Error Node-Red
@haselchen sagte in Error Node-Red:
iob diag
I'm sorry is late!
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: AquaPi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 04:11:43 up 1:49, 2 users, load average: 4.90, 4.37, 4.26 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: ~ Under-voltage detected ~ Arm frequency capped Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred *** Time and Time Zones *** Local time: Sun 2023-11-12 04:11:44 CET Universal time: Sun 2023-11-12 03:11:44 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 2.0G 557M 40M 1.3G 2.2G Swap: 99M 2.0M 97M Total: 3.9G 2.0G 655M 3838 M total memory 1968 M used memory 669 M active memory 2430 M inactive memory 557 M free memory 218 M buffer memory 1093 M swap cache 99 M total swap 2 M used swap 97 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** 0 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 23G 4.3G 85% / devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 1.9G 42M 1.9G 3% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 384M 0 384M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var:
@aphofis sagte in Error Node-Red:
Current issues:
~ Arm frequency cappedNetzteil kaputt oder das Falsche fürn 4er Raspi?!
Und dann ist Dein OS Buster...updaten auf Bullseye oder Bookworm
Und dann die Langfassung von iob diag bitte.
Edit:
Viel zu hoch. Da rödelt auch was ordentlich.
@haselchen
Wie ich load average einstelle weiß ich nicht.
und OS umstellen auf zB Bullseye muss ich mal gucken wie das funktioniert.
Netzteil ist Original passend mit dem Pi in einem Paket gekauft.@Homoran Danke fürs verschieben in die richtige Abteilung
das war alles aus iob diag
nee, der war noch lange nicht fertig.
warten!@aphofis sagte in Error Node-Red:
dann ist es entweder Schrott, oder es hängt viel zu viel an den USB Ports.
gar nicht.
ist die Anzeige wie sehr sich dein Rechner quält.@aphofis sagte in Error Node-Red:
wie löse ich denn den full check aus !?
iob diag
starten und wenn das fertig ist keine Taste drücken -
ja hab ich gemerkt da kommt noch mehr ! War etwas spät heute nacht.
So nu aber:======================= SUMMARY ======================= v.2023-10-10 Static hostname: AquaPi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Installation: native Kernel: armv7l Userland: armhf Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: true Boot Target: graphical.target Pending OS-Updates: 72 Pending iob updates: 32 Nodejs-Installation: /usr/bin/nodejs v16.20.2 /usr/bin/node v16.20.2 /usr/bin/npm 8.19.4 /usr/bin/npx 8.19.4 /usr/bin/corepack 0.17.0 Recommended versions are nodejs 18.18.2 and npm 9.8.1 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.8G 2.2G 271M 172M 1.4G 1.8G Swap: 99M 46M 53M Total: 3.9G 2.2G 324M Active iob-Instances: 30 Active repo(s): Stable (default) ioBroker Core: js-controller 5.0.12 admin 6.12.0 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : AquaPi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : AquaPi - enabled, port: 8084, bind: 0.0.0.0, run as: admin Objects: 2 States: 14166 Size of iob-Database: 27M /opt/iobroker/iobroker-data/objects.jsonl 16M /opt/iobroker/iobroker-data/objects.json.migrated 16M /opt/iobroker/iobroker-data/objects.json.bak.migrated 4.0M /opt/iobroker/iobroker-data/objects.json.broken 75M /opt/iobroker/iobroker-data/states.jsonl 2.9M /opt/iobroker/iobroker-data/states.json.migrated 2.9M /opt/iobroker/iobroker-data/states.json.bak.migrated 0 /opt/iobroker/iobroker-data/states.json.broken =================== END OF SUMMARY ====================
zumindest ist das alles was iob diag ausspuckt
updaten!
updaten!
updaten!
dann hast du aber
@homoran sagte in Error Node-Red:
nicht befolgt
ich bin gerade dabei update upgrade zu machen bzw auf Bullseye upzudaten -
Bullseye upzudaten
Installer es komplett neu.
Diesmal als 64Bit Lite Version. -
Ob die Update Versuche helfen?
In dem System ist alles breit .
Sogar der Swap wird schon angeknabbert.
