Kein iobroker Backup mehr über BackitUp Adapter
gibt auch eine NAS auf die die Files bis auf das eine gehen. Influx ist nicht korrekt eingerichtet
@toki1973 sagte in Kein iobroker Backup mehr über BackitUp Adapter:
Sicherst du da in zwei Instanzen oder in einer? Wie wird das NAS eingebunden? Per CIFS? NFS? FTP? Sonst irgendwie?
Richtig.
Zeig man einen vollständigen Lauf eines Backups aus dem Debug-Fenster.
CIFS - Hier der Block in dem das ioBroker Backup erstellt wird:
[DEBUG] [mount] - noserverino option: false [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.0.100/NetBackup/Standard /opt/iobroker/backups" [DEBUG] [mount] - mount successfully completed [DEBUG] [mount] - done [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"14:15","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"ignoreErrors":true,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.0.51","port":"8086","dbversion":"1.x","token":"","protocol":"http","exe":"","dbType":"remote","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":true,"deleteDataBase":false},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":true},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"host":"192.168.0.51","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":10000,"hostName":"","ignoreErrors":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [iobroker] - host.iobrokerNUC1 89730 states saved [DEBUG] [iobroker] - host.iobrokerNUC1 116073 objects saved [DEBUG] [iobroker] - done
Dann das kopieren - Würde ein Fehler kommen falls die NAS voll ist? Ich schaue mal
[DEBUG] [cifs] - used copy path: /NetBackup/Standard [DEBUG] [cifs] - done [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":9,"wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
Das Debug-Log ist wesentlich länger.
"smb":"vers=1.0"
wird hoffentlich nicht mehr verwendet. Dreh das höher. Aktuell ist das 3.1.1.
Irgendwie kopiere ich mehr in die Code Tags rein als dann angezeigt wird?
Das weiß ich nicht.
IN dem lokalen iobroker Verzeichnis (/opt/iobroker/backups) wird das ioBroker Backup auch schon nicht erzeugt
Wenn per CIFS das Dateisystem eingehängt wird fungiert das Verzeichnis als Mountpunkt und ist dementsprechend leer, wenn das NAS gerade nicht gemountet ist.
Ich verstehe den Adapter so, das er erst lokal in /opt/iobroker/backups die Backups erzeugt und später dann kopiert. Ich sehe auch in diesem Ordenr die Erstellung von Zigbee, Javascipt und Grafana. Nur eine iobroker Backup Datei wird nicht erzeugt.
Jein. Das kommt darauf an, was da genau wie mit welchen Optionen gemacht wird.
Zeig mal deine Einstellungen. Zu NAS/Copy und zu googledrive. -
Danke für den Hinweis zu SMB 1.0 - werde ich dann auch mal ändernIn dem Log steht ganz am Ende das er die Objekte gespeichert hat
[[DEBUG] [mount] - noserverino option: false [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.0.100/NetBackup/Standard /opt/iobroker/backups" [DEBUG] [mount] - mount successfully completed [DEBUG] [mount] - done [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"14:15","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"ignoreErrors":true,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.0.51","port":"8086","dbversion":"1.x","token":"","protocol":"http","exe":"","dbType":"remote","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":true,"deleteDataBase":false},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":true},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"host":"192.168.0.51","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":10000,"hostName":"","ignoreErrors":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [iobroker] - host.iobrokerNUC1 89730 states saved [DEBUG] [iobroker] - host.iobrokerNUC1 116073 objects saved [DEBUG] [iobroker] - done
Hier sieht man, dass die Freigabe auf /opt/iobroker/backups eingehängt wird und da schreibt dann das Backup seine Dateien rein. Und von dort nimmt die googledrive-Abteilung auch die Dateien auf und schiebt die bei gdrive hoch. Und erst danach wird das Dateisystem 'umountet' und der Mountpunkt ist wieder leer. Bei dir läuft das aber wohl schief.
Deswegen nochmal einen vollständigen Lauf von Anfang bis Ende protokollieren.Und gib mal die Ausgabe von
iob diag
bekannt.
@toki1973 Du musst Influx richtig konfigurieren... Welche Influx Version nutzt du? Läuft sie lokal oder Remote?
https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#influxdb-backup
https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#abhängigkeiten -
Okay, schon klar.
Aber müsste nicht dann trotzdemjavascripts_2023_11_16-14_53_13_backupiobroker.tar.gz" not found
iobroker_2023_11_16-14_50_47_backupiobroker.tar.gz" not foundvorhanden sein?
