    4. Test : Wasserenthärtung judo i-soft plus Adapter
      arteck Developer Most Active @roughestboy last edited by arteck
      @roughestboy installier mal den hier
      https://github.com/arteck/ioBroker.judoisoft/tarball/ResidualHardness
      danch dapter auf debug stellen ..und sich dann nach ResidualHardness im LOG suchen..sollten mehrere Stellen sein
      poste was da steht
        roughestboy @arteck last edited by
        @arteck sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
        Erstmal nach Installation 'aus github':
        2022-09-19 19:53:09.516 - info: judoisoft.0 (975) Got terminate signal TERMINATE_YOURSELF
        2022-09-19 19:53:09.526 - info: judoisoft.0 (975) cleaned everything up...
        2022-09-19 19:53:09.527 - info: judoisoft.0 (975) terminating
        2022-09-19 19:53:09.528 - info: judoisoft.0 (975) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-09-19 19:53:09.533 - info: host.pi4iobroker stopInstance system.adapter.judoisoft.0 (force=false, process=true)
        2022-09-19 19:53:09.538 - info: host.pi4iobroker iobroker Adapter "system.adapter.judoisoft.0" restarted.
        2022-09-19 19:53:09.539 - info: judoisoft.0 (975) Got terminate signal TERMINATE_YOURSELF
        2022-09-19 19:53:09.540 - info: host.pi4iobroker stopInstance system.adapter.judoisoft.0 send kill signal
        2022-09-19 19:53:09.885 - info: host.pi4iobroker iobroker Update "system.adapter.judoisoft.0"
        2022-09-19 19:53:09.903 - info: host.pi4iobroker stopInstance system.adapter.judoisoft.0 (force=false, process=true)
        2022-09-19 19:53:09.910 - info: judoisoft.0 (975) Got terminate signal TERMINATE_YOURSELF
        2022-09-19 19:53:09.920 - info: host.pi4iobroker stopInstance system.adapter.judoisoft.0 send kill signal
        2022-09-19 19:53:10.142 - info: host.pi4iobroker instance system.adapter.judoisoft.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-09-19 19:53:10.929 - info: host.pi4iobroker iobroker exit 0
        2022-09-19 19:53:13.075 - info: host.pi4iobroker instance system.adapter.judoisoft.0 started with pid 7465
        2022-09-19 19:53:14.815 - info: judoisoft.0 (7465) starting. Version 1.0.15 (non-npm: arteck/ioBroker.judoisoft#ResidualHardness) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v16.17.0, js-controller: 4.0.23
        2022-09-19 19:53:15.003 - info: javascript.0 (774) script.js.common.judoisoftsafe_scripte.cloud_online_control: 5919
        2022-09-19 19:53:15.004 - info: javascript.0 (774) script.js.common.judoisoftsafe_scripte.cloud_online_control: #00FF00
        2022-09-19 19:53:15.039 - warn: judoisoft.0 (7465) Object Connection status is invalid: Default value has to be type "string" but received type "boolean"
        2022-09-19 19:53:15.041 - warn: judoisoft.0 (7465) This object will not be created in future versions. Please report this to the developer.
        Debug Adapter nach Residual:
        judoisoft.0
        2022-09-19 20:10:54.158 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:10:54.151 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:10:38.956 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:10:38.946 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:10:23.736 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:10:23.721 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:10:08.497 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:10:08.489 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:09:53.296 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:09:53.289 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:09:38.067 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:09:38.056 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:09:22.835 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:09:22.824 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:09:07.588 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:09:07.579 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:08:52.356 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:08:52.329 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:08:37.061 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:08:37.042 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:08:21.791 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:08:21.787 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:08:06.523 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:08:06.519 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:07:51.339 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:07:51.328 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:07:36.102 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:07:36.089 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:07:20.883 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:07:20.871 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:07:05.628 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:07:05.617 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:06:50.390 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:06:50.382 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:06:35.177 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:06:35.169 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:06:19.979 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:06:19.968 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:06:04.759 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:06:04.746 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:06:03.947 info starting. Version 1.0.15 (non-npm: arteck/ioBroker.judoisoft#ResidualHardness) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v16.17.0, js-controller: 4.0.23
        Dann den Wert im DP auf 10 gesetzt:
        judoisoft.0
        2022-09-19 20:14:42.545 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:14:42.538 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:14:42.537 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:14:27.188 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:14:27.168 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:14:27.167 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:14:11.965 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:14:11.955 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:14:11.954 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:13:56.732 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:13:56.719 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:13:56.718 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:13:41.508 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:13:41.502 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:13:41.501 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:13:26.301 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:13:26.292 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:13:26.291 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:13:11.105 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:13:11.093 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:13:11.090 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:12:55.897 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:12:55.887 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:12:55.886 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:12:40.638 debug --> stateID judoisoft.0.ResidualHardness changed: 16 (ack = true)
        judoisoft.0
        2022-09-19 20:12:40.630 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:12:40.629 warn State value to set for "judoisoft.0.ResidualHardness" has value "16" greater than max "12"
        judoisoft.0
        2022-09-19 20:12:25.436 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:12:25.425 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:12:23.934 debug set ResidualHardness Cloud10
        judoisoft.0
        2022-09-19 20:12:23.931 debug --> stateID judoisoft.0.ResidualHardness changed: 10 (ack = false)
        judoisoft.0
        2022-09-19 20:12:10.244 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:12:10.236 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:11:55.062 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:11:55.035 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:11:39.795 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
        judoisoft.0
        2022-09-19 20:11:39.788 debug -> ResidualHardness
        judoisoft.0
        2022-09-19 20:11:24.563 debug --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          hmm versteh ich nicht.. zuerst wird es auf 8 gesetzt dann direkt 13 msek auf 10. läuft da ein scirpt noch was dir dazwischen funkt ?
