    4. Kein Zugriff au Iobroker
    • joergfrde
      joergfrde @Glasfaser last edited by
      @glasfaser über Webbrowser
      • joergfrde
        joergfrde @Thomas Braun last edited by
        @thomas-braun was heißt buster ist tot
        Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @joergfrde last edited by
          @joergfrde
          Zeige bitte die Full Ausgabe ... kein SUMMARY !
          joergfrde 1 Reply Last reply Reply Quote 0
            Thomas Braun Most Active @joergfrde last edited by
            @joergfrde
            Tot heißt:
            • Glasfaser
              @joergfrde sagte in Kein Zugriff au Iobroker:
              ENDE ... kein Support mehr .
              https://www.debian.org/releases/buster/index.de.html
              • joergfrde
                joergfrde @Glasfaser last edited by Homoran
                @glasfaser
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                  Operating System: Raspbian GNU/Linux 10 (buster)
                            Kernel: Linux 5.10.103-v7l+
                      Architecture: arm
                Model           : Raspberry Pi 4 Model B Rev 1.1
                Docker          : false
                Virtualization  : none
                Kernel          : armv7l
                Userland        : armhf
                Systemuptime and Load:
                 20:53:15 up 26 min,  1 user,  load average: 0.92, 1.02, 1.41
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Fri 2023-11-10 20:53:15 CET
                           Universal time: Fri 2023-11-10 19:53:15 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           3.8G        2.0G        708M        8.0M        1.1G        1.6G
                Swap:           99M          0B         99M
                Total:         3.9G        2.0G        808M
                         3837 M total memory
                         2032 M used memory
                          568 M active memory
                         2375 M inactive memory
                          708 M free memory
                          184 M buffer memory
                          912 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                  UNIT                LOAD   ACTIVE SUB    DESCRIPTION
                * deconz-init.service loaded failed failed deCONZ: ZigBee gateway -- Initialisation
                * proftpd.service     loaded failed failed LSB: Starts ProFTPD daemon
                LOAD   = Reflects whether the unit definition was properly loaded.
                ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                SUB    = The low-level unit activation state, values depend on unit type.
                2 loaded units listed. Pass --all to see loaded but inactive units, too.
                To show all installed unit files use 'systemctl list-unit-files'.
                *** FILESYSTEM ***
                /dev/root      ext4      220G   17G  195G   8% /
                devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                tmpfs          tmpfs     1.9G  8.8M  1.9G   1% /run
                tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                /dev/sda1      vfat      253M   49M  204M  20% /boot
                tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                [Fri Nov 10 20:27:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:22:43:EA vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): write access will be enabled during recovery
                [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
                [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): 50 orphan inodes deleted
                [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): recovery complete
                [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                [Fri Nov 10 20:27:09 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Fri Nov 10 20:27:12 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                TARGET        SOURCE    FSTYPE OPTIONS
                /             /dev/sda2 ext4   rw,noatime
                |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                1.3G    /var/
                1.1G    /var/cache/apt
                1.1G    /var/cache
                990M    /var/cache/apt/archives
                104M    /var/lib
                Archived and active journals take up 8.0M in the file system.
