    4. Iobroker startet nicht mehr nach Ubuntu update
    • eric2905
      eric2905 last edited by
      Evtl. weil Du die Datei überschreibst?
      Mal mit einem neuen Ziel-Dateinamen probiert?
      Gruß,
      Eric
        sveni_lee last edited by
        Yeep… das wars
        Dann mach ich mal nen reinstall.
          ist nicht ganz sauber durchgelaufen…
          DONE iobroker.javascript
          npm WARN deprecated tar.gz@1.0.7: ⚠️  WARNING ⚠️ tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
          npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
          npm WARN prefer global npm@2.15.12 should be installed with -g
          > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
          > node-gyp rebuild
          gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/svenilee/.node-gyp/6.12.0"
          gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
          make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
            CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
            SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
            COPY Release/unix_dgram.node
          make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
          > ursa@0.9.4 install /opt/iobroker/node_modules/ursa
          > node-gyp rebuild
          gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/ursa/.node-gyp"
          make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird betreten
            CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
            SOLINK_MODULE(target) Release/obj.target/ursaNative.node
            COPY Release/ursaNative.node
          make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird verlassen
          npm ERR! code 1
          FAIL iobroker.socketio
          iobroker@1.0.0 /opt/iobroker
          └─┬ iobroker.tankerkoenig@1.0.4
            └─┬ xml2js@0.2.8
              └── sax@0.5.8
          DONE iobroker.tankerkoenig
          npm WARN deprecated to-iso-string@0.0.2: to-iso-string has been deprecated, use @segment/to-iso-string instead.
          npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
          npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
          npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
          npm WARN deprecated tough-cookie@2.2.2: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
          ./reinstall.sh: Zeile 34: Dateiende beim Suchen nach »"« erreicht.
          ./reinstall.sh: Zeile 37: Syntaxfehler: Unerwartetes Dateiende.
          svenilee@Gotham-City:/opt/iobroker$
          • eric2905
            Ggf. das Original-reinstall.sh mal mit einem FTP vom Linux ziehen und die Datei mit einem "vernünftiges" Editor wieder umkonvertierten.
            Gruß,
            Eric
              paul53 last edited by
              Nimm diese Datei, nach dem Entfernen von .txt am Ende des Dateinamen.
              493_reinstall.sh.txt
                so, alles gemacht aber noch kein erfolg…
                2017-11-17 22:05:40.282  - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting
                2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker
                2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
                2017-11-17 22:05:40.289  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxxx
                2017-11-17 22:05:40.337  - ^[[32minfo^[[39m: host.Gotham-City  inMem-states listening on port 9000
                2017-11-17 22:05:40.358  - ^[[32minfo^[[39m: host.Gotham-City  inMem-objects listening on port 9001
                2017-11-17 22:05:40.365  - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
                2017-11-17 22:05:40.367  - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
                2017-11-17 22:05:40.371  - ^[[32minfo^[[39m: host.Gotham-City no instances found
                2017-11-17 22:05:40.381  - ^[[31merror^[[39m: uncaught exception: logger is not defined
                2017-11-17 22:05:40.383  - ^[[31merror^[[39m: ReferenceError: logger is not defined
                    at Object.decryptPhrase (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:77:9)
                    at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:128:27
                    at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21)
                    at ontimeout (timers.js:386:11)
                    at tryOnTimeout (timers.js:250:5)
                    at Timer.listOnTimeout (timers.js:214:5)
                2017-11-17 22:05:40.388  - ^[[32minfo^[[39m: host.Gotham-City terminated
                2017-11-17 22:05:40.396  - ^[[32minfo^[[39m: iobroker _restart
                2017-11-17 22:05:40.652  - ^[[32minfo^[[39m: iobroker Starting node restart.js
                2017-11-17 22:05:40.662  - ^[[32minfo^[[39m: iobroker exit 0
                2017-11-17 22:05:40.776  - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM
                2017-11-17 22:05:40.777  - ^[[32minfo^[[39m: host.Gotham-City terminated
                einen Fehler gab es doch beim reinstall
                iobroker.core@0.1.0 /opt/iobroker
                └── (empty)
                npm ERR! code 1
                  kannes sein, das das Problem der iobroker.core ist?
