    4. Diskussion zum HowTo nodejs-Installation und upgrade
      Thomas Braun Most Active @ma last edited by
      @ma
      Dann mit --debug-Option installieren.
      iob update
      sagt?
        ma @Thomas Braun last edited by
        iob update
        Used repository: Stable (default)
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alarm"        : 3.4.0    , installed 3.4.0
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "bidirectional-counter": 2.1.0, installed 2.1.0
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "countdown"    : 2.2.0    , installed 2.2.0
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "device-watcher": 2.9.4   , installed 2.9.4
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fritzdect"    : 2.3.1    , installed 2.5.8
        Adapter    "fullybrowser" : 2.2.0    , installed 2.1.2  [Updatable]
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "homekit-controller": 0.5.8, installed 0.5.8
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "oekofen-json" : 1.0.5    , installed 1.0.5
        Adapter    "openweathermap": 0.3.9   , installed 0.3.9
        Adapter    "operating-hours": 1.0.4  , installed 1.0.4
        Adapter    "parser"       : 1.3.2    , installed 1.3.2
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
        Adapter    "radar2"       : 2.0.8    , installed 2.0.7  [Updatable]
        Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
        Adapter    "shelly"       : 6.6.1    , installed 6.4.5  [Updatable]
        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
        Adapter    "statistics"   : 2.3.0    , installed 2.3.0
        Adapter    "telegram"     : 2.0.1    , installed 1.16.0 [Updatable]
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "unifi"        : 0.6.6    , installed 0.6.6
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.4    , installed 6.1.4
        Adapter    "windows-control": 0.1.5  , installed 0.1.5
        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        iobroker upgrade shelly --debug
        This upgrade of "shelly" will introduce the following changes:
        -> 6.6.1:
        Fixed stop reason for Shelly 2.5 / Shelly 2
        Added humidity of Shelly Plus Addon
        Not all devices have external power
        -> 6.6.0:
        Added BLE devices as states to `shelly.0.ble.*` (Shelly Scripting required)
        -> 6.5.0:
        Added Shelly Plus Smoke
        Added Shelly Bluetooth Low Energy Gateway
        More Shelly TRV Datapoints
        Would you like to upgrade shelly from @6.4.5 to @6.6.1 now? [(y)es, (n)o]: y
        Update shelly from @6.4.5 to @6.6.1
        NPM version: 9.8.1
        Installing iobroker.shelly@6.6.1... (System call)
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/@75lb/deep-merge
        npm ERR! dest /opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLA
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@75lb/deep-merge' -> '/opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLA'
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T06_39_34_733Z-debug-0.log
        Try to solve ENOTEMPTY error automatically
        Could not handle ENOTEMPTY, because no deletable files were found
        npm ERR! errno -39
        host.iobroker Cannot install iobroker.shelly@6.6.1: 217
          @ma
          Jag den
          iob fix
          drüber.
            SiKo last edited by
            Hallo, hab schon versucht nodejs zu deinstallieren und neu installieren. Bekomme aber immer wieder diesen Fehler:
            Was kann ich tun?
            pi@raspberrypi:~ $ sudo apt-get update && sudo apt-get full-upgrade
            OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Holen:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12,1 kB]
            Fehl:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
            Paketlisten werden gelesen… Fertig
            W: GPG-Fehler: https://deb.nodesource.com/node_18.x nodistro InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
            E: Das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« ist nicht signiert.
            N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
            N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
            pi@raspberrypi:~ $
              @siko sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
              mach es mit iob nodejs-update
                Thomas Braun Most Active @SiKo last edited by
                @siko
                Da fehlen die Schlüssel.
                Mach es mit
                iob nodejs-update
                dann passt es auch.
                  SiKo last edited by
                  vielen Dank, Hat direkt funktioniert.
                    Natürlich... : 😊
                      @thomas-braun der 2 durchlauf vom fix hat das problem gelößt leider nur bis gerade eben
                      $ iobroker upgrade sonos@3.0.0
                      Update sonos from @2.3.1 to @3.0.0
                      Installing iobroker.sonos@3.0.0... (System call)
                      host.iobroker deleted npm temp directory: ".acorn-jsx-zPgFNGpl")
                      host.iobroker deleted npm temp directory: ".alcalzone-shared-FgX40TmF")
                      host.iobroker deleted npm temp directory: ".all-package-names-BPhkNiF7")
                      host.iobroker deleted npm temp directory: ".ansi-colors-qAZfUuTD")
                      host.iobroker deleted npm temp directory: ".ansi-escapes-BuACp4PU")
                      host.iobroker deleted npm temp directory: ".any-observable-GucR4b7Z")
                      host.iobroker deleted npm temp directory: ".any-promise-GjCkSNL3")host.iobroker deleted npm temp directory: ".anymatch-7vz5qHmT")host.iobroker deleted npm temp directory: ".aproba-IIqIrfbB")
                      host.iobroker deleted npm temp directory: ".array-flatten-95xLgxGw")
                      host.iobroker deleted npm temp directory: ".array.prototype.findindex-JX1jwpiR")
                      host.iobroker deleted npm temp directory: ".boolbase-8130XECE")
                      host.iobroker deleted npm temp directory: ".bplist-parser-GTDOjzTC")
                      host.iobroker deleted npm temp directory: ".bundle-name-DjKLTayE")
                      host.iobroker deleted npm temp directory: ".busboy-A5FsP0CS")
                      host.iobroker deleted npm temp directory: ".chownr-E9JZijSA")
                      host.iobroker deleted npm temp directory: ".data-uri-to-buffer-GQ7HcaPL")
                      host.iobroker deleted npm temp directory: ".decamelize-keys-RDuJHe51")
                      host.iobroker deleted npm temp directory: ".decimal.js-A6TpPJWn")
                      host.iobroker deleted npm temp directory: ".dns-equal-TvMdkxWU")
                      host.iobroker deleted npm temp directory: ".es-shim-unscopables-lNCpEqsg")
                      host.iobroker deleted npm temp directory: ".esutils-1jlXlxlo")
