    4. BackItUp Update hängt
      myssv last edited by
      OK, nachdem ich beim ProxMox ein IPv6 Gateway (FritzBox) eingetragen habe, läuft es
      Volker@ioBroker:~$ ping heise.de
      PING heise.de(redirector.heise.de (2a02:2e0:3fe:1001:302::)) 56 data bytes
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=47 ttl=52 time=11.7 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=48 ttl=52 time=10.5 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=49 ttl=52 time=10.3 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=50 ttl=52 time=10.4 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=51 ttl=52 time=10.2 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=52 ttl=52 time=10.0 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=53 ttl=52 time=10.1 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=54 ttl=52 time=10.1 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=55 ttl=52 time=10.3 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=56 ttl=52 time=10.3 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=57 ttl=52 time=10.5 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=58 ttl=52 time=10.4 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=84 ttl=52 time=10.8 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=85 ttl=52 time=9.99 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=86 ttl=52 time=10.7 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=87 ttl=52 time=10.3 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=88 ttl=52 time=10.4 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=89 ttl=52 time=10.4 ms
      64 bytes from redirector.heise.de (2a02:2e0:3fe:1001:302::): icmp_seq=90 ttl=52 time=10.2 ms
      ^C
      --- heise.de ping statistics ---
      90 packets transmitted, 19 received, 78.8889% packet loss, time 90712ms
      rtt min/avg/max/mdev = 9.988/10.403/11.703/0.369 ms
      Volker@ioBroker:~$ iob upgrade ws@2.5.8 --debug
      Would you like to reinstall version 2.5.8 of ws now? [(y)es, (n)o]: y
      Update ws from @2.5.8 to @2.5.8
      NPM version: 9.8.1
      Installing iobroker.ws@2.5.8... (System call)
      up to date in 1s
      93 packages are looking for funding
        run `npm fund` for details
      Adapter "system.adapter.web.0" restarted.
      upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
      Volker@ioBroker:~$
      • Marc Berg
        Marc Berg Most Active @myssv last edited by
        @myssv sagte in BackItUp Update hängt:
        und es lief auch alles bisher.
        ja, bisher. Heute hast du das:
        Addresses:  2606:4700::6810:1e22
                  2606:4700::6810:1822
                  2606:4700::6810:323
                  2606:4700::6810:23
                  2606:4700::6810:123
                  2606:4700::6810:1b22
                  2606:4700::6810:1f22
                  2606:4700::6810:1d22
                  2606:4700::6810:1c22
                  2606:4700::6810:1922
                  2606:4700::6810:1a22
                  2606:4700::6810:223
                  104.16.24.34
                  104.16.1.35
                  104.16.30.34
                  104.16.29.34
                  104.16.31.34
                  104.16.28.34
                  104.16.25.34
                  104.16.3.35
                  104.16.0.35
                  104.16.26.34
                  104.16.2.35
                  104.16.27.34
        Und in Zukunft noch mehr.
          Homoran Global Moderator Administrators @myssv last edited by
          Es war alles sauber auf IPv4 und es lief auch alles bisher.
          dann wurde bis dahin irgendwo in deinem System auf ipv4 gewandelt, und jetzt nicht mehr
          • Marc Berg
            Na dann, frohes updaten. 🙂
              myssv @Homoran last edited by
              Leider nicht ganz so froh
              ergibt
                ich mache dafür glaube ich mal ein neues Thema auf
                  Ich habe aber schon das nächste Problem. Meine Tahoma Switch kann scheinbar kein IPv6
                  PS C:\Users\Volke> ping gateway-2001-5798-0160 -4
                  Ping wird ausgeführt für gateway-2001-5798-0160.fritz.box [192.168.115.25] mit 32 Bytes Daten:
                  Antwort von 192.168.115.25: Bytes=32 Zeit=2ms TTL=64
                  Antwort von 192.168.115.25: Bytes=32 Zeit=5ms TTL=64
                  Antwort von 192.168.115.25: Bytes=32 Zeit=4ms TTL=64
                  Ping-Statistik für 192.168.115.25:
                      Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                      (0% Verlust),
                  Ca. Zeitangaben in Millisek.:
                      Minimum = 2ms, Maximum = 5ms, Mittelwert = 3ms
                  PS C:\Users\Volke> ping gateway-2001-5798-0160 -6
                  Ping wird ausgeführt für gateway-2001-5798-0160.fritz.box [2a11:fb80:1025:6500:20e:c6ff:fea9:13b3] mit 32 Bytes Daten:
                  Zielhost nicht erreichbar.
