    4. Gosund SP111 mit Tasmota 13.2.0 Problem mit DP
    • RalfTh
      RalfTh @Ralla66 last edited by RalfTh
      @ralla66
      {"StatusSNS":{"Time":"2023-11-14T12:59:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.424,"Yesterday":0.007,"Today":0.093,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":231,"Current":0.181}}}
      So sieht die Rückmeldung aus , wenn ich im Webbrowser "http://192.xxx.xxx.xxx/cm?cmnd=status 10" eingebe.
      Mein Script:
      >D
      ;a valid script must start with >D in the first line
      Timer=0
      WEBQ=5
      VOL=0
      CUR=0
      POW=0
      TOT=0
      YES=0
      TOD=0
      APP=0
      RAP=0
      ; Meins
      MQT: tasmota_Reserve2/cmnd = {"StatusSNS":{"Time":"2023-11-14T12:59:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.424,"Yesterday":0.007,"Today":0.093,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":231,"Current":0.181}}}
      >BS
      +>subscribe EA, %topic%/cmnd/Total
      +>subscribe EA, %topic%/cmnd/Yesterday
      +>subscribe EA, %topic%/cmnd/Today
      +>subscribe EA, %topic%/cmnd/Power
      +>subscribe EA, %topic%/cmnd/ApparentPower
      +>subscribe EA, %topic%/cmnd/ReactivePower
      +>subscribe EA, %topic%/cmnd/Voltage
      +>subscribe EA, %topic%/cmnd/Current
      >S
      Timer+=1
      ;Executed every second
      if Timer>10
      then
      =>websend 192.168.178:164/cm?cmnd=status 10
      +>publish %topic%/ENERGY_Total {%0TOT% kWh}
      +>publish %topic%/ENERGY_Yesterday {%0YES% kWh}
      +>publish %topic%/ENERGY_Today {%0TOD% kWh}
      +>publish %topic%/ENERGY_ApparentPower {%0APP% VA}
      +>publish %topic%/ENERGY_ReactivePower {%RAP% VAR}
      +>publish %topic%/ENERGY_Power {%0POW% W}
      +>publish %topic%/ENERGY_Voltage {%0VOL% V}
      +>publish %topic%/ENERGY_Current {%0CUR% A}
      Timer=0
      endif
      >E
      ;Executed when a Tasmota MQTT RESULT message is received
      VOL=WebQuery#StatusSNS#ENERGY#Voltage
      print Wert Volt %VOL%
      CUR=WebQuery#StatusSNS#ENERGY#Current/1000
      print Wert Current %CUR%
      POW=WebQuery#StatusSNS#ENERGY#Power
      print Wert Power %POW%
      TOT=WebQuery#StatusSNS#ENERGY#Total
      print Wert Total %TOT%
      YES=WebQuery#StatusSNS#ENERGY#Yesterday
      print Wert Yesterday %YES%
      TOD=WebQuery#StatusSNS#ENERGY#Today
      print Wert Today %TOD%
      APP=WebQuery#StatusSNS#ENERGY#ApparentPower
      print Wert Apparent Power %APP%
      RAP=WebQuery#StatusSNS#ENERGY#ReactivePower
      print Wert Reaktive Power %RAP%
      >W
      ;The lines in this section are displayed in the web UI main page
      Power{m} %2POW% W
      Volt{m} %2VOL% V
      Ampere{m} %2CUR% A
      Total{m} %2TOT%
      Yesterday{m} %YES%
      Today{m} %2TOD%
      Apparent{m} %2APP%
      Reactive{m} %2RAP%
      Hier mal ein Auszug was im MQTT-Explorer sieht:
      Auffällig ist der DP tasmota_Reserve2/stat/RESULT Hier erscheint "Websend":Wrong Parameters
      Einiges habe ich angepasst, weil ich in MQTT am Topic und Full-Topic was geändert habe. Mein Full-Topic den Eintrag %topic%/%prefix%/ damit in MQTT der Baum anders aufgebaut wird. Das habe ich beim subscribe berücksichtigt. Und das Publish habe ich direkt unter dem Topic vorgenommen.
      Allerdings habe ich auch schon dein Original (natürlich mit den spez. Anpassungen) ausprobiert mit dem gleichen Ergebnis. Die DP's werden nicht aktualisiert
      Was mache ich falsch?
