    4. BackItUp Update hängt
      myssv last edited by
      nach 17 Minuten kam dies:
      $ iobroker upgrade ws@2.5.8
      Update ws from @2.5.5 to @2.5.8
      Installing iobroker.ws@2.5.8... (System call)
      Adapter "system.adapter.web.0" restarted.
      upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
      Process exited with code 0
      aber
      Volker@ioBroker:~$ iob update
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.4  [Updatable]
      Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
        Thomas Braun Most Active @myssv last edited by
        @myssv
        I'm Terminal
        iob upgrade ws@2.5.8 --debug
          myssv @Thomas Braun last edited by
          @thomas-braun sagte in BackItUp Update hängt:
          seit 12 Minuten so
          Volker@ioBroker:~$ iob upgrade ws@2.5.8 --debug
          This upgrade of "ws" will introduce the following changes:
          -> 2.5.8:
          Corrected adapter termination if the alias has no target
          -> 2.5.7:
          upgraded socket-classes to fix vis problems
          -> 2.5.6:
          upgraded socket-classes to correct the error by unsubscribing on client disconnect
          Would you like to upgrade ws from @2.5.5 to @2.5.8 now? [(y)es, (n)o]: y
          NPM version: 9.8.1
            So, diesmal hat es länger gedauert ...
            -> 2.5.8:
            -> 2.5.7:
            -> 2.5.6:
            NPM version: 9.8.1
            npm ERR! code ETIMEDOUT
            npm ERR! syscall connect
            npm ERR! errno ETIMEDOUT
            npm ERR! network request to https://registry.npmjs.org/iobroker.ws/-/iobroker.ws-2.5.8.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1f22:443
            npm ERR! network This is a problem related to network connectivity.
            npm ERR! network In most cases you are behind a proxy or have bad network settings.
            npm ERR! network
            npm ERR! network If you are behind a proxy, please make sure that the
            npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T08_58_10_931Z-debug-0.log
            upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
              @myssv sagte in BackItUp Update hängt:
              ich kann die Datei manuell herunterladen!
                ist das IPv6? Das wäre eine Erklärung, da ich das im Hausnetz nicht will und eigentlich überall deaktiviert habe.
                  @myssv
                  Ja, das ist eine ipv6-Adresse.
                  Warum willst du das nicht?
                  Aktivier das halt, das ist wichtig.
                    @myssv
                    Weil mein gesamtes Netzwerk auf IPv4 ausgerichtet ist und mit V6 z.B. mein Adguard nicht korrekt funktioniert.
                    Von daher möchte ich mein Netzwerk rein auf IPv4 behalten, was ja auch überhaupt kein Problem darstellen sollte, da ich so für mich genügend Adressen habe.
                    Scheinbar hat der ioBroker damit ein Problem. Kann ich den irgendwie auf rein V4 umstellen?
                      Nein, kein Problem.
                      Nodejs/npm nutzen allerdings ipv6 zu Recht bevorzugt.
                      Ipv6/ipv4 kann man auch parallel nutzen. Mache ich z.B. in meinem Netz so.
                      IPv6 ist Stand der Technik, bring dein Netzwerk halt in die Gegenwart. Adguard kann man zu 100% auch mit IPv6 betreiben.
                        Das stört mich nur, wenn nicht auf IPv4 zurück gegangen wird
                        Kann man IPv6 auch deaktivieren?
                        Sorry, aber das ist kein Argument. E-Autos sind auch stand der Technik, aber ich fahre weiterhin meinen 8 Jahre alten Diesel!
                        Sicher kann man das, aber warum dafür ein funktionierendes Netzwerk ändern?
                        So, das war genug off topic!
                        Kannst Du mir sagen, wie ich den ioBroker mit reinem IPv4 betreiben kann?
                          @myssv
                          Nein.
                            @thomas-braun ich habe dazu im Netz folgendes gefunden:
                            In der Datei /etc/sysctl.conf
                            folgenden Eintrag einfügen:
                            net.ipv6.conf.all.disable_ipv6 = 1
                            und dann mit
                            sudo sysctl -p
                            übernehmen.
                            Danach wurden beide Adapter anstandslos installiert.
                            Allerdings startet der ioBroker ohne IPv6 nicht mehr.
                            Der Server ist wieder da und ich komme auf die Konsole, daber nicht auf die ioBroker Webseite.
                              Dein Netzwerk funktioniert ja eben nicht vollumfänglich.
                                Der ioBroker funktioniert scheinbar nicht ohne IPv6. Mein Netzwerk funktioniert ohne den ioBroker einwandfrei.
                                Ich habe noch 10-15 Jahre zu leben. Da werde ich mir IPv6 nicht mehr antun!
                                Aber ist das jetzt wirklich zielführend?
                                  @myssv
                                  Ob IPv6 eingeführt und verwendet wird entscheidest aber nicht du. Du kannst natürlich sagen, ich spreche kein IPv6, dann musst du sich aber auch nicht wundern, wenn der Rest der Netzwerkwelt dann mit dir nicht mehr kommunizieren kann und Dienste nicht mehr funktionieren.
                                    @myssv
                                    Ich bin doch überhaupt nicht wichtig auf dieser Welt! Darum geht es doch auch gar nicht.
                                    Es ist aber eine klare Aussage, wenn der ioBroker in einem reinen IPv4 Netzwerk nicht mehr funktioniert.
                                    Danke dafür!
                                      Wer hat die getätigt? Klar kann man das machen. Man muss dann aber 'gegen das grundsätzliche Setup' anarbeiten und hier und da Einstellungen verändern, damit man sein kleines gallischen Netzwerk weiter mit einer auslaufenden Technik betreiben kann. IPv4 und IPv6 laufen wunderbar gleichzeitig in einem Netzwerk, die sehen einander gar nicht.
                                      Also wird dein kastrierten Netzwerkonstrukt nur unnötig komplexer.
                                      Und das würde ich mir nicht antun.
                                        @thomas-braun lass gut sein.
                                        ich werde bei IPv4 bleiben und wenn ich dann den ioBroker nicht mehr nutzen kann, dann ist das halt so.
                                          Homoran Global Moderator Administrators @myssv last edited by
                                          wer sagt den sowas?
                                          auch das stimmt nicht.
                                          ioB läuft bei mir bisher ohne Probleme im IPv4 Netz
                                          Thomas Braun M 2 Replies Last reply Reply Quote 0
                                            @homoran sagte in BackItUp Update hängt:
                                            wer sagt den sowas?
                                            Niemand.
                                            Aber offenbar ist das Netzwerk vom TE ziemlich kaputtkonfiguriert.
                                            9048