                      host.iobroker deleted npm temp directory: ".follow-redirects-vRGWWNjd")
                      host.iobroker deleted npm temp directory: ".gopd-LUHsc2oq")
                      host.iobroker deleted npm temp directory: ".got-DFICjTYm")
                      host.iobroker deleted npm temp directory: ".graceful-fs-i6Qs7iN3")
                      host.iobroker deleted npm temp directory: ".indexof-m6nUtkW4")
                      host.iobroker deleted npm temp directory: ".inflight-pQph8mNF")
                      host.iobroker deleted npm temp directory: ".influx-JoUiD55Z")host.iobroker deleted npm temp directory: ".inherits-ffYUEA4n")host.iobroker deleted npm temp directory: ".ini-HiLT2lH8")host.iobroker deleted npm temp directory: ".inquirer-0PRKJaIm")
                      host.iobroker deleted npm temp directory: ".iobroker-adapter-helpers-za1UEIZc")
                      host.iobroker deleted npm temp directory: ".iobroker.alarm-g8jjAFg9")
                      host.iobroker deleted npm temp directory: ".iobroker.alias-manager-gHAtOr6e")
                      host.iobroker deleted npm temp directory: ".iobroker.bidirectional-counter-PzmaO0Aw")
                      host.iobroker deleted npm temp directory: ".iobroker.bring-ov1aPXwP")
                      host.iobroker deleted npm temp directory: ".iobroker.broadlink2-HDK4EOgs")
                      host.iobroker deleted npm temp directory: ".iobroker.coronavirus-statistics-Kxvay9Wy")
                      host.iobroker deleted npm temp directory: ".iobroker.countdown-M3o5XFv5")
                      host.iobroker deleted npm temp directory: ".iobroker.daswetter-1t9k5PAQ")
                      host.iobroker deleted npm temp directory: ".iobroker.device-watcher-JRkscZB5")
                      host.iobroker deleted npm temp directory: ".iobroker.devices-1FmykokK")
                      host.iobroker deleted npm temp directory: ".iobroker.discovery-Domn1CAP")
                      host.iobroker deleted npm temp directory: ".iobroker.doorbird-kwq4QU5M")
                      host.iobroker deleted npm temp directory: ".iobroker.dwd-SpnK64ht")
                      host.iobroker deleted npm temp directory: ".iobroker.email-7I7P5tNz")
                      host.iobroker deleted npm temp directory: ".iobroker.energiefluss-kJMU3Qwp")
                      host.iobroker deleted npm temp directory: ".iobroker.feiertage-WV2cxVZc")
                      host.iobroker deleted npm temp directory: ".iobroker.fullybrowser-g2Durliy")
                      host.iobroker deleted npm temp directory: ".iobroker.harmony-BDALdOzG")
                      host.iobroker deleted npm temp directory: ".iobroker.heatingcontrol-fFfpnmIZ")
                      host.iobroker deleted npm temp directory: ".iobroker.hm-rega-eDrPvalf")
                      host.iobroker deleted npm temp directory: ".iobroker.hm-rpc-6COQ5CUM")
                      host.iobroker deleted npm temp directory: ".iobroker.homekit-controller-sF0AM7Io")
                      host.iobroker deleted npm temp directory: ".iobroker.ical-rrBOhFW0")
                      host.iobroker deleted npm temp directory: ".iobroker.icons-icons8-F8SpNGzQ")
                      host.iobroker deleted npm temp directory: ".iobroker.icons-material-png-A0Zx2K4e")
                      host.iobroker deleted npm temp directory: ".iobroker.icons-material-svg-E2OoIK18")
                      host.iobroker deleted npm temp directory: ".iobroker.icons-mfd-svg-UK4n9spV")
                      host.iobroker deleted npm temp directory: ".iobroker.influxdb-mtpshsVk")
                      host.iobroker deleted npm temp directory: ".iobroker.info-OtqXm2hx")
                      host.iobroker deleted npm temp directory: ".iobroker.iqontrol-JG9EP64y")
                      host.iobroker deleted npm temp directory: ".iobroker.jarvis-Dfkzlr3d")
                      host.iobroker deleted npm temp directory: ".iobroker.javascript-5NZ432mn")
                      host.iobroker deleted npm temp directory: ".iobroker.js-controller-7Q8bmsba")
                      host.iobroker deleted npm temp directory: ".iobroker.linkeddevices-SudTlN7O")
                      host.iobroker deleted npm temp directory: ".iobroker.modbus-MRiPN8Jv")
                      host.iobroker deleted npm temp directory: ".iobroker.mqtt-R5v7g772")
                      host.iobroker deleted npm temp directory: ".iobroker.mqtt-client-AcZDMICZ")
                      host.iobroker deleted npm temp directory: ".iobroker.mytime-ALCjuXxL")
                      host.iobroker deleted npm temp directory: ".iobroker.nut-M42R6CUU")
                      host.iobroker deleted npm temp directory: ".iobroker.oekofen-json-AAGebuoM")
                      host.iobroker deleted npm temp directory: ".iobroker.openweathermap-uUPAAaq5")
                      host.iobroker deleted npm temp directory: ".iobroker.operating-hours-vFpZVs6M")
                      host.iobroker deleted npm temp directory: ".iobroker.parser-lf3ZX1wK")
                      host.iobroker deleted npm temp directory: ".iobroker.ping-OPzFiLFH")
                      host.iobroker deleted npm temp directory: ".iobroker.pushover-c2imyZua")
                      host.iobroker deleted npm temp directory: ".iobroker.pushsafer-akpid5GF")
                      host.iobroker deleted npm temp directory: ".iobroker.radar2-VVWJ5P6u")
                      host.iobroker deleted npm temp directory: ".iobroker.sayit-RsEZnXzS")
                      host.iobroker deleted npm temp directory: ".iobroker.scenes-9WoxMImK")
                      host.iobroker deleted npm temp directory: ".iobroker.shelly-wfXzBUin")
                      host.iobroker deleted npm temp directory: ".iobroker.shuttercontrol-msgqlVR3")
                      host.iobroker deleted npm temp directory: ".iobroker.simple-api-q4TJvC8n")
                      host.iobroker deleted npm temp directory: ".iobroker.smartcontrol-670ft8lY")
                      host.iobroker deleted npm temp directory: ".iobroker.smartmeter-OyPCR5Lj")
                      host.iobroker deleted npm temp directory: ".iobroker.socketio-0ZB5ejpX")
                      host.iobroker deleted npm temp directory: ".iobroker.sonoff-nQCcGLOb")
                      host.iobroker deleted npm temp directory: ".iobroker.sonos-8p9DbxUk")
                      host.iobroker deleted npm temp directory: ".iobroker.sourceanalytix-xH8dPE7Z")
                      host.iobroker deleted npm temp directory: ".iobroker.sprinklecontrol-jINmg3MW")
                      host.iobroker deleted npm temp directory: ".iobroker.statistics-nDtQT913")
                      host.iobroker deleted npm temp directory: ".iobroker.telegram-qJ3kkwRA")
                      host.iobroker deleted npm temp directory: ".iobroker.terminal-LQj2rBFR")
                      host.iobroker deleted npm temp directory: ".iobroker.text2command-XKgXlG9f")
