    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      SweetLakecity last edited by
      Hi @tombox,
      The test version 0.2.2 for my Audi Etron (Late 2019) unfortunately no longer works to start or stop the charging session remotely. It keeps jumping back to the current status.
      When stopping via the remote option (false), I do get a pop up in the MyAudi app that the session has been stopped, however, the session remains active (also visible in the app that it is still active).
      In addition, I hope the climatisation status can be added again.
      I hope you can help me?
        mick70 last edited by
        Hier (e-Golf 2020) produziert der Adapter leider seit heute Morgen Fehler:
        vw-connect.0
        2023-11-17 12:00:07.265	error	Restart Adapter in 30min
        vw-connect.0
        2023-11-17 12:00:07.264	error	Login Failed
        vw-connect.0
        2023-11-17 12:00:07.262	error	"{\"description\":\"IdentityKit Response: 401 : {\\\"error\\\":\\\"invalid_client\\\",\\\"error_description\\\":\\\"Client authentication failed\\\"}\",\"errorCode\":\"IDENTITY_KIT_RESPONSE_ERROR\"}"
        vw-connect.0
        2023-11-17 12:00:07.262	error	401
        vw-connect.0
        2023-11-17 12:00:07.261	error	Please try an alternative type like Seat Cupra#2 or Etron
        vw-connect.0
        2023-11-17 12:00:07.260	error	Failed to get token
        Die neue App funktioniert noch. Ist das einer der üblichen Ausfälle zum Wochenende oder was schlimmeres?
        R RaspiUser H 3 Replies Last reply Reply Quote 0
          tombox @SweetLakecity last edited by
          @sweetlakecity the functionality is working in the app?
            reimai @mick70 last edited by
            @mick70 die selbe Meldungen habe ich auch seit heute. Auch E-Golf!
            • RaspiUser
              RaspiUser @mick70 last edited by
              @mick70 sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
              ... muss mich leider mit einem VW 2.0 Diesel Bj. 2020 anschließen ...
                hene42 @mick70 last edited by
                @mick70 bei mir Golf 8 eTSI gleicher Fehler
                  tombox @hene42 last edited by
                  @hene42 Geht es denn sich in die app einzuloggen?
                  RaspiUser H I 3 Replies Last reply Reply Quote 0
                  • RaspiUser
                    RaspiUser @tombox last edited by
                    @tombox sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                    ... bei meinem Diesel klappt alles es mit der App ...
                      hene42 @tombox last edited by
                      @tombox Ja, VW App und Einloggen funktioniert.
                      • I
                        ichderarnd @tombox last edited by
                        @tombox, @All
                        Bei mir läuft der Adapter für unseren e-Golf 2020. Kein Fehler den ganzen Tag. Die Daten sind aktuell (letzte Fahrt heute ca. 20:00 Uhr).
                        Habe gerade getestet, ob der Adapter korrekt startet und das Login funktioniert: positiv.
                        Version 0.1.9
                          @hene42 die we-connect app wurde deaktiviert ich habe das im adapter angepasst.
                          bitte mal die GitHub version testen ob die alten states gelöscht und die neuen erstellt werden
                          H X 2 Replies Last reply Reply Quote 0
                            @tombox
                            Hi, ist mein Fehler.
                            Mit dieser Einstellung geht es, hatte noch VWv2 eingestellt und das geht jetzt nicht mehr.
                            Danke für deine Super Arbeit und Sorry für meinen Fehler.
                              sunny9999 last edited by
                              Moinsen......
                              seit der Umstellung auf von der Connect App auf die Volkswagen App geht meine Standheizung nicht mehr...
                              Hab heute von github den Adapter aktualisiert, Typ in der Instanz auf Volkswagen App umgestellt, vorher Objekte gelöscht und versucht die Heizung zu starten.....kommt folgender Fehler :
                              vw-connect.0
                              2023-11-18 08:19:47.400	error	Error in OnStateChange: undefined
                              vw-connect.0
                              2023-11-18 08:19:47.400	error	{"error":{"errorCode":"gw.error.authentication","description":"Malformed request"}}
                              vw-connect.0
                              2023-11-18 08:19:47.398	error	401
                              Hab mir mal die Objekte angeschaut, es fehlt folgender Datenpunkt, der vorher mit "heating" gestartet wurde :
                              vw-connect.0.XXXXXXXXXXXXXXX.remote.standheizungv2
                              Jemand ne Idee ? Es wird langsam kalt 😉
                              Grüße und Danke
                              Sunny
                              • X
                                xawa @tombox last edited by xawa
                                Etwas aussagekräftigeres Feedback schadet vielleicht auch nicht:
                                Hatte auch das gleiche Problem beim Golf Life 2.0 l TDI SCR mit der letzten Github-Version und Type "VWv2 neue Baujahr >= 2020" seit gestern. Vor Installation der neuesten Github Version heute habe die Datenpunkte gelöscht -> Adapter auf neue Github Version aktualisiert -> Instanz gestartet -> es wurden zuerst nur einige Datenpunkte erstellt (vermutlich, weil ich den neuen Typ nach dem Update noch nicht eingestellt habe) -> Type auf "VW ID/Volkswagen App" gestellt -> Instanz neu gestartet -> nach Ablauf des Update-Intervalls wurden dann alle restlichen erstellt -> jetzt läuft wieder alles prima.