                  └── (empty)
                  npm ERR! code 1
                    Also ich bekomme iobroker einfach nicht mehr ans laufen… es läuft immer wieder auf den selben Fehler hinaus.
                    Da bei reinstall immer wieder der Fehler bei socketio auftritt habe ich versucht dieses Modul per Hand zu installieren-
                    Leider auch ohne erfolg
                    ! svenilee@Gotham-City:/opt/iobroker$ sudo npm install iobroker.socketio --loglevel verbose npm info it worked if it ends with ok npm verb cli [ '/usr/bin/node', npm verb cli '/usr/bin/npm', npm verb cli 'install', npm verb cli 'iobroker.socketio', npm verb cli '--loglevel', npm verb cli 'verbose' ] npm info using npm@3.10.10 npm info using node@v6.12.0 npm verb request uri https://registry.npmjs.org/iobroker.socketio npm verb request no auth needed npm info attempt registry request try #1 at 17:24:10 npm verb request id 7d087b006a900a50 npm verb etag W/"59f82d29-1200c" npm verb lastModified Tue, 31 Oct 2017 07:58:33 GMT npm http request GET https://registry.npmjs.org/iobroker.socketio npm http 304 https://registry.npmjs.org/iobroker.socketio npm verb headers { date: 'Sun, 19 Nov 2017 16:24:10 GMT', npm verb headers via: '1.1 varnish', npm verb headers 'cache-control': 'max-age=300', npm verb headers etag: 'W/"59f82d29-1200c"', npm verb headers age: '232', npm verb headers connection: 'keep-alive', npm verb headers 'x-served-by': 'cache-hhn1533-HHN', npm verb headers 'x-cache': 'HIT', npm verb headers 'x-cache-hits': '1', npm verb headers 'x-timer': 'S1511108650.285039,VS0,VE1', npm verb headers vary: 'Accept-Encoding, Accept' } npm verb etag https://registry.npmjs.org/iobroker.socketio from cache npm verb get saving iobroker.socketio to /home/svenilee/.npm/registry.npmjs.org/iobroker.socketio/.cache.json npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb cache add spec iobroker.socketio npm verb addNamed "latest" is being treated as a dist-tag for iobroker.socketio npm info addNameTag [ 'iobroker.socketio', 'latest' ] npm verb addNameTag registry:https://registry.npmjs.org/iobroker.socketio not in flight; fetching npm verb get https://registry.npmjs.org/iobroker.socketio not expired, no request npm verb addNamed "1.8.6" is a plain semver version for iobroker.socketio npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json not in flight; writing npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json written npm verb correctMkdir /home/svenilee/.npm/_locks correctMkdir not in flight; initializing npm verb lock using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging npm verb unbuild node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb tar unpack /home/svenilee/.npm/iobroker.socketio/1.8.6/package.tgz npm verb tar unpacking to /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c/node_modules npm info lifecycle iobroker.socketio@1.8.6~preinstall: iobroker.socketio@1.8.6 npm verb unbuild node_modules/iobroker.socketio npm info lifecycle iobroker.socketio@1.8.6~preuninstall: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~uninstall: iobroker.socketio@1.8.6 npm verb unbuild rmStuff iobroker.socketio@1.8.6 from /opt/iobroker/node_modules npm info lifecycle iobroker.socketio@1.8.6~postuninstall: iobroker.socketio@1.8.6 npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.socketio npm info linkStuff iobroker.socketio@1.8.6 npm verb linkBins iobroker.socketio@1.8.6 npm verb linkMans iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~install: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~postinstall: iobroker.socketio@1.8.6 npm verb unlock done using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging iobroker.core@0.1.0 /opt/iobroker └── (empty) ! npm verb exit [ 0, true ] npm ERR! code 1 svenilee@Gotham-City:/opt/iobroker$ !
