    4. ioBroker.Unifi verbindet nicht (Erstinstallation)
      Thomas Braun Most Active @DiMe last edited by
      @dime
      Wenn der iobrokee auf Stand gebracht worden ist sollte da auch eine Empfehlung zu nodejs@18 erscheinen.
      Oder du erzwingst die 18 direkt:
      iob nodejs-update 18
        DiMe @Guest last edited by
        @ilovegym
        v.2023-10-10
        Copy text starting here:
                                v.2023-10-10
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.19-v7l+
              Architecture: arm
        Installation:           native
        Kernel:                 armv7l
        Userland:               armhf
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    15
        This system needs to be REBOOTED NOW!
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                /usr/bin/node           v18.18.2
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                /usr/bin/corepack       0.19.0
        Recommended versions are nodejs 16.20.2 and npm 8.19.4
        MEMORY:
        Mem:            3.8G        1.1G        1.8G        0.0K        926M        2.6G
        Swap:            99M         80M         19M
        Total:          3.9G        1.2G        1.9G
        Active iob-Instances:   13
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                3374
        States:                 3133
        Size of iob-Database:
        6.8M    /opt/iobroker/iobroker-data/objects.jsonl
        1.2M    /opt/iobroker/iobroker-data/states.jsonl
          @dime
          Solltest du tun.
            DiMe @Thomas Braun last edited by DiMe
            Done
            Neuer Diag:
                                    v.2023-10-10
                     Icon name: computer
                        Kernel: Linux 6.1.21-v7l+
                  Architecture: arm
            Kernel:                 armv7l
            Userland:               armhf
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
            MEMORY:
            Mem:            3.8G        1.4G        1.6G        6.0M        917M        2.3G
            Swap:            99M          0B         99M
            Total:          3.9G        1.4G        1.7G
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                3430
            States:                 3189
            7.9M    /opt/iobroker/iobroker-data/objects.jsonl
            1.9M    /opt/iobroker/iobroker-data/states.jsonl
              A Former User @DiMe last edited by
              @dime sagte in ioBroker.Unifi verbindet nicht (Erstinstallation):
              jetzt den iobroker auf den Stand bringen..
              und wenn du das fertig hast, sagst du uns noch die Versionen von Unifi-Controller und -Netwerk, damit wir den unifi-adapter in Gang bringen.. aber erstmal das Fundament.. mit nem Haus faengt man auch nicht am Dach an zu bauen.. 🙂
                DiMe @Guest last edited by DiMe
                @ilovegym
                Alles klar, mach ich. Möchte nur schnell noch ein Backup meiner SD machen, falls etwas schief gehen sollte. Ich habe da ein Händchen dafür 😁
                  @dime
                  Das sollte man zwischen diesen Schritten sowieso immer machen.. am besten ganze SD Karte.. die geht sowieso gern kaputt..
                  und auch vom iobroker ein Backup machen, also in der Konsole "iob backup" eingeben, und das dann irgendwohin(wo es sicher ist und man es wieder findet und einfach zurueck kopieren kann) kopieren...
                    @ilovegym
                    SD Karten Backup mache ich eigentlich immer in einem bestimmt Turnus oder bevor ich gerade rumschraube.
                    Habe auch ein Adapter bei mir auf dem Broker wo täglich meine Daten vom Broker sichert (Grafana , Werte usw.).
                    Aber das mit dem "iob Backup" mache ich jetzt trotzdem auch noch. Lieber eine Sicherung zu viel.
                    Kurze Frage mit dem IOBroker update, kann ich den einfach mit
                    iob upgrade self
                    starten oder gibt es noch etwas zu beachten, ich frage für ein Freund 😆
                      @dime
                      iob update
                      iob upgrade all
                      iob stop
                      iob fix
                      iob upgrade self
                      iob start
                        @thomas-braun @ilovegym
                        So alles erledigt und noch ein Diag gemacht
                                                v.2023-10-10
                                 Icon name: computer
                              Architecture: arm
                        Kernel:                 armv7l
                        Userland:               armhf
                        User-ID:                1000
                        X-Server:               false
                        Pending iob updates:    0
                                                /usr/bin/npm            9.8.1
                                                /usr/bin/npx            9.8.1
                        Recommended versions are nodejs 18.18.2 and npm 9.8.1
                        MEMORY:
                        Mem:            3.8G        1.4G        1.5G        6.0M        1.0G        2.3G
                        Swap:            99M          0B         99M
                        Total:          3.9G        1.4G        1.6G
                        ioBroker Core:          js-controller           5.0.16
                                                admin                   6.12.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                3548
                        States:                 3267
                        6.9M    /opt/iobroker/iobroker-data/objects.jsonl
                        1.1M    /opt/iobroker/iobroker-data/states.jsonl
                        Danke für die Codes
                        Thomas Braun ? 2 Replies Last reply Reply Quote 0
                          @dime
                          Ja, jetzt ist die Basis auf aktuellem Stand.
