    4. Iobroker nicht mehr erreichbar - Firewall?
      line @Thomas Braun last edited by
      @thomas-braun ok gelöscht. Danke
      Iobroker neu gestartet, geht aber immer noch nicht. Soll ich nochmals versuchen. Aber was neues wird er hier nicht anzeigen
      iob diag
        Thomas Braun Most Active @line last edited by
        @line
        Lass nochmal sehen...
          line @Thomas Braun last edited by line
          @thomas-braun anbei
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           18:26:56 up  5:39,  3 users,  load average: 2.37, 2.24, 2.15
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          *** Time and Time Zones ***
                         Local time: Fri 2023-11-17 18:26:56 CET
                     Universal time: Fri 2023-11-17 17:26:56 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          feline
          /home/feline
          feline adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          /home/iobroker/.diag.sh: line 200: [[: 678
          4373: syntax error in expression (error token is "4373")
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        1.3G        4.2G         80M        2.3G        6.3G
          Swap:            99M          0B         99M
          Total:          7.9G        1.3G        4.3G
                   7812 M total memory
                   1251 M used memory
                   1910 M active memory
                   1298 M inactive memory
                   4232 M free memory
                    254 M buffer memory
                   2073 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
            UNIT             LOAD   ACTIVE SUB    DESCRIPTION
          * iobroker.service loaded failed failed ioBroker Server
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G   20G  8.3G  71% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G   29M  3.8G   1% /dev/shm
          tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     782M   28K  782M   1% /run/user/1000
          tmpfs          tmpfs     782M   28K  782M   1% /run/user/1002
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.5G    /var/
          3.1G    /var/log
          2.9G    /var/log/journal/378e881158e14149bc4f8e6771c6d1d7
          205M    /var/cache
          Archived and active journals take up 2.8G in the file system.
          /opt/iobroker/backups:
          230M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          384M    /opt/iobroker/iobroker-data/
          310M    /opt/iobroker/iobroker-data/files
          52M     /opt/iobroker/iobroker-data/files/javascript.admin
          51M     /opt/iobroker/iobroker-data/backup-objects
          45M     /opt/iobroker/iobroker-data/files/devices.admin/static
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
          11M     /opt/iobroker/iobroker-data/objects.jsonl
          8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          iobroker is not running on this host.
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.16
          admin:          6.12.0
          javascript:     7.1.4
          Adapters from github:   8
          Adapter State
            system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.178.69, run as: admin
            system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
            system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi                              - disabled
            system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
            system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
            system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
            system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
            system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
            system.adapter.history.0                : history               : raspberrypi                              -  enabled
            system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
            system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
            system.adapter.mediola-gateway.0        : mediola-gateway       : raspberrypi                              -  enabled
            system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
            system.adapter.modbus.0                 : modbus                : raspberrypi                              - disabled
            system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1883
            system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
            system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
            system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
            system.adapter.parser.0                 : parser                : raspberrypi                              - disabled
            system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
            system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
            system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
            system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
            system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
            system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.solaredge.0              : solaredge             : raspberrypi                              - disabled
            system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
            system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
            system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
            system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.69, run as: admin
            system.adapter.webcal.0                 : webcal                : raspberrypi                              -  enabled
            system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
          Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
          Adapter    "ble"          : 0.13.4   , installed 0.13.4
          Adapter    "bshb"         : 0.2.4    , installed 0.2.4
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "denon"        : 1.15.4   , installed 1.15.4
          Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
          Adapter    "evcc"         : 0.0.10   , installed 0.0.10
          Adapter    "fullybrowser" : 2.2.0    , installed 2.2.0
          Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
          Adapter    "homekit-controller": 0.5.8, installed 0.5.8
          Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.16   , installed 5.0.16
