    3. Entwicklung
    4. Emby 1.0.0, startet immer wieder neu...
      madison @mcm1957 last edited by
      @mcm57 kein Problem.
      wenn ich was testen soll einfach Bescheid geben.
      sonst kann ich leider nicht viel beitragen.
        A Former User @madison last edited by
        Der Entwickler hat nachdem ich ein Debug Log geschickt habe, einen ungetesteten Fix bereitgestellt: https://github.com/thewhobox/ioBroker.emby
          madison @Guest last edited by
          @apachelance habs getestet.
          host.iobroker-test
          2023-11-17 18:20:17.762	error	instance system.adapter.emby.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          emby.0
          2023-11-17 18:20:17.135	error	undefined is not a valid state value
          emby.0
          2023-11-17 18:20:17.134	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5448:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5409:21) at W3CWebSocket.webMessage [as onmessage] (/opt/iobroker/node_modules/iobroker.emby/main.js:376:25) at W3CWebSocket._dispatchEvent [as dispatchEvent] (/opt/iobroker/node_modules/yaeti/lib/EventTarget.js:107:17) at W3CWebSocket.onMessage (/opt/iobroker/node_modules/websocket/lib/W3CWebSocket.js:234:14) at WebSocketConnection.<anonymous> (/opt/iobroker/node_modules/websocket/lib/W3CWebSocket.js:205:19) at WebSocketConnection.emit (node:events:517:28) at WebSocketConnection.processFrame (/opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:554:26) at /opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:323:40
          emby.0
          2023-11-17 18:20:17.134	error	unhandled promise rejection: undefined is not a valid state value
          emby.0
          2023-11-17 18:20:17.134	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          emby.0
          2023-11-17 18:20:17.133	error	undefined is not a valid state value
          emby.0
          2023-11-17 18:20:17.133	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5448:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5409:21) at W3CWebSocket.webMessage [as onmessage] (/opt/iobroker/node_modules/iobroker.emby/main.js:375:25) at W3CWebSocket._dispatchEvent [as dispatchEvent] (/opt/iobroker/node_modules/yaeti/lib/EventTarget.js:107:17) at W3CWebSocket.onMessage (/opt/iobroker/node_modules/websocket/lib/W3CWebSocket.js:234:14) at WebSocketConnection.<anonymous> (/opt/iobroker/node_modules/websocket/lib/W3CWebSocket.js:205:19) at WebSocketConnection.emit (node:events:517:28) at WebSocketConnection.processFrame (/opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:554:26) at /opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:323:40
          emby.0
          2023-11-17 18:20:17.133	error	unhandled promise rejection: undefined is not a valid state value
          emby.0
          2023-11-17 18:20:17.132	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          emby.0
          2023-11-17 18:20:17.131	error	undefined is not a valid state value
          emby.0
          2023-11-17 18:20:17.131	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5448:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5409:21) at W3CWebSocket.webMessage [as onmessage] (/opt/iobroker/node_modules/iobroker.emby/main.js:372:25) at W3CWebSocket._dispatchEvent [as dispatchEvent] (/opt/iobroker/node_modules/yaeti/lib/EventTarget.js:107:17) at W3CWebSocket.onMessage (/opt/iobroker/node_modules/websocket/lib/W3CWebSocket.js:234:14) at WebSocketConnection.<anonymous> (/opt/iobroker/node_modules/websocket/lib/W3CWebSocket.js:205:19) at WebSocketConnection.emit (node:events:517:28) at WebSocketConnection.processFrame (/opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:554:26) at /opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:323:40
          emby.0
          2023-11-17 18:20:17.128	error	unhandled promise rejection: undefined is not a valid state value
          emby.0
          2023-11-17 18:20:17.128	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            @madison Sicher, dass du die aktuelle Version hast. Bei mir gibts die Abstürze nicht mehr. Nur noch:
            emby.0
            2023-11-17 18:25:54.975	warn	State "emby.0.b9780d9d3b7bde77c4302e70f3cfe10c.info.userName" has no existing object, this might lead to an error in future versions
            emby.0
            2023-11-17 18:25:54.974	warn	State "emby.0.b9780d9d3b7bde77c4302e70f3cfe10c.info.deviceName" has no existing object, this might lead to an error in future versions
            emby.0
            2023-11-17 18:25:54.917	warn	This object will not be created in future versions. Please report this to the developer.
