Multihost - Slave tut nix...
So, dann mal hier der Master:
======================= SUMMARY ======================= v.2023-10-10 Static hostname: iobrokermaster Icon name: computer-vm Chassis: vm Virtualization: kvm Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 6.2.0-36-generic Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Installation: kvm Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 1 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs 18.18.2 and npm 9.8.1 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.9G 1.0G 1.6G 34M 1.3G 2.6G Swap: 3.4G 0B 3.4G Total: 7.3G 1.0G 5.0G Active iob-Instances: 4 Active repo(s): stable ioBroker Core: js-controller 5.0.12 admin 6.10.1 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobrokermaster - enabled, port: 8081, bind: 0.0.0.0, run as: admin Objects: 145 States: 103 Size of iob-Database: 3.9M /opt/iobroker/iobroker-data/objects.jsonl 3.8M /opt/iobroker/iobroker-data/objects.json.migrated 3.8M /opt/iobroker/iobroker-data/objects.json.bak.migrated 52K /opt/iobroker/iobroker-data/states.jsonl 16K /opt/iobroker/iobroker-data/states.json.migrated 16K /opt/iobroker/iobroker-data/states.json.bak.migrated =================== END OF SUMMARY ====================und hier der Client:
======================= SUMMARY ======================= v.2023-10-10 Static hostname: iobrokerclient Icon name: computer-desktop Chassis: desktop Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 6.2.0-36-generic Architecture: x86-64 Installation: native Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: true Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 1 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.8G 977M 5.3G 195M 1.5G 6.4G Swap: 2.0G 0B 2.0G Total: 9.9G 977M 7.4G Active iob-Instances: 4 Active repo(s): stable ioBroker Core: js-controller 5.0.12 admin 6.10.1 ioBroker Status: iobroker is running on this host. At least one iobroker host is running. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobrokermaster - enabled, port: 8081, bind: 0.0.0.0, run as: admin Objects: 173 States: 126 Size of iob-Database: 3.9M /opt/iobroker/iobroker-data/objects.jsonl 220K /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================interessant dabei ist das der Client jetzt im Master zu sehen ist, ich habe alles nochmal neu aufgesetzt. im Client iobroker multihost connect bleibt aber wie vorher ohne weitere Meldung, der Promt wandert eine Zeil tiefer und blinkt dort nur noch vor sich hin, somit auch keine Möglichkeit den Master auszuwählen, geschweige denn ein Passwort einzugeben. Womit sich jetzt die Frage stellt wie er sich mit dem Master verbinden konnte (die Systempasswörter und für den Connect wären aber alle Identisch).
das einzige was jetzt anders gemacht wurde - ich habe noch keine updates im iobroker gemacht...
@bahnuhr lass es Bitte
@bluehannover sagte in Multihost - Slave tut nix...:
Der macht mit Multihost-Neueinrichtungen Probleme.
deshalb mein Link schon dazu ... da ich nicht wußte was er hat :
@glasfaser sagte in Multihost - Slave tut nix...:
@bluehannover sagte in Multihost - Slave tut nix...:blinkt munter vor sich hin..
da hier nichts von deiner Systemumgebung angegeben ist ... kann man nur raten !
