    • simatec
      simatec Developer Most Active @deta last edited by
      @deta Hier mal ein Beispiel...
        deta Most Active @simatec last edited by
        @simatec
        So hab ich es jetzt eingestellt und es wird der Fensteratatus nicht beachtet.
        Hatte gerade mal zum testen den Timer auf 10:50 gestellt.
        Debug Log:
        shuttercontrol.0
        12570	2023-11-09 10:50:11.044	debug	Shutdown shutters GoldenHour area: 16:18
        shuttercontrol.0
        12570	2023-11-09 10:50:11.043	debug	Starting up shutters GoldenHour area: 08:55
        shuttercontrol.0
        12570	2023-11-09 10:50:11.042	debug	Sunset today: 16:41
        shuttercontrol.0
        12570	2023-11-09 10:50:11.041	debug	Sunrise today: 07:32
        shuttercontrol.0
        12570	2023-11-09 10:50:11.040	debug	current day: 4
        shuttercontrol.0
        12570	2023-11-09 10:50:11.039	debug	goldenHour today: 15:48
        shuttercontrol.0
        12570	2023-11-09 10:50:11.038	debug	goldenHourEnd today: 08:25
        shuttercontrol.0
        12570	2023-11-09 10:50:11.037	debug	calculate astrodata ...
        shuttercontrol.0
        12570	2023-11-09 10:50:11.036	debug	Travel times of the shutters are calculated
        shuttercontrol.0
        12570	2023-11-09 10:50:11.024	info	State value to set for "shuttercontrol.0.control.autoSleep" has to be type "boolean" but received type "number"
        shuttercontrol.0
        12570	2023-11-09 10:50:11.000	info	Sleep down #26 Set ID: Stephanie Rollo value: 0%
        shuttercontrol.0
        12570	2023-11-09 10:50:10.936	debug	check xmas for Stephanie Rollo
        shuttercontrol.0
        12570	2023-11-09 10:50:10.935	debug	we are not in period, after start Wed Mar 01 2023 and before end Fri Oct 27 2023
        shuttercontrol.0
        12570	2023-11-09 10:50:10.935	debug	End Fri Oct 27 2023
        shuttercontrol.0
        12570	2023-11-09 10:50:10.934	debug	Start Wed Mar 01 2023
        shuttercontrol.0
        12570	2023-11-09 10:50:10.932	debug	check in time 31.03. 27.10.
        shuttercontrol.0
        12570	2023-11-09 10:50:03.771	debug	Auto Sleep is: 100
        shuttercontrol.0
        12570	2023-11-09 10:50:03.721	debug	complete down at 22:00
        shuttercontrol.0
        12570	2023-11-09 10:50:03.611	debug	Shutdown shutters sleep area: 10:50 debug 2
          docsnyder7 @deta last edited by
          @deta
          in den Extraeinstellung zum besagten fenster gibt es eine Punkt "Fahren nach dem Schließen des fensters"
            deta Most Active @docsnyder7 last edited by deta
            @docsnyder7 Er macht dennoch das Rollo zu, obwohl das Fenster auf ist. Er soll aufbleiben, solange das Fenster auf ist. Und wenn dann erst nach dem schliesen des Fenster zu gehen.
            • simatec
              @deta sagte in Test Adapter shuttercontrol v1.6.x:
              Du hast ja auch nicht die Einstellungen genommen, die ich gepostet habe
                deta Most Active @simatec last edited by deta
                @simatec sagte in Test Adapter shuttercontrol v1.6.x:
                Jep genau das war das.... Danke.
                Jetzt bleibt das Rollo offen, bis das Fenster zugemacht wird. Klasse.
                Und sobald das Fenster zu ist geht der Rollo runter... Top
                  bommel_030 last edited by
                  @simatec
                  Wenn ich das richtig verstehe und die Rollladenautomatik nur auf "öffnen" stelle wird der Rollladen bei geöffnetem Fenster gar nicht bewegt bzw. nur spät geschlossen.
                  Mit welcher Einstellung erreiche ich denn, dass der Rollladen bei geöffnetem Fenster nur in die "Lüftungsposition" herunterfährt, also den Wert den er anfährt wenn ich ein Fenster öffne wenn der Rollladen geschlossen ist?
                  • Negalein
                    Negalein Global Moderator last edited by Negalein
                    @simatec
                    Ich habe einen HmIP Tür- und Fensterkontakt montiert.
                    Vorher war ein Aquara, der konnte true/false.
                    Der HmIP kann closed(0) und open(1).
                    Das versteht aber Shuttercontrol irgendwie nicht, da seitdem das Rollo nicht automatisch schließt.
                    2023-11-09 17:07:10.037 - shuttercontrol.0 (351944) #14 Will close ID: Schlafzimmer.LEVEL value: 0% after the window has been closed
                    Muss der DP mit einem Alias umgewandelt werden?
                    EDIT: hab hier vergessen von false auf 0 zu ändern!
                    • CKMartens
                      CKMartens last edited by
                      Guten Morgen,
                      ich habe jetzt mal eine evtl. dumme Frage.