                      host.iobroker deleted npm temp directory: ".iobroker.trashschedule-bVFlHcrS")
                      host.iobroker deleted npm temp directory: ".iobroker.unifi-YuUe0MFZ")
                      host.iobroker deleted npm temp directory: ".iobroker.upnp-XYJa4jHA")
                      host.iobroker deleted npm temp directory: ".iobroker.virtualpowermeter-aiSWB1CL")
                      host.iobroker deleted npm temp directory: ".iobroker.vis-hqwidgets-XOleJSph")
                      host.iobroker deleted npm temp directory: ".iobroker.vis-icontwo-ZE5SYXJL")
                      host.iobroker deleted npm temp directory: ".iobroker.weatherunderground-yjlWL8nH")
                      host.iobroker deleted npm temp directory: ".iobroker.web-qhxwcVTa")
                      host.iobroker deleted npm temp directory: ".iobroker.windows-control-m2ZZnHAV")
                      host.iobroker deleted npm temp directory: ".iobroker.wiobrowser-0FquAKud")
                      host.iobroker deleted npm temp directory: ".iobroker.ws-Ul5el1jB")
                      host.iobroker deleted npm temp directory: ".iobroker.yahka-5keTFK1G")
                      host.iobroker deleted npm temp directory: ".iobroker.zigbee-1JQaSLfT")
                      host.iobroker deleted npm temp directory: ".ipaddr.js-Cv8HUhd7")
                      host.iobroker deleted npm temp directory: ".is-array-buffer-jIv3kdDM")
                      host.iobroker deleted npm temp directory: ".is-bigint-opiLNorc")host.iobroker deleted npm temp directory: ".is-binary-path-T9bvCuQK")
                      host.iobroker deleted npm temp directory: ".is-core-module-3szSVmLC")
                      host.iobroker deleted npm temp directory: ".is-docker-diEaV9Js")
                      host.iobroker deleted npm temp directory: ".is-map-DnX0Tp2n")
                      host.iobroker deleted npm temp directory: ".is-name-taken-RA37aJNO")
                      host.iobroker deleted npm temp directory: ".is-npm-Tq5PXIR1")
                      host.iobroker deleted npm temp directory: ".is-obj-H9BCY1mC")
                      host.iobroker deleted npm temp directory: ".is-promise-TcPsCtHt")
                      host.iobroker deleted npm temp directory: ".is-symbol-DyzbAfPe")
                      host.iobroker deleted npm temp directory: ".is-utf8-XzPsDN8p")
                      host.iobroker deleted npm temp directory: ".is-weakref-3wPDZaCU")
                      host.iobroker deleted npm temp directory: ".is-wsl-67INiaF0")
                      host.iobroker deleted npm temp directory: ".is-yarn-global-z8J5xFQb")
                      host.iobroker deleted npm temp directory: ".javascript-natural-sort-BSvwVhzD")
                      host.iobroker deleted npm temp directory: ".js-sdsl-RiJhgh6j")
                      host.iobroker deleted npm temp directory: ".jsonc-parser-nbReDrcG")
                      host.iobroker deleted npm temp directory: ".jsonwebtoken-b9ysUQT0")
                      host.iobroker deleted npm temp directory: ".jsprim-QmUwRLNa")
                      host.iobroker deleted npm temp directory: ".jszip-r3fGcU4N")
                      host.iobroker deleted npm temp directory: ".kind-of-ZEKy7WZt")
                      host.iobroker deleted npm temp directory: ".layerr-GPEJIlGL")
                      host.iobroker deleted npm temp directory: ".lcid-SGsSRn9Q")
                      host.iobroker deleted npm temp directory: ".libsodium-wrappers-xQoQYz7T")
                      host.iobroker deleted npm temp directory: ".lines-and-columns-ohK2P2I1")
                      host.iobroker deleted npm temp directory: ".listr-SF1ph3tc")
                      host.iobroker deleted npm temp directory: ".listr-update-renderer-CSIQ7CWX")
                      host.iobroker deleted npm temp directory: ".load-json-file-5LcbUpDJ")
                      host.iobroker deleted npm temp directory: ".locate-path-t7OptBTV")
                      host.iobroker deleted npm temp directory: ".lodash-MxVnsAsD")
                      host.iobroker deleted npm temp directory: ".lodash.isnumber-P8M8GSmV")
                      host.iobroker deleted npm temp directory: ".log-symbols-rbtC1M9g")
                      host.iobroker deleted npm temp directory: ".log-update-SuSlKzSj")
                      host.iobroker deleted npm temp directory: ".logform-Bwy2bCcs")
                      host.iobroker deleted npm temp directory: ".loupe-hV7arrgu")
                      host.iobroker deleted npm temp directory: ".lru_map-uI07ZEOk")
                      host.iobroker deleted npm temp directory: ".macaddress-dlPdmBpu")
                      host.iobroker deleted npm temp directory: ".map-obj-FDgyUQwo")
                      host.iobroker deleted npm temp directory: ".map-stream-elIH4kVT")
                      host.iobroker deleted npm temp directory: ".md5-viMx30VF")
                      host.iobroker deleted npm temp directory: ".media-typer-kYaJhV1E")
                      host.iobroker deleted npm temp directory: ".mime-db-RKfcSKNg")
                      host.iobroker deleted npm temp directory: ".mimic-fn-hAcoKpm0")
                      host.iobroker deleted npm temp directory: ".minimist-options-qXL9cbTR")
                      host.iobroker deleted npm temp directory: ".minipass-FfE0ClCz")
                      host.iobroker deleted npm temp directory: ".mkdirp-classic-HAXMCI8y")
                      host.iobroker deleted npm temp directory: ".mkdirp-yMXn50Ac")
                      host.iobroker deleted npm temp directory: ".module-not-found-error-zFjQCtp1")
                      host.iobroker deleted npm temp directory: ".moment-YVTvHlwl")
                      host.iobroker deleted npm temp directory: ".moment-timezone-LVF6Tkme")
                      host.iobroker deleted npm temp directory: ".mp3-duration-121XpnWA")
                      host.iobroker deleted npm temp directory: ".mqtt-packet-9zhbF4Ks")
                      host.iobroker deleted npm temp directory: ".mz-vxKYAgCA")
                      host.iobroker deleted npm temp directory: ".nan-VJWFtQnQ")
                      host.iobroker deleted npm temp directory: ".napi-thread-safe-callback-z2DAzfv3")
                      host.iobroker deleted npm temp directory: ".netmask-9Rl4SU3k")
                      host.iobroker deleted npm temp directory: ".new-github-release-url-rEfy33Ln")
                      host.iobroker deleted npm temp directory: ".node-arp-exu75jRl")
                      host.iobroker deleted npm temp directory: ".node-ble-gjuzQuSp")
                      host.iobroker deleted npm temp directory: ".node-fetch-blvKKu2b")
                      host.iobroker deleted npm temp directory: ".node-forge-h7cGFpHY")
                      host.iobroker deleted npm temp directory: ".node-gyp-build-r457ov9R")
                      host.iobroker deleted npm temp directory: ".node-hkdf-sync-fknK7puz")