                                Und das beste: diese doofe Datenpunkstruktur 0x001002... (die vermutlich wegen WeConnect erstellt wurde) ist jetzt weg und alles wird sehr strukturiert und aussagekräftig wie beim VW ID4 angezeigt.
                                Danke tombox
                                  tombox @sunny9999 last edited by
                                  @sunny9999 keiner der neuen remote Datenpunkt geht?
                                  A S 2 Replies Last reply Reply Quote 0
                                    Ahnungsbefreit @tombox last edited by Ahnungsbefreit
                                    @tombox Hallo, ich habe einen VW e-up! Baujahr 2021, der hat bis vor einiger Zeit über die VW Connect App funktioniert und damit auch der Adapter. Seit der Umstellung auf die neue VW App kann ich mich zwar mit der letzten Github Version vom Adapter anmelden, bekomme aber keinerlei Daten. Ich bräuchte zumindest den Batterieladestand und die Möglichkeit, das Laden zu starten und zu beenden wieder aber in der neuen Datenstruktur finde ich nix. Aus dem Log:
                                    vw-connect.0
                                    2023-11-18 14:11:03.864	info	Create vehicle WVWZZZXXXXXXX
                                    vw-connect.0
                                    2023-11-18 14:11:03.862	info	Found 1 vehicles
                                    vw-connect.0
                                    2023-11-18 14:11:02.920	info	Minimum update interval is 15min for Wallcharging data, to prevent blocking
                                    vw-connect.0
                                    2023-11-18 14:11:02.920	info	Wallcharging login was successfull
                                    vw-connect.0
                                    2023-11-18 14:11:02.582	info	Login successful
                                    vw-connect.0
                                    2023-11-18 14:11:02.581	info	Login in with id
                                    vw-connect.0
                                    2023-11-18 14:11:02.580	info	Start Wallcharging login
                                    vw-connect.0
                                    2023-11-18 14:11:02.580	info	History limit: 100, set to -1 to disable wallcharging login
                                    vw-connect.0
                                    2023-11-18 14:11:02.580	info	ID login successfull
                                    vw-connect.0
                                    2023-11-18 14:11:00.824	info	Login in with id
                                    vw-connect.0
                                    2023-11-18 14:11:00.812	info	starting. Version 0.2.2 (non-npm: ta2k/ioBroker.vw-connect#040712e43921ca1f20e3cdc58277d87826d292f2) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.18.2, js-controller: 5.0.16
                                    Edit: In der App sehe ich alle Daten.
                                    Edit2: Sorry, ich war zu ungeduldig. Jetzt kommen alle Daten an!
                                      leonundjulie @tombox last edited by
                                      @tombox , übersehe ich es? Wo kann ich die VIS-Vorlage downloaden?
                                        reimai @xawa last edited by
                                        @xawa wie geht das mit den Datenpunkten löschen?
                                          @tombox Ich hatte in der Instanz (0.2.2 alt) auch noch "VWv2 >=2020" eingestellt.
                                          Mit der Einstellung "VW / ID Volkswagen App" funktioniert das Auslesen wieder, hat aber lange gedauert, bis alle Datenpunkte da waren. Für meinen e-Golf 2020 sind jetzt halt ähnlich wie in der neuen App auch div. Remote-Funktionen entfallen. Naja, kommen ja vllt irgendwann wieder, wenn's an VW liegt.
                                            disaster123 last edited by
                                            Moin - ich habe einen Cupra born. In der My Cupra App wird der Ladezustand bzw. die Ladeinfos in Echtzeit angezeigt. Kann ich das mit dem Adapter auch irgendwie bekommen? Ich habe jetzt bisher den Updateintervall auf 1 Minute gesetzt...
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1603015
