    4. jarvis v3.1.x - just another remarkable vis
      MCU @Wahl-HHer last edited by MCU
      @wahl-hher Was steht im LOG -> F12 drücken?
      Die function mal reinstellen. In Code-tags -> </>
        Wahl-HHer @MCU last edited by
        Uncaught SyntaxError: '' string literal contains an unescaped line break
            useCustomTag http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:108
            onConnect http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            promise callback*Po</onConnect/</</</< http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            callWithErrorHandling http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            callWithAsyncErrorHandling http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            V http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            doWatch http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            watch http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            promise callback*Po</onConnect/< http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            promise callback*onConnect http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            created http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            promise callback*created http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            callHook$1 http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            applyOptions http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            finishComponentSetup http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            handleSetupResult http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            setupStatefulComponent http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            setupComponent http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            oe http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            ie http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            B http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            ge http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            mount http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            start$2 http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            Po http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            promise callback*Po</< http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            promise callback*Po< http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:112
            ko http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1
            <anonymous> http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1871
        index.html:5:18
            (Async: promise callback)
            InterpretGeneratorResume self-hosted:1469
            AsyncFunctionNext self-hosted:852
            (Async: async)
            <anonym> http://192.168.150.8:8082/jarvis/js/index-566ba00e.js:1871
        Die Funktion:
        function valPlusIcon(val){
        // return 'Test';
            let html = '';
            html+=  '<div><table>';
            html+=  '<tr>
            /* Zeilen vertauscht */
            html+=  '<td><span class="snowflake"> </span></td>';
            html+=  '<td>'+val+'</td>';
            html+=  '</tr>;
            html+=  '</table>';
            html+=  '</div>'
            return html;
          @wahl-hher
              let html = '';
              html+=  '<tr>';
              html+=  '</tr>';
              html+=  '</table>';
              html+=  '</div>'
              return html;
            Funktioniert.
            Auch in der 3.1.8.
            Vielen Dank für die schnelle Hilfe.
              A Former User @MCU last edited by
              @mcu said in jarvis v3.1.x - just another remarkable vis:
              @apachelance Versuch es mal mit v3.1.9-beta.2.
              Katze->Benutzerdefiniert
              https://github.com/Zefau/ioBroker.jarvis/tree/31ad221a4171597a434fff0b41d75dd7d09d6d6c
              Das hat nicht geklappt. Das Wetterwidget ist nicht aktuell, wenn der Tag sich ändert. Stattdessen kommt jetzt häufiger dieser Fehler, der nach einem Reload der Seite verschwindet:
                MCU @Guest last edited by MCU
                @apachelance Mehr kann ich leider nicht tun und anbieten.
                Das ist die letzte relativ funktionierende Version.
                Musst du für Dich entscheiden, ob du dann wieder zurück möchtest.
                  A Former User last edited by
                  ...anderes Thema: hat jemand eine Idee, warum die Farbwerte bei den States nicht einheitlich sind. Mal ist es helleres, mal dunkleres Grau:
                  Zusätzliche CSS-Styles sind nicht aktiv.
                    @apachelance Kannst du mal bitte mit der Maus jeweils auf den Text gehen und dann die rechte Maustaste drücken.
                    Dann kommt rechts eine Anzeige -> posten von beiden "unterschiedlichen" Stellen.
                      Was meinst du? Wenn ich mit rechter Maustaste klicke, kommt nur das Kontextmenü des Browser.
                      Ich hab mal mit dem Inspektor 3 Screenshots gemacht:
                        @apachelance Jetzt wären dazu die entsprechenden Geräte-DPs interessant.
                        Fenster
                        Ladestatus
                        Büro-Balkon
                          Bitteschön:
                          Fenster:
                          Ladestatus:
                          Büro Balkon:
                            @apachelance Nee, ich meinte die Einstellungen in jarvis zu den Geräte-DPs.
                              Ok.
                              Fenster:
                              Ladestatus:
                              Büro Balkon:
                                @apachelance Scheint wohl abhängig vom Gewerk zu sein?
                                Bitte als Issue in github eintragen.
                                Das Fenster ist anders dargestellt und ist vom Gewerk Fenster?
                                  Fenster und Ladestatus gehören zu einem PKW und sind im Gewerk Sonstiges. Büro Balkon ist Gewerk Tür. Insofern sollte eigentlich Fenster und Ladestatus die selbe Farbe haben!?
                                    @apachelance Hier wird doch die Farbe gesetzt?
                                      Ja, aber nur, wenn die Fenster offen sind, sonst gilt die Standardfarbe. f82c00 ist rot.
                                        A Former User @Guest last edited by
                                        @MCU
                                        das Verhalten seh ich auch bei 2 anderen Widgets:
                                          @apachelance
                                          Kann da leider nichts ändern.
                                          Bitte in github ein Issue anlegen mit Hinweis auf die Jarvis Version und Link zu dem ersten beitrag?
                                          https://github.com/Zefau/ioBroker.jarvis/issues
                                            @mcu Ok, danke. Mach ich.
                                            92
                                            1815
                                            662683