                      host.iobroker deleted npm temp directory: ".node-ical-qUo0I4Tm")
                      host.iobroker deleted npm temp directory: ".node-inspect-waaOWKUA")
                      host.iobroker deleted npm temp directory: ".node-persist-2EKJxgHF")
                      host.iobroker deleted npm temp directory: ".node-schedule-qQzDXhqu")
                      host.iobroker deleted npm temp directory: ".node-ssdp-m1VaQXdw")
                      host.iobroker deleted npm temp directory: ".node-telegram-bot-api-1etpN2K2")
                      host.iobroker deleted npm temp directory: ".node-unifi-3DHKBhgr")
                      host.iobroker deleted npm temp directory: ".node.extend-K6FJItiR")
                      host.iobroker deleted npm temp directory: ".nopt-H6aHmXjc")
                      host.iobroker deleted npm temp directory: ".normalize-path-OU9YSYPX")
                      host.iobroker deleted npm temp directory: ".normalize-url-SZTcDbe8")
                      host.iobroker deleted npm temp directory: ".np-rJ4MzeVW")
                      host.iobroker deleted npm temp directory: ".npmlog-BabU8SvR")
                      host.iobroker deleted npm temp directory: ".object-hash-mLu6dbUq")
                      host.iobroker deleted npm temp directory: ".on-finished-RsKM9iVb")
                      host.iobroker deleted npm temp directory: ".one-time-w9IAMdTx")
                      host.iobroker deleted npm temp directory: ".onedrive-api-P1aPRSY2")
                      host.iobroker deleted npm temp directory: ".open-QucUEWry")
                      host.iobroker deleted npm temp directory: ".optionator-PuhYgmIm")
                      host.iobroker deleted npm temp directory: ".os-tmpdir-1IsoZrn1")
                      host.iobroker deleted npm temp directory: ".p-limit-gOKrDIjV")
                      host.iobroker deleted npm temp directory: ".p-map-XQyfxwrm")
                      host.iobroker deleted npm temp directory: ".p-reflect-kbxyMQvX")
                      host.iobroker deleted npm temp directory: ".p-try-nDlwX8SY")
                      host.iobroker deleted npm temp directory: ".package-name-conflict-pgCDYPR4")
                      host.iobroker deleted npm temp directory: ".parse-json-RdQ2IyFU")
                      host.iobroker deleted npm temp directory: ".parse-listing-8te0aWIy")
                      host.iobroker deleted npm temp directory: ".parseuri-KPPXjLGZ")
                      host.iobroker deleted npm temp directory: ".parsexmlresponse-xx6pTUUG")
                      host.iobroker deleted npm temp directory: ".path-exists-ta4BL8U6")
                      host.iobroker deleted npm temp directory: ".path-parse-8gkiAjRV")
                      host.iobroker deleted npm temp directory: ".pdfkit-e7FwFah6")
                      host.iobroker deleted npm temp directory: ".pidtree-P86HYqqk")
                      host.iobroker deleted npm temp directory: ".pinkie-promise-zAO2ov7N")
                      host.iobroker deleted npm temp directory: ".png-js-diABWe2F")
                      host.iobroker deleted npm temp directory: ".portfinder-OSqONEX8")
                      host.iobroker deleted npm temp directory: ".prelude-ls-NDoRZxgk")
                      host.iobroker deleted npm temp directory: ".prepend-http-9s5cfVm0")
                      host.iobroker deleted npm temp directory: ".progress-Kac1LqJ7")host.iobroker deleted npm temp directory: ".promisify-child-process-qtJuXdmi")
                      host.iobroker deleted npm temp directory: ".proto-list-nfO8tqoz")
                      host.iobroker deleted npm temp directory: ".proxy-from-env-vcslNjmL")
                      host.iobroker deleted npm temp directory: ".pump-7uzcbBxQ")
                      host.iobroker deleted npm temp directory: ".pushover-notifications-hkCkDXkO")
                      host.iobroker deleted npm temp directory: ".pushsafer-notifications-kh9EJENe")
                      host.iobroker deleted npm temp directory: ".q-SKXE2OoR")
                      host.iobroker deleted npm temp directory: ".qs-zUtDfLzC")
                      host.iobroker deleted npm temp directory: ".read-file-safe-cjdRRRu9")
                      host.iobroker deleted npm temp directory: ".read-json-safe-laZsPfMf")
                      host.iobroker deleted npm temp directory: ".read-pkg-A2Az6mLS")
                      host.iobroker deleted npm temp directory: ".readdir-glob-uUrpbb1G")
                      host.iobroker deleted npm temp directory: ".readline-sync-OZdd0hqJ")
                      host.iobroker deleted npm temp directory: ".reinterval-wLApnByp")
                      host.iobroker deleted npm temp directory: ".request-promise-aj2YEifc")
                      host.iobroker deleted npm temp directory: ".request-promise-core-cNo6sLbS")
                      host.iobroker deleted npm temp directory: ".requires-port-Uktyik13")
                      host.iobroker deleted npm temp directory: ".resolve-alpn-RTKpuZSr")
                      host.iobroker deleted npm temp directory: ".resolve-from-j6Gv9Ebe")
                      host.iobroker deleted npm temp directory: ".rfdc-cHAORKEZ")
                      host.iobroker deleted npm temp directory: ".rimraf-eynkDvvy")
                      host.iobroker deleted npm temp directory: ".rrule-y9C9hovL")
                      host.iobroker deleted npm temp directory: ".run-parallel-DCURDW1N")
                      host.iobroker deleted npm temp directory: ".set-blocking-q9SMvfvB")
                      host.iobroker deleted npm temp directory: ".simple-swizzle-r4Lxbm1X")
                      host.iobroker deleted npm temp directory: ".sinon-chai-hl4FcWX3")host.iobroker deleted npm temp directory: ".sinon-vBaWPxBD")host.iobroker deleted npm temp directory: ".slash-R0a5JLyH")host.iobroker deleted npm temp directory: ".slice-ansi-eEa9CtYe")host.iobroker deleted npm temp directory: ".slip-OVBIyeXx")host.iobroker deleted npm temp directory: ".smartmeter-obis-KbLeNtYQ")host.iobroker deleted npm temp directory: ".socket.io-EtoLYra9")host.iobroker deleted npm temp directory: ".socket.io-adapter-tLg9dAuy")host.iobroker deleted npm temp directory: ".socket.io-client-ENiKueA5")host.iobroker deleted npm temp directory: ".socket.io-parser-hH5dvNyh")host.iobroker deleted npm temp directory: ".socksv5-3JzHnAms")host.iobroker deleted npm temp directory: ".sonos-discovery-Uazo0hAg")host.iobroker deleted npm temp directory: ".sorted-array-functions-vKv0t5Tc")host.iobroker deleted npm temp directory: ".source-map-SyGGTVk5")host.iobroker deleted npm temp directory: ".source-map-support-VomWiKMb")host.iobroker deleted npm temp directory: ".spdx-correct-TFUby1KY")host.iobroker deleted npm temp directory: ".spdx-exceptions-ft4zmrVV")host.iobroker deleted npm temp directory: ".spdx-expression-parse-Pekjrfn8")host.iobroker deleted npm temp directory: ".spdx-license-ids-7Yhp2ojQ")host.iobroker deleted npm temp directory: ".split-xwUwBTsG")host.iobroker deleted npm temp directory: ".split2-wyloIfG0")host.iobroker deleted npm temp directory: ".sshpk-cCL4zyMp")host.iobroker deleted npm temp directory: ".stack-trace-lNG2rObG")host.iobroker deleted npm temp directory: ".stampit-event-bus-xEgjX5b8")host.iobroker deleted npm temp directory: ".stampit-state-machine-aC9As91Z")