            emby.0
            2023-11-17 18:25:54.917	warn	Object emby.0.0625f91c9e5aa817d97f3c2df711452c.command.togglemute is invalid: obj.common.type has an invalid value (button) but has to be one of number, string, boolean, array, object, mixed, file, json
            emby.0
            emby.0
            2023-11-17 18:25:54.916	warn	Object emby.0.0625f91c9e5aa817d97f3c2df711452c.command.mute is invalid: obj.common.type has an invalid value (button) but has to be one of number, string, boolean, array, object, mixed, file, json
              @apachelance hab jetzt den Adapter neu installiert, jetzt hab ich die selben Warnings wie du!
                @madison sagte in Emby 1.0.0, startet immer wieder neu...:
                Scheint trotzdem nicht stabil zu sein. Hatte gerade einen Crash:
                host.ioBroker
                2023-11-17 19:38:50.979	warn	Do not restart adapter system.adapter.emby.0 because restart loop detected
                host.ioBroker
                2023-11-17 19:38:50.978	info	Restart adapter system.adapter.emby.0 because enabled
                host.ioBroker
                2023-11-17 19:38:50.978	error	instance system.adapter.emby.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                emby.0
                2023-11-17 19:38:50.942	warn	get state error: Connection is closed.
                emby.0
                2023-11-17 19:38:50.935	info	terminating
                emby.0
                2023-11-17 19:38:50.433	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                mcm1957 M 2 Replies Last reply Reply Quote 0
                • mcm1957
                  mcm1957 @Guest last edited by mcm1957
                  @apachelance
                  Ich habe auf Guithub ein Issue erstellt mit der Bitte an den Dev eine neue saubere Release zu erstellen:
                  https://github.com/thewhobox/ioBroker.emby/issues/24
                  Derzeit passen die versionsangaben absolut nicht zusammen:
                  • package.json states 1.0.5
                  • io-package.json states 1.0.3
                  • npm lists 1.02
                  Weiters sollten die Abhängigkeiten aktualisisert werden. Der Adapter verwendet adapter-sore 1.x.x - aktuell ist 3.0.3. Das wird sicher in Zukunft auch zu Problemen führen.
                  Falls Maintzainer hier mitliest - bitte im Bedarfsfall nachfragen. Ich und andere helfen gern wenn was unkalr ist.
                  mcm1957
                  mcm1957 created this issue in thewhobox/ioBroker.emby
                  closed Please consider a new release and updating dependencies #24
                    A Former User @mcm1957 last edited by
                    @mcm57 Danke.
                    Hatte ich auch schon: https://github.com/thewhobox/ioBroker.emby/issues/23
                    Wurde vom Entwickler jedoch heute geschlossen.
                    apachelance created this issue in thewhobox/ioBroker.emby
                    closed Undefined error in ioBroker #23
                      @apachelance bisher noch kein Absturz bei mir
                      • mcm1957
                        @apachelance
                        Bei deinem Issue gings um den Crash. Das hat ja zuerst gut ausgesehen.
                        Mein Issue bezieht sich primär mal auf den Releaseablauf. Da der Adapter in latest und stable repository gelistet ist, sollten neue Versionen auch sauber veröffentlicht werden. Würde ungern einen Adapter wegen organisatorischer Abläufe rausnehmen. Daher main Angebot an den Entwickler hier gerne zu helfen, ggF auch mit PR(s).
                        • mcm1957
                          Ich habe den Adapter ioBroker.emby nun in den iobroker-community-adapters Bereich verschoben, die notwendigen Anpassungen vorgenommen und eine neue Release gebaut.
                          Ab morgen steht 1.1.1 im Latest zur Verfügung.
                          Zum Tester Thread gehts da:
                          https://forum.iobroker.net/topic/70397/test-adapter-emby-moved-to-community-adapters
                          DANKE an @thewhobox für seine Fehlerbehebungen und die Freigabe des Adapters sowie das Angebot auch weiterhin bei der Wartung aktiv zu sein soweit es ohne passende Hardwar möglich ist.
                          emby neustart
                          6242