          der 10ner Wert ist nicht bestätigt
            @arteck
            Ich habe in der Tat gleich 5 laufende Skripte in Zusammenhang mit dem Adapter, aber auch wenn ich die Skripte stoppe und ResidualHardness per DP auf 10 setze, ist das Verhalten gleich. Landet am Ende auf 16 (nur zwischendurch die gewünschte 10). Bei Werten kleiner 10 läufts holprig, so über das Abfrageintervall hinweg sehe ich mal die 2 (nachdem ich sie gesetzt habe), dann zwischendurch wieder 8 (was der Ausgangswert war), am Ende klappts aber mit der 2.
            Kann man viel vermuten, eine davon ist, dass das verbaute Connection-Modul nichts taugt bzw. der Cloudserver der Fa. Judo. Wobei in den letzten Wochen die App besser funktioniert als noch im Sommer/Juli, und auch lastinfoupdate nur noch selten nicht aktuell ist. Den Techniker hatte ich auch so verstanden, dass man wohl gemerkt hat, dass die Antwortzeiten ihres Servers zu lang sind, und er hatte eben auch die Entwicklung eines neuen Connection-Moduls angekündigt ("Ende Q1/23"). Wann es denn dann mal kommt und ob man es haben muss, sie werdens wohl nicht kostenlos umrüsten...).
              Brandy_f1 @roughestboy last edited by
              @roughestboy Mittlerweile gibt es bei Judo neue Connectivity Module kostenlos zum Austausch bei einer i-soft Anlage. Auch eine API Doku hat Judo Online gestellt. ich hab die Infos unter https://github.com/arteck/ioBroker.judoisoft/issues im Judo Adapter für IOBroker abgelegt. Evtl. kann sich Arteck die Sache mal ansehen ob man den Adapter weiterentwickeln kann.
              R S 2 Replies Last reply Reply Quote 1
                roughestboy @Brandy_f1 last edited by
                @brandy_f1 super vielen Dank für den Hinweis ! Da werd ich mal nachhaken.
                  SmartHomer 0 @Brandy_f1 last edited by
                  @brandy_f1 sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
                  @arteck
                  Das wäre wirklich fein, dann könnte man vermutlich auch direkt lokal auf das Modul zugreifen und müsste nicht über das doch recht instabile Online-Portal von judo gehen - das ist leider häufig nicht verfügbar.
                    arteck Developer Most Active @SmartHomer 0 last edited by
                    @smarthomer-0 gesehen hab ich es .. jetzt noch die Zeit dazu finden
                      SmartHomer 0 @arteck last edited by
                      @arteck
                      Fa. Judo hat mir das neue Connectivity-Modul mit WLAN zukommen lassen - dieses Unternehmen bietet wirklich einen unkomplizierten und kundenorientierten Service.
                      Das neue Modul hat einen Aufkleber mit SW3.06 und HW4.0.
                      Nach Tausch gegen das alte Modul war die Einbindung in LAN und WLAN problemlos, nach Anmeldung im judo-Portal wurden auch auch sofort die Daten angezeigt (Fortführung der bislang aufgelaufenen Daten).
                      Leider funktioniert das Zusammenspiel mit dem ioBroker-Adapter nicht, die Datenpunkte werden nicht gelesen, beim Debug kommen Comm.-Error-Meldungen. Das wundert mich zwar, weil ich dachte der Adapter liest bei gesetztem Haken "Cloud Login" aus dem Judo-Account - aber irgendwas ist scheinbar doch anders.
                      Es wurde sowohl mit W-LAN als auch mit LAN-Kommunikation getestet.
                      Ich habe wieder zurückgebaut auf mein altes Connectivity-Modul, was ja funktioniert und auch nach Rückbau sofort wieder funktioniert hat.
