    3. Einsteigerfragen
    4. Installation
    5. Raspberry Pi 5 8Gb Iobroker Installation
      Thomas Braun Most Active @teletapi last edited by
      @teletapi
      Mit einem pager wie z. B.
      less /home/pi/.npm/_logs/2023-11 -08T21_03_31_496Z-debug-0.log
      • hg6806
        hg6806 Most Active @Thomas Braun last edited by
        Ich habe seit gestern auf einen Pi5 und das gleiche Problem.
        Das Log-File ist zu groß zu posten, deshalb habe ich es angehängt.
        2023-11-09T17_43_57_638Z-debug-0.log
          Thomas Braun Most Active @hg6806 last edited by
          @hg6806
          Der Hase liegt dort im Pfeffer:
          2229 verbose stack FetchError: Invalid response body while trying to fetch https://registry.npmjs.org/@iobroker%2fdb-states-file: Socket timeout
          2229 verbose stack     at /usr/lib/node_modules/npm/node_modules/minipass-fetch/lib/body.js:170:15
          2229 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          2229 verbose stack     at async Response.json (/usr/lib/node_modules/npm/node_modules/minipass-fetch/lib/body.js:75:17)
          2229 verbose stack     at async RegistryFetcher.packument (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:94:25)
          2229 verbose stack     at async RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:118:23)
          2229 verbose stack     at async Promise.all (index 43)
          2229 verbose stack     at async #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1034:5)
          2229 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:196:7)
          2229 verbose stack     at async Promise.all (index 1)
          2229 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
          2230 verbose cwd /opt/iobroker
          2231 verbose Linux 6.1.0-rpi4-rpi-2712
          2232 verbose node v18.18.2
          2233 verbose npm  v9.8.1
          2234 error code ERR_SOCKET_TIMEOUT
          2235 error errno ERR_SOCKET_TIMEOUT
          2236 error network Invalid response body while trying to fetch https://registry.npmjs.org/@iobroker%2fdb-states-file: Socket timeout
          2237 error network This is a problem related to network connectivity.
          2237 error network In most cases you are behind a proxy or have bad network settings.
          2237 error network
          2237 error network If you are behind a proxy, please make sure that the
          2237 error network 'proxy' config is set properly.  See: 'npm help config'
          2238 verbose exit 1
          Warum es an der Stelle hakt, bei den anderen Modulen aber nicht kann ich dir nicht sagen.
          • hg6806
            Ok
            Da es ja nach mehrfachen Versuchen bei @teletapi geklappt hat, liegt es doch nahe, dass das Timeout der ersten Zeile vielleicht nur höher gesetzt werden muss?
            @teletapi Läuft bei dir ioBroker nun auf dem Pi5?
            teletapi 1 Reply Last reply Reply Quote 0
            • Marc Berg
              Marc Berg Most Active last edited by
              Wenn man das hier so liest, könnte man glauben, dass der Pi 5 grundsätzliche Netzwerkprobleme hat, oder?
              Drei Leute mit ähnlichen Konnektivitätsfehlern ...
              • hg6806
                hg6806 Most Active last edited by
                Bei mir läuft es jetzt auch.
                Nach dem 3. Installationsversuch.
                • teletapi
                  teletapi @hg6806 last edited by teletapi
                  @hg6806 Ja läuft ist zwar noch nicht produktiv im Einsatz aber läuft
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: Raspberrypi5
                         Icon name: computer
                            Kernel: Linux 6.1.0-rpi6-rpi-2712
                      Architecture: arm64
                  Model           : Raspberry Pi 5 Model B Rev 1.0
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   00:31:49 up 24 min,  2 users,  load average: 0.61, 0.37, 0.25
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Sat 2023-11-11 00:31:49 CET
                             Universal time: Fri 2023-11-10 23:31:49 UTC
                                   RTC time: Fri 2023-11-10 23:31:49
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            8.4G        2.9G        4.3G        5.3M        1.4G        5.6G
                  Swap:           104M          0B        104M
                  Total:          8.5G        2.9G        4.4G
                           8053 M total memory
                           2721 M used memory
                           2616 M active memory
                            887 M inactive memory
                           4120 M free memory
                             75 M buffer memory
                           1237 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  vc_gencmd_read_response returned -1
                  error=1 error_msg="Command not registered"
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  3.8G     0  3.8G   0% /dev
                  tmpfs          tmpfs     806M  5.1M  801M   1% /run
                  /dev/mmcblk0p2 ext4       59G  5.4G   50G  10% /
                  tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                  tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                  /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
                  tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                  [Sat Nov 11 00:07:42 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:A3:25:8A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=beeda195-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                  [Sat Nov 11 00:07:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Sat Nov 11 00:07:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  TARGET           SOURCE         FSTYPE OPTIONS
                  /                /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  939M    /var/
                  542M    /var/lib
                  361M    /var/lib/influxdb/engine/data/2a3f1759f802b32d/autogen
                  Archived and active journals take up 80.0M in the file system.