                /opt/iobroker/backups:
                293M    /opt/iobroker/backups/
                208K    /opt/iobroker/backups/scripte
                112K    /opt/iobroker/backups/scripte/common
                88K     /opt/iobroker/backups/scripte/Eigener_Ordner
                /opt/iobroker/iobroker-data:
                3.8G    /opt/iobroker/iobroker-data/
                2.8G    /opt/iobroker/iobroker-data/history
                524M    /opt/iobroker/iobroker-data/files
                283M    /opt/iobroker/iobroker-data/backup-objects
                78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                50M     /opt/iobroker/iobroker-data/objects.jsonl
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                31M     /opt/iobroker/iobroker-data/states.jsonl
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                19M     /opt/iobroker/iobroker-data/objects.json.migrated
                USB-Devices by-id:
                /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149438-if00
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.16.0
                /usr/bin/node           v18.16.0
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                /usr/bin/corepack       0.17.0
                nodejs:
                  Installed: 18.16.0-deb-1nodesource1
                  Candidate: 18.17.1-deb-1nodesource1
                  Version table:
                     18.17.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                 *** 18.16.0-deb-1nodesource1 100
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u3 500
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.12
                admin:          6.12.0
                javascript:     7.1.4
                Adapters from github:   1
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                + system.adapter.calendar.0               : calendar              : raspberrypi                              -  enabled, port: 8095
                + system.adapter.calendar.1               : calendar              : raspberrypi                              -  enabled, port: 8095
                + system.adapter.cameras.0                : cameras               : raspberrypi                              -  enabled, port: 8085, bind: 0.0.0.0
                + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                  system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                  system.adapter.egigeozone.0             : egigeozone            : raspberrypi                              -  enabled, port: 7654
                + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
                  system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                  system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
                + system.adapter.geofency.0               : geofency              : raspberrypi                              -  enabled, port: 7999, bind: 0.0.0.0
                  system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 8081
                + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                + system.adapter.homee.0                  : homee                 : raspberrypi                              -  enabled
                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                  system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                  system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                  system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                  system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              -  enabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
                + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                + system.adapter.landroid.0               : landroid              : raspberrypi                              -  enabled
                + system.adapter.lifx.0                   : lifx                  : raspberrypi                              -  enabled
                + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                  system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
                + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
                  system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                + system.adapter.parcel.0                 : parcel                : raspberrypi                              -  enabled
                + system.adapter.paw.0                    : paw                   : raspberrypi                              -  enabled, port: 8898
                  system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
                  system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
                  system.adapter.schoolfree.1             : schoolfree            : raspberrypi                              -  enabled
                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                + system.adapter.toyota.0                 : toyota                : raspberrypi                              -  enabled
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                + system.adapter.trashschedule.2          : trashschedule         : raspberrypi                              -  enabled
                + system.adapter.trashschedule.3          : trashschedule         : raspberrypi                              -  enabled
                  system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                  system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                  system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                  system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
                  system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
                  system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                  system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                  system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                  system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                  system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
                  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                  system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.12.0   , installed 6.12.0
                Adapter    "alarm"        : 3.4.0    , installed 3.4.0
                Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
                Adapter    "deconz"       : 1.3.21   , installed 2.0.5
                Adapter    "denon"        : 1.15.4   , installed 1.15.4
                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                Adapter    "egigeozone"   : 0.1.2    , installed 0.1.2
                Adapter    "email"        : 1.2.0    , installed 1.2.0
                Adapter    "exchangerates": 0.0.14   , installed 0.0.14
                Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                Adapter    "fullcalendar" : 2.2.6    , installed 1.2.0  [Updatable]
                Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                Adapter    "hm-rega"      : 4.0.0    , installed 3.0.47 [Updatable]
                Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                Adapter    "homee"        : 1.2.0    , installed 1.2.0
                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                Controller "js-controller": 5.0.12   , installed 5.0.12
                Adapter    "landroid"     : 1.0.3    , installed 1.0.3
                Adapter    "lifx"         : 1.0.3    , installed 1.0.3
                Adapter    "meross"       : 1.15.1   , installed 1.15.1
                Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                Adapter    "onvif"        : 1.0.5    , installed 1.0.5
                Adapter    "openweathermap": 0.4.5   , installed 0.3.9  [Updatable]
                Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                Adapter    "paw"          : 0.3.2    , installed 0.3.2
                Adapter    "ring"         : 3.2.2    , installed 3.2.2
                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
                Adapter    "shelly"       : 6.6.1    , installed 6.4.5  [Updatable]
                Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                Adapter    "telegram"     : 2.0.1    , installed 1.16.0 [Updatable]
                Adapter    "text2command" : 3.0.2    , installed 3.0.2
                Adapter    "toyota"       : 0.0.3    , installed 0.0.3
                Adapter    "trashschedule": 2.3.0    , installed 2.2.0  [Updatable]
                Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                Adapter    "web"          : 6.1.10   , installed 6.1.2  [Updatable]
                Adapter    "worx"         : 2.3.4    , installed 2.3.2  [Updatable]
                Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                Objects and States
                Objects:        74009
                States:         60139
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:3 https://phoscon.de/apt/deconz buster InRelease
                Hit:4 https://deb.nodesource.com/node_18.x buster InRelease
                Reading package lists...