Eigentlich hilft nur ne saubere Neuinstallation mit Backup.Vorher Node Red Ordner , Skripte , VIS sichern……
Mag gutgehen die Updaterei, aber die Erfahrungen zeigen , dass es ein Flickenteppich wird .
Edit: und kontrolliere das Netzteil. Privat im Paket gekauft oder in einem renommierten Shop?
Und wie @Homoran schon fragte , zuviele Abnehmer an den USB Ports?
Ansonsten, 15€ investieren und neues Netzteil kaufen. -
@haselchen
OK klingt plausibel ist nur ne menge Arbeit
Hatte den Pi auch noch nie neu aufgesetzt seid dem er nicht mehr für das Meerwasser Aquarium zuständig ist. -
Bei einem renomierten Verkäufer! Sowas kaufe ich nicht privat.
An den USB Ports hängt nichts dran. -
Die Stromversorgung wird aber nachhaltig bemängelt. Da stimmt was nicht.
Neben den anderen Baustellen... -
So Betriebssystem neu Bullseye in 64 bit iobroker neu installiert wie siehts denn jetzt aus !?======== Start marking the full check here ========= Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: GordonX-Home Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : aarch64 Userland : armhf Systemuptime and Load: 11:44:25 up 18:55, 2 users, load average: 5.02, 3.60, 3.22 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: ~ Under-voltage detected ~ Arm frequency capped Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred *** Time and Time Zones *** Local time: Sun 2023-12-10 11:44:26 CET Universal time: Sun 2023-12-10 10:44:26 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp admin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: true Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 3.7G 1.9G 768M 1.0M 1.1G 1.8G Swap: 99M 0B 99M Total: 3.8G 1.9G 868M 3744 M total memory 1874 M used memory 2012 M active memory 727 M inactive memory 768 M free memory 111 M buffer memory 990 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 12G 16G 42% / devtmpfs devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 749M 1.1M 748M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 51M 205M 20% /boot tmpfs tmpfs 375M 20K 375M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc harset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 593M /var/ 202M /var/log 164M /var/lib 125M /var/cache 115M /var/cache/apt Archived and active journals take up 96.0M in the file system. /opt/iobroker/backups: 11M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 480M /opt/iobroker/iobroker-data/ 414M /opt/iobroker/iobroker-data/files 131M /opt/iobroker/iobroker-data/files/vis-2 76M /opt/iobroker/iobroker-data/files/vis-2/static 75M /opt/iobroker/iobroker-data/files/vis-2/static/js The five largest files in iobroker-data are: 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m ap 23M /opt/iobroker/iobroker-data/objects.jsonl 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m ap 21M /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.6c01 4a31.js.map 18M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.3d92bcec.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package s Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.16 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : GordonX-Home - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as : admin + system.adapter.alarm.0 : alarm : GordonX-Home - enabled + system.adapter.alexa-timer-vis.0 : alexa-timer-vis : GordonX-Home - enabled + system.adapter.alexa2.0 : alexa2 : GordonX-Home - enabled + system.adapter.backitup.0 : backitup : GordonX-Home - enabled system.adapter.daswetter.0 : daswetter : GordonX-Home - enabled + system.adapter.discovery.0 : discovery : GordonX-Home - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : GordonX-Home - enabled system.adapter.flot.0 : flot : GordonX-Home - enabled + system.adapter.fritzbox.0 : fritzbox : GordonX-Home - enabled + system.adapter.fritzdect.0 : fritzdect : GordonX-Home - enabled + system.adapter.fullcalendar.0 : fullcalendar : GordonX-Home - enabled system.adapter.fullybrowser.0 : fullybrowser : GordonX-Home - disabled + system.adapter.harmony.0 : harmony : GordonX-Home - enabled system.adapter.hass.0 : hass : GordonX-Home - disabled, port: 8123 + system.adapter.history.0 : history : GordonX-Home - enabled + system.adapter.hue.0 : hue : GordonX-Home - enabled, port: 443 system.adapter.ical.0 : ical : GordonX-Home - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Gor donX-Home - enabled system.adapter.icons-icons8.0 : icons-icons8 : GordonX-Home - enabled system.adapter.influxdb.0 : influxdb : GordonX-Home - disabled, port: 8086 + system.adapter.iot.0 : iot : GordonX-Home - enabled + system.adapter.javascript.0 : javascript : GordonX-Home - enabled + system.adapter.node-red.0 : node-red : GordonX-Home - enabled, port: 1880, bind: 0.0.0.0 system.adapter.octoprint.0 : octoprint : GordonX-Home - disabled system.adapter.owfs.0 : owfs : GordonX-Home - disabled, port: 4304 + system.adapter.roborock.0 : roborock : GordonX-Home - enabled + system.adapter.rpi2.0 : rpi2 : GordonX-Home - enabled + system.adapter.smartthings.0 : smartthings : GordonX-Home - enabled + system.adapter.sql.0 : sql : GordonX-Home - enabled, port: 3307 + system.adapter.synology.0 : synology : GordonX-Home - enabled, port: 5001 + system.adapter.telegram-menu.0 : telegram-menu : GordonX-Home - enabled + system.adapter.telegram.0 : telegram : GordonX-Home - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : GordonX-Home - enabled + system.adapter.tr-064.0 : tr-064 : GordonX-Home - enabled + system.adapter.tuya.0 : tuya : GordonX-Home - enabled + system.adapter.vis-2.0 : vis-2 : GordonX-Home - enabled system.adapter.vis-bars.0 : vis-bars : GordonX-Home - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : GordonX-Home - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : GordonX-Home - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : GordonX-Home - enabled system.adapter.vis-icontwo.0 : vis-icontwo : GordonX-Home - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : GordonX-Home - enabled system.adapter.vis.0 : vis : GordonX-Home - disabled + system.adapter.web.0 : web : GordonX-Home - enabled, port: 8082, bind: 0.0.0.0, run as: admi n + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : GordonX-Home - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.hue.0 : hue : GordonX-Home - enabled, port: 443 + system.adapter.node-red.0 : node-red : GordonX-Home - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.sql.0 : sql : GordonX-Home - enabled, port: 3307 + system.adapter.synology.0 : synology : GordonX-Home - enabled, port: 5001 + system.adapter.telegram.0 : telegram : GordonX-Home - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : GordonX-Home - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "alarm" : 3.4.3 , installed 3.4.3 Adapter "alexa-timer-vis": 0.2.0 , installed 0.2.0 Adapter "alexa2" : 3.26.3 , installed 3.26.3 Adapter "backitup" : 2.8.7 , installed 2.8.7 Adapter "daswetter" : 3.1.11 , installed 3.1.10 [Updatable] Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzbox" : 0.5.0 , installed 0.5.0 Adapter "fritzdect" : 2.5.9 , installed 2.3.1 [Updatable] Adapter "fullcalendar" : 2.2.6 , installed 2.2.6 Adapter "fullybrowser" : 3.0.6 , installed 3.0.6 Adapter "harmony" : 1.3.0 , installed 1.3.0 Adapter "hass" : 1.4.0 , installed 1.4.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hue" : 3.10.1 , installed 3.10.1 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.16 , installed 5.0.16 Adapter "node-red" : 4.0.3 , installed 4.0.3 Adapter "octoprint" : 5.1.0 , installed 5.1.0 Adapter "owfs" : 0.7.0 , installed 0.7.0 Adapter "roborock" : 0.4.4 , installed 0.4.4 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartthings" : 0.0.4 , installed 0.0.4 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sql" : 2.2.0 , installed 2.2.0 Adapter "synology" : 3.0.1 , installed 3.0.1 Adapter "telegram" : 3.0.0 , installed 3.0.0 Adapter "telegram-menu": 0.8.5 , installed 0.8.5 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 0.98.0 , installed 0.98.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "ws" : 2.5.8 , installed 2.5.8 Objects and States Please stand by - This may take a while Objects: 15236 States: 11961 *** OS-Repositories and Updates *** W: GPG error: https://repos.influxdata.com/ubuntu bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E E: The repository 'https://repos.influxdata.com/ubuntu bullseye InRelease' is not signed. Pending Updates: 1 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 118 163682 8961/influxd tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 24810 1640/node-red tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 16623 559/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 18433 559/iobroker.js-con tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15629 592/sshd: /usr/sbin tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 995325 26097/cupsd tcp6 0 0 ::1:631 :::* LISTEN 0 995324 26097/cupsd tcp6 0 0 :::8082 :::* LISTEN 1001 278145 15570/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 23200 1123/io.admin.0 tcp6 0 0 :::8086 :::* LISTEN 118 161441 8961/influxd tcp6 0 0 :::22 :::* LISTEN 0 14142 592/sshd: /usr/sbin tcp6 0 0 :::4369 :::* LISTEN 0 13802 1/init tcp6 0 0 :::61991 :::* LISTEN 1001 22479 1894/io.harmony.0 udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 27656 1579/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 27657 1579/io.tuya.0 udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 22480 1894/io.harmony.0 udp 0 0 0.0.0.0:631 0.0.0.0:* 0 998442 26103/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 115551 6077/avahi-daemon: udp 0 0 0.0.0.0:48483 0.0.0.0:* 108 115553 6077/avahi-daemon: udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15683 483/dhcpcd udp6 0 0 :::546 :::* 0 14328 483/dhcpcd udp6 0 0 :::33783 :::* 108 115554 6077/avahi-daemon: udp6 0 0 :::5353 :::* 108 115552 6077/avahi-daemon: *** Log File - Last 25 Lines *** 2023-12-10 11:48:18.453 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpBlue.png": Error: Not exists 2023-12-10 11:48:18.680 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorz.png": Error: Not exists 2023-12-10 11:48:18.776 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorzDockClosed.png": Error: Not exists 2023-12-10 11:48:19.281 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorzDockOpen.png": Error: Not exists 2023-12-10 11:48:19.744 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsVert.png": Error: Not exists 2023-12-10 11:48:19.977 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpRed.png": Error: Not exists 2023-12-10 11:48:20.360 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTextHorz.png": Error: Not exists 2023-12-10 11:48:20.789 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTextVert.png": Error: Not exists 2023-12-10 11:48:21.010 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTransp.png": Error: Not exists 2023-12-10 11:48:21.537 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-bottom.png": Error: Not exists 2023-12-10 11:48:21.780 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-left.png": Error: Not exists 2023-12-10 11:48:21.969 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-right.png": Error: Not exists 2023-12-10 11:48:21.992 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-top.png": Error: Not exists 2023-12-10 11:48:22.066 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/js/bars.js": Error: Not exists 2023-12-10 11:48:22.087 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/js/jquery.sidebar.js": Error: Not exists 2023-12-10 11:48:22.145 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars.html": Error: Not exists 2023-12-10 11:48:22.187 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/css/table.css": Error: Not exists 2023-12-10 11:48:22.201 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/doc.html": Error: Not exists 2023-12-10 11:48:22.475 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_AckBool.png": Error: Not exists 2023-12-10 11:48:22.524 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_BasicState.png": Error: Not exists 2023-12-10 11:48:22.775 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_BulbOnOffCtrl.png": Error: Not exists 2023-12-10 11:48:23.063 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_ContainerView.png": Error: Not exists 2023-12-10 11:48:23.385 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_FilterDropdown.png": Error: Not exists 2023-12-10 11:48:23.834 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_FullScreen.png": Error: Not exists 2023-12-10 11:48:24.156 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_HTML.png": Error: Not exists ============ Mark until here for C&P =============
oder sollte ich doch ein neues Netzteil kaufen !? Das jetzige ist extra für den Pi4 gekauft und hat 3A aber vllt hat es auch in der Technik gelitten als es im Unterschrank vom Meerwasser Aquarium gesteckt hatte. Es war zwar die Technik abgeschirmt mit einer Acryl Platte aber die Meer Luft ist ja trotzdem im Raum die sogar dazu geführt hatte das ich die Pi Lüfter regelmäßig jedes Jahr tauschen musste da diese durch Slaz Luft verklebt waren.
Spannungsversorgung immer noch schlapp.
also neues Netzteil -
Bullseye in 64 bit
Nö, das ist noch ein Mix aus 64bit-Kernel und 32bit-Userland.
Ich hatte alles komplett neu aufgesetzt -
zu hoch für 4 Kerne.
Graphisches Gedönse ausschalten...
Ich dachte du hättest die Kiste neuaufgesetzt... Warum dann nicht gleich gescheit?
Hab ich doch!
Nur wenn ein Touchscreen Display dran kommt brauche ich doch grafische unterstützung