                  /opt/iobroker/backups:
                  447M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  302M    /opt/iobroker/iobroker-data/
                  220M    /opt/iobroker/iobroker-data/files
                  67M     /opt/iobroker/iobroker-data/files/javascript.admin
                  62M     /opt/iobroker/iobroker-data/node-red.0
                  61M     /opt/iobroker/iobroker-data/node-red.0/node_modules
                  33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                  22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                  14M     /opt/iobroker/iobroker-data/objects.jsonl
                  8.9M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
                  USB-Devices by-id:
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.18.2
                  /usr/bin/node           v18.18.2
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  /usr/bin/corepack       0.19.0
                  nodejs:
                    Installed: 18.18.2-1nodesource1
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                   *** 18.18.2-1nodesource1 500
                          100 /var/lib/dpkg/status
                       18.18.1-1nodesource1 500
                       18.18.0-1nodesource1 500
                       18.17.1-1nodesource1 500
                       18.17.0-1nodesource1 500
                       18.16.1-1nodesource1 500
                       18.16.0-1nodesource1 500
                       18.15.0-1nodesource1 500
                       18.14.2-1nodesource1 500
                       18.14.1-1nodesource1 500
                       18.14.0-1nodesource1 500
                       18.13.0+dfsg1-1 500
                       18.13.0-1nodesource1 500
                       18.12.0-1nodesource1 500
                       18.11.0-1nodesource1 500
                       18.10.0-1nodesource1 500
                       18.9.1-1nodesource1 500
                       18.9.0-1nodesource1 500
                       18.8.0-1nodesource1 500
                       18.7.0-1nodesource1 500
                       18.6.0-1nodesource1 500
                       18.5.0-1nodesource1 500
                       18.4.0-1nodesource1 500
                       18.3.0-1nodesource1 500
                       18.2.0-1nodesource1 500
                       18.1.0-1nodesource1 500
                       18.0.0-1nodesource1 500
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.16
                  admin:          6.12.2
                  javascript:     7.1.6
                  Adapters from github:   2
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             - disabled
                  + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
                  + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
                  + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
                    system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             - disabled
                  + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
                  + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 12001
                  + system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 12010
                  + system.adapter.hm-rpc.3                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 0
                  + system.adapter.hue-extended.0           : hue-extended          : Raspberrypi5                             -  enabled
                    system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
                  + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
                  + system.adapter.info.0                   : info                  : Raspberrypi5                             -  enabled
                  + system.adapter.iot.0                    : iot                   : Raspberrypi5                             -  enabled
                  + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled
                  + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
                    system.adapter.modbus.0                 : modbus                : Raspberrypi5                             - disabled
                  + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
                  + system.adapter.node-red.0               : node-red              : Raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.nuki.0                   : nuki                  : Raspberrypi5                             -  enabled
                  + system.adapter.opendtu.0                : opendtu               : Raspberrypi5                             -  enabled
                  + system.adapter.panasonic-viera.0        : panasonic-viera       : Raspberrypi5                             -  enabled
                  + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
                  + system.adapter.shelly.0                 : shelly                : Raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
                    system.adapter.smartmeter.0             : smartmeter            : Raspberrypi5                             - disabled
                    system.adapter.smartmeter.1             : smartmeter            : Raspberrypi5                             - disabled
                  + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
                  + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
                  + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): beta
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter    "admin"        : 6.12.2   , installed 6.12.2
                  Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
                  Adapter    "backitup"     : 2.9.1    , installed 2.9.1
                  Adapter    "fritzdect"    : 2.5.8    , installed 2.5.8
                  Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                  Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                  Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                  Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                  Adapter    "iot"          : 2.0.11   , installed 2.0.11
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
                  Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                  Controller "js-controller": 5.0.16   , installed 5.0.16
                  Adapter    "modbus"       : 6.0.1    , installed 6.0.1
                  Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                  Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                  Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                  Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
