    4. Immer gleiche Warnung im Protokoll....
      Vermutlich.
      Unix und Linux sind sich ja sehr ähnlich...
        Peter c last edited by
        @thomas-braun Habe es jetzt mit dem Apple geschafft die diagnose zu starten und das einzufügen.
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Static hostname: iobroker
        Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
        Kernel: Linux 6.1.21-v8+
        Architecture: arm64
        Model : Raspberry Pi 4 Model B Rev 1.1
        Docker : false
        Virtualization : none
        Kernel : aarch64
        Userland : armhf
        Systemuptime and Load:
        19:37:08 up 102 days, 5:38, 3 users, load average: 0.83, 0.41, 0.23
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
        Local time: Sun 2023-11-12 19:37:08 CET
        Universal time: Sun 2023-11-12 18:37:08 UTC
        RTC time: n/a
        NTP service: active
        RTC in local TZ: no
        *** User and Groups ***
        pt
        /home/pt
        pt adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: true
        Desktop:
        Terminal: tty
        Boot Target: graphical.target
        *** MEMORY ***
        total used free shared buff/cache available
        Mem: 3.8G 1.6G 864M 35M 1.3G 2.0G
        Swap: 99M 0B 99M
        Total: 3.9G 1.6G 964M
             3794 M total memory
             1634 M used memory
             1907 M active memory
              716 M inactive memory
              864 M free memory
              148 M buffer memory
             1147 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem Type Size Used Avail Use% Mounted on
        /dev/root ext4 29G 5.1G 23G 19% /
        devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
        tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
        tmpfs tmpfs 759M 1.2M 758M 1% /run
        tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
        /dev/mmcblk0p1 vfat 255M 51M 205M 20% /boot
        tmpfs tmpfs 380M 20K 380M 1% /run/user/1000
        [Wed Aug 2 14:58:41 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:1F:EE:06 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=00900e5c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Wed Aug 2 14:58:42 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Aug 2 14:58:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Aug 2 14:58:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET SOURCE FSTYPE OPTIONS
        / /dev/mmcblk0p2 ext4 rw,noatime
        `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        587M /var/
        235M /var/log
        233M /var/log/journal/061ea1674ff8454f9e4d5c7dfa8e6e06
        128M /var/cache
        Archived and active journals take up 232.0M in the file system.
        /opt/iobroker/backups:
        41M /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        205M /opt/iobroker/iobroker-data/
        152M /opt/iobroker/iobroker-data/files
        52M /opt/iobroker/iobroker-data/files/javascript.admin
        35M /opt/iobroker/iobroker-data/backup-objects
        34M /opt/iobroker/iobroker-data/files/javascript.admin/static
        21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        18M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        14M /opt/iobroker/iobroker-data/objects.jsonl
        8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        8.0M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        *** NodeJS-Installation ***
        /home/iobroker/.diag.sh: line 277: nodejs: command not found
        /usr/bin/node v18.17.0
        /usr/bin/npm 9.6.7
        /usr/bin/npx 9.6.7
        /usr/bin/corepack 0.18.0
        /home/iobroker/.diag.sh: line 288: nodejs: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
        Installed: 18.17.0-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
        18.17.1-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
        *** 18.17.0-deb-1nodesource1 100
        100 /var/lib/dpkg/status
        12.22.12~dfsg-1~deb11u4 500
