    4. Diskussion zum HowTo nodejs-Installation und upgrade
      Thomas Braun Most Active @ma last edited by
      @ma
      iob stop
      iob fix
      iob nodejs-update
        ma last edited by
        Hat funktioniert
        danke für die schnelle rückmeldung ☺
          ma @Thomas Braun last edited by
          @thomas-braun bin doch noch auf ein problem gestoßen ich kann aktuell keine adapter mehr updaten
          $ iobroker upgrade telegram@2.0.1
          host.iobroker Adapter "system.adapter.telegram.0" is stopped.
          host.iobroker Adapter "system.adapter.telegram.1" is stopped.
          Installing iobroker.telegram@2.0.1... (System call)
          host.iobroker Cannot install iobroker.telegram@2.0.1: 217
          ERROR: Process exited with code 25
          $ iobroker upgrade shelly@6.6.1
          Update shelly from @6.4.5 to @6.6.1
          Installing iobroker.shelly@6.6.1... (System call)
          Try to solve ENOTEMPTY error automaticallyInstalling iobroker.shelly@6.6.1... (System call)
          host.iobroker deleted npm temp directory: ".bindings-4WLiqHNJ")
          host.iobroker Cannot install iobroker.shelly@6.6.1: 217
          NPM version: 9.8.1
          Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@75lb/deep-mergenpm ERR! dest /opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLAnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@75lb/deep-merge' -> '/opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLA'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_04_36_193Z-debug-0.loghost.iobroker Cannot install iobroker.shelly@6.6.1: 217
            ma @ma last edited by
            @ma
            $ iobroker upgrade fullybrowser@2.2.0
            Update fullybrowser from @2.1.2 to @2.2.0
            Installing iobroker.fullybrowser@2.2.0... (System call)
            Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@alcalzone/jsonl-dbnpm ERR! dest /opt/iobroker/node_modules/@alcalzone/.jsonl-db-koHBLxk9npm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@alcalzone/jsonl-db' -> '/opt/iobroker/node_modules/@alcalzone/.jsonl-db-koHBLxk9'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_27_01_858Z-debug-0.loghost.iobroker Cannot install iobroker.fullybrowser@2.2.0: 217
              @ma
              iob stop
              iob fix
              iob start
                @thomas-braun schon probiert leider keine Besserung
                  @ma
                  Dann mit --debug-Option installieren.
                  iob update
                  sagt?
                    iob update
                    Used repository: Stable (default)
                    Adapter    "admin"        : 6.12.0   , installed 6.12.0
                    Adapter    "alarm"        : 3.4.0    , installed 3.4.0
                    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                    Adapter    "bidirectional-counter": 2.1.0, installed 2.1.0
                    Adapter    "bring"        : 1.8.4    , installed 1.8.4
                    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                    Adapter    "device-watcher": 2.9.4   , installed 2.9.4
                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                    Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
                    Adapter    "email"        : 1.2.0    , installed 1.2.0
                    Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                    Adapter    "fritzdect"    : 2.3.1    , installed 2.5.8
                    Adapter    "fullybrowser" : 2.2.0    , installed 2.1.2  [Updatable]
                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                    Adapter    "homekit-controller": 0.5.8, installed 0.5.8
                    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                    Controller "js-controller": 5.0.12   , installed 5.0.12
                    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                    Adapter    "oekofen-json" : 1.0.5    , installed 1.0.5
                    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                    Adapter    "operating-hours": 1.0.4  , installed 1.0.4
                    Adapter    "parser"       : 1.3.2    , installed 1.3.2
                    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
                    Adapter    "radar2"       : 2.0.8    , installed 2.0.7  [Updatable]
                    Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
                    Adapter    "shelly"       : 6.6.1    , installed 6.4.5  [Updatable]
                    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                    Adapter    "telegram"     : 2.0.1    , installed 1.16.0 [Updatable]
                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                    Adapter    "text2command" : 3.0.2    , installed 3.0.2
                    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                    Adapter    "vis"          : 1.4.16   , installed 1.4.16
                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                    Adapter    "web"          : 6.1.4    , installed 6.1.4
                    Adapter    "windows-control": 0.1.5  , installed 0.1.5
                    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                    iobroker upgrade shelly --debug
                    This upgrade of "shelly" will introduce the following changes:
                    -> 6.6.1:
                    Fixed stop reason for Shelly 2.5 / Shelly 2
                    Added humidity of Shelly Plus Addon
                    Not all devices have external power
                    -> 6.6.0:
                    Added BLE devices as states to `shelly.0.ble.*` (Shelly Scripting required)
                    -> 6.5.0:
                    Added Shelly Plus Smoke
                    Added Shelly Bluetooth Low Energy Gateway
                    More Shelly TRV Datapoints
                    Would you like to upgrade shelly from @6.4.5 to @6.6.1 now? [(y)es, (n)o]: y
                    NPM version: 9.8.1
                    npm ERR! errno -39
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T06_39_34_733Z-debug-0.log
                    npm ERR! errno -39
                      @ma
                      Jag den
                      iob fix
                      drüber.
                        SiKo last edited by
                        Hallo, hab schon versucht nodejs zu deinstallieren und neu installieren. Bekomme aber immer wieder diesen Fehler:
                        Was kann ich tun?