                  Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                  Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                  Adapter    "telegram"     : 3.0.0    , installed 3.0.0
                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                  Objects and States
                  Objects:        9004
                  States:         8403
                  Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:5 https://repos.influxdata.com/debian stable InRelease
                  Hit:6 https://apt.grafana.com stable InRelease
                  Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16637      968/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16630      968/iobroker.js-con
                  tcp        0      0 192.168.178.121:12001   0.0.0.0:*               LISTEN      1001       17859      1336/io.hm-rpc.1
                  tcp        0      0 192.168.178.121:12010   0.0.0.0:*               LISTEN      1001       14188      1351/io.hm-rpc.2
                  tcp        0      0 192.168.178.121:18701   0.0.0.0:*               LISTEN      1001       17824      1306/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17696      1113/node-red
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18673      1433/io.shelly.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        961        794/mosquitto
                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18048      1454/io.sonoff.0
                  tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       17887      1366/io.hm-rpc.3
                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       23565      2264/io.jarvis.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          975        807/sshd: /usr/sbin
                  tcp        0      0 192.168.178.121:9092    0.0.0.0:*               LISTEN      1001       23892      2310/io.nuki.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17483      996/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25013      2451/io.web.0
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23369      2432/io.socketio.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        16591      891/influxd
                  tcp6       0      0 :::3000                 :::*                    LISTEN      107        15958      967/grafana
                  tcp6       0      0 :::1883                 :::*                    LISTEN      106        962        794/mosquitto
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          977        807/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15696      677/avahi-daemon: r
                  udp        0      0 0.0.0.0:60563           0.0.0.0:*                           104        15698      677/avahi-daemon: r
                  udp6       0      0 fe80::f05b:9255:16f:546 :::*                                0          17446      758/NetworkManager
                  udp6       0      0 fe80::38be:beb2:fe6:546 :::*                                0          16559      758/NetworkManager
                  udp6       0      0 :::5353                 :::*                                104        15697      677/avahi-daemon: r
                  udp6       0      0 :::34544                :::*                                104        15699      677/avahi-daemon: r
                  2023-11-11 00:10:01.823  - info: simple-api.0 (2409) Allow states only when user is owner: false
                  2023-11-11 00:10:05.024  - info: host.Raspberrypi5 instance system.adapter.socketio.0 started with pid 2432
                  2023-11-11 00:10:05.985  - info: socketio.0 (2432) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.18.2, js-controller: 5.0.16
                  2023-11-11 00:10:06.016  - warn: socketio.0 (2432) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                  2023-11-11 00:10:06.044  - info: socketio.0 (2432) socket.io server listening on port 8084
                  2023-11-11 00:10:09.006  - info: host.Raspberrypi5 instance system.adapter.web.0 started with pid 2451
                  2023-11-11 00:10:09.929  - info: web.0 (2451) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.18.2, js-controller: 5.0.16
                  2023-11-11 00:10:10.067  - info: web.0 (2451) socket.io server listening on port 8082
                  2023-11-11 00:10:10.072  - info: web.0 (2451) http server listening on port 8082
                  2023-11-11 00:10:22.543  - info: cloud.0 (1526) Trying to connect as system.user.admin to cloud
                  2023-11-11 00:10:22.667  - info: cloud.0 (1526) Connection changed: connect
                  2023-11-11 00:21:24.723  - info: admin.0 (996) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
                  2023-11-11 00:30:00.108  - info: host.Raspberrypi5 instance system.adapter.ical.0 started with pid 4855
                  2023-11-11 00:30:01.141  - info: ical.0 (4855) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                  xxxxxxxxxxxxxxxx
                  2023-11-11 00:30:06.664  - info: ical.0 (4855) Terminated (NO_ERROR): Without reason
                  2023-11-11 00:30:07.183  - info: host.Raspberrypi5 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-11-11 00:30:56.211  - info: admin.0 (996) ==> Connected system.user.admin from ::ffff:192.168.178.63
                  2023-11-11 00:31:04.428  - info: host.Raspberrypi5 "system.adapter.telegram.0" enabled
                  2023-11-11 00:31:04.554  - info: host.Raspberrypi5 instance system.adapter.telegram.0 started with pid 5016
                  2023-11-11 00:31:05.767  - info: telegram.0 (5016) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.16
                  2023-11-11 00:31:24.629  - info: admin.0 (996) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
                  • hg6806
                    hg6806 Most Active last edited by hg6806
                    Die Fehler haben evtl. etwas mit einer zu langsamen SD Karte zu tun.
                    Ich habe jetzt bestimmte 4-5x auf dem Pi5 neu installiert und mit einer Sandisk Extreme pro KEINE Probleme gehabt.
                    Nur mit einer langsameren Karte hatte ich die von allen beschriebenen Fehler.
                    Vielleicht ein Zufall, aber bei solchen Sachen glaube ich nicht an Zufälle 🙂
                    Also, bitte das mal checken.
                    ioBroker auf einer SD Karte zu installieren ist natürlich nur zulange von Dauer bis es ein PCIe HAT dafür gibt.
