    4. Test Adapter Weather-Warnings
    • Armilar
      Armilar Most Active Forum Testing @ticaki last edited by
      @ticaki
      habe folgende Fehler:
      weather-warnings.0
      2023-11-09 18:04:19.343	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      weather-warnings.0
      2023-11-09 18:04:18.785	error	Cannot read properties of undefined (reading 'join')
      weather-warnings.0
      2023-11-09 18:04:18.784	error	TypeError: Cannot read properties of undefined (reading 'join') at new BaseProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:49:104) at new UWZProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:458:9) at ProviderController.createProviderIfNotExist (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:784:25) at /opt/iobroker/node_modules/iobroker.weather-warnings/src/main.ts:508:49 at processTicksAndRejections (node:internal/process/task_queues:95:5)
      weather-warnings.0
      2023-11-09 18:04:18.639	error	unhandled promise rejection: Cannot read properties of undefined (reading 'join')
      weather-warnings.0
      2023-11-09 18:04:18.639	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      weather-warnings.0
      2023-11-09 18:03:40.466	error	DB closed
      weather-warnings.0
      2023-11-09 18:03:40.466	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at TCP.<anonymous> (node:net:350:12)
      weather-warnings.0
      2023-11-09 18:03:40.464	error	unhandled promise rejection: DB closed
      weather-warnings.0
      2023-11-09 18:03:40.464	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      weather-warnings.0
      2023-11-09 18:03:39.939	error	Cannot read properties of undefined (reading 'join')
      weather-warnings.0
      2023-11-09 18:03:39.939	error	TypeError: Cannot read properties of undefined (reading 'join') at new BaseProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:49:104) at new UWZProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:458:9) at ProviderController.createProviderIfNotExist (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:784:25) at /opt/iobroker/node_modules/iobroker.weather-warnings/src/main.ts:508:49 at processTicksAndRejections (node:internal/process/task_queues:95:5)
      weather-warnings.0
      2023-11-09 18:03:39.834	error	unhandled promise rejection: Cannot read properties of undefined (reading 'join')
      weather-warnings.0
      2023-11-09 18:03:39.833	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        ticaki Developer @Armilar last edited by
        @armilar
        Version?
        Latzi 1 Reply Last reply Reply Quote 0
        • Latzi
          Latzi @ticaki last edited by
          @ticaki
          laut Screenshot 0.5.3 😉
            ticaki Developer @Latzi last edited by ticaki
            @latzi
            Ich gucke mir Bilder i.d.R. nicht direkt an, deshalb danke 🙂
            @Armilar
            Bitte ein Screenshot der UWZ Konfiguration. Ich schätze mal das es für die eingegebenen Koordinaten keine Warnzelle gibt. Das hab ich nicht überprüft und würde zu diesem Fehler führen. Wird in 0.5.4 behoben werden.
            EDIT: Der Screenshot würde mich doch interessieren, ob ich mit meiner Annahme recht habe. Oder die Koordinaten.
            EDIT: falsche Koordinaten war es schon mal nicht. Das gab zwar auch einen Fehler, aber nicht diesen.
            • Armilar
              @ticaki
              klar - alles was du brauchst
              Wenn du noch mehr brauchst, dann bescheid geben
              • Armilar
                Armilar Most Active Forum Testing @Armilar last edited by Armilar
                @armilar
                Es waren natürlich die Koordinaten... Hätte jetzt ehrlich gesagt gedacht, dass er sich die Geodaten aus dem ioBroker zieht...
                Habe auf den Pin gedrückt, die Koordinaten kamen und ...
                Keine Ahnung warum da DE12345 drin stand
                  @armilar
                  Die DE12345 waren mal ganz zu anfang ein Beispiel, Hab die Konfiguration da stark verändert. Wird wohl ein Rest gewesen sein. Jetzt muß ich nur gucken wie es ein DE12345 durch die Checks geschafft hat. Danke.
                    ticaki Developer last edited by ticaki
                    Gleich geht ne neue Version auf den Weg:
                    v0.5.4
                    • Hinzugefügt: Anzahl der maximalen Warnungen pro Provider einstellbar (Default 5)
                    • Behoben: Zufälliger Fehler in den ersten ca 6-15 Sekunden nach Start des Adapters. Die Auswirkungen habe ich wohl schon größten Teils behoben gehabt, jetzt hab ich aber den Grund gefunden. 🙂
                    • Behoben: kleine Sache in den Ruhezeiten
                    • UWZ Warnzellenüberprüfung verbessert.
                    Edit: ist das eigentlich ok das ich unter .warning. keine leeren Standardordner erzeuge, sondern nur wenn auch einen Warnung da ist, bis zur maximalen Anzahl, die man jetzt konfigurieren kann?!
                      ticaki Developer @sigi234 last edited by ticaki
                      @sigi234 sagte in Test Adapter Weather-Warnings:
                      @ticaki
                      Kurz um, welche warntypename gibt es Alle im Ort.
                      Hier sollte dann Gewitter, Glatteis stehen.