        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        Core adapters versions
        js-controller: 5.0.12
        admin: 6.12.0
        javascript: 7.1.4
        Adapters from github: 3
        Adapter State
        • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        • system.adapter.alexa2.0 : alexa2 : iobroker - enabled
        • system.adapter.backitup.0 : backitup : iobroker - enabled
        • system.adapter.bmw.0 : bmw : iobroker - enabled
          system.adapter.cloud.0 : cloud : iobroker - disabled
        • system.adapter.device-reminder.0 : device-reminder : iobroker - enabled
        • system.adapter.discovery.0 : discovery : iobroker - enabled
        • system.adapter.energiefluss.0 : energiefluss : iobroker - enabled
        • system.adapter.fritzdect.0 : fritzdect : iobroker - enabled
        • system.adapter.javascript.0 : javascript : iobroker - enabled
        • system.adapter.modbus.0 : modbus : iobroker - enabled
        • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.94
        • system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 0.0.0.0
        • system.adapter.pushover.0 : pushover : iobroker - enabled
        • system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0
        • system.adapter.text2command.0 : text2command : iobroker - enabled
        • system.adapter.tibberlink.0 : tibberlink : iobroker - enabled
          system.adapter.vis.0 : vis : iobroker - enabled
        • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        • system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - enabled
        • instance is alive
        ioBroker-Repositories
        stable : http://download.iobroker.net/sources-dist.json
        beta : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): stable, __
        Installed ioBroker-Instances
        Used repositories: stable, __
        Error: unknown repository is active - "__". Known: stable, beta
        Adapter "admin" : 6.12.0 , installed 6.12.0
        Adapter "alexa2" : 3.26.1 , installed 3.26.1
        Adapter "backitup" : 2.8.7 , installed 2.8.7
        Adapter "bmw" : 2.5.7 , installed 2.6.2
        Adapter "cloud" : 4.4.1 , installed 4.4.1
        Adapter "device-reminder": 3.0.0 , installed 3.0.0
        Adapter "discovery" : 4.2.0 , installed 4.2.0
        Adapter "fritzdect" : 2.3.1 , installed 2.3.1
        Adapter "javascript" : 7.1.4 , installed 7.1.4
        Controller "js-controller": 5.0.12 , installed 5.0.12
        Adapter "modbus" : 5.0.11 , installed 5.0.11
        Adapter "mqtt" : 5.1.0 , installed 5.1.0
        Adapter "node-red" : 4.0.3 , installed 4.0.3
        Adapter "ping" : 1.6.2 , installed 1.6.2
        Adapter "pushover" : 3.0.3 , installed 3.0.3
        Adapter "shelly" : 6.6.1 , installed 6.6.1
        Adapter "simple-api" : 2.7.2 , installed 2.7.2
        Adapter "socketio" : 6.5.5 , installed 6.5.5
        Adapter "text2command" : 3.0.2 , installed 3.0.2
        Adapter "tibberlink" : 1.4.2 , installed 1.4.2
        Adapter "vis" : 1.4.16 , installed 1.4.16
        Adapter "web" : 6.1.10 , installed 6.1.10
        Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3
        Adapter "ws" : 2.5.8 , installed 2.5.8
        Objects and States
        Objects: 2766
        States: 2304
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Get:3 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
        Fetched 4586 B in 1s (5085 B/s)
        Reading package lists...
        Pending Updates: 123
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 1985 569/sshd: /usr/sbin
        tcp 0 0 192.168.178.94:1883 0.0.0.0:* LISTEN 1001 9764333 30232/io.mqtt.0
        tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 9807076 1646/cupsd
        tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 8890325 32109/iobroker.js-c
        tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 8891922 32109/iobroker.js-c
        tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 9692062 23452/io.shelly.0
        tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 8891049 32176/node-red