          Adapter    "lgtv"         : 2.1.2    , installed 2.1.1  [Updatable]
          Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
          Adapter    "meross"       : 1.15.1   , installed 1.15.1
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
          Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
          Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
          Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "radar2"       : 2.0.8    , installed 2.0.8
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "solarviewdatareader": 1.0.7, installed 1.0.7
          Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
          Adapter    "trashschedule": 2.3.0    , installed 2.2.0  [Updatable]
          Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.1.10   , installed 6.1.2  [Updatable]
          Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Objects and States
          Objects:        12529
          States:         10443
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Get:4 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Fetched 5127 B in 3s (1924 B/s)
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15515      659/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15651      612/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15517      659/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15650      612/cupsd
          tcp6       0      0 :::4712                 :::*                    LISTEN      116        107895     22094/evcc
          tcp6       0      0 :::3000                 :::*                    LISTEN      120        17960      620/grafana
          tcp6       0      0 :::7070                 :::*                    LISTEN      116        107024     22094/evcc
          tcp6       0      0 :::3389                 :::*                    LISTEN      117        13027      683/xrdp
          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          15521      649/xrdp-sesman
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13004      696/cups-browsed
          udp        0      0 0.0.0.0:58178           0.0.0.0:*                           108        16393      467/avahi-daemon: r
          udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1002       107880     4761/chromium-brows
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16391      467/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16549      543/dhcpcd
          udp6       0      0 :::546                  :::*                                0          23799      543/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        16392      467/avahi-daemon: r
          udp6       0      0 :::59193                :::*                                108        16394      467/avahi-daemon: r
          Thomas Braun DJMarc75 3 Replies Last reply Reply Quote 0
            @line
            Das sollte 0.0.0.0. heißen.
              @line
              Und schalt den Desktop aus!
              Insbesondere den Remote Desktop!
              • DJMarc75
                DJMarc75 @line last edited by
                @line sagte in Iobroker nicht mehr erreichbar - Firewall?:
                Netzteil zu schwach ?
                  @thomas-braun sagte in Iobroker nicht mehr erreichbar - Firewall?:
                  @line
                  @line
                  siehe Doku:
                  ist sogar rot
                    line @Homoran last edited by
                    @homoran das hab ich nun umgestellt. Jetzt erreiche ich den iobroker nicht mal mehr über den raspi. Was nun?
                      Homoran Global Moderator Administrators @line last edited by
                      iob list instances bitte
                        @homoran Danke dir
                        system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                        + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                        + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                        + system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                        + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                        + system.adapter.mediola-gateway.0        : mediola-gateway       : raspberrypi                              -  enabled
                        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                        + system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                        + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
                        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                        + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                        + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                        + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.69, run as: admin
                        + system.adapter.webcal.0                 : webcal                : raspberrypi                              -  enabled
                        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                        + instance is alive
                          @line iob start admin
                            @homoran ok jetzt läuft er auf dem raspberry wieder - jetzt war ich gerade völlig verzweifelt. Danke dafür
                            Aber auf dem Pad oder pc sieht es immer noch nicht besser aus
                              @line
                              pgrep -f "Xorg"
                              Und nochmal die Ausgabe von
                              iob diag
                                pgrep -f "Xorg"
                                673
                                2969
                                Ion diag
                                + instance is alive
                                feline@raspberrypi:~ $ iob start admin
                                The adapter "admin.0" was started.
                                feline@raspberrypi:~ $ pgrep -f "Xorg"
                                673
                                2969
                                feline@raspberrypi:~ $ iob diag
                                *** iob diag is starting up, please wait ***
                                *** ioBroker Diagnosis ***
                                Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                https://forum.iobroker.net
                                Just copy and paste the Summary Page, including the ``` characters at start and end.
                                It helps us to help you!