@simatec Ja das hatte ich geschrieben das dass noch nicht richtig konfiguriert ist. Ich will sowieso iobroker und das debian neu aufsetzen.
iob diag mach ich auf dem alten System unter root lieber nicht - das wird dir nicht gefallenAber ich wollte das schöne Wetter nutzen um endlich mal alles sauber incl. Debian neu aufzusetzten - daher hätte ich gerne zuvor ein Backup
Das Zigbee,Java u.Grafana wird ja seltsamerweise auf die NAS kopiert.
Started iobroker ... [DEBUG] [mount] - mount activ... umount is started before mount!! [DEBUG] [mount] - umount successfully completed [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true} [DEBUG] [mount] - noserverino option: false [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.0.100/NetBackup/Standard /opt/iobroker/backups" [DEBUG] [mount] - mount successfully completed [DEBUG] [mount] - done [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:15","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"ignoreErrors":true,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":true},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"host":"192.168.0.51","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":10000,"hostName":"","ignoreErrors":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [iobroker] - host.iobrokerNUC1 89730 states saved [DEBUG] [iobroker] - host.iobrokerNUC1 116073 objects saved [DEBUG] [iobroker] - done [DEBUG] [zigbee] - found zigbee database: zigbee.0 [DEBUG] [zigbee] - done [DEBUG] [grafana] - Start Grafana Backup ... [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp" [DEBUG] [grafana] - Created dashboard directory [DEBUG] [grafana] - Created dashboards_manually_restore directory [DEBUG] [grafana] - Created datasource directory [DEBUG] [grafana] - start Grafana request ... [DEBUG] [grafana] - Grafana is available ... Status: 200 [DEBUG] [grafana] - found Dashboard: new-dashboard [DEBUG] [grafana] - found Dashboard: temperatur [DEBUG] [grafana] - found Dashboard: it [DEBUG] [grafana] - found Dashboard: power-dashboard [DEBUG] [grafana] - found Dashboard: energie [DEBUG] [grafana] - found Dashboard: new-dashboard-copy [DEBUG] [grafana] - found Dashboard: brenner [DEBUG] [grafana] - found Dashboard: b15 [DEBUG] [grafana] - found Dashboard: heizung [DEBUG] [grafana] - found Dashboard: pool-uns-sauna [DEBUG] [grafana] - found Dashboard: wasser [DEBUG] [grafana] - found Dashboard: unifi-ap-dashboard [DEBUG] [grafana] - found Dashboard: proxmox-ve-home [DEBUG] [grafana] - found Dashboard: proxmox [DEBUG] [grafana] - found Dashboard: power-meter [DEBUG] [grafana] - start Grafana backup compress ... [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2023_11_16-16_29_40_backupiobroker.tar.gz [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp" [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted [DEBUG] [grafana] - done [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts" [DEBUG] [javascripts] - found Script: AdapterStatus [DEBUG] [javascripts] - found Script: Aktionen [DEBUG] [javascripts] - found Script: AlexaAbfrage [DEBUG] [javascripts] - found Script: Garage1 [DEBUG] [javascripts] - found Script: Beleuchtung_2 [DEBUG] [javascripts] - found Script: Bewegung [DEBUG] [javascripts] - found Script: Briefkasten [DEBUG] [javascripts] - found Script: CalendarWidget [DEBUG] [javascripts] - found Script: Fenster [DEBUG] [javascripts] - found Script: Gaszähler [DEBUG] [javascripts] - found Script: Heizung [DEBUG] [javascripts] - found Script: HeizungThermostat_NEU [DEBUG] [javascripts] - found Script: Heizung_Thermostat [DEBUG] [javascripts] - found Script: Heizungssteuerungsscript [DEBUG] [javascripts] - found Script: Klingel [DEBUG] [javascripts] - found Script: Kontakte_Check [DEBUG] [javascripts] - found Script: Muelleimer [DEBUG] [javascripts] - found Script: PV_Laden [DEBUG] [javascripts] - found Script: Pool [DEBUG] [javascripts] - found Script: RainSensor [DEBUG] [javascripts] - found Script: Rasenmäher [DEBUG] [javascripts] - found Script: Schalter_Licht [DEBUG] [javascripts] - found Script: StromZähler [DEBUG] [javascripts] - found Script: StromZähler1 [DEBUG] [javascripts] - found Script: TauchPumpe [DEBUG] [javascripts] - found Script: TestWiese [DEBUG] [javascripts] - found Script: Trockner [DEBUG] [javascripts] - found Script: Tueren [DEBUG] [javascripts] - found Script: UniFi [DEBUG] [javascripts] - found Script: Waschmaschine_fertig [DEBUG] [javascripts] - found Script: lightcontroll [DEBUG] [javascripts] - found Script: zigbee_State [DEBUG] [javascripts] - found Script: WasserSensor [DEBUG] [javascripts] - found Script: CO2 [DEBUG] [javascripts] - found Script: vis-materialdesign0 [DEBUG] [javascripts] - found Script: Hue_Polling [DEBUG] [javascripts] - found Script: Fuellstand [DEBUG] [javascripts] - found Script: SungrowWR [DEBUG] [javascripts] - found Script: Sauna_Pool [DEBUG] [javascripts] - found Script: WallboxÜberschuss [DEBUG] [javascripts] - found Script: WallboxUeberschuss [DEBUG] [javascripts] - found Script: Beleuchtung_HUE [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts" [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_16-16_29_46_backupiobroker.tar.gz [DEBUG] [javascripts] - done [DEBUG] [cifs] - used copy path: /NetBackup/Standard [DEBUG] [cifs] - done [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0} [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/iobroker_2023_11_16-16_28_33_backupiobroker.tar.gz" not found [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2023_11_16-16_29_38_backupiobroker.tar.gz... [DEBUG] [googledrive] start with {"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true,"deleteBackupAfter":0} [DEBUG] [googledrive] - Google Drive: Copy grafana_2023_11_16-16_29_40_backupiobroker.tar.gz... [DEBUG] [googledrive] - Google Drive: Copy javascripts_2023_11_16-16_29_46_backupiobroker.tar.gz... [DEBUG] [googledrive] - done [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors. [DEBUG] [clean] - done [DEBUG] [telegram] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:15","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_11_16-16_28_33_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2023_11_16-16_29_38_backupiobroker.tar.gz","/opt/iobroker/backups/grafana_2023_11_16-16_29_40_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2023_11_16-16_29_46_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["umount","mount","iobroker","zigbee.0","grafana","javascripts","googledrive"],"types":["iobroker","zigbee.0","grafana","javascripts"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"ignoreErrors":true,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":true},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"host":"192.168.0.51","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":10000,"hostName":"","ignoreErrors":true,"systemLang":"de","time":"16. November 2023 um 16:29 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]} [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0 [DEBUG] [telegram] - done [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:15","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_11_16-16_28_33_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2023_11_16-16_29_38_backupiobroker.tar.gz","/opt/iobroker/backups/grafana_2023_11_16-16_29_40_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2023_11_16-16_29_46_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["umount","mount","iobroker","zigbee.0","grafana","javascripts","googledrive"],"types":["iobroker","zigbee.0","grafana","javascripts"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"ignoreErrors":true,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":true},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"host":"192.168.0.51","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de","time":"16. November 2023 um 16:30 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":10000,"hostName":"","ignoreErrors":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]} [DEBUG] [historyHTML] - new history html values created [DEBUG] [historyHTML] - done [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:15","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_11_16-16_28_33_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2023_11_16-16_29_38_backupiobroker.tar.gz","/opt/iobroker/backups/grafana_2023_11_16-16_29_40_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2023_11_16-16_29_46_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["umount","mount","iobroker","zigbee.0","grafana","javascripts","googledrive"],"types":["iobroker","zigbee.0","grafana","javascripts"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"ignoreErrors":true,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":true},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":true},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":true},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":true},"googledrive":{"enabled":true,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":true},"host":"192.168.0.51","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":true,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"10","ignoreErrors":true,"systemLang":"de","time":"16. November 2023 um 16:30 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":10000,"hostName":"","ignoreErrors":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":true,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]} [DEBUG] [historyJSON] - new history json values created [DEBUG] [historyJSON] - done [DEBUG] [umount] - mount activ, umount is started ... [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NetBackup/Standard","dirMinimal":"NetBackup/Standard","user":"backup","pass":"****","ignoreErrors":true,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]} [DEBUG] [umount] - umount successfully completed [DEBUG] [umount] - done [EXIT] 0
NAS:
@toki1973 sagte in Kein iobroker Backup mehr über BackitUp Adapter:
"smb":"vers=1.0"
Vermutlich (hoffentlich) zu alt. Stell das mal auf 3.
Daran lag es leider nicht
@toki1973 Sicherlich hast du unabsichtlich die Bemühungen von @Thomas-Braun mit einem Downvote versehen
