    4. jarvis v3.1.x - just another remarkable vis
      Wahl-HHer @MCU last edited by
      @mcu sagte in jarvis v3.1.x - just another remarkable vis:
      {"default":"valPlusIcon({val})"}
      Dabei bekomme ich folgende Fehlermeldung:
      Anzeigevariante im Gerät:
      Funktion in Scripts:
      styles:
      Anzeige:
      Was mache ich falsch?
        MCU @Wahl-HHer last edited by MCU
        @wahl-hher Hast du PRO?
        Version von jarvis?
          @mcu
          Ja, ich habe die PRO.
          Jarvis 3.1.8
            @wahl-hher Geh mal bitte auf v3.1.9-beta.2
            Adapter->Expertenmodus einschalten -> Katze -> Benutzerdefiniert
            https://github.com/Zefau/ioBroker.jarvis/tree/31ad221a4171597a434fff0b41d75dd7d09d6d6c
              Bringt den selben Fehler.
                @wahl-hher Was steht im LOG -> F12 drücken?
                Die function mal reinstellen. In Code-tags -> </>
                  Uncaught SyntaxError: '' string literal contains an unescaped line break
                      useCustomTag http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:108
                      onConnect http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      promise callback*Po</onConnect/</</</< http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      callWithErrorHandling http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      callWithAsyncErrorHandling http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      V http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      doWatch http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      watch http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      promise callback*Po</onConnect/< http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      promise callback*onConnect http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      created http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      promise callback*created http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      callHook$1 http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      applyOptions http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      finishComponentSetup http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      handleSetupResult http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      setupStatefulComponent http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      setupComponent http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      oe http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      ie http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      B http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      ge http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      mount http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      start$2 http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      Po http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      promise callback*Po</< http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      promise callback*Po< http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
                      ko http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
                      <anonymous> http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1871
                  index.html:5:18
                      (Async: promise callback)
                      InterpretGeneratorResume self-hosted:1469
                      AsyncFunctionNext self-hosted:852
                      (Async: async)
                      <anonym> http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1871
                  Die Funktion:
                  function valPlusIcon(val){
                  // return 'Test';
                      let html = '';
                      html+=  '<div><table>';
                      html+=  '<tr>
                      /* Zeilen vertauscht */
                      html+=  '<td><span class="snowflake"> </span></td>';
                      html+=  '<td>'+val+'</td>';
                      html+=  '</tr>;
                      html+=  '</table>';
                      html+=  '</div>'
                      return html;
                    @wahl-hher
                        let html = '';
                        html+=  '<tr>';
                        html+=  '</tr>';
                        html+=  '</table>';
                        html+=  '</div>'
                        return html;
                      Funktioniert.
                      Auch in der 3.1.8.
                      Vielen Dank für die schnelle Hilfe.
                        A Former User @MCU last edited by
                        @mcu said in jarvis v3.1.x - just another remarkable vis:
                        @apachelance Versuch es mal mit v3.1.9-beta.2.
                        Katze->Benutzerdefiniert
                        Das hat nicht geklappt. Das Wetterwidget ist nicht aktuell, wenn der Tag sich ändert. Stattdessen kommt jetzt häufiger dieser Fehler, der nach einem Reload der Seite verschwindet:
                          MCU @Guest last edited by MCU
                          @apachelance Mehr kann ich leider nicht tun und anbieten.
                          Das ist die letzte relativ funktionierende Version.
                          Musst du für Dich entscheiden, ob du dann wieder zurück möchtest.
                            A Former User last edited by
                            ...anderes Thema: hat jemand eine Idee, warum die Farbwerte bei den States nicht einheitlich sind. Mal ist es helleres, mal dunkleres Grau:
                            Zusätzliche CSS-Styles sind nicht aktiv.
                              @apachelance Kannst du mal bitte mit der Maus jeweils auf den Text gehen und dann die rechte Maustaste drücken.
                              Dann kommt rechts eine Anzeige -> posten von beiden "unterschiedlichen" Stellen.
                                Was meinst du? Wenn ich mit rechter Maustaste klicke, kommt nur das Kontextmenü des Browser.
                                Ich hab mal mit dem Inspektor 3 Screenshots gemacht:
                                  @apachelance Jetzt wären dazu die entsprechenden Geräte-DPs interessant.
                                  Fenster
                                  Ladestatus
                                  Büro-Balkon
                                    Bitteschön:
                                    Fenster:
                                    Ladestatus:
                                    Büro Balkon:
                                      @apachelance Nee, ich meinte die Einstellungen in jarvis zu den Geräte-DPs.
                                        Ok.
                                        Fenster:
                                        Ladestatus:
                                        Büro Balkon:
                                          @apachelance Scheint wohl abhängig vom Gewerk zu sein?
                                          Bitte als Issue in github eintragen.
                                          Das Fenster ist anders dargestellt und ist vom Gewerk Fenster?
                                            Fenster und Ladestatus gehören zu einem PKW und sind im Gewerk Sonstiges. Büro Balkon ist Gewerk Tür. Insofern sollte eigentlich Fenster und Ladestatus die selbe Farbe haben!?
                                            92
                                            1815
                                            671454
