    4. BackUp Restore funktioniert nicht mehr
      dpt last edited by
      @Bluefox:
      Wie sieht deine iobroker-data/iobroker.json Datei aus? `
        "system": {
          "memoryLimitMB": 0,
          "hostname": ""
        "network": {
          "IPv4": true,
          "IPv6": true,
          "bindAddress": null,
          "useSystemNpm": true
        "objects": {
          "type": "file",
          "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
          "host": "127.0.0.1",
          "port": 9001,
          "user": "",
          "pass": "",
          "noFileCache": false,
          "connectTimeout": 2000,
          "dataDir": "../../iobroker-data/"
        "states": {
          "type": "redis",
          "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
          "port": 6379,
          "maxQueue": 1000,
          "options": {
            "auth_pass": null,
            "retry_max_delay": 15000
        "log": {
          "level": "info",
          "maxDays": 7,
          "noStdout": true,
          "transport": {
            "file1": {
              "type": "file",
              "enabled": true,
              "filename": "log/iobroker",
              "fileext": ".log",
              "maxsize": null,
              "maxFiles": null
            "syslog1": {
              "type": "syslog",
              "enabled": false,
              "host": "localhost",
              "host_comment": "The host running syslogd, defaults to localhost.",
              "port_comment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
              "protocol": "udp4",
              "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
              "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
              "facility_comment": "Syslog facility to use (Default: local0).",
              "localhost": "iobroker",
              "localhost_comment": "Host to indicate that log messages are coming from (Default: localhost).",
              "sysLogType_comment": "The type of the syslog protocol to use (Default: BSD).",
              "app_name_comment": "The name of the application (Default: process.title).",
              "eol_comment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
        "dataDirComment": "Always relative to iobroker.js-controller/",
      • Bluefox
        Bluefox last edited by
        Ist from redis da?
          dpt last edited by
          @Bluefox:
          Ist from redis da? `
          Blöde Frage,
          wie meinst das?
          "sudo apt-get install redis-server" ?
          erledigt, jetzt geht es 😉
          Dominik
            dpt last edited by
            @dpt:
            erledigt, jetzt geht es 😉 `
            zu früh die Freude
            Log:
            host.nas	2017-11-20 14:57:11.937	info	States connected to redis: 127.0.0.1:6379
            host.nas	2017-11-20 14:57:08.826	info	Adapter admin still running
            host.nas	2017-11-20 14:57:08.825	info	force terminating
            host.nas	2017-11-20 14:57:05.051	info	received SIGTERM
            host.nas	2017-11-20 14:57:03.789	error	Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-co
            host.nas	2017-11-20 14:57:00.040	info	received SIGTERM
            admin.0	2017-11-20 14:56:59.849	warn	Reconnection to DB.
            admin.0	2017-11-20 14:56:59.743	warn	Reconnection to DB.
            Das ist hartnäckig
              dpt last edited by
              @dpt:
              @dpt:
              zu früh die Freude
              Log:
              Das ist hartnäckig `
              jetzt habe ich die Schreibrechte angepasst
              sudo chmod -R 777 /opt/iobroker
              jetzt kommen andere Fehlermeldungen, langsam habe ich das Gefühl, es liegt an mir :roll:
              TypeError:	2017-11-20 16:09:25.995	error	at Timer.listOnTimeout (timers.js:92:15)
              TypeError:	2017-11-20 16:09:25.995	error	at ontimeout (timers.js:195:34)
              TypeError:	2017-11-20 16:09:25.995	error	at null. (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1603:25)
              TypeError:	2017-11-20 16:09:25.995	error	at startInstance (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1952:41)
              TypeError:	2017-11-20 16:09:25.995	error	Cannot read property 'on' of null
              uncaught	2017-11-20 16:09:25.990	error	exception: Cannot read property 'on' of null
              host.nas	2017-11-20 16:09:25.957	info	starting 2 instances
              host.nas	2017-11-20 16:09:25.932	info	23 instances found
              host.nas	2017-11-20 16:09:25.900	info	InMemoryDB connected
              host.nas	2017-11-20 16:09:25.880	info	inMem-objects listening on port 9001
              host.nas	2017-11-20 16:09:25.549	info	ip addresses: 192.168.1.16 2a02:1205:c6a0:3000:5054:ff:fe26:e93d fe80::5054:ff:fe26:e93d
              host.nas	2017-11-20 16:09:25.547	info	hostname: nas, node: v4.8.6
              host.nas	2017-11-20 16:09:25.546	info	Copyright (c) 2014-2017 bluefox, 2014 hobbyquaker
              host.nas	2017-11-20 16:09:25.536	info	iobroker.js-controller version 1.2.1 js-controller starting
              Adapter	2017-11-20 16:09:23.084	info	admin still running
              host.nas	2017-11-20 16:09:23.083	info	force terminating
              host.nas	2017-11-20 16:09:19.266	info	received SIGTERM
              host.nas	2017-11-20 16:09:14.694	info	"system.adapter.cloud.0" enabled
              host.nas	2017-11-20 16:09:14.694	info	object change system.adapter.cloud.0
              admin.0	2017-11-20 16:09:14.627	warn	Reconnection to DB.
              admin.0	2017-11-20 16:09:14.582	warn	Reconnection to DB.
