datalabel_show":false,"color":"#000000","datalabel_color":"#FFFFFF","datalabel_align":"start","use_gradient_color":true,"yAxis_show":false,"yAxis_min":0,"yAxis_maxSteps":4,"yAxis_gridLines_border_show":false,"yAxis_gridLines_ticks_show":false,"yAxis_gridLines_show":false,"gradient_color":[{"value":9.1,"color":"#ED97A8"},{"value":5.5,"color":"#F3D8A5"},{"value":-5,"color":"#7CA27E"}]}]}
              • mickym
                mickym Most Active @dos1973 last edited by mickym
                @dos1973 na dann passt es doch - oder brauchst nicht alle 30 und Dein Tool hat deswegen ein Problem? Daten sind doch alle da? Schau halt erst mal, ob das Objekt im Debug Fenster mit dem identisch ist, als ob Du das Objekt aus dem iobroker kopierst. Wenn das identisch ist - dann hast Du mit dem Tool ein Problem und musst vielleicht Daten ausselektieren oder wirklich nur die ersten 10 Tage nehmen - ich hab halt alles genommen, weil das am schnellsten ging.
                Willst Du also exakt nur die Daten von Datum-1 bis Datum-10. ?
                  @mickym
                  ja, wollte nur 10 Tage haben.
                  kann ja nicht die 30 tage in das kleine fenster packen
                  mickym D 2 Replies Last reply Reply Quote 0
                  • mickym
                    @dos1973 OK - also nur Datum-1 bis Datum-10 und Verbrauch genauso?
                    ... ich arbeite ...
                      dos1973 @dos1973 last edited by
                      ich will heute und 10 tage zurück
                      doch komplizierter als gedacht 🙂
                      • mickym
                        @dos1973 Ja aber das Objekt wie im Debug muss genauso im iobroker erscheinen - das kann nicht sein, dass die axisLabels fehlen. Wie gesagt nur die ersten 10 - muss ich noch bissi arbeiten, weil die List Node erst mal alles ausliest.
                          @mickym
                          gibt noch ein Problem.
                          das Heutige Datum existiert nicht als DP.
                          und
                          die Quelle für den Verbrauch für den Heutigen Tag liegt hier:
                          sourceanalytix.0.0_userdata__0__mqtt__shellies__Pro3_EM__events__rpc__params__em:0__total_act_power.currentYear.consumed.01_currentDay
                          • mickym
                            @dos1973 darum kümmern wir uns später - eins nach dem anderen. Hast du jetzt mal überprüft on das Objekt im iobroker Datenpunkt mit dem Debug Fenster in Node Red identisch ist?
                              @mickym, ja das kommt sauber an, soweit ich das überblicken kann.
                              • mickym
                                @dos1973 Was hast Du denn da gepostet, wo angeblich die x-Achsen werte fehlen?
                                  @mickym ?
                                  kann dir nicht folgen...
                                  ich hatte den Root folder ursprünglich in deinem export nicht gewählt...
                                  • mickym
                                    @dos1973 So tausch mal in der Change Node Analyse den Code wie folgt:
                                    Dann sollten jetzt nur die Tage Datum-1 bis Datum-10 und Verbrauch-1 bis Verbrauch-10 ausgefiltert sein.
                                    Halt nein 20 und 30 sind jetzt auch drin- warte .... - (schlimm wenn man die Daten selbst nicht hat)
                                    So müsste es stimmen:
                                    payload.{"xasisLabels": [_id~>/(Datum-\d$|Datum-10$)/] ? val, "data" : [_id~>/(Verbrauch-\d$|Verbrauch-10$)/] ? val}
                                    D mickym 2 Replies Last reply Reply Quote 0
                                      dos1973 @mickym last edited by dos1973
                                      @mickym : nicht ganz, es sind 12 Tage, heute fehlt... und die Reihenfolge ist nicht sortiert
                                      • edit:es sind auch nicht die letzten 10, da u.a. auch der 10.10 aufgeführt
                                      • mickym
                                        @mickym Wie gesagt mit dem heute - da muss der gesamte Flow noch ergänzt werden.
                                        payload.{"xasisLabels": [_id~>/(Datum-(\d|10)$)/] ? val, "data" : [_id~>/(Verbrauch-(\d|10)$)/] ? val}
                                        Schau mal ob bis auf heute alles richtig ist - sortieren kommt gleich. Das Dumme ist das Du den 10. Datenpunkt 10 genannt hast. und nicht von 0-9
                                          @mickym
                                          ne das passt nicht.
                                          • mickym
                                            @dos1973 Kannst Du einfach eine DebugNode hinter die list Node machen und mir die payload dann in Code-Tags hier reinkopieren?
                                            3183