                      host.iobroker deleted npm temp directory: ".statuses-WEHZIwCf")
                      host.iobroker deleted npm temp directory: ".stream-read-all-kYFKG9vU")
                      host.iobroker deleted npm temp directory: ".string.prototype.trim-3h9X678k")
                      host.iobroker deleted npm temp directory: ".string.prototype.trimstart-ocxtG8ll")
                      host.iobroker deleted npm temp directory: ".strip-bom-2r41bWnk")
                      host.iobroker deleted npm temp directory: ".supermixer-2nesEymU")
                      host.iobroker deleted npm temp directory: ".symbol-observable-ffTkQjDe")
                      host.iobroker deleted npm temp directory: ".table-layout-eRPOhyPw")
                      host.iobroker deleted npm temp directory: ".tableify-6kfCgw4D")
                      host.iobroker deleted npm temp directory: ".tcp-ping-KW9OnocR")
                      host.iobroker deleted npm temp directory: ".through-GyJcvh09")
                      host.iobroker deleted npm temp directory: ".to-array-kzG8FZoy")
                      host.iobroker deleted npm temp directory: ".to-regex-range-iJFZCsex")
                      host.iobroker deleted npm temp directory: ".ts-api-utils-JmchtaEL")
                      host.iobroker deleted npm temp directory: ".tweetnacl-ldfAdbL9")
                      host.iobroker deleted npm temp directory: ".typed-array-byte-length-sOVOOL9g")
                      host.iobroker deleted npm temp directory: ".typed-function-lamN6wQc")
                      host.iobroker deleted npm temp directory: ".types-pkg-json-3UOXZDfJ")
                      host.iobroker deleted npm temp directory: ".typescript-rKKYB1QG")
                      host.iobroker deleted npm temp directory: ".typical-B01ZUP8W")
                      host.iobroker deleted npm temp directory: ".unbox-primitive-odeTH77h")
                      host.iobroker deleted npm temp directory: ".unicode-properties-Bg5RLVuQ")
                      host.iobroker deleted npm temp directory: ".untildify-2NFtYD13")
                      host.iobroker deleted npm temp directory: ".update-notifier-XWnvBRxV")
                      host.iobroker deleted npm temp directory: ".url-parse-pnENsky7")
                      host.iobroker deleted npm temp directory: ".url-template-XLjsNAfv")
                      host.iobroker deleted npm temp directory: ".usb-PqjvAhv3")
                      host.iobroker deleted npm temp directory: ".utils-merge-lRdITr83")
                      host.iobroker deleted npm temp directory: ".uuid-hFM3FfPu")
                      host.iobroker deleted npm temp directory: ".wake_on_lan-6cMB5f0e")
                      host.iobroker deleted npm temp directory: ".web-streams-polyfill-L6ofGwWB")
                      host.iobroker deleted npm temp directory: ".webidl-conversions-dJIVq13g")
                      host.iobroker deleted npm temp directory: ".websocket-stream-02UKbziB")
                      host.iobroker deleted npm temp directory: ".which-GGzfHdLT")
                      host.iobroker deleted npm temp directory: ".wide-align-CJ7lqbuZ")
                      host.iobroker deleted npm temp directory: ".widest-line-lhDznLKg")
                      host.iobroker deleted npm temp directory: ".winston-daily-rotate-file-tjvnY6ZU")
                      host.iobroker deleted npm temp directory: ".winston-syslog-rknbmCPQ")
                      host.iobroker deleted npm temp directory: ".workerpool-mqY76ZXw")
                      host.iobroker deleted npm temp directory: ".xdg-basedir-A6kKkuxL")
                      host.iobroker deleted npm temp directory: ".y18n-puq37lLA")
                      host.iobroker deleted npm temp directory: ".yallist-RyZDxIwA")
                      host.iobroker deleted npm temp directory: ".yaml-Re02D0MQ")
                      host.iobroker deleted npm temp directory: ".yargs-parser-sA7Dt5No")
                      host.iobroker deleted npm temp directory: ".yocto-queue-1wbR3uAZ")
                      host.iobroker deleted npm temp directory: ".zigbee-herdsman-KZGHBvfL")
                      host.iobroker deleted npm temp directory: ".zip-stream-qFO8RuhX")
                      host.iobroker Cannot install iobroker.sonos@3.0.0: 217
                      ERROR: Process exited with code 25
                        ma last edited by
                        $ iobroker upgrade parser@2.0.7
                        Update parser from @1.3.2 to @2.0.7
                        Installing iobroker.parser@2.0.7... (System call)
                        npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/ursa-optional/node_modules/bindingsnpm ERR! dest /opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ursa-optional/node_modules/bindings' -> '/opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJ'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_07_22_021Z-debug-0.log
                        host.iobroker Cannot install iobroker.parser@2.0.7: 217
                          ma last edited by
                          sonos update nochmal mit debug
                          iobroker upgrade sonos —debug
                          This upgrade of "sonos" will introduce the following changes:
                          -> 3.0.0:
                          Added support for the playing Sonos playlists (added new state `playlist_set`)
                          The minimal node.js version is 16
                          -> 2.3.3:
                          fixed cover url
                          -> 2.3.2:
                          store the cover file in files instead of binary states
                          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                          Would you like to upgrade sonos from @2.3.1 to @3.0.0 now? [(y)es, (n)o]: y
                          NPM version: 9.8.1
                          host.iobroker deleted npm temp directory: ".bindings-4WLiqHNJ")
                          npm ERR! errno -39
                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_24_19_780Z-debug-0.log
                          host.iobroker Cannot install iobroker.sonos@3.0.0: 217```
                            ma last edited by
                            habe den fixer nochmal durchlaufen lassen danach nochmal das update von sonos und sonoff gestartet.
                            Danach ist der iobroker garnicht mehr gestartet, konnte ich lösen indem ich den PC neugestartet habe.
                            Nun starten die adapter garnicht mehr.