dieses war mal hier so :
https://forum.iobroker.net/post/1055387
https://forum.iobroker.net/topic/68802/gelöst-hilfe-bei-multihost -
@glasfaser Sorry, dachte falsch verstanden:
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobrokermaster Icon name: computer-vm Chassis: vm Virtualization: kvm Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 6.2.0-36-generic Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : amd64 Systemuptime and Load: 18:25:40 up 32 min, 2 users, load average: 0.46, 0.15, 0.09 CPU threads: 2 *** Time and Time Zones *** Local time: Sat 2023-11-11 18:25:40 CET Universal time: Sat 2023-11-11 17:25:40 UTC RTC time: Sat 2023-11-11 17:25:40 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** master /home/master master adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker *** X-Server-Setup *** X-Server: false Desktop: ubuntu Terminal: wayland Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 3.9G 1.7G 270M 38M 1.9G 1.9G Swap: 3.4G 5.0M 3.4G Total: 7.3G 1.7G 3.7G 3907 M total memory 1729 M used memory 942 M active memory 2394 M inactive memory 270 M free memory 57 M buffer memory 1850 M swap cache 3429 M total swap 5 M used swap 3424 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 391M 1.6M 390M 1% /run /dev/sda3 ext4 31G 15G 15G 51% / tmpfs tmpfs 2.0G 0 2.0G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda2 vfat 512M 6.1M 506M 2% /boot/efi tmpfs tmpfs 391M 104K 391M 1% /run/user/1000 /dev/sr0 iso9660 4.7G 4.7G 0 100% /media/master/Ubuntu 22.04.3 LTS amd64 Messages concerning ext4 filesystem in dmesg: [Sat Nov 11 17:53:41 2023] EXT4-fs (sda3): mounted filesystem 91234521-1cf2-4a18-9713-9ac651eb2267 with ordered data mode. Quota mode: none. [Sat Nov 11 17:53:42 2023] EXT4-fs (sda3): re-mounted 91234521-1cf2-4a18-9713-9ac651eb2267. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda3 ext4 rw,relatime,errors=remount-ro |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 |-/snap/bare/5 /dev/loop0 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core22/858 /dev/loop1 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core20/1974 /dev/loop2 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/firefox/2987 /dev/loop3 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/gnome-42-2204/120 /dev/loop5 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/gnome-3-38-2004/143 /dev/loop4 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/curl/1754 /dev/loop6 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd-desktop-integration/83 /dev/loop7 squashfs ro,nodev,relatime,errors=continue,threads=single |-/var/snap/firefox/common/host-hunspell /dev/sda3[/usr/share/hunspell] ext4 ro,noexec,noatime,errors=remount-ro |-/snap/snapd/19457 /dev/loop9 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/gtk-common-themes/1535 /dev/loop10 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snap-store/959 /dev/loop8 squashfs ro,nodev,relatime,errors=continue,threads=single |-/boot/efi /dev/sda2 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro `-/media/master/Ubuntu 22.04.3 LTS amd64 /dev/sr0 iso9660 ro,nosuid,nodev,relatime,nojoliet,check=s,map=n,blocksize=2048,uid=1000,gid=1000,dmode=500,fmode=400,iocharset=utf8 Files in neuralgic directories: /var: 3.9G /var/ 3.1G /var/lib 2.7G /var/lib/snapd 1.4G /var/lib/snapd/snaps 1.4G /var/lib/snapd/seed/snaps Archived and active journals take up 32.0M in the file system. /opt/iobroker/backups: 1.3M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 28M /opt/iobroker/iobroker-data/ 15M /opt/iobroker/iobroker-data/files 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static 13M /opt/iobroker/iobroker-data/files/admin.admin/custom The five largest files in iobroker-data are: find: '/dev/serial/by-id/': No such file or directory 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 3.9M /opt/iobroker/iobroker-data/objects.jsonl 3.8M /opt/iobroker/iobroker-data/objects.json.migrated 3.8M /opt/iobroker/iobroker-data/objects.json.bak.migrated 2.8M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 12.22.9~dfsg-1ubuntu3.1 500 500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages 500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.12 admin: 6.12.0 javascript: "javascript" not found Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : iobrokermaster - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobrokermaster - enabled + system.adapter.discovery.0 : discovery : iobrokermaster - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobrokermaster - enabled, port: 8081, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "backitup" : 2.8.7 , installed 2.8.7 Adapter "discovery" : 3.1.0 , installed 3.1.0 Controller "js-controller": 5.0.12 , installed 5.0.12 Objects and States Please stand by - This may take a while Objects: 174 States: 127 *** OS-Repositories and Updates *** Hit:1 https://linux.teamviewer.com/deb stable InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 1803 1/init tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 101 18173 366/systemd-resolve tcp 0 0 127.0.0.1:5939 0.0.0.0:* LISTEN 0 46859 5027/teamviewerd tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 22788 510/iobroker.js-con tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 22796 510/iobroker.js-con tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 20818 507/cupsd tcp6 0 0 :::111 :::* LISTEN 0 1805 1/init tcp6 0 0 ::1:631 :::* LISTEN 0 20817 507/cupsd tcp6 0 0 :::8081 :::* LISTEN 1001 48970 5514/io.admin.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 114 19821 416/avahi-daemon: r udp 0 0 0.0.0.0:48998 0.0.0.0:* 0 50397 5027/teamviewerd udp 0 0 127.0.0.53:53 0.0.0.0:* 101 18172 366/systemd-resolve udp 0 0 0.0.0.0:111 0.0.0.0:* 0 1804 1/init udp 0 0 0.0.0.0:631 0.0.0.0:* 0 21184 581/cups-browsed udp 0 0 0.0.0.0:58293 0.0.0.0:* 114 19823 416/avahi-daemon: r udp6 0 0 :::5353 :::* 114 19822 416/avahi-daemon: r udp6 0 0 :::111 :::* 0 1806 1/init udp6 0 0 :::60348 :::* 114 19824 416/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-11-11 18:09:57.828 - info: admin.0 (915) ==> Connected system.user.admin from ::ffff:192.168.20.224 2023-11-11 18:21:53.042 - info: host.iobrokermaster "system.adapter.admin.0" disabled 2023-11-11 18:21:53.043 - info: host.iobrokermaster stopInstance system.adapter.admin.0 (force=false, process=true) 2023-11-11 18:21:53.045 - info: admin.0 (915) Got terminate signal TERMINATE_YOURSELF 2023-11-11 18:21:53.047 - info: admin.0 (915) terminating http server on port 8081 2023-11-11 18:21:53.048 - info: admin.0 (915) terminating 2023-11-11 18:21:53.048 - info: admin.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-11-11 18:21:53.087 - info: host.iobrokermaster stopInstance system.adapter.admin.0 send kill signal 2023-11-11 18:21:53.550 - info: admin.0 (915) terminating 2023-11-11 18:21:53.569 - info: host.iobrokermaster instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-11-11 18:21:56.048 - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Server is running on http://localhost:8081 2023-11-11 18:22:00.291 - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Successfully upgraded admin to version 6.12.0 2023-11-11 18:22:01.393 - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Final information delivered 2023-11-11 18:22:01.397 - info: host.iobrokermaster "system.adapter.admin.0" enabled 2023-11-11 18:22:01.398 - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Successfully started adapter 2023-11-11 18:22:01.461 - info: host.iobrokermaster instance system.adapter.admin.0 started with pid 5514 2023-11-11 18:22:02.217 - info: admin.0 (5514) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12 2023-11-11 18:22:02.236 - info: admin.0 (5514) requesting all objects 2023-11-11 18:22:02.401 - info: admin.0 (5514) received all objects 2023-11-11 18:22:02.516 - info: admin.0 (5514) socket.io server listening on port 8081 2023-11-11 18:22:02.517 - info: admin.0 (5514) http server listening on port 8081 2023-11-11 18:22:02.517 - info: admin.0 (5514) Use link "http://127.0.0.1:8081" to configure. 