                    • teletapi
                      @hg6806 said in Raspberry Pi 5 8Gb Iobroker Installation:
                      PCIe
                      Ich halte schon dauernd Ausschau danach abernoch tut sich nix besonderes was die neuen M.2 angeht, wobei mir ein System ähnlich wie mit dem Argon one M.2 Gehäuse schon reichen würde.
                      Ich hab gerade mal so eine sandisk Extreme Pro geordert
                      und wenn die da ist werde ich das auch mal testen
                      • hg6806
                        hg6806 Most Active @teletapi last edited by hg6806
                        @teletapi
                        Genau, die habe ich auch. Die höhere Geschwindigkeit merkt man definitiv!
                        Auf jeden Fall macht der 5er echt Laune.
                        • teletapi
                          @hg6806
                          Ich hab heute die sd Karte bekommen und hab das gleich getestet und es hat auf Anhieb funktioniert.
                          • I
                            itwegner72 last edited by
                            Der Raspberry 5 macht Richtig Laune.
                            Habe meine ioBroker Installation nun komplett fertig auf dem Raspberry 5 mit dem Pineberry Pi BM1L HatDrive! Bottom NVMe Adapter und einer SAMSUNG 980 Festplatte Retail 1 TB SSD M.2 NVMe intern.
                            Läuft alles Super Flüssig und sowas von fix gegenüber dem RPi4, bin einfach nur Begeistert.
                            Kann ich allen nur empfehlen, wer mit dem Raspberry arbeitet.
                            mcm1957 Meister Mopper S 3 Replies Last reply Reply Quote 0
                            • mcm1957
                              mcm1957 @itwegner72 last edited by
                              @itwegner72
                              Welches Gehäuse hast du im Einsatz?
                              • Meister Mopper
                                Meister Mopper @itwegner72 last edited by
                                @itwegner72 sagte in Raspberry Pi 5 8Gb Iobroker Installation:
                                Wieviel Energie zieht der im ioBroker-Betrieb bei dir?
                                Winni I 2 Replies Last reply Reply Quote 0
                                • Winni
                                  Winni @Meister Mopper last edited by
                                  @meister-mopper schau hier:
                                  https://forum.iobroker.net/topic/68665/rasperry-5-im-anrollen/52
                                    Snopy_16 @itwegner72 last edited by
                                    Hast du eventuell Links von deinen Komponenten?
                                    • I
                                      itwegner72 @mcm1957 last edited by itwegner72
                                      @mcm57
                                      Ein Selbstgebautes aus Holz und dem 3D Drucker. Kann die Tage mal ein Foto hochladen. Ist mit Display.
                                      Er ist auf 2900Mhz getaktet und hat einen zusätzlichen Lüfter an der Oberseite plus folgenden Kühler auf dem Raspberry.
                                      https://www.kaufland.de/product/480466071/?search_value=raspberry pi 5
                                      Temperatur liegt immer so bei 40 Grad im Normalbetrieb.
                                      Anzeige läuft allerdings noch nicht auf dem Raspi5 mit Bockworm, da sich das bei Bockworm mit Python was geändert hat und ich noch nicht dazu gekommen bin mich da reinzufuchsen.
                                      Deshalb sind die Bilder mit dem Display von meinem Raspi4 8Gb (im gleichen Gehäuse) aufgenommen. Der Pi4 läuft allerdings gefühlt 8x langsammer als der Pi5.
                                      • I
                                        itwegner72 @Snopy_16 last edited by itwegner72
                                        @snopy_16
                                        Den Raspberry 5 8Gb hatte ich bei Kaufland gekauft (weil er zu dem Zeitpunkt nicht überall so schnell erhältlich war und ich ihn unbedingt haben wollte).
                                        https://www.kaufland.de/product/482626171/?search_value=raspberry pi 5
                                        Dazu dann zur besseren Kühlung folgendes.
                                        Das Hat ist folgendes.
                                        https://www.welectron.com/Pineberry-Pi-BM1L-HatDrive-Bottom-NVMe-Adapter-fuer-Raspberry-Pi-5
                                        Und die SSD kommt von MediaMarkt (Hatte für eine Woche eine von Samsung drin wie oben schon mal beschrieben ; habe die durch folgende ausgetauscht).
                                        https://www.mediamarkt.de/de/product/_crucial-p5-plus-ssd-intern-500-gb-ssd-m2-via-nvme-intern-2749350.html
                                        • I
                                          itwegner72 @Meister Mopper last edited by
                                          @meister-mopper
                                          Messe ich die Tage mal aus.
                                          • I
                                            itwegner72 @itwegner72 last edited by
                                            @itwegner72
                                            48
                                            11719
