    3. Einsteigerfragen
    4. Installation
    5. Wie führe ich ein sauberes Updates durch?
      Thomas Braun Most Active @philipp_lappe last edited by
      @philipp_lappe
      iob stop
      iob fix
      iob upgrade all
      iob upgrade self --debug
        @philipp_lappe
        iob stop
        iob fix
        iob upgrade all
          philipp_lappe @Thomas Braun last edited by Homoran
          @thomas-braun said in Wie führe ich ein sauberes Updates durch?:
          @philipp_lappe
          iob stop
          iob fix
          iob upgrade all
          Update js-controller from @4.0.24 to @5.0.12
          Stopped Objects DB
          Stopped States DB
          NPM version: 8.19.4
          Installing iobroker.js-controller@5.0.12... (System call)
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/acme-http-01-standalone
          npm ERR! dest /opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acme-http-01-standalone' -> '/opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK'
          npm ERR!     /home/iobroker/.npm/_logs/2023-11-12T22_09_46_524Z-debug-0.log
          host.homepi_phil Cannot install iobroker.js-controller@5.0.12: 217
          da_Woody Homoran 2 Replies Last reply Reply Quote 0
          • da_Woody
            da_Woody @philipp_lappe last edited by
            @philipp_lappe bitte, setz deine logs in 3b78940c-63e7-4156-b8fc-6d42ca860f0d-grafik.png
              Homoran Global Moderator Administrators @philipp_lappe last edited by
              @philipp_lappe sagte in Wie führe ich ein sauberes Updates durch?:
              und die anderen Ausgaben?
                philipp_lappe @Homoran last edited by
                pi@homepi_phil:~ $ iob stop
                pi@homepi_phil:~ $
                pi@homepi_phil:~ $ iob fix
                library: loaded
                Library version=2023-10-13
                    Welcome to the ioBroker installation fixer!
                    Script version: 2023-10-13
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/5)
                Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
                Err:3 http://raspbian.raspberrypi.org/raspbian stretch Release
                  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
                Get:4 https://download.docker.com/linux/raspbian stretch InRelease [31.1 kB]
                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                Hit:7 https://deb.nodesource.com/node_16.x stretch InRelease
                Reading package lists... Done
                E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file.
                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                    Checking ioBroker user and directory permissions (2/5)
                Created /etc/sudoers.d/iobroker
                Fixing directory permissions...
                    Check and cleanup npm temporary directories (3/5)
                Done.
                    Database maintenance (4/5)
                Checking for uncompressed JSONL databases... This might take a while!
                Compressing /opt/iobroker/iobroker-data/states.jsonl
                Compressing /opt/iobroker/iobroker-data/objects.jsonl
                Compressed 2 JSONL files. Done
                    Checking autostart (5/5)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                pi@homepi_phil:~ $
                pi@homepi_phil:~ $ iob upgrade all
                This upgrade of "yahka" will introduce the following changes:
                -> 1.0.3:
                Corrected empty device list with rebuild
                -> 1.0.1:
                we ensured controller 5 compatibility
                Formatting
                -> 0.17.0:
                Added AVAHI advertiser as default and updated HomeKit Library to improve performance and stability
                -> 0.14.0:
                Updated HomeKit Library
                -> 0.13.2:
                Fixed crashes due to changes in used HomeKit Library
                BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                Would you like to upgrade yahka from @0.13.1 to @1.0.3 now? [(y)es, (n)o]: No upgrade of "yahka" desired.
                This upgrade of "text2command" will at least introduce the following changes:
                -> 3.0.2:
                Corrected link from admin
                -> 3.0.1:
                Corrected many GUI errors
                -> 2.3.1:
                Migrated GUI to v5
                Would you like to upgrade text2command from @2.3.0 to @3.0.2 now? [(y)es, (n)o]: y
                Update text2command from @2.3.0 to @3.0.2
                NPM version: 8.19.4
                Installing iobroker.text2command@3.0.2... (System call)
                host.homepi_phil Cannot install iobroker.text2command@3.0.2: 244
                pi@homepi_phil:~ $ iob upgrade self --debug
                Stopped Objects DB
                Stopped States DB
                NPM version: 8.19.4
                npm ERR! errno -39
                  Ernsthaft?
