    4. BackItUp Update hängt
      Thomas Braun Most Active @myssv last edited by
      @myssv
      Bis sich was tut.
        myssv @Thomas Braun last edited by
        @thomas-braun hat sich was getan:
        $ iobroker upgrade ws@2.5.8
        Update ws from @2.5.5 to @2.5.8
        Installing iobroker.ws@2.5.8... (System call)
        Adapter "system.adapter.web.0" restarted.
        upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
        Process exited with code 0
        Der Adapter scheint aber noch der Alte zu sein:
          @myssv
          iob update
          zeigen. GUIs lügen.
            @thomas-braun sagte in BackItUp Update hängt:
            iob update
            Volker@ioBroker:~$ iob update
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
            Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
            Adapter    "email"        : 1.2.0    , installed 1.2.0
            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
            Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
            Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
            Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
            Controller "js-controller": 5.0.12   , installed 5.0.12
            Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
            Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
            Adapter    "telegram"     : 2.0.1    , installed 2.0.1
            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
            Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.1.10   , installed 6.1.4  [Updatable]
            Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
            Volker@ioBroker:~$
              Homoran Global Moderator Administrators @myssv last edited by
              @myssv iob upload ws
                myssv @Homoran last edited by
                @homoran sagte in BackItUp Update hängt:
                iob upload ws
                Volker@ioBroker:~$ iob upload ws
                upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                  @myssv
                  Das passt. Du bist auf 'Stable', die Updates sind aber erst in 'Beta' verfügbar.
                  M Homoran 2 Replies Last reply Reply Quote 0
                    @thomas-braun Warum werden sie mir dann angezeigt?
                      Das passt. D
                      nee,
                      @myssv sagte in BackItUp Update hängt:
                          Thomas Braun Most Active @Homoran last edited by Thomas Braun
                          ws
                          github:	2.5.8
                          latest:	2.5.8 for 30 days
                          stable:	2.5.5 for 56 days
                          Kann auch sein, dass die beiden Adapter just im Moment in Stable rüber wandern und der Mirror noch nicht gesynct ist.
                          Schau dir das in ein paar Stunden nochmal an.
                            @thomas-braun ok, dann versuche ich es morgen früh noch einmal.
                            Danke und einen tollen Abend noch!
                              Guten Morgen zusammen, es hat sich nichts an dem Verhalten geändert.
                              Warte schon wieder 5 Minuten:
                                nach 17 Minuten kam dies:
                                aber
                                  @myssv
                                  I'm Terminal
                                  iob upgrade ws@2.5.8 --debug
                                    seit 12 Minuten so
                                    Volker@ioBroker:~$ iob upgrade ws@2.5.8 --debug
                                    This upgrade of "ws" will introduce the following changes:
                                    -> 2.5.8:
                                    Corrected adapter termination if the alias has no target
                                    -> 2.5.7:
                                    upgraded socket-classes to fix vis problems
                                    -> 2.5.6:
                                    upgraded socket-classes to correct the error by unsubscribing on client disconnect
                                    Would you like to upgrade ws from @2.5.5 to @2.5.8 now? [(y)es, (n)o]: y
                                    NPM version: 9.8.1
                                      So, diesmal hat es länger gedauert ...
                                      -> 2.5.8:
                                      -> 2.5.7:
                                      -> 2.5.6:
                                      NPM version: 9.8.1
                                      npm ERR! code ETIMEDOUT
                                      npm ERR! syscall connect
                                      npm ERR! errno ETIMEDOUT
                                      npm ERR! network request to https://registry.npmjs.org/iobroker.ws/-/iobroker.ws-2.5.8.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1f22:443
                                      npm ERR! network This is a problem related to network connectivity.
                                      npm ERR! network In most cases you are behind a proxy or have bad network settings.
                                      npm ERR! network
                                      npm ERR! network If you are behind a proxy, please make sure that the
                                      npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T08_58_10_931Z-debug-0.log
                                        ich kann die Datei manuell herunterladen!
                                          ist das IPv6? Das wäre eine Erklärung, da ich das im Hausnetz nicht will und eigentlich überall deaktiviert habe.
                                            @myssv
                                            Ja, das ist eine ipv6-Adresse.
                                            Warum willst du das nicht?
                                            Aktivier das halt, das ist wichtig.
                                            9020