2023-11-11 18:22:04.227 - info: admin.0 (5514) ==> Connected system.user.admin from ::ffff:192.168.20.224 2023-11-11 18:22:04.859 - info: admin.0 (5514) <== Disconnect system.user.admin from ::ffff:192.168.20.224 admin 2023-11-11 18:22:10.688 - info: admin.0 (5514) ==> Connected system.user.admin from ::ffff:192.168.20.224Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobrokerclient Icon name: computer-desktop Chassis: desktop Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 6.2.0-36-generic Architecture: x86-64 model name : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz Docker : false Virtualization : none Kernel : x86_64 Userland : amd64 Systemuptime and Load: 18:28:55 up 21 min, 2 users, load average: 0.34, 0.27, 0.29 CPU threads: 4 *** Time and Time Zones *** Local time: Sat 2023-11-11 18:28:55 CET Universal time: Sat 2023-11-11 17:28:55 UTC RTC time: Sat 2023-11-11 17:28:55 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** client /home/client client adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker *** X-Server-Setup *** X-Server: true Desktop: ubuntu-xorg Terminal: x11 Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 1.0G 5.3G 212M 1.6G 6.4G Swap: 2.0G 0B 2.0G Total: 9.9G 1.0G 7.3G 7829 M total memory 1006 M used memory 621 M active memory 1453 M inactive memory 5270 M free memory 54 M buffer memory 1498 M swap cache 2047 M total swap 0 M used swap 2047 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 783M 1.8M 782M 1% /run /dev/sda2 ext4 55G 14G 39G 26% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 511M 6.1M 505M 2% /boot/efi tmpfs tmpfs 783M 104K 783M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sat Nov 11 18:07:13 2023] EXT4-fs (sda2): mounted filesystem 406be6a0-17ec-4dbb-b69a-8cd7f490e14f with ordered data mode. Quota mode: none. [Sat Nov 11 18:07:13 2023] EXT4-fs (sda2): re-mounted 406be6a0-17ec-4dbb-b69a-8cd7f490e14f. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,relatime,errors=remount-ro |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 |-/snap/bare/5 /dev/loop1 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core20/1974 /dev/loop0 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core22/858 /dev/loop2 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/firefox/2987 /dev/loop3 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/curl/1754 /dev/loop4 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/gnome-3-38-2004/143 /dev/loop5 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/gnome-42-2204/120 /dev/loop6 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/gtk-common-themes/1535 /dev/loop7 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/19457 /dev/loop9 squashfs ro,nodev,relatime,errors=continue,threads=single |-/var/snap/firefox/common/host-hunspell /dev/sda2[/usr/share/hunspell] ext4 ro,noexec,noatime,errors=remount-ro |-/snap/snapd-desktop-integration/83 /dev/loop10 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snap-store/959 /dev/loop8 squashfs ro,nodev,relatime,errors=continue,threads=single `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 3.9G /var/ 3.1G /var/lib 2.7G /var/lib/snapd 1.4G /var/lib/snapd/snaps 1.4G /var/lib/snapd/seed/snaps Archived and active journals take up 40.0M in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 19M /opt/iobroker/iobroker-data/ 15M /opt/iobroker/iobroker-data/files 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static 13M /opt/iobroker/iobroker-data/files/admin.admin/custom The five largest files in iobroker-data are: 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 3.9M /opt/iobroker/iobroker-data/objects.jsonl 2.8M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js 1.6M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map 652K /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 12.22.9~dfsg-1ubuntu3.1 500 500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages 500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.12 admin: 6.10.1 javascript: "javascript" not found Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : iobrokermaster - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobrokermaster - enabled + system.adapter.discovery.0 : discovery : iobrokermaster - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobrokermaster - enabled, port: 8081, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.10.1 [Updatable] Adapter "backitup" : 2.8.7 , installed 2.8.7 Adapter "discovery" : 3.1.0 , installed 3.1.0 Controller "js-controller": 5.0.12 , installed 5.0.12 Objects and States Please stand by - This may take a while Objects: 174 