    4. BackItUp Update hängt
      myssv @Thomas Braun last edited by
      @thomas-braun hat sich was getan:
      $ iobroker upgrade ws@2.5.8
      Update ws from @2.5.5 to @2.5.8
      Installing iobroker.ws@2.5.8... (System call)
      Adapter "system.adapter.web.0" restarted.
      upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
      Process exited with code 0
      Der Adapter scheint aber noch der Alte zu sein:
        Thomas Braun Most Active @myssv last edited by
        @myssv
        iob update
        zeigen. GUIs lügen.
          @thomas-braun sagte in BackItUp Update hängt:
          iob update
          Volker@ioBroker:~$ iob update
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
          Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
          Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
          Adapter    "telegram"     : 2.0.1    , installed 2.0.1
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.1.10   , installed 6.1.4  [Updatable]
          Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
          Volker@ioBroker:~$
            Homoran Global Moderator Administrators @myssv last edited by
            @myssv iob upload ws
              myssv @Homoran last edited by
              @homoran sagte in BackItUp Update hängt:
              iob upload ws
              Volker@ioBroker:~$ iob upload ws
              upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
              upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
              upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                @myssv
                Das passt. Du bist auf 'Stable', die Updates sind aber erst in 'Beta' verfügbar.
                M Homoran 2 Replies Last reply Reply Quote 0
                  @thomas-braun Warum werden sie mir dann angezeigt?
                    Das passt. D
                    nee,
                    @myssv sagte in BackItUp Update hängt:
                        Thomas Braun Most Active @Homoran last edited by Thomas Braun
                        ws
                        github:	2.5.8
                        latest:	2.5.8 for 30 days
                        stable:	2.5.5 for 56 days
                        Kann auch sein, dass die beiden Adapter just im Moment in Stable rüber wandern und der Mirror noch nicht gesynct ist.
                        Schau dir das in ein paar Stunden nochmal an.
                          @thomas-braun ok, dann versuche ich es morgen früh noch einmal.
                          Danke und einen tollen Abend noch!
                            Guten Morgen zusammen, es hat sich nichts an dem Verhalten geändert.
                            Warte schon wieder 5 Minuten:
                              nach 17 Minuten kam dies:
                              aber
                                @myssv
                                I'm Terminal
                                iob upgrade ws@2.5.8 --debug
                                  seit 12 Minuten so
                                  Volker@ioBroker:~$ iob upgrade ws@2.5.8 --debug
                                  This upgrade of "ws" will introduce the following changes:
                                  -> 2.5.8:
                                  Corrected adapter termination if the alias has no target
                                  -> 2.5.7:
                                  upgraded socket-classes to fix vis problems
                                  -> 2.5.6:
                                  upgraded socket-classes to correct the error by unsubscribing on client disconnect
                                  Would you like to upgrade ws from @2.5.5 to @2.5.8 now? [(y)es, (n)o]: y
                                  NPM version: 9.8.1
                                    So, diesmal hat es länger gedauert ...
                                    -> 2.5.8:
                                    -> 2.5.7:
                                    -> 2.5.6:
                                    NPM version: 9.8.1
                                    npm ERR! code ETIMEDOUT
                                    npm ERR! syscall connect
                                    npm ERR! errno ETIMEDOUT
                                    npm ERR! network request to https://registry.npmjs.org/iobroker.ws/-/iobroker.ws-2.5.8.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1f22:443
                                    npm ERR! network This is a problem related to network connectivity.
                                    npm ERR! network In most cases you are behind a proxy or have bad network settings.
                                    npm ERR! network
                                    npm ERR! network If you are behind a proxy, please make sure that the
                                    npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T08_58_10_931Z-debug-0.log
                                      ich kann die Datei manuell herunterladen!
                                        ist das IPv6? Das wäre eine Erklärung, da ich das im Hausnetz nicht will und eigentlich überall deaktiviert habe.
                                          @myssv
                                          Ja, das ist eine ipv6-Adresse.
                                          Warum willst du das nicht?
                                          Aktivier das halt, das ist wichtig.
                                            @myssv
                                            Weil mein gesamtes Netzwerk auf IPv4 ausgerichtet ist und mit V6 z.B. mein Adguard nicht korrekt funktioniert.
                                            Von daher möchte ich mein Netzwerk rein auf IPv4 behalten, was ja auch überhaupt kein Problem darstellen sollte, da ich so für mich genügend Adressen habe.
                                            Scheinbar hat der ioBroker damit ein Problem. Kann ich den irgendwie auf rein V4 umstellen?
                                            9020