        tcp6 0 0 :::22 :::* LISTEN 0 1987 569/sshd: /usr/sbin
        tcp6 0 0 ::1:631 :::* LISTEN 0 9807075 1646/cupsd
        tcp6 0 0 :::8082 :::* LISTEN 1001 9775067 32094/io.web.0
        tcp6 0 0 :::8081 :::* LISTEN 1001 8892685 32127/io.admin.0
        udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15539 469/dhcpcd
        udp 0 0 0.0.0.0:631 0.0.0.0:* 0 9807897 1650/cups-browsed
        udp 0 0 0.0.0.0:44127 0.0.0.0:* 108 1625 349/avahi-daemon: r
        udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 12774 349/avahi-daemon: r
        udp6 0 0 :::49251 :::* 108 1626 349/avahi-daemon: r
        udp6 0 0 :::546 :::* 0 9765602 469/dhcpcd
        udp6 0 0 :::5353 :::* 108 12775 349/avahi-daemon: r
        2023-11-12 19:15:27.443 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
        2023-11-12 19:16:03.881 - info: web.0 (32094) <== Disconnect system.user.admin from ::ffff:192.168.178.80 vis.0
        2023-11-12 19:17:35.056 - info: web.0 (32094) ==> Connected system.user.admin from ::ffff:192.168.178.20
        2023-11-12 19:18:33.451 - info: admin.0 (32127) <== Disconnect system.user.admin from ::ffff:192.168.178.20 javascript
        2023-11-12 19:30:00.011 - info: javascript.0 (32191) script.js.Skript_Shelly_Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 1
        2023-11-12 19:31:31.695 - info: mqtt.0 (30232) Client [SOYO_f4695a] reconnected. Old secret 1699812927206_137. New secret 1699813891694_4143
        2023-11-12 19:31:31.716 - info: mqtt.0 (30232) Client [SOYO_f4695a] subscribes on "mqtt.0.Soyosource.SOYO_f4695a.L1L2L3"
        2023-11-12 19:31:31.722 - info: mqtt.0 (30232) Client [SOYO_f4695a] subscribes on "mqtt.0.Soyosource.SOYO_f4695a.NotAus"
        2023-11-12 19:31:31.728 - info: mqtt.0 (30232) Client [SOYO_f4695a] subscribes on "mqtt.0.Soyosource.SOYO_f4695a.WaitSekunden"
        2023-11-12 19:31:31.734 - info: mqtt.0 (30232) Client [SOYO_f4695a] subscribes on "mqtt.0.Soyosource.SOYO_f4695a.MaxPower"
        2023-11-12 19:31:31.917 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
        2023-11-12 19:31:31.924 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
        2023-11-12 19:31:31.928 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
        2023-11-12 19:31:31.934 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
        2023-11-12 19:37:59.392 - warn: host.iobroker Requested repository "__" does not exist in config.
        2023-11-12 19:38:02.062 - warn: admin.0 (32127) No repository source configured
        2023-11-12 19:38:09.982 - info: mqtt.0 (30232) Client [SOYO_f4695a] reconnected. Old secret 1699813891694_4143. New secret 1699814289982_4399
        2023-11-12 19:38:09.993 - info: mqtt.0 (30232) Client [SOYO_f4695a] subscribes on "mqtt.0.Soyosource.SOYO_f4695a.L1L2L3"
        2023-11-12 19:38:10.003 - info: mqtt.0 (30232) Client [SOYO_f4695a] subscribes on "mqtt.0.Soyosource.SOYO_f4695a.NotAus"
        2023-11-12 19:38:10.016 - info: mqtt.0 (30232) Client [SOYO_f4695a] subscribes on "mqtt.0.Soyosource.SOYO_f4695a.WaitSekunden"
        2023-11-12 19:38:10.022 - info: mqtt.0 (30232) Client [SOYO_f4695a] subscribes on "mqtt.0.Soyosource.SOYO_f4695a.MaxPower"
        2023-11-12 19:38:10.194 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
        2023-11-12 19:38:10.203 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
        2023-11-12 19:38:10.217 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
        2023-11-12 19:38:10.222 - info: mqtt.0 (30232) Client [SOYO_f4695a] publishOnSubscribe
          Thomas Braun Most Active @Peter c last edited by Thomas Braun
          @peter-c
          sudo systemctl set-default multi-user.target
          iob stop
          iob fix
          iob nodejs-update
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Dann nochmal
          iob diag
          P 2 Replies Last reply Reply Quote 0
            Peter c @Thomas Braun last edited by Homoran
            @thomas-braun War ganz schön viel Veränderung...