                      Deshalb github request. Ich kann mich nichtmal errinnern dass du danach gefragt hast. 😄
                      Sollte jetzt unter .alerts. zu finden sein... Oder hatte ich das schon eingebaut und kann mich auch daran nicht errinnern... Alt werden ist doof, kann ich nicht empfehlen.
                        mp24 last edited by mp24
                        @ticaki
                        Ich habe 2 Warnungen gefunden:
                        und
                        Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40) at WeatherWarnings._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                        und noch: cannot get Warncellid.
                        Ich hatte die Koordinaten eingegeben.
                          ticaki Developer @mp24 last edited by
                          @mp24
                          Bitte gib mir das ganze Log um die Fehler herum. Mit den Fehlermeldungen kann ich leider nichts anfangen
                            mp24 last edited by
                            Ich werde später den Adapter noch einmal installieren und dann mitloggen.
                            Der Admin - Adapter hat gerade diese Fehlermeldung abgegeben:
                            	weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","textSendTo","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                              @mp24
                              Der Admin Adapter hat dir einen fehlerhafte Warnmeldung ins Log geschrieben. Das ist ein Adminproblem und kann ich nicht beheben. Eine Option die ich in der Konfiguration benutze und die funktioniert, wird vom Admin fälschlicherweise als Invalid angesehen.
                              • rtwl
                                rtwl last edited by
                                Falls mehrere Warnungen vorhanden sind (ZAMG). Wie werden denn die Ordner 00-04 in formatedKeys sortiert?
                                  ticaki Developer @rtwl last edited by ticaki
                                  @rtwl
                                  Nach startzeit - außer du änderst die Systemsprache, dann ist die Reihenfolge, wohl auch nach startzeit, aber wird nicht extra kontrolliert.
                                  rtwl 1 Reply Last reply Reply Quote 0
                                  • rtwl
                                    rtwl @ticaki last edited by
                                    @ticaki perfekt, danke!
                                      Hab noch 2 Fehler und 1 was mich nervt gefunden.
                                      1. Vorlage EmailMessage - da fehlt ein Leerzeichen
                                      2. ${status} zeigt noch immer den falschen Wert an bei keiner Warnung
                                      3. Das die Testingoptionen über 2 tabs gehen ist mist - kommt wieder auf die erste Seite.
                                      Wird in der kommenden Version behoben werden. Wahrscheinliche heute abend - für das fehlende Leerzeichen muß ich auf weblate warten.
                                      Ach und Ist schon gefixt oder mit der nächsten Admin version:
                                      • expert kann dann nicht mehr deaktiviert werden
                                      • dwd man kann eigene aber falsche Ortsnamen nicht mehr auswählen.
                                        @ticaki
                                        Hallo, ich möchte wenn keine Warnung ist das Alexa mir das ansagt aber nur bei manuellen auslösen.
                                        Wie mache ich das?
                                        Edit:
                                        Des Weiteren wäre noch ein DP mit true/false interessant ob eine Warnung vorliegt für die Weiterverarbeitung in ein Blockly. Beispiel: Frage an Alexa: Gibt es eine Warnung?
                                        Brauchst du Punkt 1 noch? Das geht bis her nicht.
                                        Punkt 2. sollte mit alerts bzw. dem Zähler für aktive Warnungen ja abgedeckt sein.
                                        update v0.5.5 auf dem weg ins latest, auf npm verfügbar.
                                        update v0.5.6
                                        • die Vorlage für keine Warnung bei manueller Auslösung ist konfigurierbar also auch keine.
                                        • Vorlagenschlüssel die nicht existieren werden rot markiert
                                        Info zu Admin >= v6.12.3
                                        • DWD Auswahl funktioniert wie von mir vorgesehen
                                          v0.6.0
                                          • Hinzugefügt: globale Alarme, in diesen gibt es zusätzlich das Feld Provider.
                                          • Geändert: Token **adverb - wenn kein Adverb vorhanden ist, wird der Tag der Woche verwendet. Entweder ist es gestern, heute, morgen, übermorgen oder Wochentag.
                                          Jetzt ist der nächste halt stable, bin aber Nina langsam am integieren.
                                          Wäre nett wenn ihr in den nächsten 7 Tagen mal bescheid sagt, dass alles geht wie gewünscht.
                                          v0.6.1
                                          • Deutsch nochmal etwas verbessert
                                          • Adminkonfiguration verbessert
                                          • DWD Ortsnamen verbessert
                                            MartyBr @ticaki last edited by
                                            @ticaki hallo @ticaki , ich hatte deinen Adapter bisher auf einen Slave laufen. Dort ist ja kein Admin installiert. Nun habe ich versucht, ein Update durchzuführen, was aber schiefging. Ursache ist der fehlende Admin auf dem Slave.
                                            Ich konnte weather-Warnings ohne Probleme auf dem Master installieren.
                                            Könntest du die Prüfung auf den Admin-Prozess entfernen oder gibt es eine Möglichkeit, den Adapter trotz nicht installiertem Admin auf einen Slave Rechner zu installieren?
                                            1077
                                            265207