                Pending Updates: 112
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       17915      463/deCONZ
                tcp        0      0 192.168.178.27:2001     0.0.0.0:*               LISTEN      1001       58919      6359/io.hm-rpc.4
                tcp        0      0 192.168.178.27:8083     0.0.0.0:*               LISTEN      1001       54935      5990/io.hm-rpc.0
                tcp        0      0 0.0.0.0:8085            0.0.0.0:*               LISTEN      1001       60653      8227/io.cameras.0
                tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          17313      798/dnsmasq
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20583      792/sshd
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       24250      387/node-red
                tcp        0      0 192.168.178.27:2010     0.0.0.0:*               LISTEN      1001       54939      6268/io.hm-rpc.1
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          16257      776/mosquitto
                tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16146      463/deCONZ
                tcp        0      0 192.168.178.27:8701     0.0.0.0:*               LISTEN      1001       59620      6289/io.hm-rpc.2
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19965      775/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19935      775/iobroker.js-con
                tcp        0      0 192.168.178.27:9292     0.0.0.0:*               LISTEN      1001       59625      6311/io.hm-rpc.3
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49568      2563/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       58313      3905/io.web.0
                tcp6       0      0 :::53                   :::*                    LISTEN      0          17315      798/dnsmasq
                tcp6       0      0 :::22                   :::*                    LISTEN      0          20585      792/sshd
                tcp6       0      0 :::1883                 :::*                    LISTEN      0          16258      776/mosquitto
                tcp6       0      0 :::7999                 :::*                    LISTEN      1001       49602      3337/io.geofency.0
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       59873      4059/io.shelly.0
                udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          17312      798/dnsmasq
                udp        0      0 0.0.0.0:52801           0.0.0.0:*                           108        18675      467/avahi-daemon: r
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          17309      798/dnsmasq
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17006      773/dhcpcd
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19051      610/dhclient
                udp        0      0 0.0.0.0:43084           0.0.0.0:*                           1001       54063      6995/io.lifx.0
                udp        0      0 192.168.178.27:5353     0.0.0.0:*                           1001       58441      5099/io.tr-064.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        18673      467/avahi-daemon: r
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       64536      8123/io.deconz.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18165      463/deCONZ
                udp6       0      0 :::53160                :::*                                108        18676      467/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          19714      773/dhcpcd
                udp6       0      0 :::53                   :::*                                0          17314      798/dnsmasq
                udp6       0      0 :::5353                 :::*                                108        18674      467/avahi-daemon: r
                udp6       0      0 :::1900                 :::*                                1001       64539      8123/io.deconz.0
                udp6       0      0 :::1900                 :::*                                1001       64538      8123/io.deconz.0
                udp6       0      0 :::1900                 :::*                                1001       64537      8123/io.deconz.0
                2023-11-10 20:54:24.446  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 6(Lenovo-Tablet/48:88:CA:DF:E3:9F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:24.669  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 8(Meross-Smart-Plug/48:E1:E9:04:34:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:26.334  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 20(joerg/98:09:CF:8C:90:48) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:26.684  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 23(ccu3-webui/B8:27:EB:00:A4:4A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:26.703  - warn: shelly.0 (4059) [authEnabled] 192.168.178.57 (shelly1 / shelly1-A4CF12F41BAF / SHSW-1#A4CF12F41BAF#1): This device is not protected via restricted login (see adapter documentation for details)