      Ralla66 1 Reply Last reply Reply Quote 0
      • Ralla66
        Ralla66 Most Active @RalfTh last edited by Ralla66
        @ralfth sagte in Gosund SP111 mit Tasmota 13.2.0 Problem mit DP:
        Erst auf default lassen bis das läuft.
        Das mag Tasmota gar nicht.
        Mqtt kannst du später prüfen, das muß erst auf dem ESP laufen.
        ! hinter dem ; ist Text und wird im Programm nicht Berücksichtigt
        da fehlt was am Anfang ; MQT: tasmota_Reserve2/cmnd = {"StatusSNS":{"Time":"2023-11-14T...........................
        Nicht soviel auf einmal ändern , macht nur das Debuggen schwerer.
        • Ralla66
          Ralla66 Most Active @Ralla66 last edited by Ralla66
          @ralla66
          Wrong Parameters kann auch vom publish sein, sowas {%0TOT% kWh}
          Das subscribe und publish ist auf Sonoff Adapter gemünzt, nicht für Mqtt Adapter.
          Nachtrag eckige Klammern !
          if Timer>10
          then
          =>websend [192.168.2.85] /cm?cmnd=status 10
          RalfTh 1 Reply Last reply Reply Quote 0
          • RalfTh
            @ralla66 Habe jetzt dein original Script eingebunden:
            >D
            Timer=0
            WEBQ=5
            VOL=0
            CUR=0
            POW=0
            TOT=0
            YES=0
            TOD=0
            APP=0
            RAP=0
            ; Meins
            ; MQT: tasmota_Reserve2 = {"StatusSNS":{"Time":"2023-11-14T12:59:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.424,"Yesterday":0.007,"Today":0.093,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":231,"Current":0.181}}}
            >BS
            +>subscribe EA, cmnd/%topic%/Total
            +>subscribe EA, cmnd/%topic%/Yesterday
            +>subscribe EA, cmnd/%topic%/Today
            +>subscribe EA, cmnd/%topic%/Power
            +>subscribe EA, cmnd/%topic%/ApparentPower
            +>subscribe EA, cmnd/%topic%/ReactivePower
            +>subscribe EA, cmnd/%topic%/Voltage
            +>subscribe EA, cmnd/%topic%/Current
            >S
            Timer+=1
            if Timer>10
            then
            =>websend [192.168.178.164] /cm?cmnd=status 10
            +>publish stat/%topic%/RESULT {"Total":%0TOT%}
            +>publish stat/%topic%/RESULT {"Yesterday":%0YES%}
            +>publish stat/%topic%/RESULT {"Today":%0TOD%}
            +>publish stat/%topic%/RESULT {"ApparentPower":%0APP%}
            +>publish stat/%topic%/RESULT {"ReactivePower":%RAP%}
            +>publish stat/%topic%/RESULT {"Power":%0POW%}
            +>publish stat/%topic%/RESULT {"Voltage":%0VOL%}
            +>publish stat/%topic%/RESULT {"Current":%0CUR%}
            Timer=0
            endif
            >E
            >W
            Power{m} %2POW% W
            Volt{m} %2VOL% V
            Ampere{m} %2CUR% A
            Total{m} %2TOT%
            Yesterday{m} %YES%
            Today{m} %2TOD%
            Apparent{m} %2APP%
            Reactive{m} %2RAP%
            angepasst habe ich Zeile 21 und 45
            Im Log des ioBroker steht:
            sonoff.0
            2023-11-14 18:48:06.358	debug	[Reserve2] Received: stat/tasmota_Reserve2/RESULT = {"WebSend":"Connect failed"}
            Habe keine Ahnung woran das liegen kann.
            Nachtrag:
            Ralla66 2 Replies Last reply Reply Quote 0
            • Ralla66
              @ralfth
              Passwort Rot ? Zum testen einfach 12345 nehmen
              Topic nicht default
              was steht in der Console ?
              websend done ?
              Nachtrag:
              Das ist alles verbogen,
              neu flashen
              gosund einrichten template
              nix an Topic / Full Topic basteln, rein gar nix !!
              im Sonoff Adapter altes löschen
              Mqtt verbinden
              das muß erst einmal rennen
              danach Script einfügen, speichern, rebooten,aktivieren
              • Ralla66
                @ralfth
                was bastelst du da 🙂
                • RalfTh
                  @ralla66 So, habe jetzt alles so eingestellt wie du es mir in den Bildern gezeigt hast. Habe vorher den Adapter gestoppt und die Objekte gelöscht.