                        pi@raspberrypi:~ $ sudo apt-get update && sudo apt-get full-upgrade
                        OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Holen:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12,1 kB]
                        Fehl:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                        Paketlisten werden gelesen… Fertig
                        W: GPG-Fehler: https://deb.nodesource.com/node_18.x nodistro InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                        E: Das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« ist nicht signiert.
                        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                        pi@raspberrypi:~ $
                          @siko sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                          mach es mit iob nodejs-update
                            Thomas Braun Most Active @SiKo last edited by
                            @siko
                            Da fehlen die Schlüssel.
                            Mach es mit
                            iob nodejs-update
                            dann passt es auch.
                              SiKo last edited by
                              vielen Dank, Hat direkt funktioniert.
                                Natürlich... : 😊
                                  @thomas-braun der 2 durchlauf vom fix hat das problem gelößt leider nur bis gerade eben
                                  $ iobroker upgrade sonos@3.0.0
                                  Update sonos from @2.3.1 to @3.0.0
                                  Installing iobroker.sonos@3.0.0... (System call)
                                  host.iobroker deleted npm temp directory: ".acorn-jsx-zPgFNGpl")
                                  host.iobroker deleted npm temp directory: ".alcalzone-shared-FgX40TmF")
                                  host.iobroker deleted npm temp directory: ".all-package-names-BPhkNiF7")
                                  host.iobroker deleted npm temp directory: ".ansi-colors-qAZfUuTD")
                                  host.iobroker deleted npm temp directory: ".ansi-escapes-BuACp4PU")
                                  host.iobroker deleted npm temp directory: ".any-observable-GucR4b7Z")
                                  host.iobroker deleted npm temp directory: ".any-promise-GjCkSNL3")host.iobroker deleted npm temp directory: ".anymatch-7vz5qHmT")host.iobroker deleted npm temp directory: ".aproba-IIqIrfbB")
                                  host.iobroker deleted npm temp directory: ".array-flatten-95xLgxGw")
                                  host.iobroker deleted npm temp directory: ".array.prototype.findindex-JX1jwpiR")
                                  host.iobroker deleted npm temp directory: ".boolbase-8130XECE")
                                  host.iobroker deleted npm temp directory: ".bplist-parser-GTDOjzTC")
                                  host.iobroker deleted npm temp directory: ".bundle-name-DjKLTayE")
                                  host.iobroker deleted npm temp directory: ".busboy-A5FsP0CS")
                                  host.iobroker deleted npm temp directory: ".chownr-E9JZijSA")
                                  host.iobroker deleted npm temp directory: ".data-uri-to-buffer-GQ7HcaPL")
                                  host.iobroker deleted npm temp directory: ".decamelize-keys-RDuJHe51")
                                  host.iobroker deleted npm temp directory: ".decimal.js-A6TpPJWn")
                                  host.iobroker deleted npm temp directory: ".dns-equal-TvMdkxWU")
                                  host.iobroker deleted npm temp directory: ".es-shim-unscopables-lNCpEqsg")
                                  host.iobroker deleted npm temp directory: ".esutils-1jlXlxlo")
                                  host.iobroker deleted npm temp directory: ".follow-redirects-vRGWWNjd")
                                  host.iobroker deleted npm temp directory: ".gopd-LUHsc2oq")
                                  host.iobroker deleted npm temp directory: ".got-DFICjTYm")
                                  host.iobroker deleted npm temp directory: ".graceful-fs-i6Qs7iN3")
                                  host.iobroker deleted npm temp directory: ".indexof-m6nUtkW4")
                                  host.iobroker deleted npm temp directory: ".inflight-pQph8mNF")
                                  host.iobroker deleted npm temp directory: ".influx-JoUiD55Z")host.iobroker deleted npm temp directory: ".inherits-ffYUEA4n")host.iobroker deleted npm temp directory: ".ini-HiLT2lH8")host.iobroker deleted npm temp directory: ".inquirer-0PRKJaIm")
                                  host.iobroker deleted npm temp directory: ".iobroker-adapter-helpers-za1UEIZc")
                                  host.iobroker deleted npm temp directory: ".iobroker.alarm-g8jjAFg9")
                                  host.iobroker deleted npm temp directory: ".iobroker.alias-manager-gHAtOr6e")
                                  host.iobroker deleted npm temp directory: ".iobroker.bidirectional-counter-PzmaO0Aw")
                                  host.iobroker deleted npm temp directory: ".iobroker.bring-ov1aPXwP")
                                  host.iobroker deleted npm temp directory: ".iobroker.broadlink2-HDK4EOgs")
                                  host.iobroker deleted npm temp directory: ".iobroker.coronavirus-statistics-Kxvay9Wy")
                                  host.iobroker deleted npm temp directory: ".iobroker.countdown-M3o5XFv5")
                                  host.iobroker deleted npm temp directory: ".iobroker.daswetter-1t9k5PAQ")
                                  host.iobroker deleted npm temp directory: ".iobroker.device-watcher-JRkscZB5")