                            sonoff.0 2023-11-19 02:44:31.858	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            sonoff.0 2023-11-19 02:44:31.857	info	terminating
                            sonoff.0 2023-11-19 02:44:31.839	error	Cannot read properties of undefined (reading 'length')
                            sonoff.0 2023-11-19 02:44:31.838	error	TypeError: Cannot read properties of undefined (reading 'length') at decrypt (/opt/iobroker/node_modules/iobroker.sonoff/main.js:25:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.sonoff/main.js:43:39) at processImmediate (node:internal/timers:478:21)
                            sonoff.0 2023-11-19 02:44:31.837	error	uncaught exception: Cannot read properties of undefined (reading 'length')
                            sonoff.0 2023-11-19 02:44:31.794	info	starting. Version 2.5.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v18.18.2, js-controller: 5.0.12
                            sonos.0
                            	2023-11-19 02:52:04.672	warn	State "sonos.0.root.192_168_170_7.favorites_list_html" has no existing object, this might lead to an error in future versions
                            sonos.0
                            	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_5.favorites_list_html" has no existing object, this might lead to an error in future versions
                            sonos.0
                            	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_8.favorites_list_html" has no existing object, this might lead to an error in future versions
                            sonos.0
                            	2023-11-19 02:52:04.666	warn	State "sonos.0.root.192_168_170_5.current_track_number" has no existing object, this might lead to an error in future versions
                            sonos.0
                            	2023-11-19 02:52:04.646	error	Cannot getFavorites: TypeError: Cannot read properties of null (reading 'players')
                            sonos.0
                            	2023-11-19 02:52:04.638	warn	State "sonos.0.root.192_168_170_7.current_track_number" has no existing object, this might lead to an error in future versions
                            sonos.0
                            	2023-11-19 02:52:04.623	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            sonos.0
                            	2023-11-19 02:52:04.622	info	terminating
                            sonos.0
                            	2023-11-19 02:52:04.617	info	terminating
                            sonos.0
                            	2023-11-19 02:52:04.614	error	sonos is not an object of type "meta"
                            sonos.0
                            	2023-11-19 02:52:04.614	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:591:35) at ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:24) at AdapterClass.writeFile (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:4809:31) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.writeFileAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at takeSonosState (/opt/iobroker/node_modules/iobroker.sonos/main.js:1456:31) at processSonosEvents (/opt/iobroker/node_modules/iobroker.sonos/main.js:1693:17) at SonosSystem.<anonymous> (/opt/iobroker/node_modules/iobroker.sonos/main.js:2105:13) at SonosSystem.emit (node:events:517:28)
                            sonos.0
                            	2023-11-19 02:52:04.611	error	unhandled promise rejection: sonos is not an object of type "meta"
                            sonos.0
                            	2023-11-19 02:52:04.610	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            sonos.0
                            	2023-11-19 02:52:04.577	error	sonos is not an object of type "meta"
                            sonos.0
                            	2023-11-19 02:52:04.577	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:587:39) at runNextTicks (node:internal/process/task_queues:60:5) at process.processImmediate (node:internal/timers:447:9) at async ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:13)
                            sonos.0
                            	2023-11-19 02:52:04.575	error	unhandled promise rejection: sonos is not an object of type "meta"
                            sonos.0
                            	2023-11-19 02:52:04.575	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            sonos.0
                            	2023-11-19 02:52:04.571	error	Cannot write file coverImage/192_168_170_5.png: sonos is not an object of type "meta"
                            sonos.0
                            	2023-11-19 02:52:04.538	error	Cannot write file coverImage/192_168_170_7.png: sonos is not an object of type "meta"
                            sonos.0
                            	2023-11-19 02:52:03.470	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.18.2, js-controller: 5.0.12
                            brauche dazu eine lösung.
                            vor dem update auf node v18 gab es da nie probleme
                              reutli @ma last edited by reutli
                              @ma sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                              und das gemacht und dann nochmals Update gestartet?
                              und da mal reingeschaut?
                                kkickingereder @reutli last edited by kkickingereder
                                Könnt ihr mir helfen bitte, bin noch auf 16.15.1
                                nach
                                iob stop
                                iob fix (schon 2x)
                                iob nodejs-update
                                bekomme ich folgend Fehlermeldung
                                You are running nodejs v16.15.1. Do you want to install recommended version 18.19.0?
                                Press <y> to continue or any other key to quit
                                Trying to update your installation now. Please be patient.
                                find: '/run/user/1000/gvfs': Permission denied
                                Waiting for ioBroker to shut down - Give me a minute...
                                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                W: Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                                W: Failed to fetch https://repos.influxdata.com/ubuntu/dists/bionic/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Some index files failed to download. They have been ignored, or old ones used instead.
                                E: Broken packages
                                Installing the recommended nodejs version!
                                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://dl.google.com/linux/chrome/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                E: Broken packages
                                We tried our best to fix your nodejs. Please run iob diag again to verify.
                                  Thomas Braun Most Active @kkickingereder last edited by Thomas Braun
                                  @kkickingereder
                                  grafana und influx Repository müssen nochmal frisch angelegt werden.
                                  Das Ganze muss allerdings bereits geraume Zeit bei dir falsch laufen. Regelmäßiger das System pflegen!
                                  Und schalt den Desktop AUS!
                                  Und das google-Repo brauchst du vermutlich nicht.
                                  Alles rauswerfen, was nicht für den Serverbetrieb benötigt wird.
                                    kkickingereder @Thomas Braun last edited by
                                    @thomas-braun vielen lieben Dank
                                    grafana und influx brauch ich eh nicht
                                    Hast du einen Tip wie ich sauber runter kriege?
                                    Was meinst du mit, schalt den Desktop aus?
                                      @kkickingereder
                                      Poste mal on einem separaten Thread die Langfassung von
                                      iob diag
                                      Da scheint mir so einiges im Argen zu liegen.
                                        @thomas-braun oh oh 😖
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                           Static hostname: iob-server
                                                 Icon name: computer-laptop
                                                   Chassis: laptop
                                          Operating System: Ubuntu 18.04.4 LTS
                                                    Kernel: Linux 5.4.0-150-generic
                                              Architecture: x86-64
                                        model name	: Intel(R) Pentium(R) 3805U @ 1.90GHz
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        Systemuptime and Load:
                                         16:46:43 up 89 days,  3:58,  2 users,  load average: 0.65, 0.74, 0.92
                                        CPU threads: 2
                                        *** Time and Time Zones ***
                                                              Local time: Sun 2023-12-17 16:46:43 CET
                                                          Universal time: Sun 2023-12-17 15:46:43 UTC
        RTC time: Sun 2023-12-17 15:46:43
                                        systemd-timesyncd.service active: yes
                                                         RTC in local TZ: no
                                        *** User and Groups ***
                                        iob
                                        /home/iob
                                        iob adm cdrom sudo dip plugdev lpadmin sambashare iobroker
                                        *** X-Server-Setup ***
                                        X-Server: 	true
                                        Desktop:
                                        Terminal:
                                        Boot Target: 	graphical.target
                                        *** MEMORY ***
                                        Mem:           3.9G        2.9G        263M        1.7M        761M        768M
                                        Swap:          2.1G        1.4G        733M
                                        Total:         6.0G        4.3G        996M
                                                 3848 M total memory
                                                 2847 M used memory
                                                 2464 M active memory
                                                  752 M inactive memory
                                                  256 M free memory
                                                   96 M buffer memory
                                                  647 M swap cache
                                                 2047 M total swap
                                                 1331 M used swap
                                                  716 M free swap
                                        *** FAILED SERVICES ***
                                        0 loaded units listed. Pass --all to see loaded but inactive units, too.
                                        To show all installed unit files use 'systemctl list-unit-files'.