                  Das Script ist nicht aktiviert.
                  Instanz gestartet, die Objekte werden angelegt.
                  Di DP's welche mit "ENERGY_" beginnen werden,wenn überhaupt nur nach einer Ewigkeit aktualisiert und das obwohl die Message ankam. Hier Auszug aus der Konsole:
                  B8D3E7/POWER = ON
                  07:14:16.291 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:14:16","Uptime":"0T00:36:54","UptimeSec":2214,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  07:14:16.302 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:14:16","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.527,"Yesterday":0.170,"Today":0.026,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.183}}
                  07:14:46.290 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:14:46","Uptime":"0T00:37:24","UptimeSec":2244,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  07:14:46.299 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:14:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.528,"Yesterday":0.170,"Today":0.027,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.183}}
                  07:15:16.280 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:15:16","Uptime":"0T00:37:54","UptimeSec":2274,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  07:15:16.293 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:15:16","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.528,"Yesterday":0.170,"Today":0.027,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.183}}
                  07:15:46.251 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:15:46","Uptime":"0T00:38:24","UptimeSec":2304,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  07:15:46.262 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:15:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.528,"Yesterday":0.170,"Today":0.027,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.186}}
                  07:16:16.257 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:16:16","Uptime":"0T00:38:54","UptimeSec":2334,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  07:16:16.267 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:16:16","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.529,"Yesterday":0.170,"Today":0.028,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.185}}
                  07:16:46.256 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:16:46","Uptime":"0T00:39:24","UptimeSec":2364,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  07:16:46.268 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:16:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.529,"Yesterday":0.170,"Today":0.028,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.186}}
                  07:17:16.261 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:17:16","Uptime":"0T00:39:54","UptimeSec":2394,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":60,"Signal":-70,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  07:17:16.273 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:17:16","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.530,"Yesterday":0.170,"Today":0.029,"Period":0,"Power":44,"ApparentPower":44,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.188}}
                  07:17:46.275 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:17:46","Uptime":"0T00:40:24","UptimeSec":2424,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  07:17:46.285 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:17:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.530,"Yesterday":0.170,"Today":0.029,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.185}}
                  Derweil im ioBroker:
                  Und das, obwohl laut LOG auch hier die Informationen eintrudeln:
                  Ich habe die Steckdose mittlerweile drei mal geflasht und jedesmal eine andere Konfiguration verwendet. Ich denke, ein erneutes flashen bringt da auch nicht die Lösung. Falls keine anderen Ideen mehr da sind werde ich mir einen anderen MQTT-Broker suchen und das JSON aufdröseln.
                  • Ralla66
                    @ralfth
                    alle print des Scriptes werden in der Console nicht ausgegeben, bedeutet dein Script läuft nicht.
                    Topic ist noch Reserve2 und nicht default.
                    Ob deine .bin überhaupt in Ordnung ist weiß keiner.
                    Daher das compilieren mit Tasmocompiler. Das ist halt viel einfacher.
                    Solange die Topic / Full Topic nicht in Ordnung sind und das Script nicht läuft kann
                    ich auch nicht weiter helfen. Da es ja bei mir läuft liegt das ja an deinem System.
                    • RalfTh
                      @ralla66 sagte in Gosund SP111 mit Tasmota 13.2.0 Problem mit DP:
                      Hatte ich auch geschrieben, dass das Script nicht aktiviert ist.
                      Meine .bin habe ich mit Gitpod kompiliert (Quelle: https://github.com/arendst/Tasmota) und alle von dir genannten Defines, soweit in my_user_config.h vorhanden, aktiviert. In einem Post weiter oben hatte ich das auch schon erwähnt.
                      Diese .bin habe ich dann auf den Gosund geflasht.