                                  host.iobroker deleted npm temp directory: ".iobroker.devices-1FmykokK")
                                  host.iobroker deleted npm temp directory: ".iobroker.discovery-Domn1CAP")
                                  host.iobroker deleted npm temp directory: ".iobroker.doorbird-kwq4QU5M")
                                  host.iobroker deleted npm temp directory: ".iobroker.dwd-SpnK64ht")
                                  host.iobroker deleted npm temp directory: ".iobroker.email-7I7P5tNz")
                                  host.iobroker deleted npm temp directory: ".iobroker.energiefluss-kJMU3Qwp")
                                  host.iobroker deleted npm temp directory: ".iobroker.feiertage-WV2cxVZc")
                                  host.iobroker deleted npm temp directory: ".iobroker.fullybrowser-g2Durliy")
                                  host.iobroker deleted npm temp directory: ".iobroker.harmony-BDALdOzG")
                                  host.iobroker deleted npm temp directory: ".iobroker.heatingcontrol-fFfpnmIZ")
                                  host.iobroker deleted npm temp directory: ".iobroker.hm-rega-eDrPvalf")
                                  host.iobroker deleted npm temp directory: ".iobroker.hm-rpc-6COQ5CUM")
                                  host.iobroker deleted npm temp directory: ".iobroker.homekit-controller-sF0AM7Io")
                                  host.iobroker deleted npm temp directory: ".iobroker.ical-rrBOhFW0")
                                  host.iobroker deleted npm temp directory: ".iobroker.icons-icons8-F8SpNGzQ")
                                  host.iobroker deleted npm temp directory: ".iobroker.icons-material-png-A0Zx2K4e")
                                  host.iobroker deleted npm temp directory: ".iobroker.icons-material-svg-E2OoIK18")
                                  host.iobroker deleted npm temp directory: ".iobroker.icons-mfd-svg-UK4n9spV")
                                  host.iobroker deleted npm temp directory: ".iobroker.influxdb-mtpshsVk")
                                  host.iobroker deleted npm temp directory: ".iobroker.info-OtqXm2hx")
                                  host.iobroker deleted npm temp directory: ".iobroker.iqontrol-JG9EP64y")
                                  host.iobroker deleted npm temp directory: ".iobroker.jarvis-Dfkzlr3d")
                                  host.iobroker deleted npm temp directory: ".iobroker.javascript-5NZ432mn")
                                  host.iobroker deleted npm temp directory: ".iobroker.js-controller-7Q8bmsba")
                                  host.iobroker deleted npm temp directory: ".iobroker.linkeddevices-SudTlN7O")
                                  host.iobroker deleted npm temp directory: ".iobroker.modbus-MRiPN8Jv")
                                  host.iobroker deleted npm temp directory: ".iobroker.mqtt-R5v7g772")
                                  host.iobroker deleted npm temp directory: ".iobroker.mqtt-client-AcZDMICZ")
                                  host.iobroker deleted npm temp directory: ".iobroker.mytime-ALCjuXxL")
                                  host.iobroker deleted npm temp directory: ".iobroker.nut-M42R6CUU")
                                  host.iobroker deleted npm temp directory: ".iobroker.oekofen-json-AAGebuoM")
                                  host.iobroker deleted npm temp directory: ".iobroker.openweathermap-uUPAAaq5")
                                  host.iobroker deleted npm temp directory: ".iobroker.operating-hours-vFpZVs6M")
                                  host.iobroker deleted npm temp directory: ".iobroker.parser-lf3ZX1wK")
                                  host.iobroker deleted npm temp directory: ".iobroker.ping-OPzFiLFH")
                                  host.iobroker deleted npm temp directory: ".iobroker.pushover-c2imyZua")
                                  host.iobroker deleted npm temp directory: ".iobroker.pushsafer-akpid5GF")
                                  host.iobroker deleted npm temp directory: ".iobroker.radar2-VVWJ5P6u")
                                  host.iobroker deleted npm temp directory: ".iobroker.sayit-RsEZnXzS")
                                  host.iobroker deleted npm temp directory: ".iobroker.scenes-9WoxMImK")
                                  host.iobroker deleted npm temp directory: ".iobroker.shelly-wfXzBUin")
                                  host.iobroker deleted npm temp directory: ".iobroker.shuttercontrol-msgqlVR3")
                                  host.iobroker deleted npm temp directory: ".iobroker.simple-api-q4TJvC8n")
                                  host.iobroker deleted npm temp directory: ".iobroker.smartcontrol-670ft8lY")
                                  host.iobroker deleted npm temp directory: ".iobroker.smartmeter-OyPCR5Lj")
                                  host.iobroker deleted npm temp directory: ".iobroker.socketio-0ZB5ejpX")
                                  host.iobroker deleted npm temp directory: ".iobroker.sonoff-nQCcGLOb")
                                  host.iobroker deleted npm temp directory: ".iobroker.sonos-8p9DbxUk")
                                  host.iobroker deleted npm temp directory: ".iobroker.sourceanalytix-xH8dPE7Z")
                                  host.iobroker deleted npm temp directory: ".iobroker.sprinklecontrol-jINmg3MW")
                                  host.iobroker deleted npm temp directory: ".iobroker.statistics-nDtQT913")
                                  host.iobroker deleted npm temp directory: ".iobroker.telegram-qJ3kkwRA")
                                  host.iobroker deleted npm temp directory: ".iobroker.terminal-LQj2rBFR")