                                        *** FILESYSTEM ***
                                        udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                        tmpfs          tmpfs     385M  2.0M  383M   1% /run
                                        /dev/sda1      ext4       59G   30G   27G  53% /
                                        tmpfs          tmpfs     1.9G  176K  1.9G   1% /dev/shm
                                        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                                        /dev/loop0     squashfs   74M   74M     0 100% /snap/core22/864
                                        /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16091
                                        /dev/loop4     squashfs   92M   92M     0 100% /snap/gtk-common-themes/1535
                                        /dev/loop5     squashfs  1.5M  1.5M     0 100% /snap/gnome-system-monitor/184
                                        /dev/loop6     squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/143
                                        /dev/loop7     squashfs  219M  219M     0 100% /snap/gnome-3-34-1804/90
                                        /dev/loop9     squashfs  896K  896K     0 100% /snap/gnome-logs/119
                                        /dev/loop15    squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/140
                                        /dev/loop17    squashfs  165M  165M     0 100% /snap/gnome-3-28-1804/194
                                        /dev/loop18    squashfs  128K  128K     0 100% /snap/bare/5
                                        /dev/loop20    squashfs  219M  219M     0 100% /snap/gnome-3-34-1804/93
                                        /dev/loop22    squashfs  165M  165M     0 100% /snap/gnome-3-28-1804/198
                                        /dev/loop24    squashfs   82M   82M     0 100% /snap/gtk-common-themes/1534
                                        /dev/loop26    squashfs   64M   64M     0 100% /snap/core20/2015
                                        tmpfs          tmpfs     385M   56K  385M   1% /run/user/1000
                                        /dev/loop27    squashfs  497M  497M     0 100% /snap/gnome-42-2204/132
                                        /dev/loop23    squashfs  896K  896K     0 100% /snap/gnome-logs/121
                                        /dev/loop28    squashfs  512K  512K     0 100% /snap/gnome-characters/791
                                        /dev/loop8     squashfs  497M  497M     0 100% /snap/gnome-42-2204/141
                                        /dev/loop10    squashfs  512K  512K     0 100% /snap/gnome-characters/795
                                        /dev/loop12    squashfs  2.3M  2.3M     0 100% /snap/gnome-calculator/953
                                        /dev/loop2     squashfs  106M  106M     0 100% /snap/core/16202
                                        /dev/loop3     squashfs  1.7M  1.7M     0 100% /snap/gnome-system-monitor/186
                                        /dev/loop11    squashfs   56M   56M     0 100% /snap/core18/2796
                                        /dev/loop21    squashfs  2.3M  2.3M     0 100% /snap/gnome-calculator/955
                                        /dev/loop19    squashfs   56M   56M     0 100% /snap/core18/2812
                                        /dev/loop16    squashfs   75M   75M     0 100% /snap/core22/1033
                                        /dev/loop13    squashfs   64M   64M     0 100% /snap/core20/2105
                                        findmnt: unrecognized option '--real'
                                        Try 'findmnt --help' for more information.
                                        /var:
                                        9.4G	/var/
                                        5.3G	/var/lib
                                        4.6G	/var/lib/snapd
                                        3.9G	/var/log/journal
                                        3.9G	/var/log
                                        Archived and active journals take up 3.5G in the file system.
                                        /opt/iobroker/backups:
                                        373M	/opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        666M	/opt/iobroker/iobroker-data/
                                        321M	/opt/iobroker/iobroker-data/files
                                        255M	/opt/iobroker/iobroker-data/backup-objects
                                        67M	/opt/iobroker/iobroker-data/files/javascript.admin
                                        48M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                        33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                        26M	/opt/iobroker/iobroker-data/states.jsonl
                                        26M	/opt/iobroker/iobroker-data/objects.jsonl
                                        21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                        16M	/opt/iobroker/iobroker-data/objects.json.migrated
                                        USB-Devices by-id:
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs 	v16.15.1
                                        /usr/bin/node 		v16.15.1
                                        /usr/bin/npm 		8.11.0
                                        /usr/bin/npx 		8.11.0
                                        /usr/bin/corepack 	0.10.0
                                        nodejs:
                                          Installed: 16.15.1-1nodesource1
                                          Candidate: 18.19.0-1nodesource1
                                          Version table:
                                             18.19.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                         *** 16.15.1-1nodesource1 100
                                                100 /var/lib/dpkg/status
                                             8.10.0~dfsg-2ubuntu0.4 500
                                                500 http://de.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                                             8.10.0~dfsg-2ubuntu0.2 500
                                                500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                                             8.10.0~dfsg-2 500
                                                500 http://de.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller: 	5.0.17
                                        admin: 		6.12.0
                                        javascript: 	7.1.6
                                        Adapters from github: 	2
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : iob-server                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : iob-server                               -  enabled
                                        + system.adapter.backitup.0               : backitup              : iob-server                               -  enabled
                                        + system.adapter.bmw.0                    : bmw                   : iob-server                               -  enabled
                                        + system.adapter.cloud.0                  : cloud                 : iob-server                               -  enabled
                                          system.adapter.daswetter.0              : daswetter             : iob-server                               -  enabled
                                        + system.adapter.discovery.0              : discovery             : iob-server                               -  enabled
                                          system.adapter.dwd.0                    : dwd                   : iob-server                               -  enabled
                                        + system.adapter.dysonairpurifier.0       : dysonairpurifier      : iob-server                               -  enabled
                                        + system.adapter.easee.0                  : easee                 : iob-server                               -  enabled
                                        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iob-server                               -  enabled
                                          system.adapter.feiertage.0              : feiertage             : iob-server                               -  enabled
                                        + system.adapter.fritzdect.0              : fritzdect             : iob-server                               -  enabled
                                        + system.adapter.hmip.0                   : hmip                  : iob-server                               -  enabled
                                        + system.adapter.homeconnect.0            : homeconnect           : iob-server                               -  enabled
                                        + system.adapter.hue-extended.0           : hue-extended          : iob-server                               -  enabled
                                        + system.adapter.hue.0                    : hue                   : iob-server                               -  enabled, port: 443
                                          system.adapter.ical.0                   : ical                  : iob-server                               -  enabled
                                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob-server                               - disabled
                                          system.adapter.icons-material-png.0     : icons-material-png    : iob-server                               - disabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob-server                               - disabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-server                               - disabled
                                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob-server                               - disabled
                                        + system.adapter.info.0                   : info                  : iob-server                               -  enabled
                                        + system.adapter.iot.0                    : iot                   : iob-server                               -  enabled
                                        + system.adapter.javascript.0             : javascript            : iob-server                               -  enabled
                                          system.adapter.mobile.0                 : mobile                : iob-server                               - disabled
                                        + system.adapter.netatmo.0                : netatmo               : iob-server                               -  enabled
                                        + system.adapter.nuki-extended.0          : nuki-extended         : iob-server                               -  enabled
                                        + system.adapter.nuki.0                   : nuki                  : iob-server                               -  enabled
                                          system.adapter.openweathermap.0         : openweathermap        : iob-server                               -  enabled
                                        + system.adapter.panasonic-viera.0        : panasonic-viera       : iob-server                               -  enabled
                                        + system.adapter.ping.0                   : ping                  : iob-server                               -  enabled
                                        + system.adapter.ring.0                   : ring                  : iob-server                               -  enabled
                                        + system.adapter.simple-api.0             : simple-api            : iob-server                               -  enabled, port: 8087, run as: admin
                                        + system.adapter.smart-eq.0               : smart-eq              : iob-server                               -  enabled
                                        + system.adapter.socketio.0               : socketio              : iob-server                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          system.adapter.spotify-premium.0        : spotify-premium       : iob-server                               - disabled
                                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iob-server                               -  enabled