                  Ping-Statistik für 2a11:fb80:1025:6500:20e:c6ff:fea9:13b3:
                      Pakete: Gesendet = 3, Empfangen = 0, Verloren = 3
                      (100% Verlust),
                    Wildbill @myssv last edited by
                    @myssv Ja und dann? In einem korrekt eingerichtetem Netzwerk mit IPv4 und IPv6 parallel läuft sie mit IPv4 ganz genau so weiter als wenn nie was gewesen wäre und ist auch genau wie vorher ganz normal per IPv4 erreichbar und erreicht auch alles, was sie bisher erreichen konnte weiterhin per IPv4. Wo siehst Du da jetzt das Problem?
                    Gruss, Jürgen
                      myssv @Wildbill last edited by
                      @wildbill sagte in BackItUp Update hängt:
                      Mein Problem war, dass der ioBroker die Switch nicht mehr erreicht hat.
                      Ich habe jetzt mal, die Switch neu gestartet und nun ist auch wieder alles in Ordnung.
                      Wie bei einem "korrekt eingerichtetem Netzwerk" 😉
                        Wildbill @myssv last edited by Wildbill
                        @myssv Es hat sich ja auch auf IPv4-Ebene nix geändert. Stell Dir das so ähnlich vor, als wenn Du jetzt zwei unabhängige Netzwerke hast, die einander nicht sehen und kennen. Geräte die sowohl IPv4 als auch IPv6 können, haben jetzt quasi zwei Netzwerkadressen. Die IPv4 macht alles wie bisher, sie kann ale IPv4-Geräte weiterhin direkt erreichen, nichts verändert. Nur, dass das Gerät eben nun auch eine IPv6-Adresse hat, die von den großen Betriebssystemen (Mac, Linux, Windows) auch bevorzugt verwendet wird. Versuchst Du, eine Website zu öffnen, wird das über IPv6 versucht. Geht das nicht erfolgt ein Fallback auf IPv4. Versuchst Du direkt in Deinem Netzwerk ein IPv4-Gerät zu erreichen, so geht das direkt über die IPv4-Adresse wie bisher auch. Du musst Dich da um nix kümmern.
                        Du kannst ja am PC mal einen IPv6-Test machen. Je nach Konfiguration (SLAAC, private usw.) solltest Du da 17-20 Punkte erreichen, dann passt alles. Ansonsten siehst Du auch gleich, wo es klemmt.
                        Und, wie gesagt, für Dein IPv4-Netzwerk hat sich nichts geändert!
                        Gruss, Jürgen
                        EDIT: Ein Hinweis noch: So, wie bisher auch, solltest Du Deine öffentlich IPv6 nicht öffentlich hier reinschreiben oder so. Und bei IPv6 erhält eben nun jedes Gerät eine eigene IPv6-Adresse. Alles was mit fe… oder fd… anfängt ist intern, das ist OK, aber alles andere enthält dann den öffentlichen Präfix, den solltest Du aus-x-en, wenn Du da was zeigen willst!
                          myssv @Wildbill last edited by myssv
                          @wildbill sieht wie erwartet gut aus
                            @myssv Ja, scheint zu passen. Das mit dem Hostname ist mir zwar unbekannt, warum der nicht aufgelöst wird, aber das sollte keinje Rolle spielen. Glückwunsch und willkommen in der Gegenwart. 😊
                            Mein EDIT oben hast Du (fast beachtet). Lösch auch die öffentliche IPv4 aus dem Bild!
                            Gruss, Jürgen
                            M Thomas Braun 2 Replies Last reply Reply Quote 0
                              Danke!
                                Thomas Braun Most Active @Wildbill last edited by
                                Das ist bei meinem Kabelanschluss via Vodafone in NRW auch so.
                                Ein guter Test (Connection) ist auch unter internet.nl zu finden.
                                  Wildbill @Thomas Braun last edited by
                                  @thomas-braun Den kannte ich gar nicht. Komischerweise zeigt mir ipv6-test.com 20/20 an, andere melden auch Erfolgt, während internet.nl nur 10% anzeigt und sagt, IPv6 wäre nicht möglich?!
                                  Und schon hab ich was zu tun. Schauen, was da anders ist... 😊
                                  Gruss, Jürgen
                                    Bei mir gerade auch 10%, sonst hab ich da immer 100%.
                                    Ich würde es einfach später nochmal probieren, könnte sein das es da in Holland klemmt.
                                      @thomas-braun Ja, scheint deutsche DNS-Server nicht zu mögen. Kurz hatte ich mal 40%, im nächsten Versuch waren es wieder 10...
                                      Gruss, Jürgen
                                        @wildbill
                                        Merkwürdig. Der ist nämlich sonst sehr stabil und zuverlässig.
                                          myssv last edited by myssv
                                          Ich habe 100
                                          Dafür zeigt mir der Andere nur noch 4/20 an, obwohl es vorhin noch 17 waren ???
                                            @myssv Bei mir waren es eben einmal 70 und dann beim Aktualisieren wieder 10. Naja, man kann sich auch tot testen. Hauptsache Internetseiten bauen sich immer zügig auf…
                                            Gruss, Jürgen
                                            8706