                                  host.iobroker deleted npm temp directory: ".iobroker.text2command-XKgXlG9f")
                                  host.iobroker deleted npm temp directory: ".iobroker.trashschedule-bVFlHcrS")
                                  host.iobroker deleted npm temp directory: ".iobroker.unifi-YuUe0MFZ")
                                  host.iobroker deleted npm temp directory: ".iobroker.upnp-XYJa4jHA")
                                  host.iobroker deleted npm temp directory: ".iobroker.virtualpowermeter-aiSWB1CL")
                                  host.iobroker deleted npm temp directory: ".iobroker.vis-hqwidgets-XOleJSph")
                                  host.iobroker deleted npm temp directory: ".iobroker.vis-icontwo-ZE5SYXJL")
                                  host.iobroker deleted npm temp directory: ".iobroker.weatherunderground-yjlWL8nH")
                                  host.iobroker deleted npm temp directory: ".iobroker.web-qhxwcVTa")
                                  host.iobroker deleted npm temp directory: ".iobroker.windows-control-m2ZZnHAV")
                                  host.iobroker deleted npm temp directory: ".iobroker.wiobrowser-0FquAKud")
                                  host.iobroker deleted npm temp directory: ".iobroker.ws-Ul5el1jB")
                                  host.iobroker deleted npm temp directory: ".iobroker.yahka-5keTFK1G")
                                  host.iobroker deleted npm temp directory: ".iobroker.zigbee-1JQaSLfT")
                                  host.iobroker deleted npm temp directory: ".ipaddr.js-Cv8HUhd7")
                                  host.iobroker deleted npm temp directory: ".is-array-buffer-jIv3kdDM")
                                  host.iobroker deleted npm temp directory: ".is-bigint-opiLNorc")host.iobroker deleted npm temp directory: ".is-binary-path-T9bvCuQK")
                                  host.iobroker deleted npm temp directory: ".is-core-module-3szSVmLC")
                                  host.iobroker deleted npm temp directory: ".is-docker-diEaV9Js")
                                  host.iobroker deleted npm temp directory: ".is-map-DnX0Tp2n")
                                  host.iobroker deleted npm temp directory: ".is-name-taken-RA37aJNO")
                                  host.iobroker deleted npm temp directory: ".is-npm-Tq5PXIR1")
                                  host.iobroker deleted npm temp directory: ".is-obj-H9BCY1mC")
                                  host.iobroker deleted npm temp directory: ".is-promise-TcPsCtHt")
                                  host.iobroker deleted npm temp directory: ".is-symbol-DyzbAfPe")
                                  host.iobroker deleted npm temp directory: ".is-utf8-XzPsDN8p")
                                  host.iobroker deleted npm temp directory: ".is-weakref-3wPDZaCU")
                                  host.iobroker deleted npm temp directory: ".is-wsl-67INiaF0")
                                  host.iobroker deleted npm temp directory: ".is-yarn-global-z8J5xFQb")
                                  host.iobroker deleted npm temp directory: ".javascript-natural-sort-BSvwVhzD")
                                  host.iobroker deleted npm temp directory: ".js-sdsl-RiJhgh6j")
                                  host.iobroker deleted npm temp directory: ".jsonc-parser-nbReDrcG")
                                  host.iobroker deleted npm temp directory: ".jsonwebtoken-b9ysUQT0")
                                  host.iobroker deleted npm temp directory: ".jsprim-QmUwRLNa")
                                  host.iobroker deleted npm temp directory: ".jszip-r3fGcU4N")
                                  host.iobroker deleted npm temp directory: ".kind-of-ZEKy7WZt")
                                  host.iobroker deleted npm temp directory: ".layerr-GPEJIlGL")
                                  host.iobroker deleted npm temp directory: ".lcid-SGsSRn9Q")
                                  host.iobroker deleted npm temp directory: ".libsodium-wrappers-xQoQYz7T")
                                  host.iobroker deleted npm temp directory: ".lines-and-columns-ohK2P2I1")
                                  host.iobroker deleted npm temp directory: ".listr-SF1ph3tc")
                                  host.iobroker deleted npm temp directory: ".listr-update-renderer-CSIQ7CWX")
                                  host.iobroker deleted npm temp directory: ".load-json-file-5LcbUpDJ")
                                  host.iobroker deleted npm temp directory: ".locate-path-t7OptBTV")
                                  host.iobroker deleted npm temp directory: ".lodash-MxVnsAsD")
                                  host.iobroker deleted npm temp directory: ".lodash.isnumber-P8M8GSmV")
                                  host.iobroker deleted npm temp directory: ".log-symbols-rbtC1M9g")
                                  host.iobroker deleted npm temp directory: ".log-update-SuSlKzSj")
                                  host.iobroker deleted npm temp directory: ".logform-Bwy2bCcs")
                                  host.iobroker deleted npm temp directory: ".loupe-hV7arrgu")
                                  host.iobroker deleted npm temp directory: ".lru_map-uI07ZEOk")
                                  host.iobroker deleted npm temp directory: ".macaddress-dlPdmBpu")
                                  host.iobroker deleted npm temp directory: ".map-obj-FDgyUQwo")
                                  host.iobroker deleted npm temp directory: ".map-stream-elIH4kVT")
                                  host.iobroker deleted npm temp directory: ".md5-viMx30VF")
                                  host.iobroker deleted npm temp directory: ".media-typer-kYaJhV1E")