                                Press any key to continue
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 21:52:48 up 55 min,  3 users,  load average: 0.61, 0.54, 0.54
                                CPU threads: 4
                                Current issues:
                                               Local time: Fri 2023-11-17 21:52:48 CET
                                           Universal time: Fri 2023-11-17 20:52:48 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                feline
                                /home/feline
                                /home/iobroker/.diag.sh: line 200: [[: 673
                                2969: syntax error in expression (error token is "2969")
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            7.8G        2.3G        4.1G         73M        1.4G        5.3G
                                Swap:            99M          0B         99M
                                Total:          7.9G        2.3G        4.2G
                                         7812 M total memory
                                         2335 M used memory
                                         2930 M active memory
                                          618 M inactive memory
                                         4065 M free memory
                                           75 M buffer memory
                                         1335 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                0 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/root      ext4       29G   20G  8.2G  71% /
                                tmpfs          tmpfs     3.9G   24M  3.8G   1% /dev/shm
                                [Fri Nov 17 20:57:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:38:62:0F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b4c0fa64-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Fri Nov 17 20:57:08 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Fri Nov 17 20:57:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Fri Nov 17 20:57:10 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                `-/home/feline2/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1002,group_id=1002
                                /var:
                                3.6G    /var/
                                3.1G    /var/log
                                205M    /var/cache
                                412M    /opt/iobroker/iobroker-data/
                                23M     /opt/iobroker/iobroker-data/states.jsonl
                                20M     /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.4
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                Objects and States
                                /Objects:       12529
                                        States:         10686
                                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                                Fetched 5127 B in 2s (3331 B/s)
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       23905      2764/io.shelly.0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12146      652/sshd: /usr/sbin
                                tcp        0      0 192.168.178.69:8082     0.0.0.0:*               LISTEN      1001       22476      2840/io.web.0
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23627      2620/iobroker.js-co
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23634      2620/iobroker.js-co
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12213      611/cupsd
                                tcp6       0      0 :::38137                :::*                    LISTEN      1001       27437      3826/io.yahka.0
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12212      611/cupsd
                                tcp6       0      0 :::4712                 :::*                    LISTEN      116        34678      5241/evcc
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          12148      652/sshd: /usr/sbin
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34899      4873/io.admin.0
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       26414      3842/io.socketio.0
                                tcp6       0      0 :::3389                 :::*                    LISTEN      117        12250      679/xrdp
                                tcp6       0      0 :::7070                 :::*                    LISTEN      116        37154      5241/evcc
                                tcp6       0      0 :::3000                 :::*                    LISTEN      120        19507      613/grafana
                                tcp6       0      0 ::1:3350                :::*                    LISTEN      0          11133      645/xrdp-sesman
                                udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       24557      3407/io.mediola-gat
                                udp        0      0 0.0.0.0:40074           0.0.0.0:*                           108        14830      467/avahi-daemon: r
                                udp        0      0 0.0.0.0:41021           0.0.0.0:*                           1001       24558      3407/io.mediola-gat
                                udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22262      2753/io.radar2.0
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14961      546/dhcpcd
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12230      687/cups-browsed
                                udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1002       26205      3418/chromium-brows
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14828      467/avahi-daemon: r
                                udp6       0      0 :::44206                :::*                                108        14831      467/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          14990      546/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        14829      467/avahi-daemon: r
                                iob diag has finished.
                                Press any key for a summary
                                Copy text starting here:
                                                        v.2023-10-10
                                         Icon name: computer
                                      Architecture: arm64
                                Installation:           native
                                Kernel:                 aarch64
                                Userland:               arm64
                                Timezone:               Europe/Berlin (CET, +0100)
                                User-ID:                1000
                                /home/iobroker/.diag.sh: line 469: [[: 673
                                X-Server:               false
                                Boot Target:            graphical.target
                                Pending OS-Updates:     0
                                Pending iob updates:    7
                                Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                        /usr/bin/npm            9.8.1
                                                        /usr/bin/npx            9.8.1
                                Recommended versions are nodejs 18.18.2 and npm 9.8.1
                                MEMORY:
                                Mem:            7.8G        2.4G        3.9G         73M        1.5G        5.2G
                                Swap:            99M          0B         99M
                                Total:          7.9G        2.4G        4.0G
                                Active iob-Instances:   28
                                ioBroker Core:          js-controller           5.0.16
                                                        admin                   6.12.0
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                12529
                                States:                 10686
                                Size of iob-Database:
                                === Mark text until here for copying ===
                                  Homoran Global Moderator Administrators @line last edited by Homoran
                                  @line der admin ist ja schon wieder deaktiviert!