                      Das Script habe ich jetzt aktiviert und in der Konsole kommt folgende Fehlermeldung:
                      17:32:38.869 SCR: performs "websend [192.168.178.164] /cm?cmnd=status 10"
                      17:32:44.249 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
                      17:32:44.257 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
                      17:32:44.264 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
                      17:32:44.272 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
                      17:32:44.279 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
                      17:32:44.286 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
                      17:32:44.293 MQT: stat/tasmota_B8D3E7/RESULT = {"Power":0}
                      17:32:44.300 MQT: stat/tasmota_B8D3E7/RESULT = {"Voltage":0}
                      17:32:44.307 MQT: stat/tasmota_B8D3E7/RESULT = {"Current":0}
                      17:32:48.393 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T17:32:48","Uptime":"0T10:55:26","UptimeSec":39326,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":4,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:03"}}
                      17:32:48.406 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T17:32:48","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.544,"Yesterday":0.170,"Today":0.043,"Period":1,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":230,"Current":0.181}}
                      17:32:54.371 SCR: performs "websend [192.168.178.164] /cm?cmnd=status 10"
                      17:32:59.783 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
                      17:32:59.792 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
                      17:32:59.799 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
                      17:32:59.808 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
                      17:32:59.815 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
                      17:32:59.823 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
                      Die IP für das websend ist die des ioBroker oder der Gosund?
                      Hier noch mal mein Script:
                      >D
                      Timer=0
                      WEBQ=5
                      VOL=0
                      CUR=0
                      POW=0
                      TOT=0
                      YES=0
                      TOD=0
                      APP=0
                      RAP=0
                      ; Meins
                      >BS
                      >S
                      Timer+=1
                      if Timer>10
                      then
                      Timer=0
                      endif
                      >E
                      >W
                      Power{m} %2POW% W
                      Volt{m} %2VOL% V
                      Ampere{m} %2CUR% A
                      Total{m} %2TOT%
                      Yesterday{m} %YES%
                      Today{m} %2TOD%
                      Apparent{m} %2APP%
                      Reactive{m} %2RAP%
                      Ich habe es nochmal verglichen. Ich habe lediglich die Zeilen 21 und 45 angepasst.
                      • Ralla66
                        vom Gosund, das sieht doch gut aus 🙂
                        Daten per IP websend kannst du von jedem Tasmota Gerät abfragen der die gleiche
                        StatusSNS/Energy/xxx............................ hat.
                        • RalfTh
                          RalfTh last edited by RalfTh
                          @ralla66 Ok, dann habe ich es richtig gemacht.
                          Allerdings stimmt der Inhalt nicht und diese Meldung scheint die Ursache zu sein:
                          18:34:19.588 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
                          Steht auch in meinem letzten Post in der Konsolenausgabe.
                          Gebe ich im Browser http://192.168.178.164/cm?cmnd=status 10 ein erhalte ich folgendes:
                          {"StatusSNS":{"Time":"2023-11-15T18:37:01","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.556,"Yesterday":0.170,"Today":0.055,"Power":41,"ApparentPower":41,"ReactivePower":0,"Factor":1.00,"Voltage":229,"Current":0.181}}}
                          In der Konsole sieht es folgend aus:
                          18:38:48.972 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T18:38:48","Uptime":"0T12:01:26","UptimeSec":43286,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":4,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":82,"Signal":-59,"LinkCount":1,"Downtime":"0T00:00:03"}}
                          18:38:48.984 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T18:38:48","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.558,"Yesterday":0.170,"Today":0.057,"Period":1,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":229,"Current":0.183}}
                          18:38:50.972 SCR: performs "websend [192.168.178.164] /cm?cmnd=status 10"
                          18:38:56.176 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
                          18:38:56.184 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
                          18:38:56.191 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
                          18:38:56.199 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
                          18:38:56.206 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
                          18:38:56.213 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
                          18:38:56.221 MQT: stat/tasmota_B8D3E7/RESULT = {"Power":0}
                          18:38:56.228 MQT: stat/tasmota_B8D3E7/RESULT = {"Voltage":0}
                          18:38:56.235 MQT: stat/tasmota_B8D3E7/RESULT = {"Current":0}
                          In den ersten beiden Zeilen siehst du die JSON-Inhalte, aber ab Zeile 5 sind alle Werte 0??!!
                          Ich vermute das liegt am Connection failed in Zeile 4.
                          • Ralla66
                            @ralfth
                            ja richtig, vermute da ist was falsch in Zeile 45 beim send
                            Hattest du nicht 2 Gosund ? Dann nimm mal die andere IP
                            • RalfTh
                              @ralla66 ich habe viele. Du meinst ich soll mal die Daten einer anderen abfragen und publishen?!
