    4. Backitup und Synology
      Kopterframe last edited by
      Servus,
      habe Iobroker im Container auf der Synology laufen.
      Habe das Problem nach ein paar Änderungen nun, dass
      Backitup die Datensicherungen in ein separates Verzeichnis nicht mehr macht.
      Ich habe gleichzeitig ein neues DSM sowie auch das Verzeichnis auf dem NAS geändert.
      Mit meinen alten Eistellungen ging es problemlos.
      Die Gruppe User hat alle Rechte.
      Started iobroker ...
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.0.99/Sicherungen/Iobroker/ /opt/iobroker/backups"
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.99/Sicherungen/Iobroker/ /opt/iobroker/backups"
      [ERROR] [mount] - [undefined Error: Command failed: mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.99/Sicherungen/Iobroker/ /opt/iobroker/backups
      mount.cifs: permission denied: no match for /opt/iobroker/backups found in /etc/fstab
      [DEBUG] [mount] - Error: Command failed: mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.99/Sicherungen/Iobroker/ /opt/iobroker/backups
      [DEBUG] [iobroker] - host.iobroker_heiko 4731 states saved
      [DEBUG] [iobroker] - host.iobroker_heiko 5465 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_15-17_03_38_backupiobroker.tar.gz
      [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
      [DEBUG] [iobroker] - done
      [DEBUG] [cifs] - used copy path: /Sicherungen/Iobroker/
      [DEBUG] [cifs] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      Grüße Heiko
      Thomas Braun ? 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Kopterframe last edited by
        @kopterframe
        Wie sehen deine Einstellungen für das NAS im Adapter aus?
          A Former User @Kopterframe last edited by
          @kopterframe sagte in Backitup und Synology:
          Moin,
          ich frage mal ganz doof, wieso versuchst Du auf der Synology in einem Container, ein auf der Synology erstelltes Verzeichnis mittels SMB/CIFS in den Container zu mounten?
          Wieso legst Du nicht gleich wie für den ioBroker ein Backupverzeichnis an und mountest das beim Container start?
          Wie hast Du den Container erstellt?
          Also mit z. B. mit einem Docker Compose File
          version: '2'
          services:
            iobroker:
              container_name: iobroker
              image: buanet/iobroker
              hostname: iobroker
              restart: always
              ports:
                - "8081:8081"
           volumes:
                - /volume1/docker/iobroker/iob_data:/opt/iobroker
                - /volume1/docker/iobroker/iob_backups:/opt/iobroker/backups
          Wobei das Verzeichnisse /volume1/docker/iobroker/iob_data das Standardverzeichnis ist, in welchem alles Daten des ioBrokers liegen, das andere das Verzeichnis für die Backups
          VG
          Bernd
          P.S.: vielleicht verstehe ich aber auch wieder nur das Problem nicht 🙂
            NAS/Kopieren
            CIFS
            Server: die IP vom NAS
            SMB 1.0 (2.0, 3.0) alle probiert
            Benutzer und Passwort..
            Als root-Benutzer mounten, mit und ohne Haken versucht.
            Pfad: /Sicherungen/Iobroker/
            @dp20eic
            der Ordnung halber, da ich in dem Verzeichnis Sicherungen noch andere Sachen sichere. so habe ich einen zentralen Platz. Mir ist es schon passiert, dass ich im docker Ordner versehentlich was gelöscht habe.
              @kopterframe
              Zeig Mal einen Screenshot.
              Mich irritiert die Meldung
              In der fstab muss nämlich gar kein Eintrag sein...
                Kopterframe @Thomas Braun last edited by
                Ich hoffe es ist der richtige?
                Thomas Braun Kalle Blomquist 2 Replies Last reply Reply Quote 0
                  @kopterframe
                  Mounte als root und stell den SMB-Dialekt von 'Altgriechisch (1.0)' auf 3.1.1 (oder was auch immer dein NAS da an modernerem Protokoll anbietet).
                  • Kalle Blomquist
                    Kalle Blomquist @Kopterframe last edited by
                    @kopterframe
                    Versuch mal ohne iobroker in der Pfad Angabe, also nur /sicherungen
                    bei mir läuft es so:
                      Kopterframe @Thomas Braun last edited by Kopterframe
                      @thomas-braun als root bekomme ich im Log eine Fehlermeldung.
                      [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.99
                      Sorry
                      SMB3.0 mehr geht nicht.
                      @Kalle-Blomquist das geht auch nicht.
                      Grüße Heiko
                        Geheime Fehlermeldungen sind die schlimmsten!
                          Sorry
                            @kopterframe
                            Da fehlt ja auch das Ziel.
                              habe es gerad noch mal versucht.
                              [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.99/Sicherungen /opt/iobroker/backups
                              sudo: unable to resolve host iobroker_heiko: Name or service not known
                              mount error(13): Permission denied
                              den Pfad hatte ich auf Sicherungen geändert.
                                @kopterframe
                                sudo nicht eingerichtet?
                                Wassen das da für ein System?
                                iob diag
                                anschauen.
                                  Moin,
                                  wie sieht denn das Verzeichnis auf der Syno aus?
                                  Nur ein Beispiel musst Du an Deine Gegebenheiten anpassen
                                  VG
                                  Bernd
                                  P.S: Richte es Dir wie ich oben schon gesagt habe ein, da kannst Du auch gern den Pfad zu Deiner Sicherung nutzten.
                                    A Former User @Thomas Braun last edited by
                                    @thomas-braun sagte in Backitup und Synology:
                                    Moin,
                                    stand im ersten Post, ist ein Docker auf der Synology
                                    VG
                                    Bernd
                                    Thomas Braun K 2 Replies Last reply Reply Quote 0
                                      @dp20eic sagte in Backitup und Synology:
                                      Muss ich überlesen haben...
                                      Zu Docker sag ich nix.
                                        Kopterframe @Guest last edited by
                                        @dp20eic
                                        Habe den Container mit Portainer gemacht. und jezt das Verzeichnis gemountet.
                                        Die Eigenschaften der Ordners passen auch.
                                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.0.99/Sicherungen/iobroker/ /opt/iobroker/backups"
                                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.99/Sicherungen/iobroker/ /opt/iobroker/backups"
                                        [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Heiko,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.99/Sicherungen/iobroker/ /opt/iobroker/backups
                                        es ging ja schon einmal.
                                        Ich gebe es bald auf....
                                        ? Glasfaser 2 Replies Last reply Reply Quote 0
                                          Moin,
                                          wenn Du den in den Container hängst, dann musst Du beim BackitUp Adapter nicht mehr als CIFS mounten, einfach CFIS raus und Standard Pfad in den Adapter.
                                          VG
                                          Bernd
                                          • Glasfaser
                                            Glasfaser @Kopterframe last edited by Glasfaser
                                            @dp20eic
                                            du mußt dich schon entscheiden wie deine Ordner jetzt heißen ... ich sehe hier mal so .. dann so .
                                            Vergleiche hier dein Post dann findest du den Fehler -
                                            .... mal klein geschrieben das i .. dann Groß das I , dann wieder anderen Namen ...
                                            ... aber mache es so wie @dp20eic schreibt ... CIFS ist blödsinn auf der eigenen Synology !
                                            642