                                        + system.adapter.telegram.0               : telegram              : iob-server                               -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.tr-064.0                 : tr-064                : iob-server                               -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : iob-server                               - disabled
                                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob-server                               - disabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob-server                               - disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-server                               - disabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : iob-server                               - disabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iob-server                               -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-server                               - disabled
                                          system.adapter.vis-knob.0               : vis-knob              : iob-server                               - disabled
                                          system.adapter.vis-material.0           : vis-material          : iob-server                               - disabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-server                               - disabled
                                          system.adapter.vis-metro.0              : vis-metro             : iob-server                               - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-server                               - disabled
                                          system.adapter.vis-weather.0            : vis-weather           : iob-server                               - disabled
                                          system.adapter.vis.0                    : vis                   : iob-server                               -  enabled
                                        + system.adapter.web.0                    : web                   : iob-server                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.worx.0                   : worx                  : iob-server                               -  enabled
                                        + system.adapter.yahka.0                  : yahka                 : iob-server                               -  enabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                        Adapter    "bmw"          : 2.5.7    , installed 2.6.0
                                        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                                        Adapter    "dysonairpurifier": 2.5.9 , installed 2.5.9
                                        Adapter    "easee"        : 1.0.10   , installed 1.0.10
                                        Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                                        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                                        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                                        Adapter    "hue"          : 3.10.1   , installed 3.10.1
                                        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                        Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                        Controller "js-controller": 5.0.17   , installed 5.0.17
                                        Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
                                        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                                        Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                                        Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                                        Adapter    "ring"         : 5.0.10   , installed 3.2.2  [Updatable]
                                        Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
                                        Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
                                        Adapter    "telegram"     : 3.0.0    , installed 3.0.0
                                        Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
                                        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                        Adapter    "web"          : 6.1.10   , installed 6.1.10
                                        Adapter    "worx"         : 2.3.4    , installed 2.3.4
                                        Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                        Objects and States
                                        Objects: 	36971
                                        States: 	29630
                                        Get:1 http://dl.google.com/linux/chrome/deb stable InRelease [1825 B]
                                        Hit:2 http://de.archive.ubuntu.com/ubuntu bionic InRelease
                                        Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
                                        Get:4 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
                                        Get:5 https://repos.influxdata.com/ubuntu bionic InRelease [7047 B]
                                        Hit:6 http://de.archive.ubuntu.com/ubuntu bionic-updates InRelease
                                        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Hit:8 http://de.archive.ubuntu.com/ubuntu bionic-backports InRelease
                                        Err:1 http://dl.google.com/linux/chrome/deb stable InRelease
                                        Err:4 https://packages.grafana.com/oss/deb stable InRelease
                                        Err:5 https://repos.influxdata.com/ubuntu bionic InRelease
                                        Fetched 7047 B in 1s (5895 B/s)
                                        Reading package lists...
                                        Pending Updates: 100
                                        *** Listening Ports ***
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       81137075   2865/iobroker.js-co
                                        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      125        28671      824/mysqld
                                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      123        28780      791/redis-server 12
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          22257      456/rpcbind
                                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22287      459/systemd-resolve
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          81096893   783/sshd
                                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          80457378   29056/cupsd
                                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        34230      1402/influxd
                                        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          29805      663/python
                                        tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          28902      766/anydesk
                                        tcp        0      0 127.0.0.1:40007         0.0.0.0:*               LISTEN      1001       81147331   4068/io.yahka.0
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       81137082   2865/iobroker.js-co
                                        tcp6       0      0 ::1:6379                :::*                    LISTEN      123        28781      791/redis-server 12
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          22260      456/rpcbind
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       81137183   2884/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       81146340   4035/io.web.0
                                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       81147056   3985/io.socketio.0
                                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       81147932   4175/io.nuki-extend
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          81096895   783/sshd
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        34678      1402/influxd
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       81147008   3967/io.simple-api.
                                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          80457377   29056/cupsd
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      124        34587      1407/grafana-server
                                        tcp6       0      0 :::35107                :::*                    LISTEN      1001       81146436   4068/io.yahka.0
                                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22286      459/systemd-resolve
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          81095893   28837/dhclient
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          22255      456/rpcbind
                                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          80457386   29057/cups-browsed
                                        udp        0      0 0.0.0.0:632             0.0.0.0:*                           0          22256      456/rpcbind
                                        udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          28903      766/anydesk
                                        udp        0      0 192.168.0.20:5353       0.0.0.0:*                           1001       81138845   3067/io.tr-064.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        25090      656/avahi-daemon: r
                                        udp        0      0 0.0.0.0:48439           0.0.0.0:*                           116        25092      656/avahi-daemon: r
                                        udp6       0      0 :::48975                :::*                                116        25093      656/avahi-daemon: r
                                        udp6       0      0 :::111                  :::*                                0          22258      456/rpcbind
                                        udp6       0      0 :::632                  :::*                                0          22259      456/rpcbind
                                        udp6       0      0 :::5353                 :::*                                116        25091      656/avahi-daemon: r
                                        2023-12-17 16:39:37.301  - info: admin.0 (2884) ==> Connected system.user.admin from ::ffff:192.168.0.32
                                        2023-12-17 16:39:39.585  - info: host.iob-server Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                        2023-12-17 16:47:37.193  - error: bmw.0 (3115) update  failed
                                        2023-12-17 16:47:37.196  - error: bmw.0 (3115) AxiosError: Request failed with status code 403
                                        2023-12-17 16:47:37.196  - error: bmw.0 (3115) {"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:12:23."}
                                        iob diag has finished.
                                          @kkickingereder
                                          Ubuntu 18.irgendwas ist tot.
                                          Brauch ich gar nicht weiterlesen.
                                          Installier da was lebendes.
                                          Ich würde ein Debian 12 'Bookworm' empfehlen.
                                          Als Server dann natürlich OHNE Desktop-Umgebung.
                                          S R 2 Replies Last reply Reply Quote 1
                                            skorpil @Thomas Braun last edited by
                                            @thomas-braun auch wenn es hier nicht direkt hinpasst: ich bin auf debian bullseye. Ich sollte auf bookworm… Hier im Forum hast Du irgendwo geschrieben, man solle das System komplett neu aufsetzen. Das wäre für mich als Linux Dummy ein Wahnsinn. Gilt Dein Hinweis auf komplette Neuinstallation nur für Raspian Installationen auf einem Raspi? Oder auch für Debian Installationen? Bei mir läuft der Iob in einer VM unter Oracle Virtual Box sehr gut, bisher…
                                            1.2k
                                            nodejs
                                            91
                                            844
                                            229071