                              • Ralla66
                                @ralfth
                                ja zum testen ob websend rausgeht und ein Done kommt
                                Nachtrag: lösch mal den Kommentar
                                ; MQT: tasmota_Reserve2 = {"StatusSNS":{"Time":"2023-11-14T12:59:46","ENERGY":{"TotalStart...............................
                                nicht das die Zeile zu lang ist
                                • RalfTh
                                  @ralla66 OK, hier kommt eine DONE. allerdings werden die Die Werte nich ins Result geschrieben. Oder werden sie nicht richt gelesen?
                                  18:57:45.317 SCR: performs "websend [192.168.178.151] /cm?cmnd=status 10"
                                  18:57:45.391 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Done"}
                                  18:57:45.398 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
                                  18:57:45.404 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
                                  18:57:45.408 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
                                  18:57:45.412 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
                                  18:57:45.416 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
                                  18:57:45.421 MQT: stat/tasmota_B8D3E7/RESULT = {"Power":0}
                                  18:57:45.425 MQT: stat/tasmota_B8D3E7/RESULT = {"Voltage":0}
                                  18:57:45.429 MQT: stat/tasmota_B8D3E7/RESULT = {"Current":0}
                                  Hier läuft übrigens eine .bin 13.2.0 DE ganz normal von der Tasmota-Seite.
                                  Die folgenden defines sind nicht mehr Bestandteil my_user_config.h
                                  #define USE_SCRIPT_GLOBVARS
                                  #define USE_SCRIPT_STATUS
                                  #define USE_SCRIPT_FULL_JSON_PARSER
                                  #define USE_SCRIPT_JSON_EXPORT
                                  #define USE_SCRIPT_WEB_DISPLAY
                                  #define USE_SCRIPT_SERIAL
                                  #define USE_SML_M
                                  Damit steht es nicht in Zusammenhang. Hatte ich weiter oben schon geschrieben.
                                  • Ralla66
                                    192.168.178.151
                                    geprüft im Browser ?
                                    Topic ist default ?
                                    • RalfTh
                                      192.168.178.151
                                      Topic ist default ?
                                      Ja und Ja
                                      Browser-Antwort:
                                      {"StatusSNS":{"Time":"2023-11-15T19:10:25","ENERGY":{"TotalStartTime":"2020-01-10T16:35:26","Total":196.003,"Yesterday":0.483,"Today":0.467,"Power":84,"ApparentPower":104,"ReactivePower":61,"Factor":0.81,"Voltage":226,"Current":0.459}}}
                                      • Ralla66
                                        @ralfth
                                        den langen kommentar hast du gelöscht ?
                                        Telemetrie steht bei mir auf 10
                                        • RalfTh
                                          @ralla66 Beides Ja, allerdings immer noch:
                                          19:19:27.382 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
                                          Ich verstehe das nicht, wenn ich das im Webbrowser aufrufe funktioniert es doch!!!!
                                          Das ist allerdings neu:
                                          19:21:50.738 var not found: WebQuery#StatusSNS#ENERGY#Voltage
                                          19:21:50.740 Wert Volt 0.00
                                          19:21:50.742 var not found: WebQuery#StatusSNS#ENERGY#Current/1000
                                          19:21:50.743 Wert Current 0.00
                                          19:21:50.745 var not found: WebQuery#StatusSNS#ENERGY#Power
                                          19:21:50.746 Wert Power 0.00
                                          19:21:50.748 var not found: WebQuery#StatusSNS#ENERGY#Total
                                          19:21:50.750 Wert Total 0.00
                                          19:21:50.751 var not found: WebQuery#StatusSNS#ENERGY#Yesterday
                                          19:21:50.753 Wert Yesterday 0.00
                                          19:21:50.755 var not found: WebQuery#StatusSNS#ENERGY#Today
                                          19:21:50.756 Wert Today 0.00
                                          19:21:50.758 var not found: WebQuery#StatusSNS#ENERGY#ApparentPower
                                          19:21:50.759 Wert Apparent Power 0.00
                                          19:21:50.761 var not found: WebQuery#StatusSNS#ENERGY#ReactivePower
                                          19:21:50.763 Wert Reaktive Power 0.00
                                          • Ralla66
                                            @ralfth
                                            der Parser zerlegt die Antwort vom websend der Anfrage in Today, Voltage usw.
                                            Der Parser wird zwingend benötigt.
                                            RalfTh 2 Replies Last reply Reply Quote 0
                                            10556