                            @dime
                            Jetzt mal den Unifi Adapter starten und das komplette log vom start bis zur Fehlermeldung posten, bitte..
                              @ilovegym
                              Geht klar
                              unifi.0
                              2023-11-16 16:13:58.862	info	terminating
                              unifi.0
                              2023-11-16 16:13:58.358	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              unifi.0
                              2023-11-16 16:13:58.357	debug	Plugin sentry destroyed
                              unifi.0
                              2023-11-16 16:13:58.355	info	terminating
                              unifi.0
                              2023-11-16 16:13:58.354	info	cleaned everything up...
                              unifi.0
                              2023-11-16 16:13:58.351	info	Got terminate signal TERMINATE_YOURSELF
                              unifi.0
                              2023-11-16 16:13:58.200	error	Adapter deactivated due to missing configuration.
                              unifi.0
                              2023-11-16 16:13:58.198	info	UniFi adapter is ready
                              unifi.0
                              2023-11-16 16:13:58.142	info	starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v18.18.2, js-controller: 5.0.16
                              unifi.0
                              2023-11-16 16:13:57.357	debug	Plugin sentry Initialize Plugin (enabled=true)
                              unifi.0
                              2023-11-16 16:13:57.269	debug	States connected to redis: 127.0.0.1:9000
                              unifi.0
                              2023-11-16 16:13:57.193	debug	States create User PubSub Client
                              unifi.0
                              2023-11-16 16:13:57.191	debug	States create System PubSub Client
                              unifi.0
                              2023-11-16 16:13:57.174	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                              unifi.0
                              2023-11-16 16:13:57.134	debug	Objects connected to redis: 127.0.0.1:9001
                              unifi.0
                              2023-11-16 16:13:57.122	debug	Objects client initialize lua scripts
                              unifi.0
                              2023-11-16 16:13:57.076	debug	Objects create User PubSub Client
                              unifi.0
                              2023-11-16 16:13:57.065	debug	Objects create System PubSub Client
                              unifi.0
                              2023-11-16 16:13:57.060	debug	Objects client ready ... initialize now
                              unifi.0
                              2023-11-16 16:13:56.985	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                Ich würde mal in die Einstellungen des Adapters schauen. Da fehlt offenbar irgendwas.
                                  Wie gesagt es wird ja noch im Readme auf das Nodemodul hingewiesen.
                                  Von den Einstellungen her sollte es passen
                                  Die UnifiController Version ist:
                                  Network Version 7.3.83 | Windows 10
                                    A Former User @DiMe last edited by A Former User
                                    @dime
                                    Nee, am Node-Unifi kann es nicht liegen, er kommt ja garnicht soweit, weil deine Konfiguration fehlerhaft ist..
                                    Schreib doch mal n username in die Konfiguration.. hilft ..
                                      @ilovegym
                                      Oh man,
                                      Admin ist mein Usename,
                                      der vorgegeben Benutzername "Admin" ist aber nicht "aktiv" Als ich ihn nochmals reingeschrieben habe, läuft er.
                                      @ilovegym @Thomas-Braun vielen lieben Dank für eure Unterstützung.
                                      Aber nichtsdestotrotz abe ich trotzdem etwas gelernt (Node-Update und Iobroker-Update)
                                      "kaum macht man's richtig, funktioniert's... 🙂 :-)" true
                                        A Former User last edited by
                                        @ilovegym
                                        Oh man,
                                        ja, das ist auch etwas verwirrend bei manchen Adaptern in der Konfig-Gui gemacht.. muss ich sagen..
                                        Was oft fehlt bei den Adaptern, ist ein richtiges Errorhandling, hier haette man das Fenster erst garnicht schliessen und die Konfig speichern duerfen, wenn der Login nicht geaendert wurde..
                                        Gerne, na, jetzt weisst du, wie das System aktuell zu halten ist, ich mach das einmal im Monat, hab da n festen Tag fuer Extra-Backup und Updates, so bleibt man aktuell.. und ja, den Spruch sag ich mir selbst auch immer mal wieder... 🙂
                                          @ilovegym
                                          Den Spruch habe ich mir von dir geklaut 😊
                                          • Meister Mopper
                                            Meister Mopper @DiMe last edited by
                                            Oh man,
                                            Tja, wie ich im zweiten Beitrag bereits schrieb. 🤷‍♂️
                                            1554