              host.nas	2017-11-20 16:09:14.260	info	received SIGTERM
              iobroker	2017-11-20 16:09:13.907	info	exit 0
              iobroker	2017-11-20 16:09:13.881	info	Starting node restart.js
              host.nas	2017-11-20 16:09:13.119	info	States connected to redis: 127.0.0.1:6379
              iobroker	2017-11-20 16:09:13.069	info	_restart
              soll ich ein neues Thema aufmachen? wäre dies hilfreicher?
                sveni_lee last edited by
                @dpt:
                jetzt kommen andere Fehlermeldungen, langsam habe ich das Gefühl, es liegt an mir :roll: `
                Ich glaube nicht das es an Dir liegt, ich bekomme iobroker auch seit 3 Tagen nicht mehr ans laufen…
                  @dpt:
                  jetzt kommen andere Fehlermeldungen `
                  Ist dein Backup von der Installation auf dem NAS gewesen oder kommt das von ganz woanders her?
                  Rainer
                    dpt last edited by
                    @Homoran:
                    @dpt:
                    jetzt kommen andere Fehlermeldungen Ist dein Backup von der Installation auf dem NAS gewesen oder kommt das von ganz woanders her?
                    System, vor dem Backup lief auf einem Rasp, wi ich der verdacht habe das sich die Karte langsam….. daher wechsel auf das Nas.
                      Und da war die Hardware natürlich ganz anders 😉
                      Hast du nach demiobroker restoreund vor demioBroker starteinmal````
                      iobroker host this
                      Hast du vor dem````
                      iobroker start
                      ````einmal die reinstall.sh ausgeführt um die ganzen Pakete für die neue Hardware zu kompilieren?
                      Rainer
                        dpt last edited by
                        @Homoran:
                        einmal````
                        iobroker host this
                        Hast du vor dem````
                        iobroker start
                        ````einmal die reinstall.sh ausgeführt um die ganzen Pakete für die neue Hardware zu kompilieren? `
                        Denn hatte ich nicht 😉
                        wenn ich jetzt
                        sudo iobroker stop
                        läuft er weiter, ziehe kurz ein neues System rauf, Vorteil von Virtualstadion mit Datensicherungen 😉
                          dpt last edited by
                          @dpt:
                          läuft er weiter, ziehe kurz ein neues System rauf, Vorteil von Virtualstadion mit Datensicherungen 😉 `
                          zietiere mich mal wieder selbst :roll:
                          habe mehrere Sachen getestet
                          kritisch wird es nach dem
                          cd /opt/iobroker
                          npm i https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
                          aber ohne dies kann ich die Restore nicht einspielen.
                          nach diesem, ist das System unstabil und ich kann auch ohne "iobroker restore", keine Adapter mehr installieren, es kommt auch immer wieder das "Zahnrad" im Webbrowser, was vorher fast nie kommt.
                            Vor der Neuinstallation des js-controllers stoppst du iobroker aber doch?
                              dpt last edited by
                              @Homoran:
                              Vor der Neuinstallation des js-controllers stoppst du iobroker aber doch? `
                              ja, eigentlich immer, wenn ich via Komandozeile arbeite
                              versuch es sicherheitshalber nochmals
                                dpt last edited by
                                @dpt:
                                versuch es sicherheitshalber nochmals `
                                nochmals versucht:
                                erst 2-3 Adapter installiert, ohne Probleme
                                danach
                                sudo iobroker stop  "getestet ob er wirklich stopt"
                                cd /opt/iobroker
                                danach wieder Problem wie oben beschrieben
                                Qnap Virtualization Stadion 3
                                System Ubuntu "server-version" 16.04.3 mit "normalem" Kernel
                                node 4.8.6
                                installiert nach der Anleitung http://www.iobroker.net/docu/?page_id=5634&lang=de & noch npm installiert
                                  Kann es sein, dass deine vm damit beschäftigt ist die Module neu zu kompilieren.
                                  Auf einem pi3 oder tinkerboard hat das zwei Stunden gefauert.
                                  Welches nas mit welcher cpu hast du denn?
                                  Rainer
                                    dpt last edited by
                                    @Homoran:
                                    Welches nas mit welcher cpu hast du denn? `
                                    Danke, wird gestestet
                                    Qnap 453A
                                    https://www.qnap.com/en/product/ts-453a
                                    VM 1GB Ram und i7 eingestellt
                                    das Module komplimieren, geht erst nach dem Start?
                                      @dpt:
                                      das Module komplimieren, geht erst nach dem Start? `
                                      Ich glaube das geht nach dem restore erst dem darauffolgenden start los.
                                      Sieht man aber im log.
                                      In etwa
                                      Tried to start Adapter xy
                                      Not possible
                                      Install adapter xy
                                      Usw.
                                      Gruß Rainer
                                        dpt last edited by
                                        @Homoran:
                                        @dpt:
                                        In etwa
                                        Not possible
                                        Install adapter xy `
                                        hier einer meiner Log, als Anhang da er sonst zu gross wäre
                                        3100_log.txt
                                          Immer wieder
                                          Da muss mal ein Linux freak ran
                                          Gruß Rainer
                                            jensus11 last edited by
                                            wie ist denn der Befehl um die reinstall.sh laufen zu lassen?
                                            84
                                            16657