                      Kann, und wenn ja wie, ich einstellen das die Rollos bei Sonnenuntergang, aber nicht vor Zeit x fahren. Umgekehrt geht es ja, was für den Sommer ganz nützlich ist.
                      Nur wird es ja im Winter jetzt früher dunkel, und ich möchte nicht dass das Wohnzimmer vor 20:00 Uhr schließt, auch wenn Sonnenuntergang schon um 17 Uhr ist.
                      Kann ich das irgendwie einstellen?
                      Danke schon einmal,
                      Carsten
                      D FredF 2 Replies Last reply Reply Quote 0
                        docsnyder7 @CKMartens last edited by
                        @ckmartens
                        ich meine man kann pro Rollo eine Verzögerung einstellen, oder du änderst den modus auf ohne Sonne und lässt sie nach festen zeiten fahren
                        CKMartens 1 Reply Last reply Reply Quote 0
                        • FredF
                          FredF Most Active Forum Testing @CKMartens last edited by
                          @ckmartens Ja das geht
                          Siehe: https://github.com/simatec/ioBroker.shuttercontrol/wiki/Shuttercontrol-Wiki-Deutsch#rollladen-einstellungen
                          und hier: https://github.com/simatec/ioBroker.shuttercontrol/wiki/Shuttercontrol-Wiki-Deutsch#sonderzeiten
                          • CKMartens
                            CKMartens @docsnyder7 last edited by
                            Hallo @docsnyder7 ,
                            das würde aber nicht meine Anforderung erfüllen, denn ich möchte ja nicht nach festen Zeiten fahren, sondern max. erst um x Uhr, solange der Sonnenuntergang vor dieser zeit liegt, ansonsten zum Sonnenuntergang. Spätestens im Frühjahr müsste ich alles wieder neu einstellen.
                            • CKMartens
                              CKMartens @FredF last edited by
                              Hallo @fredf
                              das lässt sich so leider nicht umsetzen, denn wenn ich einstelle Schließen bei Sonnenuntergang fährt er herunter, auch wenn die Zeit von X Uhr noch nicht erreicht ist, denn ich will ja nicht später schließen. und in der Beschreibung steht eindeutig das dies eine zusätzliche Fahrt wäre.
                                @ckmartens
                                das stimmt natürlich
                                  axel @docsnyder7 last edited by
                                  @docsnyder7 Das ist auch mein Problem.
                                  Ich stelle folgendes ein:
                                  • Zeit Wohnbereich mit Sonnenauf- & Sonnenuntergang
                                  • Schließen der Rollläden in der Arbeitswoche 19:00
                                  • Alle Rollläden in der Zwischenposition vollständig schließen um 19:00
                                  • Einstellungen Helligkeitssensor 75 Lux für das Schliessen, frühstes Schliessen 17:00
                                  • und beim einzelnen Rollladen "in Zwischenposition fahren und später komplett schliessen"
                                  Ergebnis ist, dass die Rollladen zum Zeitpunkt Sonnenuntergang in die Zwischenposition Fahren und um 19:00 Uhr vollständig schliessen.
                                  Wäre es nicht möglich, die Zeit zum "vollständigen Schließen" in einen Datenpunkt zu schreiben. Dann könnte ich mit seinem Skript z. B. diese Zeit immer auf Sonnenuntergang + xx Minuten selber dynamisch einstellen. Ein weitere Fahrt im Adapter wäre nicht erforderlich, und die Änderung sollte eigentlich nich so kompliziert sein wir eine komplett neue Fahrt zu implementieren.
                                  Was haltet Ihr davon?
                                    @axel
                                    Reicht dir evt die im jeweiligen Rollo unter extraeinstellungen-extraeinstellungen zu tätigende Verzögerung? Die sollte doch genau das bewirken oder
                                      @docsnyder7 Danke für den Hinweis, löst das Problem aber nicht. Einstellung ist auf das Öffnen/Schliessen der Fenster bezogen und steuert einen evtl. erforderlichen Nachlauf. Aber trotzdem Danke.
                                        axel @CKMartens last edited by
                                        @ckmartens sagte in Test Adapter shuttercontrol v1.6.x:
                                        Hallo @fredf
                                        • Andreas Kleinert
                                          Andreas Kleinert @simatec last edited by
                                          @simatec
                                          Dank dir,
                                          für die super Arbeit.
                                          Eine Frage hätte ich arbeitet er auch mit HM-LC-Bl1PBU-FM und HmIP-BROLL-2 zusammen.
                                          Gruß Andy
                                          simatec M 2 Replies Last reply Reply Quote 0
                                          • simatec
                                            simatec Developer Most Active @Andreas Kleinert last edited by
                                            @andreas-kleinert Der Adapter ist nicht an Geräte gebunden. Es können alle Aktoren verwendet werden, die sich über ein Level steuern lassen.
                                            Wenn du einen Aktor hast, der kein Level unterstützt, dann kannst du die Level über einen Alias simulieren
                                            81.1k
                                            332
                                            7403
                                            10536237