                      Ich erwähne es deshalb, weil evtl. künftige Neu-Anwender, die von judo direkt das neue Modul bekommen, dann mit dem Auslesen der Daten ebenfalls Probleme haben werden?
                      Wenn @arteck gelegentlich die Zeit findet, sich der Sache anzunehmen und ich weitere Informationen liefern kann - jederzeit gerne.
                      arteck G 2 Replies Last reply Reply Quote 0
                        @smarthomer-0 muss ich mir live ansehen..
                          @arteck
                          Entschuldige-ich hab‘s nicht so ganz verstanden:
                          Möchtest Du mal zB via TeamViewer auf mein System schauen, nachdem ich zuvor das neue Connectivity Modul wieder eingebaut habe?
                          Oder soll ich Dir das neue Connectivity-Modul mal zukommen lassen?
                          Bin diese Woche weitgehend unterwegs und könnte am Wochenende aktiv werden,
                          LG
                            @smarthomer-0 ja genau per TeamViewer oder AnyDesk.. aber
                            das wird erst nächstes Wocheende was..
                            das Modul bring mir garnix da ich die Anlage überhaupt nicht habe...
                              @arteck
                              Super, das können wir sehr gerne so machen.
                              Melde Dich bitte einfach mit etwas Vorlauf, wenn es mal bei Dir reinpasst, dann können
                              wir uns zeitlich sicher synchronisieren.
                              Schöne Grüße
                                deifel last edited by
                                wir haben seit neuestem eine Isoft Pro-Anlage. Mit diesem Adapter hier bekomme ich zwar ein paar Infos angezeigt, aber Datenpunkte ändern scheint so wie es aussieht nicht möglich zu sein.
                                Oder sehe ich das falsch?
                                Gibt es ggfls. Pläne oder einen Adapter, mit dem ich das über IOBroker nutzen kann?
                                Vielen Dank und Grüße
                                  Gengo @SmartHomer 0 last edited by
                                  @smarthomer-0 Ich habe ebenfalls Probleme das neue Modul lokal zu verbinden.
                                  Ich habe eine Judo iSoft safe+ mit dem Connectivity Modul (Hardware-Version 4.0 und Software-Version 3.07) Ich bekomme aber keine Verbindung hin hier die Fehler aus dem Protokoll: 96fd5c8a-ce6a-480f-9e0d-868c6c7979c3-image.png
                                  und hier noch meine Einstellungen:
                                  An was kann das liegen? Mache ich irgendetwas falsch? Zugriff über die JU-Control App ist gegeben.
                                    SmartHomer 0 @Gengo last edited by
                                    @gengo sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
                                    Nein, ich denke Du machst nichts falsch, diese Fehlermeldungen vom ioBroker-Adapter hatte ich mit
                                    dem neuen Judo Connectivity-Modul auch.
                                    Der Zugriff über die Judo-App hat bei mir ebenfalls geklappt (wenn das Judo-Portal "online" war).
                                    Ich habe dann wieder auf das das alte Modul zurückgebaut (siehe oben).
                                    Ich denke, das wird jetzt zunehmend aufkommen, nachdem Judo die Anlagen mit den neuen Connectivity-Modulen ausliefert.
                                    Der Entwickler @arteck hatte meines Wissens bisher noch keine Gelegenheit, sich den judo-Adapter in Bezug auf
                                    das neue Connectivity-Modul anzuschauen.
                                    Schöne Grüße
                                      @smarthomer-0 sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
                                      der Entwickler hat noch ein anderes Problem.. der hat die Anlage garnicht..
                                      da ist es noch schwierieger..ich guck mal.
                                        Gengo @arteck last edited by
                                        Hallo, Ich habe nun versucht selber die Daten auszulesen. Das klappt auch schon ganz gut. Nur weis ich nicht wie ich diese Daten zu interpretieren habe. In der Schnittstellendoku steht:
                                        Die daten sollen per HEX Zeichenkette übertragen werden (laut Bedienungsanleitung). aber wie kann ich die umrechnen?
                                        Wie komme ich von z.B. EC221000 für die Gesamtwassermenge auf 1057,516m³. Wenn ich das in den Hex to dec umrechnet packe kommt was ganz anderes raus.
                                          @gengo du musst das umwandel
                                          EC221000 -> 001022EC dann ist es hex dann kannst du es umwandeln 1057516 -> 1057,516 3 nachkomma stellen
                                            Gengo last edited by Gengo
                                            @arteck
                                            Danke dir, da wäre ich nie drauf gekommen 🙂
                                            Ist das eine normale Vorgehensweise? den HEX code rückwärts zu lesen? oder ist das von Seiten Judo falsch? Gibt es da einen JavaScript befehlt dazu? oder muss ich mir da was basteln? Ich kenne mich leider noch nicht so gut mit JavaScript aus, bzw. stehe noch am Anfang.
                                            i-soft judo wasserenthärtung
                                            22
                                            216
                                            23097