                                  host.iobroker deleted npm temp directory: ".mime-db-RKfcSKNg")
                                  host.iobroker deleted npm temp directory: ".mimic-fn-hAcoKpm0")
                                  host.iobroker deleted npm temp directory: ".minimist-options-qXL9cbTR")
                                  host.iobroker deleted npm temp directory: ".minipass-FfE0ClCz")
                                  host.iobroker deleted npm temp directory: ".mkdirp-classic-HAXMCI8y")
                                  host.iobroker deleted npm temp directory: ".mkdirp-yMXn50Ac")
                                  host.iobroker deleted npm temp directory: ".module-not-found-error-zFjQCtp1")
                                  host.iobroker deleted npm temp directory: ".moment-YVTvHlwl")
                                  host.iobroker deleted npm temp directory: ".moment-timezone-LVF6Tkme")
                                  host.iobroker deleted npm temp directory: ".mp3-duration-121XpnWA")
                                  host.iobroker deleted npm temp directory: ".mqtt-packet-9zhbF4Ks")
                                  host.iobroker deleted npm temp directory: ".mz-vxKYAgCA")
                                  host.iobroker deleted npm temp directory: ".nan-VJWFtQnQ")
                                  host.iobroker deleted npm temp directory: ".napi-thread-safe-callback-z2DAzfv3")
                                  host.iobroker deleted npm temp directory: ".netmask-9Rl4SU3k")
                                  host.iobroker deleted npm temp directory: ".new-github-release-url-rEfy33Ln")
                                  host.iobroker deleted npm temp directory: ".node-arp-exu75jRl")
                                  host.iobroker deleted npm temp directory: ".node-ble-gjuzQuSp")
                                  host.iobroker deleted npm temp directory: ".node-fetch-blvKKu2b")
                                  host.iobroker deleted npm temp directory: ".node-forge-h7cGFpHY")
                                  host.iobroker deleted npm temp directory: ".node-gyp-build-r457ov9R")
                                  host.iobroker deleted npm temp directory: ".node-hkdf-sync-fknK7puz")
                                  host.iobroker deleted npm temp directory: ".node-ical-qUo0I4Tm")
                                  host.iobroker deleted npm temp directory: ".node-inspect-waaOWKUA")
                                  host.iobroker deleted npm temp directory: ".node-persist-2EKJxgHF")
                                  host.iobroker deleted npm temp directory: ".node-schedule-qQzDXhqu")
                                  host.iobroker deleted npm temp directory: ".node-ssdp-m1VaQXdw")
                                  host.iobroker deleted npm temp directory: ".node-telegram-bot-api-1etpN2K2")
                                  host.iobroker deleted npm temp directory: ".node-unifi-3DHKBhgr")
                                  host.iobroker deleted npm temp directory: ".node.extend-K6FJItiR")
                                  host.iobroker deleted npm temp directory: ".nopt-H6aHmXjc")
                                  host.iobroker deleted npm temp directory: ".normalize-path-OU9YSYPX")
                                  host.iobroker deleted npm temp directory: ".normalize-url-SZTcDbe8")
                                  host.iobroker deleted npm temp directory: ".np-rJ4MzeVW")
                                  host.iobroker deleted npm temp directory: ".npmlog-BabU8SvR")
                                  host.iobroker deleted npm temp directory: ".object-hash-mLu6dbUq")
                                  host.iobroker deleted npm temp directory: ".on-finished-RsKM9iVb")
                                  host.iobroker deleted npm temp directory: ".one-time-w9IAMdTx")
                                  host.iobroker deleted npm temp directory: ".onedrive-api-P1aPRSY2")
                                  host.iobroker deleted npm temp directory: ".open-QucUEWry")
                                  host.iobroker deleted npm temp directory: ".optionator-PuhYgmIm")
                                  host.iobroker deleted npm temp directory: ".os-tmpdir-1IsoZrn1")
                                  host.iobroker deleted npm temp directory: ".p-limit-gOKrDIjV")
                                  host.iobroker deleted npm temp directory: ".p-map-XQyfxwrm")
                                  host.iobroker deleted npm temp directory: ".p-reflect-kbxyMQvX")
                                  host.iobroker deleted npm temp directory: ".p-try-nDlwX8SY")
                                  host.iobroker deleted npm temp directory: ".package-name-conflict-pgCDYPR4")
                                  host.iobroker deleted npm temp directory: ".parse-json-RdQ2IyFU")
                                  host.iobroker deleted npm temp directory: ".parse-listing-8te0aWIy")
                                  host.iobroker deleted npm temp directory: ".parseuri-KPPXjLGZ")
                                  host.iobroker deleted npm temp directory: ".parsexmlresponse-xx6pTUUG")
                                  host.iobroker deleted npm temp directory: ".path-exists-ta4BL8U6")
                                  host.iobroker deleted npm temp directory: ".path-parse-8gkiAjRV")
                                  host.iobroker deleted npm temp directory: ".pdfkit-e7FwFah6")
                                  host.iobroker deleted npm temp directory: ".pidtree-P86HYqqk")
                                  host.iobroker deleted npm temp directory: ".pinkie-promise-zAO2ov7N")
                                  host.iobroker deleted npm temp directory: ".png-js-diABWe2F")
                                  host.iobroker deleted npm temp directory: ".portfinder-OSqONEX8")
