    3. Einsteigerfragen
    4. Installation
    5. Wie führe ich ein sauberes Updates durch?
    • da_Woody
      da_Woody @philipp_lappe last edited by
      @philipp_lappe bitte, setz deine logs in 3b78940c-63e7-4156-b8fc-6d42ca860f0d-grafik.png
        Homoran Global Moderator Administrators @philipp_lappe last edited by
        @philipp_lappe sagte in Wie führe ich ein sauberes Updates durch?:
        iob upgrade self --debug
        und die anderen Ausgaben?
          philipp_lappe @Homoran last edited by
          pi@homepi_phil:~ $ iob stop
          pi@homepi_phil:~ $
          pi@homepi_phil:~ $ iob fix
          library: loaded
          Library version=2023-10-13
              Welcome to the ioBroker installation fixer!
              Script version: 2023-10-13
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
          Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
          Err:3 http://raspbian.raspberrypi.org/raspbian stretch Release
            404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
          Get:4 https://download.docker.com/linux/raspbian stretch InRelease [31.1 kB]
          Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
          Hit:7 https://deb.nodesource.com/node_16.x stretch InRelease
          Reading package lists... Done
          E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
              Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@homepi_phil:~ $
          pi@homepi_phil:~ $ iob upgrade all
          This upgrade of "yahka" will introduce the following changes:
          -> 1.0.3:
          Corrected empty device list with rebuild
          -> 1.0.1:
          we ensured controller 5 compatibility
          Formatting
          -> 0.17.0:
          Added AVAHI advertiser as default and updated HomeKit Library to improve performance and stability
          -> 0.14.0:
          Updated HomeKit Library
          -> 0.13.2:
          Fixed crashes due to changes in used HomeKit Library
          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
          Would you like to upgrade yahka from @0.13.1 to @1.0.3 now? [(y)es, (n)o]: No upgrade of "yahka" desired.
          This upgrade of "text2command" will at least introduce the following changes:
          -> 3.0.2:
          Corrected link from admin
          -> 3.0.1:
          Corrected many GUI errors
          -> 2.3.1:
          Migrated GUI to v5
          Would you like to upgrade text2command from @2.3.0 to @3.0.2 now? [(y)es, (n)o]: y
          Update text2command from @2.3.0 to @3.0.2
          NPM version: 8.19.4
          Installing iobroker.text2command@3.0.2... (System call)
          host.homepi_phil Cannot install iobroker.text2command@3.0.2: 244
          pi@homepi_phil:~ $ iob upgrade self --debug
          Update js-controller from @4.0.24 to @5.0.12
          Stopped Objects DB
          Stopped States DB
          NPM version: 8.19.4
          Installing iobroker.js-controller@5.0.12... (System call)
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/acme-http-01-standalone
          npm ERR! dest /opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acme-http-01-standalone' -> '/opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK'
          npm ERR!     /home/iobroker/.npm/_logs/2023-11-12T22_09_46_524Z-debug-0.log
          host.homepi_phil Cannot install iobroker.js-controller@5.0.12: 217
            Ernsthaft?
            Ansonsten jede Menge Fehler, der Fixer ist nicht durchgelaufen,
            Kein Wunder dass nichts gefixt wurde
              Thomas Braun Most Active @philipp_lappe last edited by
              Ist ja auch schon Quark...
              Schmeiß die bullseye-Quelle raus und reinstalliere nodejs in passender Version.
                philipp_lappe @Thomas Braun last edited by
                @thomas-braun said in Wie führe ich ein sauberes Updates durch?:
                In /etc/apt/sources.list ist nur die stretch Quelle drin. Also kein Plan wo und wie ich die falschen Quellen löschen kann.
                Irgendwann war das System down und dann hatte ich aus lauter Verzweiflung jede Menge probiert und verutlich Chaos angerichtet.
                Es wäre vermutlich doch besser alles von Grund auf neu aufzusetzen oder?
                  Das ohnehin. Aber ich würde den Umzug mit einem Backup aus einem halbwegs aktuellen ioBroker machen.