States: 127 *** OS-Repositories and Updates *** Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:3 https://linux.teamviewer.com/deb stable InRelease Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:6 http://security.ubuntu.com/ubuntu jammy-security InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 101 23098 468/systemd-resolve tcp 0 0 127.0.0.1:5939 0.0.0.0:* LISTEN 0 29980 1565/teamviewerd tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 24143 670/cupsd tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 16964 1/init tcp6 0 0 ::1:631 :::* LISTEN 0 24142 670/cupsd tcp6 0 0 :::111 :::* LISTEN 0 16966 1/init udp 0 0 127.0.0.53:53 0.0.0.0:* 101 23097 468/systemd-resolve udp 0 0 0.0.0.0:111 0.0.0.0:* 0 16965 1/init udp 0 0 0.0.0.0:631 0.0.0.0:* 0 30824 1544/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 114 27154 574/avahi-daemon: r udp 0 0 0.0.0.0:50463 0.0.0.0:* 114 27156 574/avahi-daemon: r udp 0 0 0.0.0.0:39577 0.0.0.0:* 0 40199 1565/teamviewerd udp6 0 0 :::111 :::* 0 16967 1/init udp6 0 0 :::45934 :::* 114 27157 574/avahi-daemon: r udp6 0 0 :::5353 :::* 114 27155 574/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-11-11 18:06:54.687 - info: host.iobrokerclient instance system.adapter.admin.0 terminated with code 0 (NO_ERROR) 2023-11-11 18:06:54.688 - info: host.iobrokerclient All instances are stopped. 2023-11-11 18:06:54.899 - info: host.iobrokerclient terminated 2023-11-11 18:07:19.924 - info: host.iobrokerclient iobroker.js-controller version 5.0.12 js-controller starting 2023-11-11 18:07:19.928 - info: host.iobrokerclient Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2023-11-11 18:07:19.929 - info: host.iobrokerclient hostname: iobrokerclient, node: v18.18.2 2023-11-11 18:07:19.930 - info: host.iobrokerclient ip addresses: 2023-11-11 18:07:49.956 - error: host.iobrokerclient No connection to databases possible, restart 2023-11-11 18:07:49.960 - info: host.iobrokerclient iobroker _restart 2023-11-11 18:07:50.601 - info: host.iobrokerclient iobroker Starting node restart.js 2023-11-11 18:07:50.607 - error: host.iobrokerclient [sendTo] Could not push message "{ command: 'cmdStdout', message: { id: undefined, data: 'Starting node restart.js' }, from: 'system.host.iobrokerclient' }" to "system.host.iobrokerclient": Cannot read properties of null (reading 'pushMessage') 2023-11-11 18:07:55.054 - info: host.iobrokerclient iobroker.js-controller version 5.0.12 js-controller starting 2023-11-11 18:07:55.058 - info: host.iobrokerclient Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2023-11-11 18:07:55.058 - info: host.iobrokerclient hostname: iobrokerclient, node: v18.18.2 2023-11-11 18:07:55.059 - info: host.iobrokerclient ip addresses: 192.168.20.115 fe80::3a77:89f:66f8:985 2023-11-11 18:07:55.204 - info: host.iobrokerclient connected to Objects and States 2023-11-11 18:07:55.218 - info: host.iobrokerclient Node.js version has changed from unknown to 18.18.2 2023-11-11 18:07:55.243 - info: host.iobrokerclient added notifications configuration of host 2023-11-11 18:07:55.265 - info: host.iobrokerclient Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node 2023-11-11 18:07:55.546 - info: host.iobrokerclient 3 instances found 2023-11-11 18:07:55.548 - warn: host.iobrokerclient does not start any instances on this host -
die Lösung dazu , habe ich dir schon geschrieben !
Schalt die Desktops auf den beiden Kisten aus.
... wofür das !?
Damit man auf den unnötigen Desktops auch was zu klicken hat...
@thomas-braun das ist damit auch mal jemand von aussen helfen kann..
aber ausser Ressourcen doch jetzt kein Problem, oder?
Das 'von außen über eine GUI' ist genau das Problem.
Auf Servern läuft KEINE GUI.
Aus 1000 Gründen. -
@thomas-braun So ein Windowsserver hat auch ne GUI... aber wir sind ja im Einsteigerbereich, ich lerne also noch.
Und die 1000 Gründe werden die Sicherheit sein, also müsste man auch klären wie sich der client jetzt ohne Passwort verbinden konnte
Auch.
Neben Ressourcen des GUI, der Stabilität des GUI, der höheren Komplexität des GUI usw...Die gleichen Gründe sprechen aber auch unter Windows gegen eine GUI.
Dann kannste ja als erste Lektion lernen: Kein Desktop mit allem Zipp und Zapp auf einem Server.