                    • Bluefox
                      Bluefox last edited by
                      Ich empfehle die neuste js-controller vom github zu installieren:
                      cd /opt/iobroker
                      iobroker stop
                      npm i https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
                      iobroker start
                      Danach sollte js-controller alle fehlende Pakete selbst nachinstallieren.
                        hallo Bluefox,
                        hab ich Probiert:
                        ` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker stop
                        [sudo] Passwort für svenilee:
                        iobroker controller daemon is not running
                        svenilee@Gotham-City:/opt/iobroker$ sudo npm i https://github.com/ioBroker/ioBroker.js … all/master --production
                        npm WARN deprecated tar.gz@1.0.7: <emoji seq="26a0">⚠️</emoji> WARNING <emoji seq="26a0">⚠️</emoji> tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
                        iobroker.js-controller@1.2.1 install /opt/iobroker/node_modules/iobroker.js-controller
                        node iobroker.js setup first
                        └── iobroker.js-controller@1.2.1
                        svenilee@Gotham-City:/opt/iobroker$ sudo iobroker start
                        Starting iobroker controller daemon...
                        iobroker controller daemon started. PID: 13515 `
                        log:
                        ` > 2017-11-19 20:45:53.635 - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.1 js-controller starting
                        2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City Copyright © 2014-2017 bluefox, 2014 hobbyquaker
                        2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
                        2017-11-19 20:45:53.641 - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 fd2d:5cf3:5594:0:be5f:f4ff:fe7d:a73c fe80::be5f:f4ff:fe7d:a$
                        2017-11-19 20:45:53.691 - ^[[32minfo^[[39m: host.Gotham-City inMem-states listening on port 9000
                        2017-11-19 20:45:53.711 - ^[[32minfo^[[39m: host.Gotham-City inMem-objects listening on port 9001
                        2017-11-19 20:45:53.718 - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
                        2017-11-19 20:45:53.720 - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
                        2017-11-19 20:45:53.725 - ^[[32minfo^[[39m: host.Gotham-City no instances found
                        2017-11-19 20:45:53.746 - ^[[33mwarn^[[39m: host.Gotham-City multihost service started on 0.0.0.0:50005 `
                        sollte laufen…
                        ` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker status
                        iobroker is running `
                        ist aber unter port 8081 nicht erreichbar
                        muß ich noch einen reinstall ausführen?
                        • Bluefox
                          @sveni_lee:
                          hallo Bluefox,
                          hab ich Probiert:
                          log:
                          sollte laufen…
                          muß ich noch einen reinstall ausführen? `
                          Wo sind deine Einstellungen? Die datei /opt/iobroker-data/objects.json lehr oder default.
                            ich würde sagen default…
                            steht fast überall was drin
                            • Bluefox
                              Ich wollte damit sagen, dass die Einstellungen weg sind.
                                sorry… versteh nicht was Du meinst?
                                die Datei ist doch da?
                                oder Anders... wie bekomme ich diese wieder?
                                  so, ich habe jetzt eine Image-Sicherung vom Server genommen und den iobroker-ordner in
                                  mein aktuelles Image kopiert. Danach funktioniert es schon einmal wieder…
                                  Aber wie bekomme ich jetzt meinen aktuellen Datenstand dort rein, einfach den iobroker-data ordner wieder zurück
                                  kopieren?
                                  • Dutchman
                                    @sveni_lee:
                                    kopieren? `
                                    Definiere Datenstand, history Daten oder?
                                    Send from mobile device
                                      Objektpunkte, Skripte, Adaptereinstellungen
                                      Edit: hat nicht funktioniert…
                                      Gibt es einen Ordner in dem die Skripte abgelegt werden, do das ich wenigstens diese wieder herstellen kann?
                                      2905