                                  host.iobroker deleted npm temp directory: ".prelude-ls-NDoRZxgk")
                                  host.iobroker deleted npm temp directory: ".prepend-http-9s5cfVm0")
                                  host.iobroker deleted npm temp directory: ".progress-Kac1LqJ7")host.iobroker deleted npm temp directory: ".promisify-child-process-qtJuXdmi")
                                  host.iobroker deleted npm temp directory: ".proto-list-nfO8tqoz")
                                  host.iobroker deleted npm temp directory: ".proxy-from-env-vcslNjmL")
                                  host.iobroker deleted npm temp directory: ".pump-7uzcbBxQ")
                                  host.iobroker deleted npm temp directory: ".pushover-notifications-hkCkDXkO")
                                  host.iobroker deleted npm temp directory: ".pushsafer-notifications-kh9EJENe")
                                  host.iobroker deleted npm temp directory: ".q-SKXE2OoR")
                                  host.iobroker deleted npm temp directory: ".qs-zUtDfLzC")
                                  host.iobroker deleted npm temp directory: ".read-file-safe-cjdRRRu9")
                                  host.iobroker deleted npm temp directory: ".read-json-safe-laZsPfMf")
                                  host.iobroker deleted npm temp directory: ".read-pkg-A2Az6mLS")
                                  host.iobroker deleted npm temp directory: ".readdir-glob-uUrpbb1G")
                                  host.iobroker deleted npm temp directory: ".readline-sync-OZdd0hqJ")
                                  host.iobroker deleted npm temp directory: ".reinterval-wLApnByp")
                                  host.iobroker deleted npm temp directory: ".request-promise-aj2YEifc")
                                  host.iobroker deleted npm temp directory: ".request-promise-core-cNo6sLbS")
                                  host.iobroker deleted npm temp directory: ".requires-port-Uktyik13")
                                  host.iobroker deleted npm temp directory: ".resolve-alpn-RTKpuZSr")
                                  host.iobroker deleted npm temp directory: ".resolve-from-j6Gv9Ebe")
                                  host.iobroker deleted npm temp directory: ".rfdc-cHAORKEZ")
                                  host.iobroker deleted npm temp directory: ".rimraf-eynkDvvy")
                                  host.iobroker deleted npm temp directory: ".rrule-y9C9hovL")
                                  host.iobroker deleted npm temp directory: ".run-parallel-DCURDW1N")
                                  host.iobroker deleted npm temp directory: ".set-blocking-q9SMvfvB")
                                  host.iobroker deleted npm temp directory: ".simple-swizzle-r4Lxbm1X")
                                  host.iobroker deleted npm temp directory: ".sinon-chai-hl4FcWX3")host.iobroker deleted npm temp directory: ".sinon-vBaWPxBD")host.iobroker deleted npm temp directory: ".slash-R0a5JLyH")host.iobroker deleted npm temp directory: ".slice-ansi-eEa9CtYe")host.iobroker deleted npm temp directory: ".slip-OVBIyeXx")host.iobroker deleted npm temp directory: ".smartmeter-obis-KbLeNtYQ")host.iobroker deleted npm temp directory: ".socket.io-EtoLYra9")host.iobroker deleted npm temp directory: ".socket.io-adapter-tLg9dAuy")host.iobroker deleted npm temp directory: ".socket.io-client-ENiKueA5")host.iobroker deleted npm temp directory: ".socket.io-parser-hH5dvNyh")host.iobroker deleted npm temp directory: ".socksv5-3JzHnAms")host.iobroker deleted npm temp directory: ".sonos-discovery-Uazo0hAg")host.iobroker deleted npm temp directory: ".sorted-array-functions-vKv0t5Tc")host.iobroker deleted npm temp directory: ".source-map-SyGGTVk5")host.iobroker deleted npm temp directory: ".source-map-support-VomWiKMb")host.iobroker deleted npm temp directory: ".spdx-correct-TFUby1KY")host.iobroker deleted npm temp directory: ".spdx-exceptions-ft4zmrVV")host.iobroker deleted npm temp directory: ".spdx-expression-parse-Pekjrfn8")host.iobroker deleted npm temp directory: ".spdx-license-ids-7Yhp2ojQ")host.iobroker deleted npm temp directory: ".split-xwUwBTsG")host.iobroker deleted npm temp directory: ".split2-wyloIfG0")host.iobroker deleted npm temp directory: ".sshpk-cCL4zyMp")host.iobroker deleted npm temp directory: ".stack-trace-lNG2rObG")host.iobroker deleted npm temp directory: ".stampit-event-bus-xEgjX5b8")host.iobroker deleted npm temp directory: ".stampit-state-machine-aC9As91Z")
                                  host.iobroker deleted npm temp directory: ".statuses-WEHZIwCf")
                                  host.iobroker deleted npm temp directory: ".stream-read-all-kYFKG9vU")
                                  host.iobroker deleted npm temp directory: ".string.prototype.trim-3h9X678k")
                                  host.iobroker deleted npm temp directory: ".string.prototype.trimstart-ocxtG8ll")
                                  host.iobroker deleted npm temp directory: ".strip-bom-2r41bWnk")
                                  host.iobroker deleted npm temp directory: ".supermixer-2nesEymU")
                                  host.iobroker deleted npm temp directory: ".symbol-observable-ffTkQjDe")
                                  host.iobroker deleted npm temp directory: ".table-layout-eRPOhyPw")
                                  host.iobroker deleted npm temp directory: ".tableify-6kfCgw4D")
                                  host.iobroker deleted npm temp directory: ".tcp-ping-KW9OnocR")
                                  host.iobroker deleted npm temp directory: ".through-GyJcvh09")
                                  host.iobroker deleted npm temp directory: ".to-array-kzG8FZoy")