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : armhf
             20:05:16 up 2 min,  2 users,  load average: 1.18, 0.71, 0.28
            CPU threads: 4
            Current issues:
                           Local time: Sun 2023-11-12 20:05:17 CET
                       Universal time: Sun 2023-11-12 19:05:17 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pt
            /home/pt
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            Boot Target: 	multi-user.target
            *** MEMORY ***
            Mem:            3.8G        764M        2.8G        1.0M        276M        3.0G
            Swap:            99M          0B         99M
            Total:          3.9G        764M        2.9G
                     3794 M total memory
                      764 M used memory
                      796 M active memory
                      125 M inactive memory
                     2753 M free memory
                       39 M buffer memory
                      237 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/root      ext4       29G  5.6G   23G  20% /
            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
            [Sun Nov 12 20:02:57 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:1F:EE:06 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=00900e5c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Sun Nov 12 20:02:58 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Nov 12 20:02:58 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sun Nov 12 20:03:01 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            /var:
            897M	/var/
            430M	/var/cache
            418M	/var/cache/apt
            353M	/var/cache/apt/archives
            243M	/var/log
            Archived and active journals take up 240.0M in the file system.
            196M	/opt/iobroker/iobroker-data/
            7.4M	/opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            /usr/bin/nodejs 	v18.18.2
            /usr/bin/node 		v18.18.2
            /usr/bin/npm 		9.8.1
            /usr/bin/npx 		9.8.1
            /usr/bin/corepack 	0.19.0
            nodejs:
              Installed: 18.18.2-1nodesource1
              Candidate: 18.18.2-1nodesource1
              Version table:
             *** 18.18.2-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		6.12.0
            javascript: 	7.1.4
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
            + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.94
            + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
            + instance is alive
            Objects and States
            Objects: 	2910
            States: 	2434
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
            Pending Updates: 0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15305      559/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12893      524/cupsd
            tcp        0      0 192.168.178.94:1883     0.0.0.0:*               LISTEN      1001       15892      995/io.mqtt.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15422      525/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11204      525/iobroker.js-con
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       16576      916/node-red
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       16616      980/io.shelly.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          15319      559/sshd: /usr/sbin
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12892      524/cupsd
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13202      669/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18593      1117/io.web.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15368      549/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12909      575/cups-browsed
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11058      397/avahi-daemon: r
            udp        0      0 0.0.0.0:46557           0.0.0.0:*                           108        11060      397/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          15493      549/dhcpcd
            udp6       0      0 :::39806                :::*                                108        11061      397/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        11059      397/avahi-daemon: r
            2023-11-12 20:04:12.387  - info: energiefluss.0 (1098) Starting Energiefluss Adapter
            2023-11-12 20:04:12.567  - info: energiefluss.0 (1098) Adapter started and listening to 11 States
            2023-11-12 20:04:13.268  - info: host.iobroker instance system.adapter.web.0 started with pid 1117
            2023-11-12 20:04:16.977  - info: tibberlink.0 (1087) State value to set for "0_userdata.0.Tibberlink_Kanäle.beste_Kosten" has to be type "number" but received type "boolean"
            2023-11-12 20:04:16.979  - info: tibberlink.0 (1087) State value to set for "0_userdata.0.Tibberlink_Kanäle.beste_Stundenblock" has to be type "number" but received type "boolean"
            2023-11-12 20:04:17.173  - info: web.0 (1117) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.18.2, js-controller: 5.0.12
            2023-11-12 20:04:17.582  - info: web.0 (1117) socket.io server listening on port 8082
            2023-11-12 20:04:17.593  - info: web.0 (1117) http server listening on port 8082
            2023-11-12 20:04:18.341  - info: alexa2.0 (1012) Unknown Device, but enabling commands, Try it and report back if commands work.