                  Ansonsten jede Menge Fehler, der Fixer ist nicht durchgelaufen,
                  Kein Wunder dass nichts gefixt wurde
                    Ist ja auch schon Quark...
                    Schmeiß die bullseye-Quelle raus und reinstalliere nodejs in passender Version.
                      In /etc/apt/sources.list ist nur die stretch Quelle drin. Also kein Plan wo und wie ich die falschen Quellen löschen kann.
                      Irgendwann war das System down und dann hatte ich aus lauter Verzweiflung jede Menge probiert und verutlich Chaos angerichtet.
                      Es wäre vermutlich doch besser alles von Grund auf neu aufzusetzen oder?
                        Das ohnehin. Aber ich würde den Umzug mit einem Backup aus einem halbwegs aktuellen ioBroker machen.
                        Ist nämlich wesentlich einfacher.
                        cat /etc/apt/sources.list.d/node*
                        sagt?
                          sagt?
                          pi@homepi_phil:~ $ cat /etc/apt/sources.list.d/node*
                          #node 16
                          deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                          #node 18
                          deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
                          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye maindeb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x stretch main
                          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x stretch main
                            @philipp_lappe
                            Da hast du die falschen Einträge. Lösch den ganzen node18 und bullseye - Kram raus, es gibt kein node18 für stretch.
                            Also alles bis auf die letzte Zeile raus.
                            Dann
                            iob stop
                            sudo apt update
                            sudo apt install --reinstall nodejs
                              @philipp_lappe
                              Dann
                              iob stop
                              sudo apt update
                              Wenn ich sources.list öffne ist dort nur eine Quelle.
                                @philipp_lappe
                                Das ist ja auch eine andere Datei. Die nodesource.list liegt hier
                                sudo nano /etc/apt/sources.list.d/nodesource.list
                                  @philipp_lappe
                                  Ich habe alle Einträge bis auf den letzten entfernt, aber trotzdem werden die noch angezeigt. Reboot habe ich auch schon versucht.
                                  pi@homepi_phil:~ $ sudo apt update
                                  Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
                                  Ign:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                                  Hit:5 https://deb.nodesource.com/node_16.x stretch InRelease
                                    Nö, jetzt gibt es nur einen 'Hit' für nodesource.
                                    Die anderen Einträge kommen daher, das der Reste der Welt den 'stretch' halt schon längst zu Grabe getragen hat. Jetzt den --reinstall wie oben schon beschrieben.
                                      Leider klappt es nicht.
                                      pi@homepi_phil:sudo apt update
                                      pi@homepi_phil:~ $ sudo apt install --reinstall nodejs
                                      Building dependency tree
                                      Reinstallation of nodejs is not possible, it cannot be downloaded.
                                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        @philipp_lappe
                                        apt policy nodejs
                                        sagt?
                                          apt policy nodejs
                                          pi@homepi_phil:~ $ apt policy nodejs
                                          nodejs:
                                            Installed: 16.20.0-deb-1nodesource1
                                            Candidate: 16.20.0-deb-1nodesource1
                                            Version table:
                                           *** 16.20.0-deb-1nodesource1 100
                                                  100 /var/lib/dpkg/status
                                               8.11.1~dfsg-2~bpo9+1 500
                                                  500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                                               4.8.2~dfsg-1 500
                                                  500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                                            @philipp_lappe
                                            Ja, dann hat nodesource die Pakete 'schon' vom Server gelöscht.
                                            Das ist auch der Grund, warum es immer schwierig ist, längst abgekündigte Versionen bei Laune zu halten.
                                            Dann versuch mit dem Backup basierend auf dem alten Stand um zuziehen.
                                            Musst du halt im neuen System entsprchende Klimmzüge machen (js-controller auf 4.0.24 drücken usw.)
                                            6290