                                  host.iobroker deleted npm temp directory: ".to-regex-range-iJFZCsex")
                                  host.iobroker deleted npm temp directory: ".ts-api-utils-JmchtaEL")
                                  host.iobroker deleted npm temp directory: ".tweetnacl-ldfAdbL9")
                                  host.iobroker deleted npm temp directory: ".typed-array-byte-length-sOVOOL9g")
                                  host.iobroker deleted npm temp directory: ".typed-function-lamN6wQc")
                                  host.iobroker deleted npm temp directory: ".types-pkg-json-3UOXZDfJ")
                                  host.iobroker deleted npm temp directory: ".typescript-rKKYB1QG")
                                  host.iobroker deleted npm temp directory: ".typical-B01ZUP8W")
                                  host.iobroker deleted npm temp directory: ".unbox-primitive-odeTH77h")
                                  host.iobroker deleted npm temp directory: ".unicode-properties-Bg5RLVuQ")
                                  host.iobroker deleted npm temp directory: ".untildify-2NFtYD13")
                                  host.iobroker deleted npm temp directory: ".update-notifier-XWnvBRxV")
                                  host.iobroker deleted npm temp directory: ".url-parse-pnENsky7")
                                  host.iobroker deleted npm temp directory: ".url-template-XLjsNAfv")
                                  host.iobroker deleted npm temp directory: ".usb-PqjvAhv3")
                                  host.iobroker deleted npm temp directory: ".utils-merge-lRdITr83")
                                  host.iobroker deleted npm temp directory: ".uuid-hFM3FfPu")
                                  host.iobroker deleted npm temp directory: ".wake_on_lan-6cMB5f0e")
                                  host.iobroker deleted npm temp directory: ".web-streams-polyfill-L6ofGwWB")
                                  host.iobroker deleted npm temp directory: ".webidl-conversions-dJIVq13g")
                                  host.iobroker deleted npm temp directory: ".websocket-stream-02UKbziB")
                                  host.iobroker deleted npm temp directory: ".which-GGzfHdLT")
                                  host.iobroker deleted npm temp directory: ".wide-align-CJ7lqbuZ")
                                  host.iobroker deleted npm temp directory: ".widest-line-lhDznLKg")
                                  host.iobroker deleted npm temp directory: ".winston-daily-rotate-file-tjvnY6ZU")
                                  host.iobroker deleted npm temp directory: ".winston-syslog-rknbmCPQ")
                                  host.iobroker deleted npm temp directory: ".workerpool-mqY76ZXw")
                                  host.iobroker deleted npm temp directory: ".xdg-basedir-A6kKkuxL")
                                  host.iobroker deleted npm temp directory: ".y18n-puq37lLA")
                                  host.iobroker deleted npm temp directory: ".yallist-RyZDxIwA")
                                  host.iobroker deleted npm temp directory: ".yaml-Re02D0MQ")
                                  host.iobroker deleted npm temp directory: ".yargs-parser-sA7Dt5No")
                                  host.iobroker deleted npm temp directory: ".yocto-queue-1wbR3uAZ")
                                  host.iobroker deleted npm temp directory: ".zigbee-herdsman-KZGHBvfL")
                                  host.iobroker deleted npm temp directory: ".zip-stream-qFO8RuhX")
                                  host.iobroker Cannot install iobroker.sonos@3.0.0: 217
                                    ma last edited by
                                    $ iobroker upgrade parser@2.0.7
                                    Update parser from @1.3.2 to @2.0.7
                                    Installing iobroker.parser@2.0.7... (System call)
                                    npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/ursa-optional/node_modules/bindingsnpm ERR! dest /opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ursa-optional/node_modules/bindings' -> '/opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJ'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_07_22_021Z-debug-0.log
                                    host.iobroker Cannot install iobroker.parser@2.0.7: 217
                                      ma last edited by
                                      sonos update nochmal mit debug
                                      iobroker upgrade sonos —debug
                                      This upgrade of "sonos" will introduce the following changes:
                                      -> 3.0.0:
                                      Added support for the playing Sonos playlists (added new state `playlist_set`)
                                      The minimal node.js version is 16
                                      -> 2.3.3:
                                      fixed cover url
                                      -> 2.3.2:
                                      store the cover file in files instead of binary states
                                      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                      Would you like to upgrade sonos from @2.3.1 to @3.0.0 now? [(y)es, (n)o]: y
                                      NPM version: 9.8.1
                                      npm ERR! errno -39
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_24_19_780Z-debug-0.log
                                      host.iobroker Cannot install iobroker.sonos@3.0.0: 217```
                                        ma last edited by
                                        habe den fixer nochmal durchlaufen lassen danach nochmal das update von sonos und sonoff gestartet.
