    4. VIS von Sigi234
    VIS von Sigi234
      sigi234 Forum Testing Most Active @Sushibomba last edited by
      @sushibomba
      Schrift kleiner machen
        Sushibomba @sigi234 last edited by
        @sigi234
        Aber dann kann man ja nichts mehr lesen auf dem Tablet an der Wand.
        Ist es nicht möglich die Größe des kompletten Fensters zu vergrößern einfach. Also 100% anzeigen bei Klick?
          @sushibomba
          Stell das Widget mal rein
            @sigi234
            [{"tpl":"tplMaListWindowShutter","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showTitle":true,"onlyTitle":false,"titleSize":" medium","widgetBackground":"","TextColor":"white","subtitleSize":"x-small","valueAlign":"left","valueVertical":"center","opacityColor":"white","inverted":true,"borderRadius":"10","showIcon":true,"centerIcon":true,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"alias.0.Rolladensteuerung.Rollo_WZ_RECHTS","border":false,"title":"WZ R. ","subtitle":"","valueSize":" medium","valueAsSubtitle":false,"borderColor":"white","useOverallRoundedValues":"checked","roundLeftUp":"10","roundLeftBottom":"0","roundRightUp":"0","roundRightBottom":"10","boxShadow":"unchecked","shadowWidth":"2","readOnly":true},"style":{"left":"1460px","top":"117px","z-index":"1","width":"275px","height":"58px","line-height":"","text-align":"center","font-style":"normal","font-variant":"","color":"#ffb900","font-weight":"","font-size":"0px"},"widgetSet":"vis-material-advanced"}]
              @sushibomba
              Ist das das Select Widget?
                @sigi234
                vis-material-advanced und das listWindowShutter widget
                  @sigi234 Hast du meine Nachricht überlesen? 😰
                    @sushibomba sagte in VIS von Sigi234:
                    Nein Herz OP
                      Andronid @sigi234 last edited by
                      @sigi234 schade, aber nicht zu ändern.
                      Noch eine andere Frage. Hast du auch eine Übersicht über Rollläden? Ich hoffe, dass ich nichts übersehen habe.
                        @sigi234
                        Oh ok. ich hoffe sie ist gut verlaufen!? 🙏
                          Gehts dir wieder besser @sigi234 ?
                            Ja geht so. Danke. Bin noch schlapp.
                              @sigi234
                              Ohhh nicht schön dann gute Besserung weiterhin.
                              Fühlst du dich denn trotzdem in der Lage meine Frage oben zu beantworten? Wäre echt klasse damit ich die Rollladensteuerung endlich nutzen kann auf dem Tablet. Vielen Dank.
                                @sushibomba
                                Zeig mir noch mal was du genau willst.
                                  Sushibomba @Sushibomba last edited by Sushibomba
                                  @sigi234
                                  Kannst du mir sagen wie ich die komplette Dropdownliste auf meinem Tablet sichtbar bekommen wenn ich drauf klicke?
                                  DU hattest selbst mal wegen der Lösung gefragt.
                                  @sigi234
                                  Und noch das Widget als Code:
                                    @sushibomba
                                    Schau ich mir mal an, haben immer wieder Stromausfall
                                      @sigi234
                                      Ok super. Ich danke dir recht herzlich vorab und wünsche dir einen schönen 1.ten Advent
                                        @sigi234
                                        vis-material-advanced funktioniert nicht mehr richtig.
                                          @sigi234
                                          Und welches Widget kannst du mir als Alternative vorschlagen wo das mit dem scrollen auf dem Tablet funktioniert?
                                            @sigi234
                                            Was möchtest du genau?
                                            ode abfrage vis vis projekte
                                            151
                                            1344
                                            596201