                                  warum?
                                  edit
                                  im diag ist er aktiv
                                    Browsercache gelöscht?
                                      @line
                                      sudo systemctl set-default multi-user.target
                                      sudo systemctl isolate multi-user.target
                                      Der web-Adapter hat auch noch ein Binding...
                                      Bring die Adapter auf Stand:
                                        @homoran keine Ahnung. Ich hab ihn nochmals neu gestartet.
                                        Jetzt steht er auf enable.
                                          @thomas-braun Ok, hab die Updates ausgeführt. Den Web Adapter das Binding raugommen. Jedoch erreiche ich ihn trotzdem nicht von einem pc oder pad
                                                   Icon name: computer
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : arm64
                                           22:30:14 up  1:33,  2 users,  load average: 0.71, 1.18, 1.44
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Fri 2023-11-17 22:30:14 CET
                                                     Universal time: Fri 2023-11-17 21:30:14 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          feline
                                          /home/feline
                                          X-Server:       true
                                          Desktop:
                                          Terminal:       tty
                                          Boot Target:    multi-user.target
                                          *** MEMORY ***
                                          Mem:            7.8G        2.4G        3.6G         98M        1.8G        5.1G
                                          Swap:            99M          0B         99M
                                          Total:          7.9G        2.4G        3.7G
                                                   7812 M total memory
                                                   2437 M used memory
                                                   3037 M active memory
                                                    940 M inactive memory
                                                   3602 M free memory
                                                    117 M buffer memory
                                                   1655 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          tmpfs          tmpfs     3.9G   60M  3.8G   2% /dev/shm
                                          /var:
                                          3.6G    /var/
                                          3.1G    /var/log
                                          205M    /var/cache
                                          425M    /opt/iobroker/iobroker-data/
                                          325M    /opt/iobroker/iobroker-data/files
                                          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                          29M     /opt/iobroker/iobroker-data/states.jsonl
                                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                          12M     /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                                          nodejs:
                                            Version table:
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.12.0
                                          javascript:     7.1.4
                                          Adapter State
                                          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + instance is alive
                                          Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                          Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                                          Adapter    "parser"       : 2.0.7    , installed 2.0.7
                                          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                          Adapter    "web"          : 6.1.10   , installed 6.1.10
                                          Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                          Objects and States
                                          Objects:        12534
                                          States:         10691
                                          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                                          Fetched 5127 B in 2s (2471 B/s)
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       55250      9859/io.shelly.0
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       56608      9666/iobroker.js-co
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54912      9666/iobroker.js-co
                                          tcp6       0      0 :::4712                 :::*                    LISTEN      116        60025      10429/evcc
                                          tcp6       0      0 :::41285                :::*                    LISTEN      1001       57653      10200/io.yahka.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       56623      9684/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       60422      10318/io.web.0
                                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       58764      10211/io.socketio.0
                                          tcp6       0      0 :::7070                 :::*                    LISTEN      116        60830      10429/evcc
                                          udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       59512      10091/io.mediola-ga
                                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       55168      9816/io.radar2.0
                                          udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1002       57876      3418/chromium-brows
                                          udp        0      0 0.0.0.0:50693           0.0.0.0:*                           1001       59513      10091/io.mediola-ga
                                          • Marc Berg
                                            Marc Berg Most Active @line last edited by Marc Berg
                                            gelöscht. Hier stand Unsinn.
                                            1683