            2023-11-12 20:04:18.342  - info: alexa2.0 (1012) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
            2023-11-12 20:04:18.343  - info: alexa2.0 (1012)     Device-type:A3BW5ZVFHRCQPO - Teichmann's BMW Group – Amazon Alexa Car Integration (BMW Group – Amazon Alexa Car Integration) (PEONY,DREAM_TRAINING,TIDAL,SIRIUSXM,TIMERS_AND_ALARMS,APPLE_MUSIC,PERSISTENT_CONNECTION,AUDIO_PLAYER,DEEZER,CHANGE_NAME,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,AMAZON_MUSIC,AUDIBLE,ADAPTIVE_LISTENING,KINDLE_BOOKS,GOLDFISH,HANDS_FREE,I_HEART_RADIO,REMINDERS,VOLUME_SETTING,DEREGISTER_DEVICE,TUNE_IN,MICROPHONE,MUSIC_SKILL,SLEEP)
            2023-11-12 20:04:19.788  - info: vis.0 (1132) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
            2023-11-12 20:04:20.204  - info: vis.0 (1132) vis license is OK.
            2023-11-12 20:04:20.902  - info: vis.0 (1132) Terminated (NO_ERROR): Without reason
            2023-11-12 20:04:21.244  - info: host.iobroker instance system.adapter.text2command.0 started with pid 1147
            2023-11-12 20:04:21.534  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
            2023-11-12 20:04:23.969  - info: text2command.0 (1147) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v18.18.2, js-controller: 5.0.12
            2023-11-12 20:04:25.255  - info: host.iobroker instance system.adapter.device-reminder.0 started with pid 1162
            2023-11-12 20:04:27.988  - info: device-reminder.0 (1162) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.18.2, js-controller: 5.0.12
            2023-11-12 20:04:28.240  - warn: device-reminder.0 (1162) State "device-reminder.0.info.connection" has no existing object, this might lead to an error in future versions
            2023-11-12 20:04:28.684  - info: alexa2.0 (1012) Using cached smart home devices list from Sun Nov 12 2023 20:02:40 GMT+0100 (Central European Standard Time)
            2023-11-12 20:04:30.069  - info: alexa2.0 (1012) No smart home devices to query
            2023-11-12 20:04:31.752  - info: alexa2.0 (1012) Subscribing to states...
            2023-11-12 20:04:33.501  - info: alexa2.0 (1012) Alexa-Push-Connection (macDms = true) established. Disable Polling
            2023-11-12 20:04:42.469  - info: alexa2.0 (1012) Initialization Done ...
              @thomas-braun Das unknown repository is active ist immer noch da.
              			v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
              Installation: 		native
              Kernel: 		aarch64
              Userland: 		armhf
              Timezone: 		Europe/Berlin (CET, +0100)
              User-ID: 		1000
              X-Server: 		false
              Pending OS-Updates: 	0
              Pending iob updates: 	0
              Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
              			/usr/bin/npm 		9.8.1
              			/usr/bin/npx 		9.8.1
              Recommended versions are nodejs 18.18.2 and npm 9.8.1
              MEMORY:
              Mem:            3.8G        830M        2.5G        1.0M        481M        2.9G
              Swap:            99M          0B         99M
              Total:          3.9G        830M        2.6G
              Active iob-Instances: 	19
              ioBroker Core: 		js-controller 		5.0.12
              			admin 			6.12.0
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: jsonl
              Objects: 		2910
              States: 		2434
              Size of iob-Database:
              7.5M	/opt/iobroker/iobroker-data/objects.jsonl
              1.8M	/opt/iobroker/iobroker-data/states.jsonl
              === Mark text until here for copying ===
                @peter-c
                iob repo unset __
                iob repo del __
                  @thomas-braun - bleibt hartnäckig da...
                  pt@iobroker:~ $ iob repo unset __
                  Repository "__" deactivated.
                  pt@iobroker:~ $ iob repo del __
                  Cannot remove repository: Repository "__" not found.
                    @peter-c
                    iob repo list
                      pt@iobroker:~ $ iob repo list
                        @peter-c
                        Ist doch weg.
                          super danke.
                            Homoran Global Moderator Administrators @Peter c last edited by
                            @peter-c sagte in Immer gleiche Warnung im Protokoll....:
                            wo?
                            ist doch weg
                            2800
