    4. BackItUp Update hängt
      myssv @Thomas Braun last edited by
      @thomas-braun sagte in BackItUp Update hängt:
      iob update
      Volker@ioBroker:~$ iob update
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.4  [Updatable]
      Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
      Volker@ioBroker:~$
        Homoran Global Moderator Administrators @myssv last edited by
        @myssv iob upload ws
          myssv @Homoran last edited by
          @homoran sagte in BackItUp Update hängt:
          iob upload ws
          Volker@ioBroker:~$ iob upload ws
          upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
          upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
          Adapter "system.adapter.web.0" restarted.
            Thomas Braun Most Active @myssv last edited by
            @myssv
            Das passt. Du bist auf 'Stable', die Updates sind aber erst in 'Beta' verfügbar.
            M Homoran 2 Replies Last reply Reply Quote 0
              @thomas-braun Warum werden sie mir dann angezeigt?
                Das passt. D
                nee,
                @myssv sagte in BackItUp Update hängt:
                Installing iobroker.ws@2.5.8... (System call)
                    Thomas Braun Most Active @Homoran last edited by Thomas Braun
                    ws
                    github:	2.5.8
                    latest:	2.5.8 for 30 days
                    stable:	2.5.5 for 56 days
                    Kann auch sein, dass die beiden Adapter just im Moment in Stable rüber wandern und der Mirror noch nicht gesynct ist.
                    Schau dir das in ein paar Stunden nochmal an.
                      @thomas-braun ok, dann versuche ich es morgen früh noch einmal.
                      Danke und einen tollen Abend noch!
                        Guten Morgen zusammen, es hat sich nichts an dem Verhalten geändert.
                        Warte schon wieder 5 Minuten:
                          nach 17 Minuten kam dies:
                          $ iobroker upgrade ws@2.5.8
                          Update ws from @2.5.5 to @2.5.8
                          Process exited with code 0
                          aber
                            @myssv
                            I'm Terminal
                            iob upgrade ws@2.5.8 --debug
                              seit 12 Minuten so
                              Volker@ioBroker:~$ iob upgrade ws@2.5.8 --debug
                              This upgrade of "ws" will introduce the following changes:
                              -> 2.5.8:
                              Corrected adapter termination if the alias has no target
                              -> 2.5.7:
                              upgraded socket-classes to fix vis problems
                              -> 2.5.6:
                              upgraded socket-classes to correct the error by unsubscribing on client disconnect
                              Would you like to upgrade ws from @2.5.5 to @2.5.8 now? [(y)es, (n)o]: y
                              NPM version: 9.8.1
                                So, diesmal hat es länger gedauert ...
                                -> 2.5.8:
                                -> 2.5.7:
                                -> 2.5.6:
                                NPM version: 9.8.1
                                npm ERR! code ETIMEDOUT
                                npm ERR! syscall connect
                                npm ERR! errno ETIMEDOUT
                                npm ERR! network request to https://registry.npmjs.org/iobroker.ws/-/iobroker.ws-2.5.8.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1f22:443
                                npm ERR! network This is a problem related to network connectivity.
                                npm ERR! network In most cases you are behind a proxy or have bad network settings.
                                npm ERR! network
                                npm ERR! network If you are behind a proxy, please make sure that the
                                npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T08_58_10_931Z-debug-0.log
                                  ich kann die Datei manuell herunterladen!
                                    ist das IPv6? Das wäre eine Erklärung, da ich das im Hausnetz nicht will und eigentlich überall deaktiviert habe.
                                      @myssv
                                      Ja, das ist eine ipv6-Adresse.
                                      Warum willst du das nicht?
                                      Aktivier das halt, das ist wichtig.
                                        @myssv
                                        Weil mein gesamtes Netzwerk auf IPv4 ausgerichtet ist und mit V6 z.B. mein Adguard nicht korrekt funktioniert.
                                        Von daher möchte ich mein Netzwerk rein auf IPv4 behalten, was ja auch überhaupt kein Problem darstellen sollte, da ich so für mich genügend Adressen habe.
                                        Scheinbar hat der ioBroker damit ein Problem. Kann ich den irgendwie auf rein V4 umstellen?
                                          Nein, kein Problem.
                                          Nodejs/npm nutzen allerdings ipv6 zu Recht bevorzugt.
                                          Ipv6/ipv4 kann man auch parallel nutzen. Mache ich z.B. in meinem Netz so.
                                          IPv6 ist Stand der Technik, bring dein Netzwerk halt in die Gegenwart. Adguard kann man zu 100% auch mit IPv6 betreiben.
                                            Das stört mich nur, wenn nicht auf IPv4 zurück gegangen wird
                                            Kann man IPv6 auch deaktivieren?
                                            Sorry, aber das ist kein Argument. E-Autos sind auch stand der Technik, aber ich fahre weiterhin meinen 8 Jahre alten Diesel!
                                            Sicher kann man das, aber warum dafür ein funktionierendes Netzwerk ändern?
                                            So, das war genug off topic!
                                            Kannst Du mir sagen, wie ich den ioBroker mit reinem IPv4 betreiben kann?
                                            8998