                  Ist nämlich wesentlich einfacher.
                  cat /etc/apt/sources.list.d/node*
                  sagt?
                    sagt?
                    pi@homepi_phil:~ $ cat /etc/apt/sources.list.d/node*
                    #node 16
                    deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                    #node 18
                    deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
                    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye maindeb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x stretch main
                    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x stretch main
                      @philipp_lappe
                      Da hast du die falschen Einträge. Lösch den ganzen node18 und bullseye - Kram raus, es gibt kein node18 für stretch.
                      Also alles bis auf die letzte Zeile raus.
                      Dann
                      iob stop
                      sudo apt update
                      sudo apt install --reinstall nodejs
                        @philipp_lappe
                        Dann
                        iob stop
                        sudo apt update
                        Wenn ich sources.list öffne ist dort nur eine Quelle.
                          @philipp_lappe
                          Das ist ja auch eine andere Datei. Die nodesource.list liegt hier
                          sudo nano /etc/apt/sources.list.d/nodesource.list
                            @philipp_lappe
                            Ich habe alle Einträge bis auf den letzten entfernt, aber trotzdem werden die noch angezeigt. Reboot habe ich auch schon versucht.
                            pi@homepi_phil:~ $ sudo apt update
                            Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
                            Ign:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                            Hit:5 https://deb.nodesource.com/node_16.x stretch InRelease
                              Nö, jetzt gibt es nur einen 'Hit' für nodesource.
                              Die anderen Einträge kommen daher, das der Reste der Welt den 'stretch' halt schon längst zu Grabe getragen hat. Jetzt den --reinstall wie oben schon beschrieben.
                                Leider klappt es nicht.
                                pi@homepi_phil:sudo apt update
                                pi@homepi_phil:~ $ sudo apt install --reinstall nodejs
                                Building dependency tree
                                Reinstallation of nodejs is not possible, it cannot be downloaded.
                                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                  @philipp_lappe
                                  apt policy nodejs
                                  sagt?
                                    apt policy nodejs
                                    pi@homepi_phil:~ $ apt policy nodejs
                                    nodejs:
                                      Installed: 16.20.0-deb-1nodesource1
                                      Candidate: 16.20.0-deb-1nodesource1
                                      Version table:
                                     *** 16.20.0-deb-1nodesource1 100
                                            100 /var/lib/dpkg/status
                                         8.11.1~dfsg-2~bpo9+1 500
                                            500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                                         4.8.2~dfsg-1 500
                                            500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                                      @philipp_lappe
                                      Ja, dann hat nodesource die Pakete 'schon' vom Server gelöscht.
                                      Das ist auch der Grund, warum es immer schwierig ist, längst abgekündigte Versionen bei Laune zu halten.
                                      Dann versuch mit dem Backup basierend auf dem alten Stand um zuziehen.
                                      Musst du halt im neuen System entsprchende Klimmzüge machen (js-controller auf 4.0.24 drücken usw.)
                                        Okay, danke für deine Unterstützung.
                                        Welchen Vorteil genau habe ich denn dadurch, wenn ich mit dem alten Backup arbeite?
                                        Glücklicherweise ist mein System realtaiv klein. Ich habe nur Sonoff und Shelly Devices und auf iobroker läuft yahka und Telegram.
                                        Also alles komplett neu machen ist zwar bestimmt ein Tag Arbeit, aber wenn das besser ist dann würde ich es in Angriff nehmen.
                                        Oder bekomme ich das auch wieder sauber, wenn ich mit dem Backup arbeite? Also was meinst du mit Klimmzügen?
                                        Gibt es für solch einen Umzug eine gute Anleitung an die ich mich halten kann?
                                        Thomas Braun da_Woody 2 Replies Last reply Reply Quote 0
                                          Keinen. Es ist nur komplizierter, weil ein frisch neu hingezauberter ioBroker mit js-controller 5 daherkommt, aber nix mit Backups aus der 4er-Version anfangen kann. Da muss man den 5er auf 4 drücken und kann dann erst versuchen ein Backup einzuspielen.
                                          • da_Woody
                                            @philipp_lappe ich würde den Tag Arbeit in kauf nehmen. Spart nerven...
                                            6291