                                        Danach ist der iobroker garnicht mehr gestartet, konnte ich lösen indem ich den PC neugestartet habe.
                                        Nun starten die adapter garnicht mehr.
                                        sonoff.0 2023-11-19 02:44:31.858	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        sonoff.0 2023-11-19 02:44:31.857	info	terminating
                                        sonoff.0 2023-11-19 02:44:31.839	error	Cannot read properties of undefined (reading 'length')
                                        sonoff.0 2023-11-19 02:44:31.838	error	TypeError: Cannot read properties of undefined (reading 'length') at decrypt (/opt/iobroker/node_modules/iobroker.sonoff/main.js:25:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.sonoff/main.js:43:39) at processImmediate (node:internal/timers:478:21)
                                        sonoff.0 2023-11-19 02:44:31.837	error	uncaught exception: Cannot read properties of undefined (reading 'length')
                                        sonoff.0 2023-11-19 02:44:31.794	info	starting. Version 2.5.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v18.18.2, js-controller: 5.0.12
                                        sonos.0
                                        	2023-11-19 02:52:04.672	warn	State "sonos.0.root.192_168_170_7.favorites_list_html" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_5.favorites_list_html" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_8.favorites_list_html" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.666	warn	State "sonos.0.root.192_168_170_5.current_track_number" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.646	error	Cannot getFavorites: TypeError: Cannot read properties of null (reading 'players')
                                        sonos.0
                                        	2023-11-19 02:52:04.638	warn	State "sonos.0.root.192_168_170_7.current_track_number" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.623	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        sonos.0
                                        	2023-11-19 02:52:04.622	info	terminating
                                        sonos.0
                                        	2023-11-19 02:52:04.617	info	terminating
                                        sonos.0
                                        	2023-11-19 02:52:04.614	error	sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.614	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:591:35) at ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:24) at AdapterClass.writeFile (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:4809:31) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.writeFileAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at takeSonosState (/opt/iobroker/node_modules/iobroker.sonos/main.js:1456:31) at processSonosEvents (/opt/iobroker/node_modules/iobroker.sonos/main.js:1693:17) at SonosSystem.<anonymous> (/opt/iobroker/node_modules/iobroker.sonos/main.js:2105:13) at SonosSystem.emit (node:events:517:28)
                                        sonos.0
                                        	2023-11-19 02:52:04.611	error	unhandled promise rejection: sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.610	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        sonos.0
                                        	2023-11-19 02:52:04.577	error	sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.577	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:587:39) at runNextTicks (node:internal/process/task_queues:60:5) at process.processImmediate (node:internal/timers:447:9) at async ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:13)
                                        sonos.0
                                        	2023-11-19 02:52:04.575	error	unhandled promise rejection: sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.575	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        sonos.0
                                        	2023-11-19 02:52:04.571	error	Cannot write file coverImage/192_168_170_5.png: sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.538	error	Cannot write file coverImage/192_168_170_7.png: sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:03.470	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.18.2, js-controller: 5.0.12
                                        brauche dazu eine lösung.
                                        vor dem update auf node v18 gab es da nie probleme
                                          reutli @ma last edited by reutli
                                          @ma sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                          und das gemacht und dann nochmals Update gestartet?
                                          und da mal reingeschaut?
                                            kkickingereder @reutli last edited by kkickingereder
                                            Könnt ihr mir helfen bitte, bin noch auf 16.15.1
                                            nach
                                            iob stop
                                            iob fix (schon 2x)
                                            iob nodejs-update
                                            bekomme ich folgend Fehlermeldung
                                            You are running nodejs v16.15.1. Do you want to install recommended version 18.19.0?
                                            Press <y> to continue or any other key to quit
                                            Trying to update your installation now. Please be patient.
                                            find: '/run/user/1000/gvfs': Permission denied
                                            Waiting for ioBroker to shut down - Give me a minute...
                                            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                            W: Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                                            W: Failed to fetch https://repos.influxdata.com/ubuntu/dists/bionic/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                            W: Some index files failed to download. They have been ignored, or old ones used instead.
                                            E: Broken packages
                                            Installing the recommended nodejs version!
                                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://dl.google.com/linux/chrome/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                            W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                            E: Broken packages
                                            We tried our best to fix your nodejs. Please run iob diag again to verify.
                                            1.2k
                                            nodejs
                                            91
                                            844
                                            229071