                2023-11-10 20:54:38.824  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 6(Lenovo-Tablet/48:88:CA:DF:E3:9F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:39.048  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 8(Meross-Smart-Plug/48:E1:E9:04:34:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:40.762  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 20(joerg/98:09:CF:8C:90:48) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:41.176  - warn: shelly.0 (4059) [authEnabled] 192.168.178.57 (shelly1 / shelly1-A4CF12F41BAF / SHSW-1#A4CF12F41BAF#1): This device is not protected via restricted login (see adapter documentation for details)
                2023-11-10 20:54:41.227  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 23(ccu3-webui/B8:27:EB:00:A4:4A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:42.216  - warn: deconz.0 (8123) Object of state "deconz.0.info.connection" is missing the required property "common.type"
                2023-11-10 20:54:46.503  - warn: shelly.0 (4059) [authEnabled] 192.168.178.86 (shelly1 / shelly1-A4CF12F41DED / SHSW-1#A4CF12F41DED#1): This device is not protected via restricted login (see adapter documentation for details)
                2023-11-10 20:54:53.013  - warn: shelly.0 (4059) [authEnabled] 192.168.178.57 (shelly1 / shelly1-A4CF12F41BAF / SHSW-1#A4CF12F41BAF#1): This device is not protected via restricted login (see adapter documentation for details)
                2023-11-10 20:54:53.556  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 6(Lenovo-Tablet/48:88:CA:DF:E3:9F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:53.774  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 8(Meross-Smart-Plug/48:E1:E9:04:34:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:55.198  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 20(joerg/98:09:CF:8C:90:48) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:54:55.583  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 23(ccu3-webui/B8:27:EB:00:A4:4A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:55:01.666  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 21418
                2023-11-10 20:55:07.737  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 6(Lenovo-Tablet/48:88:CA:DF:E3:9F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:55:07.979  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 8(Meross-Smart-Plug/48:E1:E9:04:34:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:55:09.154  - info: tvspielfilm.0 (21418) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.16.0, js-controller: 5.0.12
                2023-11-10 20:55:09.498  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 20(joerg/98:09:CF:8C:90:48) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:55:09.965  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 23(ccu3-webui/B8:27:EB:00:A4:4A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2023-11-10 20:55:11.060  - warn: shelly.0 (4059) [authEnabled] 192.168.178.57 (shelly1 / shelly1-A4CF12F41BAF / SHSW-1#A4CF12F41BAF#1): This device is not protected via restricted login (see adapter documentation for details)
                2023-11-10 20:55:11.275  - info: tvspielfilm.0 (21418) objects written
                iob diag has finished.
                Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
                  Das Ding ist Matsch. Installier da von Null an das aktuelle Release von RaspberryOS in der 64bit Lite Variante.
                  • Glasfaser
                    Objects: 74009
                    States: 60139
                    und das ist Sportlich ... das hab ich noch nicht mal !
                    • joergfrde
                      @thomas-braun Kann ich die Daten vom iob sicherm und wieder verwenden?
                        Thomas Braun Most Active @joergfrde last edited by Thomas Braun
                        Du hast doch laufend Backups via Backitup-Adapter gemacht. Nimm eines der funktionierenden von dort.
                        • Glasfaser
                          mhh .. deine aktuellen Backups !
                          • joergfrde
                            @thomas-braun Wenn ich RasberryOS erneuere, bleiben die iob-Daten erhalten?
                              Nein. Nur in einem Backup.
                              • Glasfaser
                                ... und auch dieses ist von der Größe sportlich !
                                meine Vermutung , der Ring Adapter müllt alles voll
                                • joergfrde
                                  @thomas-braun Wenn ich RasberryOS erneuert habe, muß ich sicherlich den iob neu installieren und dann das Backup einspielen. Ist das richtig?
                                    Ist das richtig?
                                    Ja, das ist das Standard-Vorgehen.
                                    • joergfrde
                                      @thomas-braun OK, danke. Werde ich dann machen, aber nicht mehr heute. Melde ich dann wieder bei Erfolg oder Probleme. Danke erstmal.
                                      iobroker zugriff oberfläche
                                      10
                                      74
                                      5372
