    4. ioBroker.Unifi verbindet nicht (Erstinstallation)
      A Former User @DiMe last edited by
      @dime
      Jetzt mal den Unifi Adapter starten und das komplette log vom start bis zur Fehlermeldung posten, bitte..
        DiMe @Guest last edited by
        @ilovegym
        Geht klar
        unifi.0
        2023-11-16 16:13:58.862	info	terminating
        unifi.0
        2023-11-16 16:13:58.358	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        unifi.0
        2023-11-16 16:13:58.357	debug	Plugin sentry destroyed
        unifi.0
        2023-11-16 16:13:58.355	info	terminating
        unifi.0
        2023-11-16 16:13:58.354	info	cleaned everything up...
        unifi.0
        2023-11-16 16:13:58.351	info	Got terminate signal TERMINATE_YOURSELF
        unifi.0
        2023-11-16 16:13:58.200	error	Adapter deactivated due to missing configuration.
        unifi.0
        2023-11-16 16:13:58.198	info	UniFi adapter is ready
        unifi.0
        2023-11-16 16:13:58.142	info	starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v18.18.2, js-controller: 5.0.16
        unifi.0
        2023-11-16 16:13:57.357	debug	Plugin sentry Initialize Plugin (enabled=true)
        unifi.0
        2023-11-16 16:13:57.269	debug	States connected to redis: 127.0.0.1:9000
        unifi.0
        2023-11-16 16:13:57.193	debug	States create User PubSub Client
        unifi.0
        2023-11-16 16:13:57.191	debug	States create System PubSub Client
        unifi.0
        2023-11-16 16:13:57.174	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        unifi.0
        2023-11-16 16:13:57.134	debug	Objects connected to redis: 127.0.0.1:9001
        unifi.0
        2023-11-16 16:13:57.122	debug	Objects client initialize lua scripts
        unifi.0
        2023-11-16 16:13:57.076	debug	Objects create User PubSub Client
        unifi.0
        2023-11-16 16:13:57.065	debug	Objects create System PubSub Client
        unifi.0
        2023-11-16 16:13:57.060	debug	Objects client ready ... initialize now
        unifi.0
        2023-11-16 16:13:56.985	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          Thomas Braun Most Active @DiMe last edited by
          @dime sagte in ioBroker.Unifi verbindet nicht (Erstinstallation):
          Ich würde mal in die Einstellungen des Adapters schauen. Da fehlt offenbar irgendwas.
            DiMe @Thomas Braun last edited by DiMe
            Wie gesagt es wird ja noch im Readme auf das Nodemodul hingewiesen.
            Von den Einstellungen her sollte es passen
            Die UnifiController Version ist:
            Network Version 7.3.83 | Windows 10
              A Former User @DiMe last edited by A Former User
              @dime
              Nee, am Node-Unifi kann es nicht liegen, er kommt ja garnicht soweit, weil deine Konfiguration fehlerhaft ist..
              Schreib doch mal n username in die Konfiguration.. hilft ..
                DiMe @Guest last edited by DiMe
                @ilovegym
                Oh man,
                Admin ist mein Usename,
                der vorgegeben Benutzername "Admin" ist aber nicht "aktiv" Als ich ihn nochmals reingeschrieben habe, läuft er.
                @ilovegym @Thomas-Braun vielen lieben Dank für eure Unterstützung.
                Aber nichtsdestotrotz abe ich trotzdem etwas gelernt (Node-Update und Iobroker-Update)
                "kaum macht man's richtig, funktioniert's... 🙂 :-)" true
                  A Former User last edited by
                  @ilovegym
                  Oh man,
                  ja, das ist auch etwas verwirrend bei manchen Adaptern in der Konfig-Gui gemacht.. muss ich sagen..
                  Was oft fehlt bei den Adaptern, ist ein richtiges Errorhandling, hier haette man das Fenster erst garnicht schliessen und die Konfig speichern duerfen, wenn der Login nicht geaendert wurde..
                  Gerne, na, jetzt weisst du, wie das System aktuell zu halten ist, ich mach das einmal im Monat, hab da n festen Tag fuer Extra-Backup und Updates, so bleibt man aktuell.. und ja, den Spruch sag ich mir selbst auch immer mal wieder... 🙂
                    @ilovegym
                    Den Spruch habe ich mir von dir geklaut 😊
                    • Meister Mopper
                      Meister Mopper @DiMe last edited by
                      Oh man,
                      Tja, wie ich im zweiten Beitrag bereits schrieb. 🤷‍♂️
                        DiMe @Meister Mopper last edited by DiMe
                        @meister-mopper
                        ja da hast du recht! Danke auch dir!!!
                        Aber arg viel Ausgegraut ist wirklich nicht, aber sehr gut erkannt. Shame on me😧
                        Immerhin ist jetzt mein Iobroker auf neusten Stand, und ich habe etwas dazugelernt.
                        Habe noch meine Eröffnung ergänzt.
                        1554
