    4. Alle Instanzen rot,
    Alle Instanzen rot,
      Thomas Braun Most Active @mibr85 last edited by
      @mibr85
      Mit einem aktuellen Docker.
      • haselchen
        haselchen Most Active last edited by
        @mibr85
        Wäre auch meine Idee (von @Thomas-Braun )
        Backup machen.
        Neuen Container starten mit identischen Einstellungen und Backup einspielen.
          mibr85 @haselchen last edited by
          Ja Habe ich gerade versucht einen ganz nackten Container mit neuem Volume aufzusetzen, leider startet der container nicht:
          -------------------------     2023-11-12 15:35:11      -------------------------
          -----              Welcome to your ioBroker Docker container!              -----
          -----                    Startupscript is now running!                     -----
          -----                          Please be patient!                          -----
          -----                          System Information                          -----
          -----                    arch:                x86_64                       -----
          -----                    hostname:            ioBrokerTWS                  -----
          -----                          Version Information                         -----
          -----                    image:               v9.0.1                       -----
          -----                    build:               2023-11-11T23:44:48+00:00    -----
          -----                    node:                v18.18.2                     -----
          -----                    node[22]: ../src/node_platform.cc:68:std::unique_ptr<long unsigned int> node::WorkerThreadsTaskRunner::DelayedTaskScheduler::Start(): Assertion `(0) == (uv_thread_create(t.get(), start_thread, this))' failed.
           1: 0xb85bc0 node::Abort() [node]
           2: 0xb85c3e  [node]
           3: 0xbf30fe  [node]
           4: 0xbf31e1 node::NodePlatform::NodePlatform(int, v8::TracingController*, v8::PageAllocator*) [node]
           5: 0xb438f3 node::InitializeOncePerProcess(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, node::ProcessFlags::Flags) [node]
           6: 0xb43f4b node::Start(int, char**) [node]
           7: 0x7f489d0e71ca  [/lib/x86_64-linux-gnu/libc.so.6]
           8: 0x7f489d0e7285 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
           9: 0xac1f4e _start [node]
          npm:                                              -----
          -----                        Environment Variables                         -----
          -----                    SETGID:              1000                         -----
          -----                    SETUID:              1000                         -----
          -----                   Step 1 of 5: Preparing container                   -----
          Updating Linux packages on first run... Error: Updating failed.
          Registering maintenance script as command... Done.
          -----             Step 2 of 5: Detecting ioBroker installation             -----
          Existing installation of ioBroker detected in "/opt/iobroker".
          -----             Step 3 of 5: Checking ioBroker installation              -----
          (Re)setting permissions (This might take a while! Please be patient!)... Done.
          Checking Database connection... Failed.
          Please check your configuration and try again.
          For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs).
          This Script will exit now.
          • haselchen
            haselchen Most Active @mibr85 last edited by
            @mibr85
            Wie genau aufgesetzt?
            Da gibt es ja anscheinend x Möglichkeiten.
            Ich mach das mit ner Synology.
            Du vermutlich.....anders?!
              @haselchen
              über Portainer auf einem Timberwolfserver. läuft eigentlich seit 2 Jahren ohne grössere Problem aber gerade hakt es
              • DJMarc75
                DJMarc75 @mibr85 last edited by
                @mibr85 sagte in Alle Instanzen rot,:
                aber gerade hakt es
                Hast Du die eventuellen (Amok) Skripte schon geprüft?
                  mibr85 @DJMarc75 last edited by
                  @djmarc75
                  nein konnte ich nicht mehr der Container ist nicht mehr gestartet 😞
                    mibr85 @mibr85 last edited by mibr85
                    kleines Update ich habe jetzt mal meinen Container neu aufgesetzt und das Backup wieder eingespielt.
                    Läuft erstmal wieder.
                    Bei den scripten habe ich erst mal alle Scripte ohne timeout wieder aktiviert, da ich glaube das evtl irgendwo immer wieder neue timer getrigert werden.
                    kann man irgendwo sehen welche timeouts im hintergrund laufen bzw kann man sich anzeigen lassen wenn ein neuer timer getriggert und wieder gestoppt wird.
                    wenn ich mit dem befehl top in der console arbeite bekommt man ja erst nach einer gewissen Zeit mit ob da mehr leistung gezogen wird, wenn es wirklich an den timeouts liegt, oder?
                    Gibt es noch andere möglichkeiten Amokscripte zu identifizieren? Debug oder silly log einstellung für Javascripz adapter evtl?
                    zur zeit sieht es nicht schlecht aus mMn:
                      zB hier
                      wird augenscheinlich 4 mal der timeout gestartet, Warum?
                      wie kann man das besser lösen?
                      wie kann man die gestartetetn timeouts wieder stoppen? Durch restart javascriptadapter?
                      • N
                        Nordischerjung @mibr85 last edited by
                        @mibr85 so zB
                          mibr85 @Nordischerjung last edited by
                          @nordischerjung
                          vielen Dank, funktioniert super
                          aber wie kann ich die ganzen laufende timouts wieder stoppen?
                          • N
                            @mibr85 Die Instanz einmal stoppen und wieder starten
                              mibr85 @Nordischerjung last edited by mibr85
                              Muss mich leider nochmal melden.
                              Weiss leider nicht mehr weiter 😞
                              Ich habe einen komplett neuen Container mit aktuellem Docker auf meinem Synology NAS aufgesetzt leider besteht das Problem, dass von zeit zu zeit alle Instanzen Rot angezeigt werden (1. Post ganz oben) immer noch
                              ich monitore die CPU Last und den Ram meines Javaadapters da sieht man nix auffälliges:
                              Hier noch mal ein komplettes iob diag, leider zu lang zum einfügen als code, deshalb als TXT
                              f0b10d5a-fcdf-4b1a-a088-cad2e8a2fa35-iob diag Log.txt
                              und hier die zusammenfassung:
                                                      v.2023-10-10
                              model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                              Kernel          : x86_64
                              Userland        : amd64
                              Docker          : v9.0.1
                              Installation:           Docker
                              Kernel:                 x86_64
                              Userland:               amd64
                              Timezone:               Etc/UTC
                              User-ID:                0
                              X-Server:               false
                              Pending OS-Updates:     0
                              Pending iob updates:    1
                              Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                      /usr/bin/node           v18.18.2
                                                      /usr/bin/npm            9.8.1
                                                      /usr/bin/npx            9.8.1
                                                      /usr/bin/corepack       0.19.0
                              Recommended versions are nodejs 18.18.2 and npm 9.8.1
                              MEMORY:
                              Mem:            8.2G        4.6G        369M        651M        4.1G        3.5G
                              Swap:           7.1G        1.3G        5.8G
                              Total:           15G        5.9G        6.1G
                              Active iob-Instances:   28
                              Active repo(s): stable
                              ioBroker Core:          js-controller           5.0.16
                                                      admin                   6.12.0
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : MIBR-DS                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : MIBR-DS                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                30678
                              States:                 23186
                              Size of iob-Database:
                              34M     /opt/iobroker/iobroker-data/objects.jsonl
                              33M     /opt/iobroker/iobroker-data/states.jsonl
                              1432
